victordascalescu54 Postat Noiembrie 29, 2019 Partajează Postat Noiembrie 29, 2019 Caut 8 condensatori mica 2 pF/500V 5%, eventual 300V Multumesc anticipat Link spre comentariu
fcon Postat Decembrie 5, 2019 Partajează Postat Decembrie 5, 2019 https://www.adelaida.ro/condensator-2pf-500v-cd15cd020do3f.html Manufacturer: Cornell Dubilier Product Category: Mica Capacitors RoHS: RoHS Compliant By Exemption Details Brand: Cornell Dubilier - CDE Termination Style: Radial Capacitance: 2 pF Voltage Rating: 500 V Tolerance: 0.5 pF Temperature Coefficient: 200 PPM / C Case Length: 11.4 mm Case Width: 4.3 mm Case Height: 9.1 mm Operating Temperature Range: - 55 C to + 125 C Dimensions: 4.3 mm L x 11.4 mm W x 9.1 mm H Lead Spacing: 5.9 mm Packaging: Bulk Product: Mica Standard Dipped Capacitors Series: CD15 Link spre comentariu
victordascalescu54 Postat Decembrie 7, 2019 Autor Partajează Postat Decembrie 7, 2019 La 05.12.2019 la 12:45, fcon a spus: https://www.adelaida.ro/condensator-2pf-500v-cd15cd020do3f.html Manufacturer: Cornell Dubilier Product Category: Mica Capacitors RoHS: RoHS Compliant By Exemption Details Brand: Cornell Dubilier - CDE Termination Style: Radial Capacitance: 2 pF Voltage Rating: 500 V Tolerance: 0.5 pF Temperature Coefficient: 200 PPM / C Case Length: 11.4 mm Case Width: 4.3 mm Case Height: 9.1 mm Operating Temperature Range: - 55 C to + 125 C Dimensions: 4.3 mm L x 11.4 mm W x 9.1 mm H Lead Spacing: 5.9 mm Packaging: Bulk Product: Mica Standard Dipped Capacitors Series: CD15 Multumesc, deja era o optiune....dar au spus ca nu-i au pe stoc si ca dureaza o saptamina si costa 25 lei in loc de 18 + transport, ce sa spun, cam neseriosi. Link spre comentariu
mojnost Postat Decembrie 8, 2019 Partajează Postat Decembrie 8, 2019 De curiozitate, la ce ii folositi? Nici in aplicatii foarte pretentioase, (oscilatoare rf cu pretentii de ex.) nu am intalnit capacitate asa de redusa cu mica. Capacitate ceva mai mare am dar de 2 pF nu am. Link spre comentariu
victordascalescu54 Postat Decembrie 9, 2019 Autor Partajează Postat Decembrie 9, 2019 Acum 8 ore, mojnost a spus: De curiozitate, la ce ii folositi? Nici in aplicatii foarte pretentioase, (oscilatoare rf cu pretentii de ex.) nu am intalnit capacitate asa de redusa cu mica. Capacitate ceva mai mare am dar de 2 pF nu am. Este o compensare pe o reactie globala la un OTL. Exista si de 1pF, 1,2pF, 1,5pF....etc decat ca este foarte greu de masurat valoarea cu o punte obisnuita. Eu pur si simplu vizualizez pe osciloscop 10kHz dreptunghiular si urmaresc frontul crescator la diverse puteri. Link spre comentariu
mojnost Postat Decembrie 9, 2019 Partajează Postat Decembrie 9, 2019 Inteleg, niste trimeri cu aer nu ar fi o varianta mai buna? Link spre comentariu
victordascalescu54 Postat Decembrie 9, 2019 Autor Partajează Postat Decembrie 9, 2019 Acum 20 minute, mojnost a spus: Inteleg, niste trimeri cu aer nu ar fi o varianta mai buna? Desigur, chiar caut asa ceva (0,5-3pF). Am gasit unii Philips pe la un bulgar dar costa mai mult transportul decat piesa. Link spre comentariu
mojnost Postat Decembrie 9, 2019 Partajează Postat Decembrie 9, 2019 Am printr-o cutie trimeri cu aer, nu imi amintesc capacitatea, daca dau de ei anunt. Am si punte care masoara capacitati mici. Link spre comentariu
victordascalescu54 Postat Decembrie 9, 2019 Autor Partajează Postat Decembrie 9, 2019 (editat) Acum 37 minute, mojnost a spus: Am printr-o cutie trimeri cu aer, nu imi amintesc capacitatea, daca dau de ei anunt. Am si punte care masoara capacitati mici. Excelent, multumesc anticipat. banuiesc ca sunt asa zisii trimeri cu piston. Editat Decembrie 9, 2019 de victordascalescu54 Link spre comentariu
Craciun Postat Decembrie 9, 2019 Partajează Postat Decembrie 9, 2019 (editat) Salut, Incercati si la distrelec.com, eu am luat piese de la ei si au o gama foarte variata. Eu am cumparat din Austria . Uitati ce am gasit eu in Germania la ei: https://www.distrelec.de/en/passive-components/capacitors/ceramic-capacitors/ceramic-disk-capacitors/c/cat-DNAV_PL_03020301?q=*&filter_Buyable=1&filter_Category4=Ceramic+Disk+Capacitors&filter_Category3=Ceramic+Capacitors&filter_Capacitance~~pF=2.2 Va costa apropae 3 eur 100buc fara transport. Au si in RO putin mai scump(adica cativa eurocenti la suta de bucati mai scump): https://www.distrelec.ro/ro/componente-pasive/condensatoare/condensatoare-ceramice/condensatoare-cu-disc-ceramic/c/cat-DNAV_PL_03020301?q=*&filter_Buyable=1&filter_Category4=Condensatoare+cu+disc+ceramic&filter_Category3=Condensatoare+ceramice&filter_Capacitance~~pF=2.2 Nu am citit foarte atent cum e cu transportul , dar mi s-a parut mai avantajos cel din Germania la comenzi mici. Succes ! Editat Decembrie 9, 2019 de Craciun Link spre comentariu
victordascalescu54 Postat Decembrie 9, 2019 Autor Partajează Postat Decembrie 9, 2019 Acum 58 minute, Craciun a spus: Salut, Incercati si la distrelec.com, eu am luat piese de la ei si au o gama foarte variata. Eu am cumparat din Austria . Uitati ce am gasit eu in Germania la ei: https://www.distrelec.de/en/passive-components/capacitors/ceramic-capacitors/ceramic-disk-capacitors/c/cat-DNAV_PL_03020301?q=*&filter_Buyable=1&filter_Category4=Ceramic+Disk+Capacitors&filter_Category3=Ceramic+Capacitors&filter_Capacitance~~pF=2.2 Va costa apropae 3 eur 100buc fara transport. Au si in RO putin mai scump(adica cativa eurocenti la suta de bucati mai scump): https://www.distrelec.ro/ro/componente-pasive/condensatoare/condensatoare-ceramice/condensatoare-cu-disc-ceramic/c/cat-DNAV_PL_03020301?q=*&filter_Buyable=1&filter_Category4=Condensatoare+cu+disc+ceramic&filter_Category3=Condensatoare+ceramice&filter_Capacitance~~pF=2.2 Nu am citit foarte atent cum e cu transportul , dar mi s-a parut mai avantajos cel din Germania la comenzi mici. Succes ! Multumesc frumos Link spre comentariu
Vizitator Postat Decembrie 10, 2019 Partajează Postat Decembrie 10, 2019 La 09.12.2019 la 8:45, victordascalescu54 a spus: Este o compensare pe o reactie globala la un OTL. Exista si de 1pF, 1,2pF, 1,5pF....etc decat ca este foarte greu de masurat valoarea cu o punte obisnuita. Eu pur si simplu vizualizez pe osciloscop 10kHz dreptunghiular si urmaresc frontul crescator la diverse puteri. 2pF compensare la un asemenea amplificator audio... e ceva interesant, mai ales ca valoarea aceasta atat de mica este comparabila sau chiar mai mare decat capacitatile din montajul practic... Adica 2pF se pot obtine si cu 2 sarme torsadate sau coaxiale, asa cum cu decenii in urma am folosit si eu ca si capacitate de compensare pentru o sonda 100:1 home made pentru osciloscop, de exemplu cablul coaxial RG-178 are cam 1 pF/cm si are dielectric teflon!! Link spre comentariu
victordascalescu54 Postat Decembrie 10, 2019 Autor Partajează Postat Decembrie 10, 2019 Acum 56 minute, Traian B a spus: 2pF compensare la un asemenea amplificator audio... e ceva interesant, mai ales ca valoarea aceasta atat de mica este comparabila sau chiar mai mare decat capacitatile din montajul practic... Adica 2pF se pot obtine si cu 2 sarme torsadate sau coaxiale, asa cum cu decenii in urma am folosit si eu ca si capacitate de compensare pentru o sonda 100:1 home made pentru osciloscop, de exemplu cablul coaxial RG-178 are cam 1 pF/cm si are dielectric teflon!! La inceput si mie mi sa parut o valoare ridicola dar, masurand si vizualizand rezultatul, a avut efect. Initial, schema primita de la Tim Mellow era fara acea compensare, doar rezistenta de reactie de 1M. Cand am realizat montajul (metoda traditionala punct cu punct in aer) au aparut niste ciocuri pe frontul crescator la 10kHz dreptunghiular, care nu-mi placeau deloc. Asa ca am aplicat acea compensare(propusa de colegul LMO), respectiv 2PF in serie cu 10K peste acel 1M si s-a lecuit. Am facut probe si cu 1,2 pF si avea efect decat ca peste 4-5 W aparea di nou ciocul. Link spre comentariu
mojnost Postat Decembrie 10, 2019 Partajează Postat Decembrie 10, 2019 (editat) Acum 20 ore, victordascalescu54 a spus: Excelent, multumesc anticipat. banuiesc ca sunt asa zisii trimeri cu piston. Prin trimeri cu aer înțeleg acei trimeri care au doar aer intre armaturi, adică minicondensatori variabili, cu armaturile argintate, un exemplu la întâmplare https://www.ebay.com/itm/Air-Variable-Trimmer-Capacitor-1-7-20pF-Johnson-193-6-NOS-Qty-1/143396084332?hash=item2163129a6c:g:vWAAAOSwtWNdjgem Celor din pozele dvs. le-as zice ceramici, având dielectric un material ceramic, am văzut însă și tubulari doar cu aer. Cautând după ei am dat de 3 buc modelul aurit din pozele dvs., măsurați indica la capete 1,3-12,5pF. Mai caut maine, azi a fost mai urgenta afumătoarea. Prima data când e plin de muște la prelucrarea lui Ghiță. La aplicația dvs nu cred ca sunt necesari condensatori cu mica sau trimeri pretențioși, cred ca tatonarea unor condensatori ceramici era suficienta, ori fire torsadate cum spune Traian, pornind de la vreo 2,5cm tot tăiați para se obține oscilograma optima. Revin maine cu rezultatul căutărilor. Editat Decembrie 10, 2019 de mojnost Corectare Link spre comentariu
flomar60 Postat Decembrie 10, 2019 Partajează Postat Decembrie 10, 2019 Dispun de 6 buc trimeri ceramici....pe ei scrie 4-15pF si masurati au minim 3,5pF pana la peste 25 pF....diametru 17mm , axa mare 23mm....daca corespund aplicatiei dvs. spuneti! Link spre comentariu
