cmariuss Postat Iunie 1, 2020 Partajează Postat Iunie 1, 2020 Motoare diverse: 1. Electromotor MAP-1156, Putere: 45W, 2800rot/min, alimentare 220V. Pret: 40 lei. https://imgur.com/6TVtd11 https://imgur.com/Ma87KUr https://imgur.com/yjymhHF 2. Servomotor Shiko HS060-T-k02. Alimentare 24Vcc, turatie 1500rpm, cuplu 1,5kgf-cm. Controler SLA6022 Sanken. Pret: 30 lei https://imgur.com/BTC7wCF 3.Servomotor DF80FT10-6. Alimentare 24Vcc. Pret: 15 lei. https://imgur.com/i1VTFJP 4. Motor picup. Pret: 5 lei. https://imgur.com/Z5qBrJf 5. Motor Tsukasa. Alimentare 20Vcc. Pret: 15 lei. https://imgur.com/vSNgtzA 6. Motor Hosiden FH7-1384. Alimentare 24Vcc/ 130mA. Pret: 10 lei https://imgur.com/2o1x2yb 7. Servomotor cu controler Nidec 45M3082094. Alimentare 24Vcc/1,3A. Turatie: 604.24-1662,49 rot/min. Pret: 12 lei. https://imgur.com/0Plj2sR 8. Motor pas-cu-pas Minibea 23PM-J247-G1V, Alimentare la 2,2 V/ 3,2A. Are un defect la mufa deconexiuni, traseele pe PCB nu sunt afectate. Pret: 12 lei https://imgur.com/DwtqBRK 9. Motoare MP40, alimentare 24Vcc. Provin din automate de cafea. Pret: 8 lei buc https://imgur.com/iKqBIB8 10. Motoare pas-cu-pas 17PM. Pret: 7 lei bucata. https://imgur.com/ttGYgUd 11. Motoare pas-cu-pas 14PM. Pret: 5 lei bucata. https://imgur.com/2T6PlH7 12. Motoare pas-cu-pas diverse. Pret: 4 lei bucata. https://imgur.com/YtpxrXv 13. Motoare pas cu pas Matsushita si Siemens. Pret: 4 lei bucata. https://imgur.com/YnauSkg 14. Motoare din imprimante . Pret: 6 lei buc https://imgur.com/nXaAZYM 15. Motor pas-cu-pas Toshiba. Pret: 5 lei. https://imgur.com/DuU1bm0 16. Motor cu ambreiaj Ogura Motor Dell 127K45893 24V cu reductor si ambreiaj Pret: 20 lei. https://imgur.com/heu6Zcr 17. Ventilator Nidec Gamma32, alimentare 24Vcc/400mA, dimensiuni 12x12cm. Pret: 20 lei. https://imgur.com/LZzoWcx 18. Motoare 127K45271. Pret: 8lei/buc https://imgur.com/nNJjTRT 19. Motor Bosch cu ax melcat. Pret: 5lei. https://imgur.com/0zfoY36 https://imgur.com/ILYQahJ https://imgur.com/a/CyfnYEh Link spre comentariu
mihaighe Postat Iunie 5, 2020 Partajează Postat Iunie 5, 2020 9. Motoare MP40, alimentare 24Vcc. Provin din automate de cafea. Pret: 8 lei buc https://imgur.com/iKqBIB8 ce grosime si lungime are axul? Link spre comentariu
cmariuss Postat Iunie 6, 2020 Autor Partajează Postat Iunie 6, 2020 fi 4mm, lungime 30mm. Link spre comentariu
cmariuss Postat Iunie 8, 2020 Autor Partajează Postat Iunie 8, 2020 Se adauga: 20. Motor ventilator turbina IG-752-006 Alimentare: 220Vac, turatie 2700, cuplu 0,6 kgcm. Pret: 30 lei. https://imgur.com/iwv61H0 https://imgur.com/DWbgtEc https://imgur.com/IhG1XbZ 21. Servomotor Copal SG-180. Alimentare: 100/12.5V, raport reductor 1/30. Pret: 9lei. https://imgur.com/BGxy5QF https://imgur.com/q97zGlv 22. Servomotoare Tamagawa Seiki TS101N42E29, alimentare 100/12,5V, raport reductor 1/30. Doua bucati. Pret: 9lei/ buc https://imgur.com/7EltFj0 https://imgur.com/VB54Nh9 23. Motor recuperat dintrun picup sovietic. Pret: 9 lei. https://imgur.com/CfSOg2h https://imgur.com/jc5hAYi Link spre comentariu
cmariuss Postat Iunie 12, 2020 Autor Partajează Postat Iunie 12, 2020 Disponibile. Link spre comentariu
cmariuss Postat Iunie 16, 2020 Autor Partajează Postat Iunie 16, 2020 Disponibile. Link spre comentariu
cmariuss Postat Iunie 22, 2020 Autor Partajează Postat Iunie 22, 2020 Punctele 5 si 15 vandute. Link spre comentariu
barbulescuorlando Postat Iunie 24, 2020 Partajează Postat Iunie 24, 2020 Buna ziua. Motoarele 1 si 20 ce diametre au axurile? Mulțumesc. Link spre comentariu
cmariuss Postat Iunie 24, 2020 Autor Partajează Postat Iunie 24, 2020 Ambele au diametru de 6 mm. Link spre comentariu
cmariuss Postat Iunie 27, 2020 Autor Partajează Postat Iunie 27, 2020 Disponibile. Link spre comentariu
visinica Postat Iulie 22, 2020 Partajează Postat Iulie 22, 2020 Buna, ma intereseaza motoarele pas cu pas de la punctele , 8 , 10 si 15 mai sant disponibile? ms Link spre comentariu
cmariuss Postat Iulie 24, 2020 Autor Partajează Postat Iulie 24, 2020 Buna, Motorul Toshiba de la pct [15], nu mai este valabil. Restul, da. Link spre comentariu
cmariuss Postat August 5, 2020 Autor Partajează Postat August 5, 2020 Disponibile Link spre comentariu
cmariuss Postat August 11, 2020 Autor Partajează Postat August 11, 2020 La 01.06.2020 la 13:19, cmariuss a spus: Motoare diverse: 1. Electromotor MAP-1156, Putere: 45W, 2800rot/min, alimentare 220V. Pret: 35 lei. https://imgur.com/6TVtd11 https://imgur.com/Ma87KUr https://imgur.com/yjymhHF 2. Servomotor Shiko HS060-T-k02. Alimentare 24Vcc, turatie 1500rpm, cuplu 1,5kgf-cm. Controler SLA6022 Sanken. Pret: 25 lei https://imgur.com/BTC7wCF 3.Servomotor DF80FT10-6. Alimentare 24Vcc. Pret: 10 lei. https://imgur.com/i1VTFJP 4. Motor picup. Pret: 5 lei. https://imgur.com/Z5qBrJf 6. Motor Hosiden FH7-1384. Alimentare 24Vcc/ 130mA. Pret: 10 lei https://imgur.com/2o1x2yb 7. Servomotor cu controler Nidec 45M3082094. Alimentare 24Vcc/1,3A. Turatie: 604.24-1662,49 rot/min. Pret: 10 lei. https://imgur.com/0Plj2sR 8. Motor pas-cu-pas Minibea 23PM-J247-G1V, Alimentare la 2,2 V/ 3,2A. Are un defect la mufa deconexiuni, traseele pe PCB nu sunt afectate. Pret: 10 lei. https://imgur.com/DwtqBRK 9. Motoare MP40, alimentare 24Vcc. Provin din automate de cafea. Pret: 8 lei buc. https://imgur.com/iKqBIB8 10. Motoare pas-cu-pas 17PM. Pret: 7 lei bucata. https://imgur.com/ttGYgUd 11. Motoare pas-cu-pas 14PM. Pret: 5 lei bucata. https://imgur.com/2T6PlH7 12. Motoare pas-cu-pas diverse. Pret: 4 lei bucata. https://imgur.com/YtpxrXv 13. Motoare pas cu pas Matsushita si Siemens. Pret: 4 lei bucata. https://imgur.com/YnauSkg 14. Motoare din imprimante . Pret: 5 lei buc https://imgur.com/nXaAZYM 16. Motor cu ambreiaj Ogura Motor Dell 127K45893 24V cu reductor si ambreiaj Pret: 18 lei. https://imgur.com/heu6Zcr 17. Ventilator Nidec Gamma32, alimentare 24Vcc/400mA, dimensiuni 12x12cm. Pret: 18 lei. https://imgur.com/LZzoWcx 18. Motoare 127K45271. Pret: 8lei/buc https://imgur.com/nNJjTRT 19. Motor Bosch cu ax melcat. Pret: 5lei. https://imgur.com/0zfoY36 https://imgur.com/ILYQahJ https://imgur.com/a/CyfnYEh Link spre comentariu
cmariuss Postat August 19, 2020 Autor Partajează Postat August 19, 2020 Disponibile. Link spre comentariu
