CRC EROARE
mercenarx
salutare !
scriu un eMMC pe ISP pentru un tv Lg , si mi-a dat eroarea  din frazele de mai jos , insa continua sa scrie memoria pana la sfarsit:
acuma sunt 2 erori , insa am citit EMMC inca odata inainte si mi-a dat o singura eroare CRC. sa fie ok softul , sau sa fie compromis din cauza acelei erori ??
  Point "read" will pop up "save" dialog box, "write" will pop up the "open" dialog box.
023:  The currently selected:THGBMBG5D1LBAIT_ISP
024:  Download device programming algorithm......
025:  Algo update OK
026:  >------------------------------------OK---------------------------------------<
027:  Point "read" will pop up "save" dialog box, "write" will pop up the "open" dialog box.
028:  The currently selected:EMMC_AUTO_ISP
029:  You have selected the GENEREAL MODE, it will ignore the ID verification and using compatible with most manufacturer's General algorithm.
030:  http://www.ifix.net.cn/thread-53130-1-1.html
031:  Download device programming algorithm......
032:  Algo update OK
033:  >------------------------------------OK---------------------------------------<
034:  Point "read" will pop up "save" dialog box, "write" will pop up the "open" dialog box.
035:  The currently selected:THGBMDG5D1LBAIL_ISP
036:  Download device programming algorithm......
037:  Algo update OK
038:  >------------------------------------OK---------------------------------------<
039:  VCCIO: 3.3V
040:  eMMC OCR: C0FF8080
041:  eMMC CID:  1101003030344736300220570C47A5
042:  eMMC CSD: D05E00320F5903FFFFFFFFE7924000
043:  Chip ID:00010011,Chip Name:004G60
044:  Chip Size: User=3776MB,Boot1=Boot2=2048KB,RPMB=512KB.
045:  TOSHIBA EMMC Version : V5.0.   0-10% device life time used.
046:  Speed set to level 1.
047:  C:\Users\Wally\Desktop\EMMC\THGBMDG5D1LBAIL_ISP_859\THGBMDG5D1LBAIL_ISP_859
048:  Start reading chip......
049:  .EXT_CSDRead successful, file saved.
050:  .BOOT1Read successful, file saved.
051:  .BOOT2Read successful, file saved.
052:  .RPMBRead successful, file saved.
053:  .Start to read the user area data and save, large capacity, please be patient ... ...
054:  CRC error @ 1355 : 0x68EF - 0xAE56
055:  CRC error @ 1356 : 0x30C3 - 0x3421
Editat de mercenarx
  • Răspunsuri 20
  • Florinel TV
    9
  • Raileanu
    7
  • mercenarx
    5
din exterior cu 3,3 si 1,8 volti.
in fine am reusit sa-l citesc fara erori (am restartat calculatorul )
apoi l-am rescris cu un alt soft , si facce absolut la fel :
porneste din telec. ,in sensul ca la actionarea ON a telecomenzii , clipeste ledul de 3 ori , si ramane stins. daca apas OFF din telec. , se aprinde rosu ledul de st-by .
cred ca de fectul se afla in alta parte.
ideea este ca nu se aprinde backlight , si in felul asta nu pot sa-mi dau seama daca sunt leduri defecte sau nu , decat daca desfac panelul...
a fost folosit in retea digi , iar eu am akta , astfel incat nu prinde nici un canal , sa vad daca are sunet sau nu..
este vorba de LG 28MT49S/LD70B  si cu mb  EAX67258106(1.0)
este edge led , si am o banda led identica cu cea din panelul asta , si n-o aprinde , deci este exclus leduri defecte
Editat de mercenarx
Scoate mufa de la backlight din sursa si alimenteaza baretele din tester si asa vezi ce se intampla, daca are lumina si daca are imagie atunci cand pornesti tv-ul
Acum 5 minute, Florinel TV a spus:
am o banda led identica (si ok) cu cea din panelul tv -ului (provine de la un tv cu display spart , si panelul este acelasi : V236BJ1-LE2C-REV.C8
nu o aprinde
nu am scris si 24C256 , dar nu cred ca poate fi defectul din asta...
softul il am , sa incerc?
Editat de mercenarx
Acum 1 oră, Florinel TV a spus:
Da incearca si cu scrierea epromului, dar spune ce defect are sa stiu cum sa te ajut
Ce tv este, ce main are, ce sursa are
am scris 2-3 posturi mai sus si main(EAX) si sasiu (LD70B) si panel V236BJ1-LE2C-REV.C8
sursa este externa de 19 volti (masurat pe placa 19,1 V)
am rescris si eeprom , degeaba
am aprins backlight cu testerul leduri , si am ecran albastrui (blocat)  cu tv pornit
retur..
Editat de mercenarx
Ai editat si din lipsa de timp nu m-am mai uitat mai sus, bun si ai scris un dump bun pentru emmc? sau nu, pune o poza cu placa, pune si legaturile la emmc ca eu m-am uitat la mine si nu am pentru aceasta placa, daca are procesor cu bile este foarte posibil sa fie de la el defectul daca dumpul este ok
  • 2 ani mai târziu...
Buna.
Imi puteti da va rog un firmware eMMC pentru aeasta placa 28MT49S/LD708 EAX67258106(1.0) EAX672581 06(1.0) HC275EXN-ABVP1-41XX ?
Tv porneste de la butonul din fata si din telecomanda dar nu aprind ledurile si nici nu afiseaza. Ecran testat, leduri testate.
Am scris 24C256 si face la el. Toate tensiunile sunt OK. Procesorului i-am facut freflow cu statie profesionala.
Nici o schimbare.
Cred ca este din eMMC si de aceea va rog pentru un firmware verificat.
Sau o alta idee.....
Am reusit pana la urma sa il pornesc "corect" tinand apasat butonul de power si bagat in priza, resetat cu penseta jumperul din placa de mai multe ori, adica multe combinatii intre acestea pana a pornit. Dupa aceea i-am dat reset din fabrica si a repornit corect doar cu imaginea intoarsa..... asta nu este o problema, se poate rezolva usor din service meniu. Am ajuns la setarile de initializare unde imi cerea retea Wifi, cu toate ca eu nu am vazut sa aiba modul de WiFi, si am iesit din setarea initiala fara a mai urma pasii..... atunci s-a restartat si aceasi poveste ca la inceput, nu leduri aprinse sau afisare. Era bine daca ii faceam un update prin USB cand a reusit sa porneasca inainte de resetare, doar ma gandise-m, dar am zis sa continui intai asa si dupa aceea update..... deci cred ca este vorba de softul pentru eMMC. Rog pe cine are sa ma ajute cu acest firmware. Il voi scrie cu RT809H. Multumesc anticipat.
Editat de raileanu
Acum 2 minute, Florinel TV a spus:
Tentru ce programator?
RT809H.
Am incercat cu unul pentru EAX67258103 gasit pe Remont dar este diferit ca marime la Boot1 Boot2 si alte fisiere. Oricum am scris User si nu porneste. Imi trebuie exact pentru EAX67258106(1.0) va rog.
