adydep Postat August 12, 2020 Autor Partajează Postat August 12, 2020 La 09.08.2020 la 20:18, adydep a spus: 1.boxe active pc Serioux - pop251b ,pret 30 lei https://postimg.cc/SjRj3bzm https://postimg.cc/NyXk1rBP https://postimg.cc/zyKy7wHW 2.pistol lipit plastic,pret 25 lei https://postimg.cc/QFN8tQ36 https://postimg.cc/75rzQQS5 https://postimg.cc/svTFTbkc https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD 3.ondulator profesional Wella Pro Curl,pret 50 lei https://postimg.cc/5Q9HfQFL https://postimg.cc/jw4wV4CR https://postimg.cc/9zcwdKN0 https://postimg.cc/mt8Y1BLT https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiAzLSh7sDqAhWL4XcKHRQBDXAYABAEGgJlZg&ohost=www.google.com&cid=CAESQOD2QfX-_vFL-aahdTHY5K79XOMcvYdiIp2UHC2BUha4eSGBAB9Wk58Xg65RQFbbRkM3fAoR9mUJKtQZMMO5aQ8&sig=AOD64_1KbI4I8uUO2jEf7M2-w5UPDVgCxA&ctype=5&q=&ved=2ahUKEwjBvqyh7sDqAhULy6QKHcunDmUQ9aACegQICxA8&adurl= 4.transformator toroidal cred ca rusesc,inaltime tor aproximativ 4,7 cm,diametru exterior tor aproximativ 10 cm primar alimentat la 230V,da in secundar 28-29V,diametru sarma secundar 1,1mm (masurat cu sublerul),pret 30 lei https://postimg.cc/Hc0VGtKW https://postimg.cc/r02KYHfY https://postimg.cc/4H5ZPL0t https://postimg.cc/XXcytVSK 5.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,40 lei ambele https://postimg.cc/18DT6QZK https://postimg.cc/wtZ0b4HB https://postimg.cc/RqzjSq5Z 6.cositor cu plumb ,diametru 1,5mm,0,5kg,pret 50 lei https://postimg.cc/K1tctzFg https://postimg.cc/Jyq1d2sr 7.pereche difuzoare rusesti, 0,5W/8 ohm,pret 15 lei perechea https://postimg.cc/CZzwy6vT https://postimg.cc/CzSYMKv4 8.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 8 lei perechea https://postimg.cc/bSNZtRyz https://postimg.cc/23KkGYTd https://postimg.cc/Lq22586S 9.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea https://postimg.cc/qNQZcJx4 https://postimg.cc/yg3QzF48 https://postimg.cc/PNZ33zQ6 10.motor pickup cu potentiometru reglare turatie,,pret 15 lei https://postimg.cc/phbtqdt6 https://postimg.cc/fJTkx8C0 Link spre comentariu
adydep Postat August 14, 2020 Autor Partajează Postat August 14, 2020 1.boxe active pc Serioux - pop251b ,pret 30 lei https://postimg.cc/SjRj3bzm https://postimg.cc/NyXk1rBP https://postimg.cc/zyKy7wHW 2.pistol lipit plastic,pret 25 lei https://postimg.cc/QFN8tQ36 https://postimg.cc/75rzQQS5 https://postimg.cc/svTFTbkc https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD 3.ondulator profesional Wella Pro Curl,pret 50 lei https://postimg.cc/5Q9HfQFL https://postimg.cc/jw4wV4CR https://postimg.cc/9zcwdKN0 https://postimg.cc/mt8Y1BLT https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiAzLSh7sDqAhWL4XcKHRQBDXAYABAEGgJlZg&ohost=www.google.com&cid=CAESQOD2QfX-_vFL-aahdTHY5K79XOMcvYdiIp2UHC2BUha4eSGBAB9Wk58Xg65RQFbbRkM3fAoR9mUJKtQZMMO5aQ8&sig=AOD64_1KbI4I8uUO2jEf7M2-w5UPDVgCxA&ctype=5&q=&ved=2ahUKEwjBvqyh7sDqAhULy6QKHcunDmUQ9aACegQICxA8&adurl= 4.transformator toroidal cred ca rusesc,inaltime tor aproximativ 4,7 cm,diametru exterior tor aproximativ 10 cm primar alimentat la 230V,da in secundar 28-29V,diametru sarma secundar 1,1mm (masurat cu sublerul),pret 30 lei https://postimg.cc/Hc0VGtKW https://postimg.cc/r02KYHfY https://postimg.cc/4H5ZPL0t https://postimg.cc/XXcytVSK 5.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,40 lei ambele https://postimg.cc/18DT6QZK https://postimg.cc/wtZ0b4HB https://postimg.cc/RqzjSq5Z 6.cositor cu plumb ,diametru 1,5mm,0,5kg,pret 50 lei https://postimg.cc/K1tctzFg https://postimg.cc/Jyq1d2sr 7.pereche difuzoare rusesti, 0,5W/8 ohm,pret 15 lei perechea https://postimg.cc/CZzwy6vT https://postimg.cc/CzSYMKv4 8.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 8 lei perechea https://postimg.cc/bSNZtRyz https://postimg.cc/23KkGYTd https://postimg.cc/Lq22586S 9.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea https://postimg.cc/qNQZcJx4 https://postimg.cc/yg3QzF48 https://postimg.cc/PNZ33zQ6 10.motor pickup cu potentiometru reglare turatie,,pret 15 lei https://postimg.cc/phbtqdt6 https://postimg.cc/fJTkx8C0 Link spre comentariu
adydep Postat August 18, 2020 Autor Partajează Postat August 18, 2020 1.boxe active pc Serioux - pop251b ,pret 30 lei https://postimg.cc/SjRj3bzm https://postimg.cc/NyXk1rBP https://postimg.cc/zyKy7wHW 2.pistol lipit plastic,pret 25 lei https://postimg.cc/QFN8tQ36 https://postimg.cc/75rzQQS5 https://postimg.cc/svTFTbkc https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD 3.ondulator profesional Wella Pro Curl,pret 50 lei https://postimg.cc/5Q9HfQFL https://postimg.cc/jw4wV4CR https://postimg.cc/9zcwdKN0 https://postimg.cc/mt8Y1BLT https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiAzLSh7sDqAhWL4XcKHRQBDXAYABAEGgJlZg&ohost=www.google.com&cid=CAESQOD2QfX-_vFL-aahdTHY5K79XOMcvYdiIp2UHC2BUha4eSGBAB9Wk58Xg65RQFbbRkM3fAoR9mUJKtQZMMO5aQ8&sig=AOD64_1KbI4I8uUO2jEf7M2-w5UPDVgCxA&ctype=5&q=&ved=2ahUKEwjBvqyh7sDqAhULy6QKHcunDmUQ9aACegQICxA8&adurl= 4.transformator toroidal cred ca rusesc,inaltime tor aproximativ 4,7 cm,diametru exterior tor aproximativ 10 cm primar alimentat la 230V,da in secundar 28-29V,diametru sarma secundar 1,1mm (masurat cu sublerul),pret 30 lei https://postimg.cc/Hc0VGtKW https://postimg.cc/r02KYHfY https://postimg.cc/4H5ZPL0t https://postimg.cc/XXcytVSK 5.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,40 lei ambele https://postimg.cc/18DT6QZK https://postimg.cc/wtZ0b4HB https://postimg.cc/RqzjSq5Z 6.cositor cu plumb ,diametru 1,5mm,0,5kg,pret 50 lei https://postimg.cc/K1tctzFg https://postimg.cc/Jyq1d2sr 7.pereche difuzoare rusesti, 0,5W/8 ohm,pret 15 lei perechea https://postimg.cc/CZzwy6vT https://postimg.cc/CzSYMKv4 8.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 8 lei perechea https://postimg.cc/bSNZtRyz https://postimg.cc/23KkGYTd https://postimg.cc/Lq22586S 9.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea https://postimg.cc/qNQZcJx4 https://postimg.cc/yg3QzF48 https://postimg.cc/PNZ33zQ6 10.motor pickup cu potentiometru reglare turatie,,pret 15 lei https://postimg.cc/phbtqdt6 https://postimg.cc/fJTkx8C0 Link spre comentariu
adydep Postat August 31, 2020 Autor Partajează Postat August 31, 2020 Am mai gasit o rola de cositor Fluitin cumparat tot de pe Elforum de la bella,rola de 0,25Kg pret 25 lei/rola(il dau cu cat l-am cumparat) https://postimg.cc/ykmXPRdt Link spre comentariu
deneinvins Postat August 31, 2020 Partajează Postat August 31, 2020 Materialele solicitate au ajuns. Pachet foarte solid. Toate materialele corespund descrierii. Bonus mult și consistent. Mulțumesc și pe această cale. User de încredere. Recomand ! 1 Link spre comentariu
adydep Postat Septembrie 3, 2020 Autor Partajează Postat Septembrie 3, 2020 La 31.08.2020 la 12:33, adydep a spus: Am mai gasit o rola de cositor Fluitin cumparat tot de pe Elforum de la bella,rola de 0,25Kg pret 25 lei/rola(il dau cu cat l-am cumparat) https://postimg.cc/ykmXPRdt Link spre comentariu
giliman66 Postat Septembrie 3, 2020 Partajează Postat Septembrie 3, 2020 Aveti pm pentru rola de cositor Fluitin.Multumesc! Link spre comentariu
adydep Postat Septembrie 5, 2020 Autor Partajează Postat Septembrie 5, 2020 Au mai ramas cele 9 repere de mai jos,100 lei pentru cine le cumpara pe toate ca sa inchid ”taraba”. 1.boxe active pc Serioux - pop251b ,pret 30 lei https://postimg.cc/SjRj3bzm https://postimg.cc/NyXk1rBP https://postimg.cc/zyKy7wHW 2.pistol lipit plastic,pret 25 lei https://postimg.cc/QFN8tQ36 https://postimg.cc/75rzQQS5 https://postimg.cc/svTFTbkc https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD 3.ondulator profesional Wella Pro Curl,pret 50 lei https://postimg.cc/5Q9HfQFL https://postimg.cc/jw4wV4CR https://postimg.cc/9zcwdKN0 https://postimg.cc/mt8Y1BLT https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiAzLSh7sDqAhWL4XcKHRQBDXAYABAEGgJlZg&ohost=www.google.com&cid=CAESQOD2QfX-_vFL-aahdTHY5K79XOMcvYdiIp2UHC2BUha4eSGBAB9Wk58Xg65RQFbbRkM3fAoR9mUJKtQZMMO5aQ8&sig=AOD64_1KbI4I8uUO2jEf7M2-w5UPDVgCxA&ctype=5&q=&ved=2ahUKEwjBvqyh7sDqAhULy6QKHcunDmUQ9aACegQICxA8&adurl= 4.transformator toroidal cred ca rusesc,inaltime tor aproximativ 4,7 cm,diametru exterior tor aproximativ 10 cm primar alimentat la 230V,da in secundar 28-29V,diametru sarma secundar 1,1mm (masurat cu sublerul),pret 30 lei https://postimg.cc/Hc0VGtKW https://postimg.cc/r02KYHfY https://postimg.cc/4H5ZPL0t https://postimg.cc/XXcytVSK 5.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,40 lei ambele https://postimg.cc/18DT6QZK https://postimg.cc/wtZ0b4HB https://postimg.cc/RqzjSq5Z 6.pereche difuzoare rusesti, 0,5W/8 ohm,pret 15 lei perechea https://postimg.cc/CZzwy6vT https://postimg.cc/CzSYMKv4 7.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 8 lei perechea https://postimg.cc/bSNZtRyz https://postimg.cc/23KkGYTd https://postimg.cc/Lq22586S 8.motor pickup cu potentiometru reglare turatie,,pret 15 lei https://postimg.cc/phbtqdt6 https://postimg.cc/fJTkx8C0 9.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea https://postimg.cc/qNQZcJx4 https://postimg.cc/yg3QzF48 https://postimg.cc/PNZ33zQ6 Link spre comentariu
adydep Postat Septembrie 6, 2020 Autor Partajează Postat Septembrie 6, 2020 Au mai ramas doar cele 8 repere de mai jos,100 lei pentru cine le cumpara pe toate ca sa inchid ”taraba”. 1.boxe active pc Serioux - pop251b ,pret 30 lei https://postimg.cc/SjRj3bzm https://postimg.cc/NyXk1rBP https://postimg.cc/zyKy7wHW 2.pistol lipit plastic,pret 25 lei https://postimg.cc/QFN8tQ36 https://postimg.cc/75rzQQS5 https://postimg.cc/svTFTbkc https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD 3.ondulator profesional Wella Pro Curl,pret 50 lei https://postimg.cc/5Q9HfQFL https://postimg.cc/jw4wV4CR https://postimg.cc/9zcwdKN0 https://postimg.cc/mt8Y1BLT https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiAzLSh7sDqAhWL4XcKHRQBDXAYABAEGgJlZg&ohost=www.google.com&cid=CAESQOD2QfX-_vFL-aahdTHY5K79XOMcvYdiIp2UHC2BUha4eSGBAB9Wk58Xg65RQFbbRkM3fAoR9mUJKtQZMMO5aQ8&sig=AOD64_1KbI4I8uUO2jEf7M2-w5UPDVgCxA&ctype=5&q=&ved=2ahUKEwjBvqyh7sDqAhULy6QKHcunDmUQ9aACegQICxA8&adurl= 4.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,40 lei ambele https://postimg.cc/18DT6QZK https://postimg.cc/wtZ0b4HB https://postimg.cc/RqzjSq5Z 5.pereche difuzoare rusesti, 0,5W/8 ohm,pret 15 lei perechea https://postimg.cc/CZzwy6vT https://postimg.cc/CzSYMKv4 6.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 8 lei perechea https://postimg.cc/bSNZtRyz https://postimg.cc/23KkGYTd https://postimg.cc/Lq22586S 7.motor pickup cu potentiometru reglare turatie,,pret 15 lei https://postimg.cc/phbtqdt6 https://postimg.cc/fJTkx8C0 8.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea https://postimg.cc/qNQZcJx4 https://postimg.cc/yg3QzF48 https://postimg.cc/PNZ33zQ6 Link spre comentariu
