FLORIN IORDACHE Postat Decembrie 23, 2019 Partajează Postat Decembrie 23, 2019 Buna ziua, Ce parere aveti despre acest laptop...cand apas pe butonul power...se aprinde ledul de la power...si clipeste de 4 ori ledul de la Caps Lock...iar apoi face o pauza de o sec..iar clipeste de 4 ori si tot asa in continuare... Va anunt ca am incercat si cu o alta baterie de bios,am incercat si cu o alta memorie ram..am incercat si cu un alt hdd-u...dar din pacate tot asa face, nu este nicio schimbare. Asa ca astept o parere de la dvs ! Va multumesc ff ff mult ! Link spre comentariu
Pityu Postat Decembrie 23, 2019 Partajează Postat Decembrie 23, 2019 Code type Number of Blinks or Beeps Component Being Checked Condition Possible solution(s) AC power adapter LED Constantly on Power adapter OK. Power is being supplied. None. The power adapter is likely not the problem. AC power adapter LED Constantly off Power adapter Power is not being supplied Try a different power outlet. Replace power adapter. AC power adapter LED Continuous blinking Power adapter Insufficient power Try a different power outlet. Replace power adapter. Caps Lock/Num Lock 1 CPU CPU not functional Reseat replace CPU. Service Caps Lock/Num Lock 2 BIOS BIOS corruption failure Restore BIOS from onboard backup (jumpers) Service Caps Lock/Num Lock 3 Memory Memory module error not functional Reseat memory modules (see next section). Test memory from UEFI or BIOS. Replace bad memory modules. Service Caps Lock/Num Lock 4 Graphics Graphics controller not functional Service Caps Lock/Num Lock 5 System board General system board failure Service Caps Lock/Num Lock 6 BIOS BIOS authentication failure Restore BIOS from onboard backup (jumpers) Service Beep Varies Varies Varies Reseat memory modules (see next section). Service For more detail on the exact code, search the Internet for "beep code" and the manufacturer of your BIOS - such as AMI or Award. 1 Link spre comentariu
FLORIN IORDACHE Postat Decembrie 23, 2019 Autor Partajează Postat Decembrie 23, 2019 (editat) Acum 11 minute, Pityu a spus: Code type Number of Blinks or Beeps Component Being Checked Condition Possible solution(s) AC power adapter LED Constantly on Power adapter OK. Power is being supplied. None. The power adapter is likely not the problem. AC power adapter LED Constantly off Power adapter Power is not being supplied Try a different power outlet. Replace power adapter. AC power adapter LED Continuous blinking Power adapter Insufficient power Try a different power outlet. Replace power adapter. Caps Lock/Num Lock 1 CPU CPU not functional Reseat replace CPU. Service Caps Lock/Num Lock 2 BIOS BIOS corruption failure Restore BIOS from onboard backup (jumpers) Service Caps Lock/Num Lock 3 Memory Memory module error not functional Reseat memory modules (see next section). Test memory from UEFI or BIOS. Replace bad memory modules. Service Caps Lock/Num Lock 4 Graphics Graphics controller not functional Service Caps Lock/Num Lock 5 System board General system board failure Service Caps Lock/Num Lock 6 BIOS BIOS authentication failure Restore BIOS from onboard backup (jumpers) Service Beep Varies Varies Varies Reseat memory modules (see next section). Service For more detail on the exact code, search the Internet for "beep code" and the manufacturer of your BIOS - such as AMI or Award. Ok,am inteles, inseamna ca este chipsetul video cu probleme...asa ca o sa-i zic sa ia altul nou pentru ca i-am mai schimbat odata placa de baza la acest laptop...acum vreun an si vreo 3 luni,iar acum vad ca a picat din nou . Va multumesc fff fff mult pentru raspunsul oferit ! Editat Decembrie 23, 2019 de FLORIN IORDACHE Link spre comentariu
bobo Postat Decembrie 23, 2019 Partajează Postat Decembrie 23, 2019 Am eu o placa de baza perfect functionala, baterie , tastatura etc. Vorbim pe privat daca vrei. Pot atasa poze si in functionare. Link spre comentariu
FLORIN IORDACHE Postat Decembrie 23, 2019 Autor Partajează Postat Decembrie 23, 2019 Chiar acum, bobo a spus: Am eu o placa de baza perfect functionala, baterie , tastatura etc. Vorbim pe privat daca vrei. Pot atasa poze si in functionare. Asa ca si chestie....cam cat ati cere pe ea. Asa ca astept mp ! Va multumesc ! Link spre comentariu
bobo Postat Decembrie 23, 2019 Partajează Postat Decembrie 23, 2019 Placa de baza cu carcasa fara balamale si display,cu baterie si tastatura la 100 lei plus transport. Mai am doua placi identice de hp15. Curand o sa fac un topic la vanzari cu componente de laptop. Link spre comentariu
FLORIN IORDACHE Postat Decembrie 23, 2019 Autor Partajează Postat Decembrie 23, 2019 Acum 3 minute, bobo a spus: Placa de baza cu carcasa fara balamale si display,cu baterie si tastatura la 100 lei plus transport. Mai am doua placi identice de hp15. Curand o sa fac un topic la vanzari cu componente de laptop. Ok,am inteles,daca doreste clientul sa mai dea inca 180-200 lei pe reparare,eu unul nu am nimic cu el. Asa ca daca o sa-mi zica ca vrea sa-l faca din nou, eu o sa va anunt imediat... si o sa vorbim atunci mai multe chesti... O seara minunata va doresc ! Link spre comentariu
