ionutz1971 Postat August 12, 2020 Autor Partajează Postat August 12, 2020 23. Fotomultiplicator PM 2018 B ( nou ) - 100 ron - vandut Link spre comentariu
ionutz1971 Postat August 31, 2020 Autor Partajează Postat August 31, 2020 Valabile in continuare : 1. N1200 controler de temperatura PID – 200 ron 2. Placa de baza laptop Hp Nc6120 functionala –50 ron 3. Motor cu pas hibrid cu cuplu mare – 150 ron 4. Indicator Programabil 5714A – 350 ron 5. Pompa expresor ODE 15 bari – 50 ron/buc 6. Placa de baza Fujitsu Siemens Amilo Pro v2000 – 50 ron 7. Lemo Swiss 8 pini – 70 ron/buc 8. Lemo Swiss 3 pini set – 60 ron/set 9. Converter RS232 to RS232 - 30 ron 11. Harduri Laptop 12. Harduri desktop 13. Tranzistori rusesti P210B - 50 ron 14. Tranzistori rusesti GT806A - 60 ron 15. Doua instrumente analogice AEG - 80 ron 16. Lot de comutatoare - 70 ron 17. Lot potentiometre - 60 ron 18. Ceramic PIO Capacitors КБГ-МХ - 30 ron ambele bucati 20. Triad SSO-23 - 50 ron/buc 21. Procesor laptop Intel Core 2 Duo T7500 SLAF8 2.2GHz - 50 ron 22. Placa de baza Samsung J1 ( 2016) - 50 ron 25. Incarcatoare laptop HP originale 26. Motoras DC 24V - 20 ron 27. Tranzistori 2N5641 Motorola - 50 ron /buc 27. Tranzistori 2N5641 Motorola - 50 ron /buc 28. Relee Varley - 15 ron/buc ( am 5 buc ) 29. Diode rectificatoare IOR 67-6130 ( 10 A; 1000V ) - pret pentru ambele bucati - 25 ron 30. RF/COAXIAL UG-58A/U - 25 ron/buc ( 7 buc disponibile - 100 ron toate ) 31. SIC-SAFCO condensator de înaltă tensiune, 0,47uF/6,3Kv - 70 ron 32. Condensator in ulei , inalta tensiune , KBG-P, 0.1uF 6kV RUSSIAN HIGH VOLTAGE - 40 ron 33. Condensator in ulei 0.05MFD/20000VDCW, productie SUA - 50 ron 34. Elemente bird 35. Modul incarcare samsung A5 2016 - 40 ron ( nou ) 36. Display Samsung SM-G360F - 40 ron 37. Varf statie de lipit Weller WD120 ( nou ) 35 ron/buc ( am 2 buc) 38. Module incarcare iphone 3G/3GS - 25 ron 39. Tub radiatii CTC-1 - 70 ron 40. Instrumente analogice amperi/volti 40 ron/buc - dimensiuni 115/100 42. Instrument analogic dimensiuni 115/100 mm , Gates Radio - 40 ron 44. Temporizator MZA-121 - nou - 60 ron 45. Condensatori ceramite - 70 ron 30 buc 46. Encoders 2 Channel 1000 CPR 8mm Film CW - 130 ron 47.Capse trecere pentru circuite integrate - 40 ron 48. MG Chemicals 8331 Adeziv epoxidic din argint - 100 ron 49. Sonda osciloscop Tektronix p6616 logic probe, noua - 700 ron 50. Kit rezistente SMD - 350 ron 52. Comutator rotativ ELMA - 80 ron 53. Panou programabil SGD 35-M - 300 ron 55. Doua socluri nixie - 35 ron 56. Conectori RF 27-9 Sub-Minax Bulkhead Jack 50 Ohm , produse de Amphenol , USA - 30 ron/buc 57. Microfon Grunding , model GDM 313, nou ( am si suportul) - 80 ron 60. Conector circular 26 pini - 50 ron 61. Conector circular 41 pini - 60 ron 62. Conector circular la 90 grade - 40 ron 63. Richtkoppler cu dioda detector - 60 ron , conectori tip N si BNC 64. Motor fara perii 400W DC , driver kit , plus sursa - 700 ron Link spre comentariu
ionutz1971 Postat Septembrie 19, 2020 Autor Partajează Postat Septembrie 19, 2020 La 31.08.2020 la 8:04, ionutz1971 a spus: Valabile in continuare : 1. N1200 controler de temperatura PID – 200 ron 2. Placa de baza laptop Hp Nc6120 functionala –50 ron 3. Motor cu pas hibrid cu cuplu mare – 150 ron 4. Indicator Programabil 5714A – 350 ron 5. Pompa expresor ODE 15 bari – 50 ron/buc 6. Placa de baza Fujitsu Siemens Amilo Pro v2000 – 50 ron 7. Lemo Swiss 8 pini – 70 ron/buc 8. Lemo Swiss 3 pini set – 60 ron/set 9. Converter RS232 to RS232 - 30 ron 11. Harduri Laptop 12. Harduri desktop 13. Tranzistori rusesti P210B - 50 ron 14. Tranzistori rusesti GT806A - 60 ron 15. Doua instrumente analogice AEG - 80 ron 16. Lot de comutatoare - 70 ron 17. Lot potentiometre - 60 ron 18. Ceramic PIO Capacitors КБГ-МХ - 30 ron ambele bucati 20. Triad SSO-23 - 50 ron/buc 21. Procesor laptop Intel Core 2 Duo T7500 SLAF8 2.2GHz - 50 ron 22. Placa de baza Samsung J1 ( 2016) - 50 ron 25. Incarcatoare laptop HP originale 26. Motoras DC 24V - 20 ron 27. Tranzistori 2N5641 Motorola - 50 ron /buc 27. Tranzistori 2N5641 Motorola - 50 ron /buc 28. Relee Varley - 15 ron/buc ( am 5 buc ) 29. Diode rectificatoare IOR 67-6130 ( 10 A; 1000V ) - pret pentru ambele bucati - 25 ron 30. RF/COAXIAL UG-58A/U - 25 ron/buc ( 7 buc disponibile - 100 ron toate ) 31. SIC-SAFCO condensator de înaltă tensiune, 0,47uF/6,3Kv - 70 ron 32. Condensator in ulei , inalta tensiune , KBG-P, 0.1uF 6kV RUSSIAN HIGH VOLTAGE - 40 ron 33. Condensator in ulei 0.05MFD/20000VDCW, productie SUA - 50 ron 34. Elemente bird 35. Modul incarcare samsung A5 2016 - 40 ron ( nou ) 36. Display Samsung SM-G360F - 40 ron 37. Varf statie de lipit Weller WD120 ( nou ) 35 ron/buc ( am 2 buc) 38. Module incarcare iphone 3G/3GS - 25 ron 39. Tub radiatii CTC-1 - 70 ron 40. Instrumente analogice amperi/volti 40 ron/buc - dimensiuni 115/100 42. Instrument analogic dimensiuni 115/100 mm , Gates Radio - 40 ron 45. Condensatori ceramite - 70 ron 30 buc 46. Encoders 2 Channel 1000 CPR 8mm Film CW - 130 ron 47.Capse trecere pentru circuite integrate - 40 ron 48. MG Chemicals 8331 Adeziv epoxidic din argint - 100 ron 49. Sonda osciloscop Tektronix p6616 logic probe, noua - 700 ron 50. Kit rezistente SMD - 350 ron 52. Comutator rotativ ELMA - 80 ron 53. Panou programabil SGD 35-M - 300 ron 55. Doua socluri nixie - 35 ron 56. Conectori RF 27-9 Sub-Minax Bulkhead Jack 50 Ohm , produse de Amphenol , USA - 30 ron/buc 57. Microfon Grunding , model GDM 313, nou ( am si suportul) - 80 ron 60. Conector circular 26 pini - 50 ron 61. Conector circular 41 pini - 60 ron 62. Conector circular la 90 grade - 40 ron 63. Richtkoppler cu dioda detector - 60 ron , conectori tip N si BNC 64. Motor fara perii 400W DC , driver kit , plus sursa - 700 ron Link spre comentariu
ionutz1971 Postat Septembrie 26, 2020 Autor Partajează Postat Septembrie 26, 2020 Valabile in continuare : 1. N1200 controler de temperatura PID – 200 ron 2. Placa de baza laptop Hp Nc6120 functionala –50 ron 3. Motor cu pas hibrid cu cuplu mare – 150 ron 4. Indicator Programabil 5714A – 350 ron 5. Pompa expresor ODE 15 bari – 50 ron/buc 6. Placa de baza Fujitsu Siemens Amilo Pro v2000 – 50 ron 7. Lemo Swiss 8 pini – 70 ron/buc 8. Lemo Swiss 3 pini set – 60 ron/set 9. Converter RS232 to RS232 - 30 ron 11. Harduri Laptop 12. Harduri desktop 13. Tranzistori rusesti P210B - 50 ron 14. Tranzistori rusesti GT806A - 60 ron 15. Doua instrumente analogice AEG - 80 ron 16. Lot de comutatoare - 70 ron 17. Lot potentiometre - 60 ron 18. Ceramic PIO Capacitors КБГ-МХ - 30 ron ambele bucati 20. Triad SSO-23 - 50 ron/buc 21. Procesor laptop Intel Core 2 Duo T7500 SLAF8 2.2GHz - 50 ron 22. Placa de baza Samsung J1 ( 2016) - 50 ron 25. Incarcatoare laptop HP originale 26. Motoras DC 24V - 20 ron 27. Tranzistori 2N5641 Motorola - 50 ron /buc 27. Tranzistori 2N5641 Motorola - 50 ron /buc 28. Relee Varley - 15 ron/buc ( am 5 buc ) 29. Diode rectificatoare IOR 67-6130 ( 10 A; 1000V ) - pret pentru ambele bucati - 25 ron 30. RF/COAXIAL UG-58A/U - 25 ron/buc ( 7 buc disponibile - 100 ron toate ) 31. SIC-SAFCO condensator de înaltă tensiune, 0,47uF/6,3Kv - 70 ron 32. Condensator in ulei , inalta tensiune , KBG-P, 0.1uF 6kV RUSSIAN HIGH VOLTAGE - 40 ron 33. Condensator in ulei 0.05MFD/20000VDCW, productie SUA - 50 ron 34. Elemente bird 35. Modul incarcare samsung A5 2016 - 40 ron ( nou ) 37. Varf statie de lipit Weller WD120 ( nou ) 35 ron/buc ( am 2 buc) 38. Module incarcare iphone 3G/3GS - 25 ron 39. Tub radiatii CTC-1 - 70 ron 40. Instrumente analogice amperi/volti 40 ron/buc - dimensiuni 115/100 42. Instrument analogic dimensiuni 115/100 mm , Gates Radio - 40 ron 45. Condensatori ceramite - 70 ron 30 buc 46. Encoders 2 Channel 1000 CPR 8mm Film CW - 130 ron 47.Capse trecere pentru circuite integrate - 40 ron 48. MG Chemicals 8331 Adeziv epoxidic din argint - 100 ron ( mai sunt 2 buc) 49. Sonda osciloscop Tektronix p6616 logic probe, noua - 700 ron 50. Kit rezistente SMD - 350 ron 52. Comutator rotativ ELMA - 80 ron 53. Panou programabil SGD 35-M - 300 ron 55. Doua socluri nixie - 35 ron 56. Conectori RF 27-9 Sub-Minax Bulkhead Jack 50 Ohm , produse de Amphenol , USA - 30 ron/buc 57. Microfon Grunding , model GDM 313, nou ( am si suportul) - 80 ron 60. Conector circular 26 pini - 50 ron 61. Conector circular 41 pini - 60 ron 62. Conector circular la 90 grade - 40 ron 64. Motor fara perii 400W DC , driver kit , plus sursa - 700 ron Link spre comentariu
ionutz1971 Postat Octombrie 12, 2020 Autor Partajează Postat Octombrie 12, 2020 valabil Link spre comentariu
ionutz1971 Postat Noiembrie 2, 2020 Autor Partajează Postat Noiembrie 2, 2020 (editat) Valabile in continuare : 1. N1200 controler de temperatura PID – 200 ron 2. Placa de baza laptop Hp Nc6120 functionala –50 ron 3. Motor cu pas hibrid cu cuplu mare – 150 ron 4. Indicator Programabil 5714A – 350 ron 5. Pompa expresor ODE 15 bari – 50 ron/buc 6. Placa de baza Fujitsu Siemens Amilo Pro v2000 – 50 ron 7. Lemo Swiss 8 pini – 70 ron/buc 8. Lemo Swiss 3 pini set – 60 ron/set 9. Converter RS232 to RS232 - 30 ron 11. Harduri Laptop 12. Harduri desktop 13. Tranzistori rusesti P210B - 50 ron 14. Tranzistori rusesti GT806A - 60 ron 15. Doua instrumente analogice AEG - 80 ron 16. Lot de comutatoare - 70 ron 17. Lot potentiometre - 60 ron 18. Ceramic PIO Capacitors КБГ-МХ - 30 ron ambele bucati 20. Triad SSO-23 - 50 ron/buc 21. Procesor laptop Intel Core 2 Duo T7500 SLAF8 2.2GHz - 50 ron - vandut 22. Placa de baza Samsung J1 ( 2016) - 50 ron 25. Incarcatoare laptop HP originale 26. Motoras DC 24V - 20 ron 27. Tranzistori 2N5641 Motorola - 50 ron /buc 27. Tranzistori 2N5641 Motorola - 50 ron /buc 28. Relee Varley - 15 ron/buc ( am 5 buc ) 29. Diode rectificatoare IOR 67-6130 ( 10 A; 1000V ) - pret pentru ambele bucati - 25 ron 30. RF/COAXIAL UG-58A/U - 25 ron/buc ( 7 buc disponibile - 100 ron toate ) 31. SIC-SAFCO condensator de înaltă tensiune, 0,47uF/6,3Kv - 70 ron - vandut 32. Condensator in ulei , inalta tensiune , KBG-P, 0.1uF 6kV RUSSIAN HIGH VOLTAGE - 40 ron - vandut 33. Condensator in ulei 0.05MFD/20000VDCW, productie SUA - 50 ron - vandut 34. Elemente bird 35. Modul incarcare samsung A5 2016 - 40 ron ( nou ) 37. Varf statie de lipit Weller WD120 ( nou ) 35 ron/buc ( am 2 buc) 38. Module incarcare iphone 3G/3GS - 25 ron 39. Tub radiatii CTC-1 - 70 ron 40. Instrumente analogice amperi/volti 40 ron/buc - dimensiuni 115/100 42. Instrument analogic dimensiuni 115/100 mm , Gates Radio - 40 ron 45. Condensatori ceramite - 70 ron 30 buc 46. Encoders 2 Channel 1000 CPR 8mm Film CW - 130 ron 47.Capse trecere pentru circuite integrate - 40 ron 48. MG Chemicals 8331 Adeziv epoxidic din argint - 100 ron ( mai sunt 2 buc) 49. Sonda osciloscop Tektronix p6616 logic probe, noua - 700 ron 50. Kit rezistente SMD - 350 ron 52. Comutator rotativ ELMA - 80 ron 53. Panou programabil SGD 35-M - 300 ron 55. Doua socluri nixie - 35 ron 56. Conectori RF 27-9 Sub-Minax Bulkhead Jack 50 Ohm , produse de Amphenol , USA - 30 ron/buc 57. Microfon Grunding , model GDM 313, nou ( am si suportul) - 80 ron 60. Conector circular 26 pini - 50 ron 61. Conector circular 41 pini - 60 ron 62. Conector circular la 90 grade - 40 ron 64. Motor fara perii 400W DC , driver kit , plus sursa - 700 ron Editat Noiembrie 2, 2020 de ionutz1971 Link spre comentariu
ionutz1971 Postat Noiembrie 21, 2020 Autor Partajează Postat Noiembrie 21, 2020 Valabil! Link spre comentariu
ionutz1971 Postat Decembrie 1, 2020 Autor Partajează Postat Decembrie 1, 2020 Valabile in continuare : 1. N1200 controler de temperatura PID – 200 ron 2. Placa de baza laptop Hp Nc6120 functionala – 80 ron 3. Motor cu pas hibrid cu cuplu mare – 150 ron 4. Indicator Programabil 5714A – 350 ron 5. Pompa expresor ODE 15 bari – 70 ron/buc 6. Placa de baza Fujitsu Siemens Amilo Pro v2000 – 50 ron 7. Lemo Swiss 8 pini – 70 ron/buc 8. Lemo Swiss 3 pini set – 60 ron/set 9. Converter RS232 to RS232 - 30 ron 10. Socluri novale - noi - 8ron/buc 11. Harduri Laptop 12. Harduri desktop 13. Tranzistori rusesti P210B - 50 ron 14. Tranzistori rusesti GT806A - 60 ron 15. Doua instrumente analogice AEG - 100 ron 16. Lot de comutatoare - 70 ron 17. Lot potentiometre - 60 ron 18. Ceramic PIO Capacitors КБГ-МХ - 30 ron ambele bucati 20. Triad SSO-23 - 50 ron/buc 21. Procesor laptop Intel Core 2 Duo T7500 SLAF8 2.2GHz - 50 ron 22. Placa de baza Samsung J1 ( 2016) - 50 ron 23. Fotomultiplicator PM 2018 B ( nou ) - 100 25. Incarcatoare laptop HP originale 26. Motoras DC 24V - 20 ron 27. Tranzistori 2N5641 Motorola - 50 ron /buc 27. Tranzistori 2N5641 Motorola - 50 ron /buc 28. Relee Varley - 15 ron/buc ( am 5 buc ) 29. Diode rectificatoare IOR 67-6130 ( 10 A; 1000V ) - pret pentru ambele bucati - 25 ron 30. RF/COAXIAL UG-58A/U - 25 ron/buc ( 7 buc disponibile - 130 ton toate ) 31. SIC-SAFCO condensator de înaltă tensiune, 0,47uF/6,3Kv - 70 ron vandut 32. Condensator in ulei , inalta tensiune , KBG-P, 0.1uF 6kV RUSSIAN HIGH VOLTAGE - 40 ron - vandut 33. Condensator in ulei 0.05MFD/20000VDCW, productie SUA - 50 ron - vandut 34. Elemente bird 35. Modul incarcare samsung A5 2016 - 40 ron ( nou ) 36. Display Samsung SM-G360F - 40 ron 37. Varf statie de lipit Weller WD120 ( nou ) 35 ron/buc ( am 3 buc) 38. Module incarcare iphone 3G/3GS - 25 ron 39. Tub radiatii CTC-1 - 70 ron 40. Instrumente analogice amperi/volti 40 ron/buc - dimensiuni 115/100 42. Instrument analogic dimensiuni 115/100 mm , Gates Radio - 40 ron 44. Temporizator MZA-121 - nou - 70 ron 45. Condensatori ceramite - 70 ron 30 buc 46. Encoders 2 Channel 1000 CPR 8mm Film CW - 130 ron 47.Capse trecere pentru circuite integrate - 40 ron 48. MG Chemicals 8331 Adeziv epoxidic din argint - 100 ron ( mai sunt 3 buc) 49. Sonda osciloscop Tektronix p6616 logic probe, noua - 700 ron 50. Kit rezistente SMD - 350 ron 52. Comutator rotativ ELMA - 80 ron 53. Panou programabil SGD 35-M - 300 ron 55. Doua socluri nixie - 35 ron 56. Conectori RF 27-9 Sub-Minax Bulkhead Jack 50 Ohm , produse de Amphenol , USA - 30 ron/buc 57. Microfon Grunding , model GDM 313, nou ( am si suportul) - 80 ron 60. Conector circular 26 pini - 50 ron 61. Conector circular 41 pini - 60 ron 62. Conector circular la 90 grade - 40 ron 63. Richtkoppler cu dioda detector - 60 ron , conectori tip N si BNC - vandut 64. Motor fara perii 400W DC , driver kit , plus sursa - 700 ron Link spre comentariu
ionutz1971 Postat Decembrie 19, 2020 Autor Partajează Postat Decembrie 19, 2020 Valabile in continuare : 1. N1200 controler de temperatura PID – 200 ron 2. Placa de baza laptop Hp Nc6120 functionala – 80 ron 3. Motor cu pas hibrid cu cuplu mare – 150 ron 4. Indicator Programabil 5714A – 350 ron 5. Pompa expresor ODE 15 bari – 70 ron/buc 6. Placa de baza Fujitsu Siemens Amilo Pro v2000 – 50 ron 7. Lemo Swiss 8 pini – 70 ron/buc 8. Lemo Swiss 3 pini set – 60 ron/set 9. Converter RS232 to RS232 - 30 ron 10. Socluri novale - noi - 8ron/buc 11. Harduri Laptop 12. Harduri desktop 13. Tranzistori rusesti P210B - 50 ron 14. Tranzistori rusesti GT806A - 60 ron 15. Doua instrumente analogice AEG - 100 ron 16. Lot de comutatoare - 70 ron 17. Lot potentiometre - 60 ron 18. Ceramic PIO Capacitors КБГ-МХ - 30 ron ambele bucati 20. Triad SSO-23 - 50 ron/buc 21. Procesor laptop Intel Core 2 Duo T7500 SLAF8 2.2GHz - 50 ron 22. Placa de baza Samsung J1 ( 2016) - 50 ron 23. Fotomultiplicator PM 2018 B ( nou ) - 100 25. Incarcatoare laptop HP originale 26. Motoras DC 24V - 20 ron 27. Tranzistori 2N5641 Motorola - 50 ron /buc 28. Relee Varley - 15 ron/buc ( am 5 buc ) 29. Diode rectificatoare IOR 67-6130 ( 10 A; 1000V ) - pret pentru ambele bucati - 25 ron 30. RF/COAXIAL UG-58A/U - 25 ron/buc ( 7 buc disponibile - 130 ton toate ) 34. Elemente bird 35. Modul incarcare samsung A5 2016 - 40 ron ( nou ) 36. Display Samsung SM-G360F - 40 ron 37. Varf statie de lipit Weller WD120 ( nou ) 35 ron/buc ( am 3 buc) 38. Module incarcare iphone 3G/3GS - 25 ron 39. Tub radiatii CTC-1 - 70 ron 40. Instrumente analogice amperi/volti 40 ron/buc - dimensiuni 115/100 42. Instrument analogic dimensiuni 115/100 mm , Gates Radio - 40 ron 44. Temporizator MZA-121 - nou - 70 ron 45. Condensatori ceramite - 70 ron 30 buc 46. Encoders 2 Channel 1000 CPR 8mm Film CW - 130 ron 47.Capse trecere pentru circuite integrate - 40 ron 48. MG Chemicals 8331 Adeziv epoxidic din argint - 100 ron ( mai sunt 3 buc) 50. Kit rezistente SMD - 350 ron 52. Comutator rotativ ELMA - 80 ron 53. Panou programabil SGD 35-M - 300 ron 55. Doua socluri nixie - 35 ron 56. Conectori RF 27-9 Sub-Minax Bulkhead Jack 50 Ohm , produse de Amphenol , USA - 30 ron/buc 57. Microfon Grunding , model GDM 313, nou ( am si suportul) - 80 ron 60. Conector circular 26 pini - 50 ron 61. Conector circular 41 pini - 60 ron 62. Conector circular la 90 grade - 40 ron 64. Motor fara perii 400W DC , driver kit , plus sursa - 700 ron Link spre comentariu
ionutz1971 Postat Decembrie 31, 2020 Autor Partajează Postat Decembrie 31, 2020 Valabile in continuare : 1. N1200 controler de temperatura PID – 200 ron 2. Placa de baza laptop Hp Nc6120 functionala – 80 ron 3. Motor cu pas hibrid cu cuplu mare – 150 ron 4. Indicator Programabil 5714A – 350 ron 5. Pompa expresor ODE 15 bari – 70 ron/buc 6. Placa de baza Fujitsu Siemens Amilo Pro v2000 – 50 ron 7. Lemo Swiss 8 pini – 70 ron/buc 8. Lemo Swiss 3 pini set – 60 ron/set 9. Converter RS232 to RS232 - 30 ron 10. Socluri novale - noi - 8ron/buc 11. Harduri Laptop 12. Harduri desktop 13. Tranzistori rusesti P210B - 50 ron 14. Tranzistori rusesti GT806A - 60 ron 15. Doua instrumente analogice AEG - 100 ron 16. Lot de comutatoare - 70 ron 17. Lot potentiometre - 60 ron 18. Ceramic PIO Capacitors КБГ-МХ - 30 ron ambele bucati 20. Triad SSO-23 - 50 ron 21. Procesor laptop Intel Core 2 Duo T7500 SLAF8 2.2GHz - 50 ron 22. Placa de baza Samsung J1 ( 2016) - 50 ron 23. Fotomultiplicator PM 2018 B ( nou ) - 100 25. Incarcatoare laptop HP originale 26. Motoras DC 24V - 20 ron 27. Tranzistori 2N5641 Motorola - 50 ron /buc 28. Relee Varley - 15 ron/buc ( am 5 buc ) 29. Diode rectificatoare IOR 67-6130 ( 10 A; 1000V ) - pret pentru ambele bucati - 25 ron 30. RF/COAXIAL UG-58A/U - 25 ron/buc ( 7 buc disponibile - 130 ton toate ) 34. Elemente bird 35. Modul incarcare samsung A5 2016 - 40 ron ( nou ) 36. Display Samsung SM-G360F - 40 ron 37. Varf statie de lipit Weller WD120 ( nou ) 35 ron/buc ( am 3 buc) 38. Module incarcare iphone 3G/3GS - 25 ron 39. Tub radiatii CTC-1 - 70 ron 40. Instrumente analogice amperi/volti 40 ron/buc - dimensiuni 115/100 42. Instrument analogic dimensiuni 115/100 mm , Gates Radio - 40 ron 44. Temporizator MZA-121 - nou - 70 ron 45. Condensatori ceramite - 60 ron 30 buc 46. Encoders 2 Channel 1000 CPR 8mm Film CW - 120 ron 47.Capse trecere pentru circuite integrate - 40 ron 50. Kit rezistente SMD - 300 ron 52. Comutator rotativ ELMA - 80 ron 53. Panou programabil SGD 35-M - 300 ron 55. Doua socluri nixie - 35 ron 56. Conectori RF 27-9 Sub-Minax Bulkhead Jack 50 Ohm , produse de Amphenol , USA - 30 ron/buc 57. Microfon Grunding , model GDM 313, nou ( am si suportul) - 80 ron 60. Conector circular 26 pini - 50 ron 61. Conector circular 41 pini - 60 ron 62. Conector circular la 90 grade - 40 ron 64. Motor fara perii 400W DC , driver kit , plus sursa - 700 ron Link spre comentariu
ionutz1971 Postat Ianuarie 18, 2021 Autor Partajează Postat Ianuarie 18, 2021 Valabile in continuare : 1. N1200 controler de temperatura PID – 200 ron 2. Placa de baza laptop Hp Nc6120 functionala – 80 ron - vanduta 3. Motor cu pas hibrid cu cuplu mare – 150 ron 4. Indicator Programabil 5714A – 350 ron 5. Pompa expresor ODE 15 bari – 70 ron/buc 6. Placa de baza Fujitsu Siemens Amilo Pro v2000 – 50 ron 7. Lemo Swiss 8 pini – 70 ron/buc 8. Lemo Swiss 3 pini set – 60 ron/set 9. Converter RS232 to RS232 - 30 ron 10. Socluri novale - noi - 8ron/buc - vandute 11. Harduri Laptop 12. Harduri desktop 13. Tranzistori rusesti P210B - 50 ron - vanduti 14. Tranzistori rusesti GT806A - 60 ron 15. Doua instrumente analogice AEG - 100 ron 16. Lot de comutatoare - 70 ron 17. Lot potentiometre - 60 ron 18. Ceramic PIO Capacitors КБГ-МХ - 30 ron ambele bucati 20. Triad SSO-23 - 50 ron 21. Procesor laptop Intel Core 2 Duo T7500 SLAF8 2.2GHz - 50 ron - vandut 22. Placa de baza Samsung J1 ( 2016) - 50 ron 23. Fotomultiplicator PM 2018 B ( nou ) - 100 25. Incarcatoare laptop HP originale 26. Motoras DC 24V - 20 ron 27. Tranzistori 2N5641 Motorola - 50 ron /buc 28. Relee Varley - 15 ron/buc ( am 5 buc ) 29. Diode rectificatoare IOR 67-6130 ( 10 A; 1000V ) - pret pentru ambele bucati - 25 ron 30. RF/COAXIAL UG-58A/U - 25 ron/buc ( 7 buc disponibile - 130 ton toate ) 34. Elemente bird 35. Modul incarcare samsung A5 2016 - 40 ron ( nou ) 36. Display Samsung SM-G360F - 40 ron 37. Varf statie de lipit Weller WD120 ( nou ) 35 ron/buc ( am 3 buc) 38. Module incarcare iphone 3G/3GS - 25 ron 39. Tub radiatii CTC-1 - 70 ron 40. Instrumente analogice amperi/volti 40 ron/buc - dimensiuni 115/100 42. Instrument analogic dimensiuni 115/100 mm , Gates Radio - 40 ron 44. Temporizator MZA-121 - nou - 70 ron 45. Condensatori ceramite - 60 ron 30 buc 46. Encoders 2 Channel 1000 CPR 8mm Film CW - 120 ron 47.Capse trecere pentru circuite integrate - 40 ron 50. Kit rezistente SMD - 270 ron 52. Comutator rotativ ELMA - 80 ron 53. Panou programabil SGD 35-M - 270 ron 55. Doua socluri nixie - 35 ron - vandute 56. Conectori RF 27-9 Sub-Minax Bulkhead Jack 50 Ohm , produse de Amphenol , USA - 30 ron/buc 57. Microfon Grunding , model GDM 313, nou ( am si suportul) - 80 ron 60. Conector circular 26 pini - 50 ron 61. Conector circular 41 pini - 60 ron 62. Conector circular la 90 grade - 40 ron 64. Motor fara perii 400W DC , driver kit , plus sursa - 700 ron Link spre comentariu
ionutz1971 Postat Februarie 10, 2021 Autor Partajează Postat Februarie 10, 2021 Valabile in continuare : 1. N1200 controler de temperatura PID – 200 ron 3. Motor cu pas hibrid cu cuplu mare – 150 ron 4. Indicator Programabil 5714A – 350 ron 5. Pompa expresor ODE 15 bari – 70 ron/buc 6. Placa de baza Fujitsu Siemens Amilo Pro v2000 – 50 ron 7. Lemo Swiss 8 pini – 70 ron/buc 8. Lemo Swiss 3 pini set – 60 ron/set 9. Converter RS232 to RS232 - 30 ron 11. Harduri Laptop 12. Harduri desktop 14. Tranzistori rusesti GT806A - 60 ron 15. Doua instrumente analogice AEG - 100 ron 16. Lot de comutatoare - 70 ron 17. Lot potentiometre - 60 ron 18. Ceramic PIO Capacitors КБГ-МХ - 30 ron ambele bucati 20. Triad SSO-23 - 50 ron 22. Placa de baza Samsung J1 ( 2016) - 50 ron 23. Fotomultiplicator PM 2018 B ( nou ) - 100 25. Incarcatoare laptop HP originale 26. Motoras DC 24V - 20 ron 27. Tranzistori 2N5641 Motorola - 50 ron /buc 28. Relee Varley - 15 ron/buc ( am 5 buc ) 29. Diode rectificatoare IOR 67-6130 ( 10 A; 1000V ) - pret pentru ambele bucati - 25 ron 30. RF/COAXIAL UG-58A/U - 25 ron/buc ( 7 buc disponibile - 130 ton toate ) 34. Elemente bird 35. Modul incarcare samsung A5 2016 - 40 ron ( nou ) 36. Display Samsung SM-G360F - 40 ron 37. Varf statie de lipit Weller WD120 ( nou ) 35 ron/buc ( am 3 buc) 38. Module incarcare iphone 3G/3GS - 25 ron 39. Tub radiatii CTC-1 - 70 ron 40. Instrumente analogice amperi/volti 40 ron/buc - dimensiuni 115/100 42. Instrument analogic dimensiuni 115/100 mm , Gates Radio - 40 ron 44. Temporizator MZA-121 - nou - 70 ron 45. Condensatori ceramite - 60 ron 30 buc 46. Encoders 2 Channel 1000 CPR 8mm Film CW - 120 ron 47.Capse trecere pentru circuite integrate - 40 ron 52. Comutator rotativ ELMA - 80 ron 53. Panou programabil SGD 35-M - 270 ron 56. Conectori RF 27-9 Sub-Minax Bulkhead Jack 50 Ohm , produse de Amphenol , USA - 30 ron/buc 57. Microfon Grunding , model GDM 313, nou ( am si suportul) - 80 ron 60. Conector circular 26 pini - 50 ron 61. Conector circular 41 pini - 60 ron 62. Conector circular la 90 grade - 40 ron 64. Motor fara perii 400W DC , driver kit , plus sursa - 700 ron Link spre comentariu
ionutz1971 Postat Februarie 22, 2021 Autor Partajează Postat Februarie 22, 2021 La 10.02.2021 la 9:53, ionutz1971 a spus: Valabile in continuare : 1. N1200 controler de temperatura PID – 200 ron 3. Motor cu pas hibrid cu cuplu mare – 150 ron 4. Indicator Programabil 5714A – 350 ron 5. Pompa expresor ODE 15 bari – 70 ron/buc 6. Placa de baza Fujitsu Siemens Amilo Pro v2000 – 50 ron 7. Lemo Swiss 8 pini – 70 ron/buc 8. Lemo Swiss 3 pini set – 60 ron/set 9. Converter RS232 to RS232 - 30 ron 11. Harduri Laptop 12. Harduri desktop 14. Tranzistori rusesti GT806A - 60 ron 15. Doua instrumente analogice AEG - 100 ron 16. Lot de comutatoare - 70 ron 17. Lot potentiometre - 60 ron 18. Ceramic PIO Capacitors КБГ-МХ - 30 ron ambele bucati 20. Triad SSO-23 - 50 ron 22. Placa de baza Samsung J1 ( 2016) - 50 ron 23. Fotomultiplicator PM 2018 B ( nou ) - 100 25. Incarcatoare laptop HP originale 26. Motoras DC 24V - 20 ron 27. Tranzistori 2N5641 Motorola - 50 ron /buc 28. Relee Varley - 15 ron/buc ( am 5 buc ) 29. Diode rectificatoare IOR 67-6130 ( 10 A; 1000V ) - pret pentru ambele bucati - 25 ron 30. RF/COAXIAL UG-58A/U - 25 ron/buc ( 7 buc disponibile - 130 ton toate ) 34. Elemente bird 35. Modul incarcare samsung A5 2016 - 40 ron ( nou ) 36. Display Samsung SM-G360F - 40 ron 37. Varf statie de lipit Weller WD120 ( nou ) 35 ron/buc ( am 3 buc) 38. Module incarcare iphone 3G/3GS - 25 ron 39. Tub radiatii CTC-1 - 70 ron 40. Instrumente analogice amperi/volti 40 ron/buc - dimensiuni 115/100 42. Instrument analogic dimensiuni 115/100 mm , Gates Radio - 40 ron 44. Temporizator MZA-121 - nou - 70 ron 45. Condensatori ceramite - 60 ron 30 buc 46. Encoders 2 Channel 1000 CPR 8mm Film CW - 120 ron 47.Capse trecere pentru circuite integrate - 40 ron 52. Comutator rotativ ELMA - 80 ron 53. Panou programabil SGD 35-M - 270 ron 56. Conectori RF 27-9 Sub-Minax Bulkhead Jack 50 Ohm , produse de Amphenol , USA - 30 ron/buc 57. Microfon Grunding , model GDM 313, nou ( am si suportul) - 80 ron 60. Conector circular 26 pini - 50 ron 61. Conector circular 41 pini - 60 ron 62. Conector circular la 90 grade - 40 ron 64. Motor fara perii 400W DC , driver kit , plus sursa - 700 ron Link spre comentariu
ionutz1971 Postat Martie 11, 2021 Autor Partajează Postat Martie 11, 2021 Valabile in continuare : ( am redus preturile la majoritatea produselor! ) 1. N1200 controler de temperatura PID – 150 ron 3. Motor cu pas hibrid cu cuplu mare – 130 ron 4. Indicator Programabil 5714A – 300 ron 5. Pompa expresor ODE 15 bari – 70 ron/buc 6. Placa de baza Fujitsu Siemens Amilo Pro v2000 – 30 ron 7. Lemo Swiss 8 pini – 70 ron/buc 8. Lemo Swiss 3 pini set – 60 ron/set 9. Converter RS232 to RS232 - 30 ron 11. Harduri Laptop 12. Harduri desktop 14. Tranzistori rusesti GT806A - 50 ron 15. Doua instrumente analogice AEG - 80 ron 16. Lot de comutatoare - 60 ron 17. Lot potentiometre - 50 ron 18. Ceramic PIO Capacitors КБГ-МХ - 30 ron ambele bucati 20. Triad SSO-23 - 50 ron 25. Incarcatoare laptop HP originale 26. Motoras DC 24V - 20 ron 27. Tranzistori 2N5641 Motorola - 40 ron /buc 28. Relee Varley - 15 ron/buc ( am 5 buc ) - toate 50 ron 29. Diode rectificatoare IOR 67-6130 ( 10 A; 1000V ) - pret pentru ambele bucati - 20 ron 30. RF/COAXIAL UG-58A/U - 25 ron/buc ( 7 buc disponibile - 130 ton toate ) 34. Elemente bird 35. Modul incarcare samsung A5 2016 - 30 ron ( nou ) 36. Display Samsung SM-G360F - 30 ron 37. Varf statie de lipit Weller WD120 ( nou ) 35 ron/buc ( am 3 buc) 38. Module incarcare iphone 3G/3GS - 25 ron 39. Tub radiatii CTC-1 - 70 ron 40. Instrumente analogice amperi/volti 35 ron/buc - dimensiuni 115/100 42. Instrument analogic dimensiuni 115/100 mm , Gates Radio - 35 ron 44. Temporizator MZA-121 - nou - 50 ron 45. Condensatori ceramite - 60 ron 30 buc 46. Encoders 2 Channel 1000 CPR 8mm Film CW - 120 ron 47.Capse trecere pentru circuite integrate - 40 ron 52. Comutator rotativ ELMA - 70 ron 53. Panou programabil SGD 35-M - 250 ron 56. Conectori RF 27-9 Sub-Minax Bulkhead Jack 50 Ohm , produse de Amphenol , USA - 25 ron/buc 57. Microfon Grunding , model GDM 313, nou ( am si suportul) - 80 ron 60. Conector circular 26 pini - 40 ron 61. Conector circular 41 pini - 50 ron 62. Conector circular la 90 grade - 30 ron 64. Motor fara perii 400W DC , driver kit - 400 ron ( sursa a fost vanduta ) Link spre comentariu
helyon Postat Martie 12, 2021 Partajează Postat Martie 12, 2021 Salut! poz. 42-43 mă interesează pe mine. Cum procedăm? ...40-42, scuze! Link spre comentariu
