OLD stuff...
O fi fost de la motoarele cu ardere internă? Sau de la motoarele avioanelor, în special de la cele cu reacție? Sau mai degrabă de la multitudinea de fabrici și uzine și nenumăratele termocentrale pe cărbune?
 Vai de capul nostru ce mult ne-am prostit și cât am decăzut și mai ales cât de mult ne-am obișnuit cu anormalitatea.
 Codoiul, bată-l vina; sărăcuțul de el...
The Orthomat was a solid-state numerically controlled engineering drafting machine made by Universal Drafting Machine Company from Cleveland Ohio (1963). It automatically translated complex mathematical formulas defined on punched or magnetic tape into accurate engineering drawings at speeds up to 85 mm/s, designed to operate as a part of a total computer engineering system, correlating with other numerically controlled data, production and inspection machines or standalone. The device is a coordinate, continuous-line contouring plotter, capable of drawing straight lines, angles, curves, circles or ellipses on paper up to 152×366 cm. It has an automatic indexing hex turret for mounting a variety of stylii. Controls permit scaling of drawings (¼, ½, full, 2×) and "mirror image". The numerical control director supplies command pulses and may be any manual or tape (punched or magnetic) input device which can supply incremental X & Y pulses of 0.0254 mm (1 mil) value at a controlled rate, plus auxiliary signals to control the stylii. The drafting machine controls all motions of a variety of scribing devices and consists of an aluminum table with desktop linoleum surface, a vacuum chuck, and a large scale digital X-Y plotter using a a precision rack and pinion drive. Controls govern X, Y and Z motion, jogging, stepping in 0.0254 mm increments, feedrate override of speed, stylus indexing, an dash-line generation. Actual position is readout for any two of X,Y and Z axes to the nearest 0.0254 mm. Zero positioning is automatic, and readouts may be reset to zero anywhere on the board to accommodate dimensioning of drawings in which the 0-0 position is off the table. A maintenance feature includes a built-in customer engineer's test panel for quick pinpointing of any malfunction.
A fost varianta low cost a receptorului Dunarea.
Acum 30 minute, okean a spus:
Radioreceptorul DELTA, 1964, cu tranzistori avea si scurte !
