arduino mega 2560 +8 relay
hauerit
salut ! am o mare nelamurire ..am folosit codul asta de pe net si nu prea functioneaza ..
ideea e simpla ,poti comanda cele 8 relee  din  serial monitor,,cu comenzile ,,-1,,+1,, on/off  prin arduino mega2560
 1 fiind nr releului ..zis si facut doar ca de la releul 1 la 6 nu primeste comanda iar la -8 porneste releul 7 si la -7 releul 8
orice alta comanda anuleaza celelalte comenzi ..multumesc mult daca ma poate ajuta cineva .
#define RELAY1  52
#define RELAY2  50
#define RELAY3  48
#define RELAY4  46
#define RELAY5  44
#define RELAY6  42
#define RELAY7  40
#define RELAY8  38
void setup()
  // Initialize the Arduino data pins for OUTPUT
  pinMode(RELAY1, OUTPUT);
  pinMode(RELAY2, OUTPUT);
  pinMode(RELAY3, OUTPUT);
  pinMode(RELAY4, OUTPUT);
  pinMode(RELAY5, OUTPUT);
  pinMode(RELAY6, OUTPUT);
  pinMode(RELAY7, OUTPUT);
  pinMode(RELAY8, OUTPUT);
//setting all pins to high so that all relays are off at start
  digitalWrite(RELAY1,HIGH);
  digitalWrite(RELAY2,HIGH);
  digitalWrite(RELAY3,HIGH);
  digitalWrite(RELAY4,HIGH);
  digitalWrite(RELAY5,HIGH);
  digitalWrite(RELAY6,HIGH);
  digitalWrite(RELAY7,HIGH);
  digitalWrite(RELAY8,HIGH);
  //wait for serial connect from COM Port
  while (!Serial);
  Serial.begin(19200);
void loop()
  String command;
  char charBuf[5];
  //waiting for data command
  if(Serial.available() > 0)
    command = Serial.readStringUntil('\r');
    command.toCharArray(charBuf, 5);
  else
    return;
  //-1 - off relay 01
  //+1 - on relay 01
  if  (charBuf[0]=='+') //relay off
    SetStatus(true, charBuf[1]);
  else if (charBuf[0]=='-') //relay on
    SetStatus(false, charBuf[1]);
  void SetStatus(boolean on,char relayNumber)
    int relayState =0;//off
    if (on)
      relayState =1;//on
    switch (relayNumber) {
    case '1':
      digitalWrite(RELAY1,relayState);
      break;
    case '2':
      digitalWrite(RELAY2,relayState);
      break;
    case '3':
      digitalWrite(RELAY3,relayState);
      break;
    case '4':
      digitalWrite(RELAY4,relayState);
      break;
    case '5':
      digitalWrite(RELAY5,relayState);
      break;
    case '6':
      digitalWrite(RELAY6,relayState);
      break;
    case '7':
      digitalWrite(RELAY7,relayState);
      break;
    case '8':
      digitalWrite(RELAY8,relayState);
      break;
  • Răspunsuri 9
Mie singura chestie neclara mi-e formatul lui charBuf[1].
1 oră în urmă, hauerit a spus:
In conditiile in care charBuf[0] e un caracter ('+' sau '-'), ma intreb daca nu cumva si charBuf[1] nu e tot un caracter (ASCII), drept pentru care as incerca cu
    SetStatus(true, charBuf[1] - '0'); //scade codul ascii al lui 0
    SetStatus(false, charBuf[1] - '0'); //scade codul ascii al lui 0
Editat de Liviu M
Oricum, constat ca programatorilor de Arduino le place sa scrie linii de cod "fara numar, fara numar". Mai putin cand e cazul sa fie vorbareti (si sa puna acolade).
Mie mi-ar fi iesit ceva mai "grupat"
#define RELAY1  52
#define RELAY2  50
#define RELAY3  48
#define RELAY4  46
#define RELAY5  44
#define RELAY6  42
#define RELAY7  40
#define RELAY8  38
uint8_t relays[] = {RELAY1, RELAY2, RELAY3, RELAY4, RELAY5, RELAY6, RELAY7, RELAY8};
void SetStatus(boolean on, char relayNumber);
void setup()
  for(uint8_t i = 0; i < 8; i++) {
    pinMode(relays[i], OUTPUT);
    digitalWrite(relays[i],HIGH);
  while (!Serial);
void loop(){
  String command;
  char charBuf[5];
  if(Serial.available() > 0) {
  } else {
    return;
  //-1 - off relay 01
  //+1 - on relay 01
  if  (charBuf[0]=='+') {       //relay off
  } else if (charBuf[0]=='-') {  //relay on
void SetStatus(boolean on, char relayNumber){
  int relayState = LOW;//off
    if (on){
      relayState =HIGH;//on
    digitalWrite(relays[relayNumber],relayState);
Chiar acum, Liviu M a spus:
#define RELAY1  52
#define RELAY2  50
#define RELAY3  48
#define RELAY4  46
#define RELAY5  44
#define RELAY6  42
#define RELAY7  40
#define RELAY8  38
void setup()
  while (!Serial);
void loop(){
  String command;
  char charBuf[5];
  } else {
    return;
  //-1 - off relay 01
  //+1 - on relay 01
    if (on){
salut !multumesc  mult.. chiar merge ..comenzile sunt de la 0 la 7 ..macar de atat m,am prins si eu ..sunt la inceputuri
multumesc frumos ..
Cu placere.
Acum 9 ore, hauerit a spus:
Ai dreptate, ca sa mearga de la 1 la 8, la ultima linie trebuia sa scad 1 din index:
    digitalWrite(relays[relayNumber - 1],relayState);
A propos, eu as mai pune si o mica intarziere dupa modificarea releelor, sa le dau timp sa se miste:
    if (on){
    delay(5 ms); //asteapta releul sa ajunga in noua pozitie.
Editat de Liviu M
Ca tot vorbeam de scris putin, o varianta echivalenta si mai scurta ar iesi:
#define RELAY1  52
#define RELAY2  50
#define RELAY3  48
#define RELAY4  46
#define RELAY5  44
#define RELAY6  42
#define RELAY7  40
#define RELAY8  38
void setup()
  while (!Serial);
void loop(){
  String command;
    boolean bNewState = false;
    if  (command[0]=='+') {       //relay off
      bNewState = true;
    } else if(command[0]!='-') { //bad data on serial port, return
      return;
    uint8_t relIdx = command[1] - '0';
    digitalWrite(relays[relIdx - 1], bNewState);
    delay(5);
De compilat se compileaza, de testat n-am cum.
Editat de Liviu M
  • 2 luni mai târziu...
nu toti utilizatorii de arduino scriu fara număr. e vorba de începători. oricum arduino in sine e pentru începători dar când depășești stadiul de incepator, garantat apar si codurile de intreruperi, optimizari etc.
sa nu fim rai, la toți a fost un început. candva. acei "fara număr" sunt sigur ca nu au astfel de preocupari vreodata.
(smile)
Editat de Gilbert Sparios
  • 2 săptămâni mai târziu...
