Upload error
Lilith
Buna ziua, cand incerc sa incarc programul din IDE primesc aceasta eroare:
Sketch uses 726 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\calin\AppData\Local\Temp\arduino_build_254713/sketch_may20a.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\calin\AppData\Local\Temp\arduino_build_254713/sketch_may20a.ino.hex"
avrdude: writing flash (726 bytes):
Writing | ########avrdude: stk500_recv(): programmer is not responding
Stie cineva de ce si care ar fi solutia ?
  • Răspunsuri 28
Mai poate fi si setarea de baudrate ale usb-serial , poate fi si un sistem Arduino care a avut probleme si care ar necesita rescrierea bootloaderului
Incercati si in alt port usb
Imaginea nu contine setarile care trebuie realizate...ci doar locul unde se pot modifica !!!
Editat de sebip
Salut,
Ca si ceilalti colegi, suspectez ca e o problema de comunicatie cu bootloaderul, dar asta poate sa aiba multiple cauze. De la viteza incorecta pe seriala procesorului pana la bootloader corupt sau inexistent, fusebiti setati incorect sau procesor defect.
Cred ca e util de stiut putina istorie a placii. Este noua luata din magazin sau ai primit-o de la cineva sub forma "ia-o si fugi" ? A functionat inainte si deodata nu mai merge sau acum e prima data cand incerci sa "vorbesti" cu placa? Daca e primita si nu i se cunoaste istoria, pot fi multe, dar in acelasi timp sansele sunt mari sa fie rezolvabile, dar de catre cineva care stie cum sa o depaneze si are si sculele necesare.
Cirip
Editat de cirip
49 minutes ago, cirip said:
Salut,
Cirip
Placa e comandata de pe xab3 si am primit-o ieri, iar azi am incercat sa o folosesc pentru a aprinde un led si a genera un sunet cu un buzzer, dar fara succes.
