Motoare diverse
cmariuss
  • Răspunsuri 94
Preturi reduse:
 1. Electromotor MAP-1156, Putere: 45W, 2800rot/min, alimentare 220V. Pret: 35
lei.
https://imgur.com/6TVtd11
https://imgur.com/Ma87KUr
https://imgur.com/yjymhHF
2. Servomotor Shiko HS060-T-k02. Alimentare 24Vcc, turatie 1500rpm, cuplu
1,5kgf-cm. Controler SLA6022 Sanken. Pret: 25 lei
https://imgur.com/BTC7wCF
3.Servomotor DF80FT10-6. Alimentare 24Vcc. Pret: 12 lei.
https://imgur.com/i1VTFJP
4. Motor Hosiden FH7-1384. Alimentare 24Vcc/ 130mA. Pret: 7 lei
https://imgur.com/2o1x2yb
5. Servomotor cu controler Nidec 45M3082094. Alimentare 24Vcc/1,3A. Turatie:
604.24-1662,49 rot/min. Pret: 7 lei.
https://imgur.com/0Plj2sR
6. Motor pas-cu-pas Minibea 23PM-J247-G1V, Alimentare la 2,2 V/ 3,2A. Are un
defect la mufa deconexiuni, traseele pe PCB nu sunt afectate. Pret: 7 lei.
https://imgur.com/DwtqBRK
7. Motoare MP40, alimentare 24Vcc. Provin din automate de cafea. Pret: 7 lei
buc.
https://imgur.com/iKqBIB8
8. Motoare pas-cu-pas 17PM. Pret: 5 lei bucata.
https://imgur.com/ttGYgUd
9. Motoare pas-cu-pas 14PM. Pret: 5 lei bucata.
https://imgur.com/2T6PlH7
10. Motoare pas-cu-pas diverse. Pret: 4 lei bucata.
https://imgur.com/YtpxrXv
11. Motoare pas cu pas Matsushita si Siemens. Pret: 3 lei bucata.
https://imgur.com/YnauSkg
14. Motoare din imprimante . Pret: 5 lei buc
https://imgur.com/nXaAZYM
15. Motor cu ambreiaj Ogura  Motor Dell 127K45893 24V cu reductor si ambreiaj
Pret: 16 lei.
https://imgur.com/heu6Zcr
16.Ventilator Nidec Gamma32, alimentare 24Vcc/400mA, dimensiuni 12x12cm. Pret:
10 lei.
https://imgur.com/LZzoWcx
17. Motor recuperat dintrun magnetofon Tesla CM-130. Pret: 25 lei.
https://imgur.com/9tdxJE8
https://imgur.com/JfJ1ueU
https://imgur.com/xwh3V4g
 18.  Motor universal masina de spalat automata MCA 45/64-148/TAT5
U= 220-240Vca, P= 420W In= 1,9 A.
Protejat termic.
Pret: 80 lei.
https://imgur.com/QEJI5Jw
https://imgur.com/3vqBmCA
https://imgur.com/AOVXSFG
https://imgur.com/aYHfcLh
https://imgur.com/ClPRr2V
https://imgur.com/KD2GEG6
https://imgur.com/571CtIj
https://imgur.com/mdqXfN2
 19. Perii/carbuni motor: grosime 16 mm, lungime 32 mm, inaltime 24mm, lungime
cablu legatura 80mm, papuc fi 6mm.
Pret: 15 lei/perechea.
https://imgur.com/9znWpdi
https://imgur.com/0ZIulWB
20. Perii/carbuni motor: grosime 8 mm, lungime 29 mm,  inaltime 15mm,lungime
cablu legatura 75 mm, papuc fi 6mm.
Pret: 8 lei/perechea.
https://imgur.com/k9dvWFI
https://imgur.com/u3cqFhV
21. Perii/carbuni motor: grosime 6 mm, lungime 24 mm, inaltime 11 mm, lungime
cablu legatura 55 mm, papuc fi 4 mm.
Pret: 5 lei/perechea.
https://imgur.com/NQK3UoF
https://imgur.com/Vk8nQ6S
 22. Motor Johnson aspirtor cu acumulatori 2x2,4V, 1300mAh.Pret: 9 lei.
https://imgur.com/siAqx8j
https://imgur.com/uHNxFt2
23. Motor stertgator luneta Ford Escort. Pret: 17 lei.
https://imgur.com/Gzxf5tK
https://imgur.com/mKzOq3V
https://imgur.com/d8WpL9E
24. Motor stergator luneta VW MK3. 12V- 3.5A. Pret: 17 lei.
https://imgur.com/v3Rs6et
https://imgur.com/9mIwePQ
25. Motor cu reductor VW MK 4, demontat dintro portiera. Pret: 15 lei.
https://imgur.com/gbBltgp
https://imgur.com/vA1nyuH
26. Modul pentru controlul motoarelor pas-cu pas Sanken SLA7051M.
Pret: 14 lei
https://imgur.com/ofxN8U8
27. Modul pentru controlul motoarelor pas cu pas STK672-410.
https://imgur.com/cwFdxuu
Pret: 12lei
28. Module pentru controlul motoarelor pas cu pas STK 672-400B.
Pret: 12 lei/per modul
https://imgur.com/FECqUy2
https://imgur.com/io0FtYe
29. Motor electrocasnice UH-20R-0805. U=220V.
Pret: 9 lei.
https://imgur.com/nYwVDKQ
https://imgur.com/4sZZTqv
30.Motor imprimanta lexmark z55, RS-385PN, alimentare 24Vcc.
Pret: 4 lei.
https://imgur.com/iyQW0Ke
31. Motor pas cu pas J81A32KT
Pret: 3lei.
https://imgur.com/yvnxGEu
https://imgur.com/gALemeS
32.Set 5 motorase recuperate din HDD-uri PC
https://imgur.com/qrz0hJF
Pret: 7 lei.
37. Motor brushless Matsushita RH7-1260, DNQ16D04R34A.
Driver 6AE11, pre-driver LB1823.
Dimensiuni 127mm x 91mm.Lungime ax 40mm. Diametru ax 7mm.
Pret: 27 lei.
https://imgur.com/Koo9tTd
https://imgur.com/ivmRs7m
https://imgur.com/1ju8QB8
38. Motor pas cu pas Minibea NEMA23, 23KM-K381-01V
24V 2000mA 1.8 grade. Rotita metalica are 14 dinti cu diametru 12mm, lungime
20mm, diametru ax 6mm.
Pret: 40 lei.
https://imgur.com/ec94mbh
https://imgur.com/vxwNGHo
https://imgur.com/KnSC79T
39. Motor pas cu pas Minibea NEMA17,17PM-k401-P5V
3V 1200mA. Lungime ax 26mm, diametru ax 5mm. Rotita metalica 16 dinti, 19mm
diametru, lungime 18mm.
Pret: 22 lei.
https://imgur.com/YIE4H5m
https://imgur.com/iDcRABy
https://imgur.com/gr7Rvee
40. Motoare (doua) pas cu pas Minibea NEMA 17,17PM-k103-p9V
3.6V 1200mA. Lungime ax 19 mm, diametru 5mm. Rotita metalica cu 16 dinti,
lungime 13 mm, diametru 9.5mm.
Pret: 22 lei buc, sau 35 lei ambele.
https://imgur.com/rO4IBxY
https://imgur.com/m3xnUig
https://imgur.com/kWQ7jLN
@utzy Din pacate nu am Nema23 la tensiunea si cuplu asta.
Se adauga:
41. Motoras macara usa stanga fata VW  Passat B6 cod 980851-113
https://imgur.com/AGNccwq
https://imgur.com/nBkSyr7
Pret: 25 lei.
42. Motoras macara usa stanga spate VW Passat B6 cod 974225-113
https://imgur.com/dVdpOLr
https://imgur.com/6EQlqHG
https://imgur.com/qvIwPFB
https://imgur.com/bkeX6fO
https://imgur.com/hOut754
Pret: 25 lei.
  • 2 săptămâni mai târziu...
  • 3 săptămâni mai târziu...
  • 2 luni mai târziu...
  • 1 lună mai târziu...
