cmariuss Postat August 17 Autor Partajează Postat August 17 Disponibile, cu excepția pct 45. Link spre comentariu
cmariuss Postat Septembrie 3 Autor Partajează Postat Septembrie 3 Au mai ramas: 1. Electromotor MAP-1156, Putere: 45W, 2800rot/min, alimentare 220V. Pret: 30 lei. https://imgur.com/6TVtd11 https://imgur.com/Ma87KUr https://imgur.com/yjymhHF 2. Servomotor Shiko HS060-T-k02. Alimentare 24Vcc, turatie 1500rpm, cuplu 1,5kgf-cm. Controler SLA6022 Sanken. Pret: 22 lei https://imgur.com/BTC7wCF 3.Servomotor DF80FT10-6. Alimentare 24Vcc. Pret: 12 lei. https://imgur.com/i1VTFJP 4. Motor Hosiden FH7-1384. Alimentare 24Vcc/ 130mA. Pret: 7 lei https://imgur.com/2o1x2yb 5. Servomotor cu controler Nidec 45M3082094. Alimentare 24Vcc/1,3A. Turatie: 604.24-1662,49 rot/min. Pret: 7 lei. https://imgur.com/0Plj2sR 6. Motor pas-cu-pas Minibea 23PM-J247-G1V, Alimentare la 2,2 V/ 3,2A. Are un defect la mufa deconexiuni, traseele pe PCB nu sunt afectate. Pret: 6 lei. https://imgur.com/DwtqBRK 7. Motoare MP40, alimentare 24Vcc. Provin din automate de cafea. Pret: 7 lei/buc. https://imgur.com/iKqBIB8 8. Motoare pas-cu-pas 17PM. Pret: 5 lei bucata. https://imgur.com/ttGYgUd 14. Motoare din imprimante . Pret: 4 lei buc https://imgur.com/nXaAZYM 15. Motor cu ambreiaj Ogura Motor Dell 127K45893 24V cu reductor si ambreiaj Pret: 16 lei. https://imgur.com/heu6Zcr 16.Ventilator Nidec Gamma32, alimentare 24Vcc/400mA, dimensiuni 12x12cm. Pret: 10 lei. https://imgur.com/LZzoWcx 18. Motor universal masina de spalat automata MCA 45/64-148/TAT5 U= 220-240Vca, P= 420W In= 1,9 A. Protejat termic. Pret: 70 lei. https://imgur.com/QEJI5Jw https://imgur.com/3vqBmCA https://imgur.com/AOVXSFG https://imgur.com/aYHfcLh https://imgur.com/ClPRr2V https://imgur.com/KD2GEG6 https://imgur.com/571CtIj https://imgur.com/mdqXfN2 19. Perii/carbuni motor: grosime 16 mm, lungime 32 mm, inaltime 24mm, lungime cablu legatura 80mm, papuc fi 6mm. Pret: 9 lei/perechea. https://imgur.com/9znWpdi https://imgur.com/0ZIulWB 20. Perii/carbuni motor: grosime 8 mm, lungime 29 mm, inaltime 15mm,lungime cablu legatura 75 mm, papuc fi 6mm. Pret: 5 lei/perechea. https://imgur.com/k9dvWFI https://imgur.com/u3cqFhV 21. Perii/carbuni motor: grosime 6 mm, lungime 24 mm, inaltime 11 mm, lungime cablu legatura 55 mm, papuc fi 4 mm. Pret: 3 lei/perechea. https://imgur.com/NQK3UoF https://imgur.com/Vk8nQ6S 22. Motor Johnson aspirtor cu acumulatori 2x2,4V, 1300mAh.Pret: 9 lei. https://imgur.com/siAqx8j https://imgur.com/uHNxFt2 23. Motor stertgator luneta Ford Escort. Pret: 15 lei. https://imgur.com/Gzxf5tK https://imgur.com/mKzOq3V https://imgur.com/d8WpL9E 24. Motor stergator luneta VW MK3. 12V- 3.5A. Pret: 15 lei. https://imgur.com/v3Rs6et https://imgur.com/9mIwePQ 26. Modul pentru controlul motoarelor pas-cu pas Sanken SLA7051M. Pret: 10 ei https://imgur.com/ofxN8U8 27. Modul pentru controlul motoarelor pas cu pas STK672-410. https://imgur.com/cwFdxuu Pret: 12lei 28. Module pentru controlul motoarelor pas cu pas STK 672-400B. Pret: 12 lei/per modul https://imgur.com/FECqUy2 https://imgur.com/io0FtYe 29. Motor electrocasnice UH-20R-0805. U=220V. Pret: 9 lei. https://imgur.com/nYwVDKQ https://imgur.com/4sZZTqv 37. Motor brushless Matsushita RH7-1260, DNQ16D04R34A. Driver 6AE11, pre-driver LB1823. Dimensiuni 127mm x 91mm.Lungime ax 40mm. Diametru ax 7mm. Pret: 22 lei. https://imgur.com/Koo9tTd https://imgur.com/ivmRs7m https://imgur.com/1ju8QB8 38. Motor pas cu pas Minibea NEMA23, 23KM-K381-01V 24V 2000mA 1.8 grade. Rotita metalica are 14 dinti cu diametru 12mm, lungime 20mm, diametru ax 6mm. Pret: 32 lei. https://imgur.com/ec94mbh https://imgur.com/vxwNGHo https://imgur.com/KnSC79T 39. Motor pas cu pas Minibea NEMA17,17PM-k401-P5V 3V 1200mA. Lungime ax 26mm, diametru ax 5mm. Rotita metalica 16 dinti, 19mm diametru, lungime 18mm. Pret: 18 lei. https://imgur.com/YIE4H5m https://imgur.com/iDcRABy https://imgur.com/gr7Rvee 40. Motoare (doua) pas cu pas Minibea NEMA 17,17PM-k103-p9V 3.6V 1200mA. Lungime ax 19 mm, diametru 5mm. Rotita metalica cu 16 dinti, lungime 13 mm, diametru 9.5mm. Pret: 17 lei buc, sau 28 lei ambele. https://imgur.com/rO4IBxY https://imgur.com/m3xnUig https://imgur.com/kWQ7jLN 41. Motoras macara usa stanga fata VW Passat B6 cod 980851-113 https://imgur.com/AGNccwq https://imgur.com/nBkSyr7 Pret: 20 lei. 42. Motoras macara usa stanga spate VW Passat B6 cod 974225-113 https://imgur.com/dVdpOLr https://imgur.com/6EQlqHG https://imgur.com/qvIwPFB https://imgur.com/bkeX6fO https://imgur.com/hOut754 Pret: 20 lei. 43. Motor Bosch cu reductor pentru masini de tocat. Pret: 25 lei. https://postimg.cc/SYpzLWkB https://postimg.cc/H8486VLV https://postimg.cc/JsdDYwRc https://postimg.cc/FYKkxFXH https://postimg.cc/PNmDXFMT 44. Motor pentru mixer vertical Russel&Hobss 18980-56 300W, 2 viteze. Suportul de prindere cu restul mixerului e rupt. Pret: 18 lei. https://postimg.cc/21jhXFhm https://postimg.cc/GBHYbLX5 https://postimg.cc/BjhHWLBF 46. Motor 12V 2,5A cu tambur aluminiu. Pret: 9 lei. https://postimg.cc/Mv5jRM4L Link spre comentariu
cmariuss Postat Septembrie 10 Autor Partajează Postat Septembrie 10 Se adauga: 47. Motor cafetiera Philips+ angrenajul macinare cafea, Domel 482.3.531. 230Vca, 180W, 13500 rot/min. Datele complete in fisa tehnica de mai jos. Pret: 50 lei. https://www.domel.com/document-download/148 https://imgur.com/2vSmrEW https://imgur.com/OBhiIvc https://imgur.com/Gu6GZCT https://imgur.com/3bhetoE https://imgur.com/Ij5p3cq 48. Motor Cafetiera Philips- Kinly motor KFC545S-16205, 24V, 55mA, turatie 3600rpm. Datele complete in fisa tehnica de mai jos. Pret: 25 lei. http://www.kindlymotor.com/upload/product/121230150647363851.pdf https://imgur.com/4uzIZsA https://imgur.com/losEoYo 49. Motor suflanta 230V, 43W (recuperat dintro centrala termica de apartament)+presostat Honeywel. Pret: 40 lei. https://imgur.com/xWlaVwt https://imgur.com/OCAWO54 https://imgur.com/nHMjmo8 https://imgur.com/FF1KAKw Link spre comentariu
cmariuss Postat Septembrie 14 Autor Partajează Postat Septembrie 14 Disponibile. Link spre comentariu
cmariuss Postat Septembrie 17 Autor Partajează Postat Septembrie 17 Disponibile. Link spre comentariu
cmariuss Postat Septembrie 21 Autor Partajează Postat Septembrie 21 Disponibile. Link spre comentariu
cmariuss Postat Septembrie 27 Autor Partajează Postat Septembrie 27 Disponibile. Link spre comentariu
cmariuss Postat Octombrie 4 Autor Partajează Postat Octombrie 4 Se adauga: 50. Ventilator cazan Fuwk Konwektor wds-6a. Produs in Polonia. Alimentare 230V, putere 70 W. Curatat de funingine, revopsit, schimbat condensator. Pret: 195 lei. https://imgur.com/a/gRG2Oo8 51. Pompa circulatie pentru centala de apartament, Grundfoss UPS 15-60 es, cu trei trepte de putere: P1 0.20 A, 45W; P2 0.31A, 70W; P3 0.40 90 W. Pompa a fost curata si revopsita: Pret: 110 lei. https://imgur.com/a/l7scbpr Link spre comentariu
