adydep Postat Iulie 30, 2020 Autor Partajează Postat Iulie 30, 2020 6.cositor cu plumb ,diametru 1,5mm,0,5kg,pret 50 lei https://postimg.cc/K1tctzFg https://postimg.cc/Jyq1d2sr Link spre comentariu
adydep Postat Iulie 31, 2020 Autor Partajează Postat Iulie 31, 2020 6.cositor cu plumb ,diametru 1,5mm,0,5kg,pret 50 lei https://postimg.cc/K1tctzFg https://postimg.cc/Jyq1d2sr Link spre comentariu
adydep Postat August 9, 2020 Autor Partajează Postat August 9, 2020 1.boxe active pc Serioux - pop251b ,pret 30 lei https://postimg.cc/SjRj3bzm https://postimg.cc/NyXk1rBP https://postimg.cc/zyKy7wHW 2.pistol lipit plastic,pret 25 lei https://postimg.cc/QFN8tQ36 https://postimg.cc/75rzQQS5 https://postimg.cc/svTFTbkc https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD 3.ondulator profesional Wella Pro Curl,pret 50 lei https://postimg.cc/5Q9HfQFL https://postimg.cc/jw4wV4CR https://postimg.cc/9zcwdKN0 https://postimg.cc/mt8Y1BLT https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiAzLSh7sDqAhWL4XcKHRQBDXAYABAEGgJlZg&ohost=www.google.com&cid=CAESQOD2QfX-_vFL-aahdTHY5K79XOMcvYdiIp2UHC2BUha4eSGBAB9Wk58Xg65RQFbbRkM3fAoR9mUJKtQZMMO5aQ8&sig=AOD64_1KbI4I8uUO2jEf7M2-w5UPDVgCxA&ctype=5&q=&ved=2ahUKEwjBvqyh7sDqAhULy6QKHcunDmUQ9aACegQICxA8&adurl= 4.transformator toroidal cred ca rusesc,inaltime tor aproximativ 4,7 cm,diametru exterior tor aproximativ 10 cm primar alimentat la 230V,da in secundar 28-29V,diametru sarma secundar 1,1mm (masurat cu sublerul),pret 30 lei https://postimg.cc/Hc0VGtKW https://postimg.cc/r02KYHfY https://postimg.cc/4H5ZPL0t https://postimg.cc/XXcytVSK 5.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,40 lei ambele https://postimg.cc/18DT6QZK https://postimg.cc/wtZ0b4HB https://postimg.cc/RqzjSq5Z 6.cositor cu plumb ,diametru 1,5mm,0,5kg,pret 50 lei https://postimg.cc/K1tctzFg https://postimg.cc/Jyq1d2sr 7.pereche difuzoare rusesti, 0,5W/8 ohm,pret 15 lei perechea https://postimg.cc/CZzwy6vT https://postimg.cc/CzSYMKv4 8.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 8 lei perechea https://postimg.cc/bSNZtRyz https://postimg.cc/23KkGYTd https://postimg.cc/Lq22586S 9.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea https://postimg.cc/qNQZcJx4 https://postimg.cc/yg3QzF48 https://postimg.cc/PNZ33zQ6 10.motor pickup cu potentiometru reglare turatie,,pret 15 lei https://postimg.cc/phbtqdt6 https://postimg.cc/fJTkx8C0 Link spre comentariu
