Ion Andrei Postat Septembrie 3, 2019 Partajează Postat Septembrie 3, 2019 Sursa este aproape noua. 2x 0V to 30V / 1x 5V, 3x 2A (130W) Linear regulated, two-quadrant power supply (current source and sink) Realtime voltage and current values Advanced parallel and serial operation Setting and readback resolution: 10mV, 1mA Electronic fuse and tracking mode Front connectors: 4mm safety sockets SENSE connectors for line loss compensation (30V channels)? External modulation of output voltages up to 20kHz Arbitrary module: 4,096 points, 12bit RS-232/USB dual interface, IEEE-488 (GPIB) optionally Pret: 1600 ron Tel: 0760.540.469 Link spre comentariu
Ion Andrei Postat Septembrie 4, 2019 Autor Partajează Postat Septembrie 4, 2019 se poate inchide 21 hours ago, Ion Andrei said: Sursa este aproape noua. 2x 0V to 30V / 1x 5V, 3x 2A (130W) Linear regulated, two-quadrant power supply (current source and sink) Realtime voltage and current values Advanced parallel and serial operation Setting and readback resolution: 10mV, 1mA Electronic fuse and tracking mode Front connectors: 4mm safety sockets SENSE connectors for line loss compensation (30V channels)? External modulation of output voltages up to 20kHz Arbitrary module: 4,096 points, 12bit RS-232/USB dual interface, IEEE-488 (GPIB) optionally Pret: 1600 ron Link spre comentariu
