Dxxx Postat Octombrie 27, 2019 Partajează Postat Octombrie 27, 2019 (editat) 2 lei bucata oricare din ce urmeaza: 1. COB ornamental rosu COB decorativ/semnalizare, culoare rosie, teoretic 12v/2W (sunt noi, chinezesti). Incep sa lumineze de la 6V. https://www.ultraimg.com/image/t2lb https://www.ultraimg.com/image/t2lH 2. borne 220~ https://www.ultraimg.com/image/t20v 3. borne letcon https://www.ultraimg.com/image/t20M 4. carcase smps https://www.ultraimg.com/image/t20O 5. COB noi, scoase din spoturi chinezesti - cele mici sunt 15V/4W. Cele mari sunt 36V/10W si costa 5 lei bucata. https://www.ultraimg.com/image/tDk7 6. banda led flexibila noi, din corp iluminat chinezesc - 13V/250mA https://www.ultraimg.com/image/tkHr 7. cabluri telefonice https://www.ultraimg.com/image/tIaN 8. cabluri Ethernet RJ45 https://www.ultraimg.com/image/tIas 9. cabluri SATA3 de PC https://www.ultraimg.com/image/tIaE 10. cabluri DVI noi, de firma https://www.ultraimg.com/image/nQ4k 11. alte cabluri https://www.ultraimg.com/image/tkHe 12. titaniu sarma sarma (bara plina) titaniu aliaj Grade5 - diametru 3mm, lungime>80mm https://www.ultraimg.com/image/tqUu 5 lei bucata oricare din ce urmeaza: 13. baghete led baghete recuperate din ecrane de laptop. Unele baghete sunt flexibile, unele au emisie perpendiculara / altele tangentiala. Au intre 30 si 80 leduri, dispuse in mai multe catene de 8 pana la 12 serie, deci se poate sa mearga spre exemplu cu sursele in curent constant de mai jos. Exista driver-pereche boost (input 10-20V+ curent continuu - merge auto, rulote, barci). La iesire este evident curent constant, cu randament foarte bun. Orice bagheta este 5 lei, driverul de la curent continuu pentru ea este 10 lei. https://www.ultraimg.com/image/t2q3 https://www.ultraimg.com/image/t2qQ https://www.ultraimg.com/image/t2q6 https://www.ultraimg.com/image/t2q2 14. surse smps iesire CC sunt mai multe surse pentru led (iesire curent constant) cu intrare 230V~: Ikea 2,5-3,8V/600mA si restul chinezesti, noi: 42-70V/280mA + 6-32v/250mA + 6-20V/250mA https://www.ultraimg.com/image/t2A9 15. Wifi + BT https://www.ultraimg.com/image/t2l3 16. huse tableta huse tableta Ipad mini generatia 2 sau 3. Cea transparenta e folosita / cealalta noua. Pretul este pentru ambele, impreuna. https://www.ultraimg.com/image/t2lj https://www.ultraimg.com/image/t2l2 17. incarcator Panasonic pentru NiCd. https://www.ultraimg.com/image/ZurB 18. cabluri smps https://www.ultraimg.com/image/t20Z 19. casti, trusa castile functionale sunt 5 lei bucata, insa doresc sa vand intreaga mea trusa, care contine castile functionale + cele reparabile din poze... plus multe subansamble mecanice, cabluri, peste 10 difuzoare, microfoane... pret pentru totul 15 lei. Placa USB pentru casti nu este inclusa in pachet si costa singura 20 lei (cea neagra, cu control volum). https://www.ultraimg.com/image/nQ4w https://www.ultraimg.com/image/nQ4z https://www.ultraimg.com/image/nQ4K https://www.ultraimg.com/image/nQ4u https://www.ultraimg.com/image/nQ4r 20. lanterna are leduri rosii, merge cu 3 baterii tip AAA/R3 https://www.ultraimg.com/image/t2Pi 21. suport HDD Corsair permite montarea HDD/SSD de 2,5 inch in bay de 3,5 - aluminiu eloxat, deci asigura si racirea https://www.ultraimg.com/image/t2PC 22. telec A/C https://www.ultraimg.com/image/t20Y 23. CFL, trusa totul 5 lei: peste 10 invertoare functionale (doua de 40W sunt noi) plus alte piese recuperate functionale, unele nu sunt in poze https://www.ultraimg.com/image/t2PL https://www.ultraimg.com/image/t2Ph 24. tastaturi 5 lei, ambele https://www.ultraimg.com/image/nxfn 25. diverse la tastatura nu merge tasta "spatiu" https://www.ultraimg.com/image/tIaR https://www.ultraimg.com/image/nxfv 26. bracket desktop USB si fireWire https://www.ultraimg.com/image/tIaW 27. Molex toate 5 lei https://www.ultraimg.com/image/tkHk 28. cabluri audio si shielduri https://www.ultraimg.com/image/tkHl 29. adaptoare RS232 https://www.ultraimg.com/image/tkHq 30. card reader extern https://www.ultraimg.com/image/tkHz 10 lei bucata oricare din ce urmeaza: 31. meanica casetofon motor bun, numarator mecanic, sistem 3 capete mono (capul inregistrare + redare este nou). https://www.ultraimg.com/image/t2lB 32. calculator cu banda calculator cu imprimanta Elekta, 10 digiti. https://www.ultraimg.com/image/t2lP 33. Maiak pretul nu include VUmetrele, nici sursa de alimentare - fie le extrag, fie accept schimb cu altele cel putin echivalente. https://www.ultraimg.com/image/t2A1 https://www.ultraimg.com/image/t2Ag https://www.ultraimg.com/image/t2Ax 34. telefon fix functioneaza https://www.ultraimg.com/image/t2Al 35. diverse telecomanda universala si invertorul sunt noi https://www.ultraimg.com/image/tIa7 https://www.ultraimg.com/image/nSuN 36. incarcator Energizer putin folosit, incarca foarte repede, dar nu suporta decat elementi in stare foarte buna. Control si afisare individuala pe 4 canale. Alimentatorul de 12V se vinde separat cu 15 lei. https://www.ultraimg.com/image/Zurz https://www.ultraimg.com/image/ZurJ 37. interfon pretul de 10 lei este pentru interfon, sursa de alimentare se da separat cu 20 lei. https://www.ultraimg.com/image/t2AC https://www.ultraimg.com/image/t2Ah 38. invertoare CCFL laptop din Dell, Toshiba, HP 10 lei bucata. Toate 3 la pachet = 15 lei https://www.ultraimg.com/image/nxfM 39. driver comutatie led unul este bazat pe XL6009, intrare 5-32V-curent continuu. Tensiunea pe iesire mai mare ca pe intrare (maxim posibil 40V) deci "duce" COB uzual. Celalalt este buck, special pentru auto - cel cu radiator (iesirea nu floteaza, este comuna cu intrarea) Curentul este programabil, dupa nevoie. https://www.ultraimg.com/image/t2Ai 40. mixer Braun motorul, comutatorul si variatorul merg bine (defectul a fost la accesorii). Pretul nu include cordonul de alimentare, adica vreau unul bun la schimb. https://www.ultraimg.com/image/t204 https://www.ultraimg.com/image/t20C https://www.ultraimg.com/image/t20h https://www.ultraimg.com/image/t20F 41. ODD unitati optice DVD-RW pentru laptop, borna SATA sau IDE, grosime 12,7mm, functionale. Una SATA este transformata pentru al doilea HDD. Mai am una SATA grosime 9,5mm, pret 15 lei. https://www.ultraimg.com/image/t2Pt 42. spoturi cfl https://www.ultraimg.com/image/t2PF 43. cabluri DP si FireWire https://www.ultraimg.com/image/tIaU 44. cablu adaptor IDE/SATA/USB https://www.ultraimg.com/image/tIaa 15 lei bucata oricare din ce urmeaza: 45. transformator trafo german 50W, miez 35x55x65mm - tensiune 23V~ in gol, montajul alimentat/stabilizat era de 20V/2A. https://www.ultraimg.com/image/t2lh 46. cabluri HDMI HDMI->RCA / HDMI->micro HDMI https://www.ultraimg.com/image/tIa8 20 lei bucata oricare din ce urmeaza: 47. baterie tableta originala Asus specificatii in poza https://www.ultraimg.com/image/t2lQ https://www.ultraimg.com/image/t2ld 48. cablu MXM audio lungime 3,5m, cablu audio stereo, zgomot redus, borne RCA aurite. https://www.ultraimg.com/image/t2P9 49. monitor complet contine toate placile pentru monitor, diverse intrari. Mai trebuie numai ecranul. https://www.ultraimg.com/image/t2Ak https://www.ultraimg.com/image/t2li 50. radio radio mic, cu 9 lungimi de unda. Ultrascurtele prind si CCIR si OIRT https://www.ultraimg.com/image/t2lO 51. incarcator GP incarca si baterii de 9V, suporta si elementi mai degradati. https://www.ultraimg.com/image/ZurK https://www.ultraimg.com/image/ZurT Diverse preturi: 52. laptop eePC, 50 lei un "specialist" a cositorit firul vizibil in imagini. Se poate repara, ofer si RAM. Ecranul, tastatura, caroseria si bateria sunt in buna stare. VARIANTE buy-back. https://www.ultraimg.com/image/t2lZ https://www.ultraimg.com/image/t2l4 https://www.ultraimg.com/image/t2kZ https://www.ultraimg.com/image/t2kO 53. laptop Lenovo G550 MoBo defect, carcasa 2 bucati, caddy, balamale (30 lei), cablu alimentare cu conector (10), difuzoare (10), LVDS (20), webcam, tastatura - una este ca noua (40), placuta USB si power, WiFi, BT, cooler (30) etc Pret pentru tot pachetul 40 lei. https://www.ultraimg.com/image/t2P8 https://www.ultraimg.com/image/t2PU https://www.ultraimg.com/image/t2AX 54. laptop Toshiba Satellite L500-128: placa video MXM in stare buna (50 lei), carcasa in stare foarte buna, completa fara ecran, MoBo defecta, tastatura buna (35) baterie (25), incarcator 90W(45), balamale (30), cooler (30) ODD, cablu alimentare cu conector (10) WiFi, difuzoare etc (ecranul din poza nu mai exista) Pret pentru tot pachetul 50 lei, nu include incarcatorul. https://www.ultraimg.com/image/t2AK https://www.ultraimg.com/image/nxfx https://www.ultraimg.com/image/t2Au https://www.ultraimg.com/image/t2P7 https://www.ultraimg.com/image/t2AJ https://www.ultraimg.com/image/nxfg 55. laptop Acer Aspire E1-532: carcasa cu unele elemente uzate, baterie (25 lei), incarcator 65W(40), balamale (35), tastatura (35), ODD (20), cablu alimentare cu conector (10), MoBo defect, WiFi, difuzoare, caddy, PCB power si USB, etc Pret pentru tot pachetul 40 lei, nu include incarcatorul. https://www.ultraimg.com/image/t2AV https://www.ultraimg.com/image/t2Ap https://www.ultraimg.com/image/t2PR 56. laptop Lenovo Y560 Tastatura in stare foarte buna (40 lei), cooler (30), LVDS (20), cablu alimentare cu conector (10), WiFi, BT. Pret pentru tot pachetul 40 lei, nu include coolerul. https://www.ultraimg.com/image/t2Ar 57. laptop HP dv6 MoBo defect, cooler (30 lei), PCB accesorii x 3, WiFi, caddy (10) , LVDS (20), cablu HDD (20), telecomanda, ODD etc Pret pentru tot pachetul 30 lei. https://www.ultraimg.com/image/t2Aq 58. CPU laptop Pret 5 lei: Celeron 900 (2,2GHz, cache 1M, fsb800) / Pentium M725 (1,6G, 2M cache, fsb400)/ P6100 pentium dual-core (2GHz) Pret 10 lei: T4300 dualcore (2,1GHz, cache 1M, fsb800) EXEMPLAR SELECTAT PT UNDERVOLTING Pret 25 lei: P8400 dualcore (2,26GHz, cache 3M, fsb1066) UNDERVOLTING Pret 35 lei: P8600 dualcore (2,4GHz, cache 3M, fsb1066) UNDERVOLTING / T8100 dualcore (2,1GHz, cache 3M, fsb800) Cele cu mentiunea UNDERVOLTING sunt capabile de UV major si sunt mapate (U in functie de frecventa) Pret pentru tot pachetul 70 lei, sau schimb cu DDR4 laptop https://www.ultraimg.com/image/t2P4 59. RAM laptop DDR3 1GB=5 lei, 2GB=10 lei, 4GB=20 lei, 4GB/L=25 lei. Pret pentru tot pachetul 50 lei, sau schimb cu DDR4 laptop https://www.ultraimg.com/image/t2PB 60. alimentator laptop mai sus aveti alimentatoare la Acer si Toshiba. In plus sunt disponibile: Lenovo original 120W - 60 lei // Dell 130W - 60 lei // HP 90W - 45 lei https://www.ultraimg.com/image/tIaf 61. optica secundara led/cob TIR=2-5 lei, lens 0,5-15 lei, oglinzi 1-15 lei, dispersoare 1,5 lei. Reflectoare/lentile/dispersoare pt. led si COB - am diverse modele/dimensiuni metalice sau de plastic metalizat, stocul se modifica in timp. https://www.ultraimg.com/image/t26P 62. sursa MEAN WELL, 40 lei MEAN WELL PT-45B -> +5V/3A, +12V/2A, -12V/0,3A, noua https://www.tme.eu/Document/05059b9874d5b54dc75eef1eb10b2675/pt-45-spec.pdf https://www.ultraimg.com/image/tkHy 63. sursa 36V/5A, 60 lei noua https://www.ultraimg.com/image/tkHw 64. CD si DVD CD-R Verbatim, 50 buc, sigilat = 40 lei // DVD+R Verbatim, 50 buc, sigilat = 45 lei // DVD-R Xdata, 25 buc = 25 lei CD-R in caseta individuala = 2 lei // CD-R si DVD-R la bucata bulk = 1 leu https://www.ultraimg.com/image/tkHK https://www.ultraimg.com/image/tkHu Procedura: declarati-va cat mai repede dorinta aici sau pe PM. Neaparat specificati cum doriti livrarea. NU ARE IMPORTANTA daca deja sunt multi doritori pentru ce ati selectat - voi face atribuirea incat sa vand cat mai multe repere cu expeditia cat mai convenabila. ordinea inscrierii nu va avea importanta decat in cazul ca volumul solicitat si facilitatea expedierii sunt egale pentru doi doritori. ce si cui vand este prerogativa mea si nu exista rezervari decat in momentul cand am promis eu. predarea personala in Bucuresti este cea mai buna. Buna este si plata in cont cu expedierea prin curier, achitat la destinatie. Prin posta numai in cazuri justificate. expedierea postala costa 15 lei. proba - se face in toate cazurile cand este posibil. Sfaturi: consultati ambele anunturi - este favorabil ca prioritate si bonusuri sa comandati cat mai multe repere. https://www.elforum.info/topic/140040-vand-aparate-subansamble-si-diverse-toate-functionale-unele-noi/ daca aveti posibilitatea sa va reprezinte cineva din Bucuresti, incat sa predau personal cu proba, va fi avantajos ca atribuire. Schimburi puteti propune schimb pentru orice produs, din cele doua anunturi. schimbul il consider o vanzare, deci puteti beneficia si de bonusuri. NEAPARAT sa va evaluati produsul similar cu modul in care le-am evaluat eu pe ale mele... neglijez oferte cu preturi proportional prea mari, chiar daca acela este pretul pietei. daca eu dau produsul la jumatate din cel al pietei, atunci la fel va trebui sa fie si pretul obiectului oferit. avand in vedere specificul operatiunii, se preteaza in special daca sunteti din Bucuresti sau veniti aici in mod periodic... Ce ma poate interesa ca sa obtin prin schimb: RAM laptop ddr4 de 4GB sau 8GB incarcator Nokia cu borna coaxiala subtire, diametru 2mm (ma intereseaza numai borna). Pentru acest produs ofer o la schimb si incarcatoare similare de diverse tipuri / tensiuni / puteri, din rezerva mea. aparat foto vechi (cu film) sa aibe obiectivul functional, manual, nu ma intereseaza ceva de performanta, poate sa fi si din plastic - probabil sta prin vreun sertar. Pe ale mele le-am dat demult, nu credeam sa imi trebuiasca... Nu doresc din cele performante, reflex, cu vizare prin obiectiv si pentaprisma - vreau din cele mai simple, dar sa aibe reglaj de focalizare si de diafragma. Smena, Lomo, sau clone de Leica. cooler placa video - volum minim si capabilitate mare de racire (nu ma intereseaza chinezisme). Foto - borna dorita este cea subtire 2mm, din stanga imaginii. Nu ma intereseaza cele de 3,5mm din dreapta, din alea am destule, le ofer la schimb: https://www.ultraimg.com/image/tDkW - cooler de placa video cum caut: https://www.ultraimg.com/image/tkHT Bonusuri la orice achizitie puteti opta pentru ceva din lista de mai jos in plus, daca achizitionati valoric mai mult, orice produs din categoriile de mai sus, pana la 20 lei poate fi solicitat si acordat gratuit, insa intr-un raport valoric rezonabil, sub 10%. puteti sa nu solicitati bonus, doar sa aveti o lista de cumparaturi si voi socoti eu automat ce vine gratis. Produse disponibile doar gratuit, ca bonusuri, posibil sa fie utile cuiva (deci fara poze sau preturi): Defecte sau incomplete: - modulator FM - mouse wireless - Laptop Dell XPS M1530 - nu mai are WiFi si ecran, HDD, RAM si alimentator - Laptop HP pp2190/Compaq nc8000 - lipsesc mai multe componente si nu include ecranul - difuzoare TomTec Diverse: - counter/timer/clock digital, functioneaza - mousi vechi, au senzori optici rotativi care cred ca pot fi utili - becuri halogen de proiector 300W/82V sunt NOS Tranzistori: 2N3055 KT812A SU160U SU169 Integrate NOS: CDB - 400, 403, 411, 416, 442, 473, 474, 490, 493 betaM - 108,301,324,723,741 betaE 565 MMC 4066 MAC156 TDA 1028, 2030, 4558, 8552 TCA440 NXP7555 Contact operativ: tel 0723-355013 - folositi numai dupa ce deja v-am confirmat rezervarea. Nu se fac rezervari la telefon. repet: daca doriti ceva - scrieti in topic, sau pe PM. Editat Decembrie 4, 2019 de Dxxx Link spre comentariu
nostromo Postat Octombrie 28, 2019 Partajează Postat Octombrie 28, 2019 Aveti Mp . Link spre comentariu
wiseboy1900 Postat Octombrie 28, 2019 Partajează Postat Octombrie 28, 2019 Si de la mine. Link spre comentariu
Dxxx Postat Octombrie 28, 2019 Autor Partajează Postat Octombrie 28, 2019 Va multumesc pentru interes, am notat toate dorintele si voi tine cont de ele. Trebuie sa intelegeti ca vand aproape 100 de repere si scopul este sa dau cat mai multe dintre ele, deci nu exista rezervari si nici prioritate pentru primul venit, ci conteaza volumul comenzii. Oricum pana la sfarsitul saptamanii doar strang clienti, nu fac vanzari. Deci asta este si dezavantaj dar si avantaj, toate reperele raman disponibile cu exceptia vreunuia pe care il blochez pentru un client privilegiat. Link spre comentariu
Dxxx Postat Octombrie 29, 2019 Autor Partajează Postat Octombrie 29, 2019 Toate sunt inca disponibile. Link spre comentariu
Dxxx Postat Octombrie 30, 2019 Autor Partajează Postat Octombrie 30, 2019 Toate sunt disponibile. Link spre comentariu
Ionelc Postat Octombrie 30, 2019 Partajează Postat Octombrie 30, 2019 Vreau eu punctul 49 si 50. Adresa o las pe mesagerie. Link spre comentariu
Dxxx Postat Octombrie 30, 2019 Autor Partajează Postat Octombrie 30, 2019 Inca nu am primit adresa, dar nu este graba. va rog sa specificati, neaparat, si modalitate de livrare verificati daca nu cumva doriti ceva si de pe celalalt anunt CLARIFICARE: sper ca nu s-a inteles gresit, peste tot este vorba de pret pentru o singura bucata, indiferent cate sunt in poze. Exceptie punctele 23 / 34 si 52 unde tot ce este in poza este inclus in pretul specificat. Cred ca citind bine reiese acelas lucru, insa posibil ca cineva sa fie mai grabit... Link spre comentariu
Dxxx Postat Octombrie 31, 2019 Autor Partajează Postat Octombrie 31, 2019 valabile Link spre comentariu
adynel Postat Octombrie 31, 2019 Partajează Postat Octombrie 31, 2019 De la punctul 39 vreau 4 cu tensiunea pînă in 40 V și 4 tip auto (12V) De la punctul 5 vreau 4 COB-uri de10 W. Transport cu poșta plata în cont bancar. Link spre comentariu
Dxxx Postat Octombrie 31, 2019 Autor Partajează Postat Octombrie 31, 2019 Din pacate driverele in comutatie sunt dintr-un lot vechi si nu mi-a mai ramas decat cate unul din fiecare, acum doresc sa nu-mi mai ocupe loc. Ai detalii pe PM. Link spre comentariu
Dxxx Postat Noiembrie 1, 2019 Autor Partajează Postat Noiembrie 1, 2019 valabile Link spre comentariu
zvonacfirst Postat Noiembrie 1, 2019 Partajează Postat Noiembrie 1, 2019 (editat) La 27.10.2019 la 15:52, Dxxx a spus: 3. borne letcon Salut. Aveti si bornele de pe panou? Adica perechea celor din poza. Este o intrebare, oricum vreau vreo 5 buc din cele din poza. La 27.10.2019 la 15:52, Dxxx a spus: 45. transformator La 27.10.2019 la 15:52, Dxxx a spus: 35. diverse telecomanda universala si invertorul sunt noi Ma intereseaza si pozitiile de mai sus. Cu livrarea este simplu, sunt din Bucuresti si ma pot deplasa. Editat Noiembrie 1, 2019 de zvonacfirst Link spre comentariu
Dxxx Postat Noiembrie 1, 2019 Autor Partajează Postat Noiembrie 1, 2019 Bornele de pe panou... le-am folosit la statiile de lipit pe care le-am facut, asa se face ca am numai partea care vine pe fir... Link spre comentariu
Dxxx Postat Noiembrie 2, 2019 Autor Partajează Postat Noiembrie 2, 2019 valabile Link spre comentariu
