Spitfire Postat August 15, 2019 Autor Partajează Postat August 15, 2019 (editat) -lot 8 microprocesoare de colectie (R80186-1978; D8088-1982; D8086-Intel `78-`79; Z80ACPU;N80L286-8/S 1982; N80186-1978; Siemens SAB80286-16-N 1991; Intel P8052AH-1980) -32 lei. -lot 8 tranzistori mosfet 14N50F -24 lei. -lot 10 condensatori MKP X2 0,22uF/250V~ -5 lei -lot 10 condensatori MKP X2 0,47uF/250V~ -5 lei - lot 4 condensatori Rubycon snap-in 120uF/400V, testati ESR=0 ohmi -10 lei -lot 4 condensatori 680uF/200V snap-in inaltime redusa -10 lei -lot 5 condensatori 470uF/200V -10 lei -alimentator 5V/2,5A, foarte buna calitate(Cisco) -20 lei -lot 10 casti(difuzoare) recuperate din telefoane mobile -3 lei -relee diverse -11 buc. 10 lei tot -relee Reed 3 buc-9 lei -lot bride cupru masiv 240mmp, 120mmp, 95 mmp, 70 mmp -10 lei -siguranta automata 25A Moeller -10 lei - lot mufe TV noi -5 lei -lot lampi vapori Hg pt. aparat bronzat, noi, nefolosite, doua de 400W, a treia de 800W-10 lei. -tub UV blacklight Regen 4W(nou)-6 lei -drossel tuburi fluorescente 40W Electrofar -5 lei -drossel 18/20W tuburi fluorescente nou, neutilizat -6 lei -CPU socket AM2 AMD Sempron SDD3000IAA3CN TDP35W -5 lei -placa PCI 5 porturi USB, testata OK -8 lei -HDD Seagate 160GB SATA testat ok, fara bad-uri-~7000 de ore functionare -20 lei -ventilator 120mm 18V -8 lei -sulfat de cupru(piatra vanata)~800g -8 lei -ESR-meter, realizat de colegul @iora, in perfecta stare, foarte putin utilizat, afisaj albastru -120 lei Editat August 15, 2019 de Spitfire Link spre comentariu
Spitfire Postat August 16, 2019 Autor Partajează Postat August 16, 2019 -lot 8 microprocesoare de colectie (R80186-1978; D8088-1982; D8086-Intel `78-`79; Z80ACPU;N80L286-8/S 1982; N80186-1978; Siemens SAB80286-16-N 1991; Intel P8052AH-1980) -32 lei. -caserola suruburi amestecate(M2/M3/M4/M5) diverse lungimi, total 1,6 kg -16 lei -lot 8 tranzistori mosfet 14N50F -24 lei. -lot 10 condensatori MKP X2 0,22uF/250V~ -5 lei -lot 10 condensatori MKP X2 0,47uF/250V~ -5 lei - lot 4 condensatori Rubycon snap-in 120uF/400V, testati ESR=0 ohmi -10 lei -lot 4 condensatori 680uF/200V snap-in inaltime redusa -10 lei -lot 5 condensatori 470uF/200V -10 lei -alimentator 5V/2,5A, foarte buna calitate(Cisco) -20 lei -lot 10 casti(difuzoare) recuperate din telefoane mobile -3 lei -relee diverse -11 buc. 10 lei tot -relee Reed 3 buc-9 lei -lot bride cupru masiv 240mmp, 120mmp, 95 mmp, 70 mmp -10 lei -siguranta automata 25A Moeller -10 lei - lot mufe TV noi -5 lei -lot lampi vapori Hg pt. aparat bronzat, noi, nefolosite, doua de 400W, a treia de 800W-10 lei. -tub UV blacklight Regen 4W(nou)-6 lei -drossel tuburi fluorescente 40W Electrofar -5 lei -drossel 18/20W tuburi fluorescente nou, neutilizat -6 lei -CPU socket AM2 AMD Sempron SDD3000IAA3CN TDP35W -5 lei -placa PCI 5 porturi USB, testata OK -8 lei -HDD Seagate 160GB SATA testat ok, fara bad-uri-~7000 de ore functionare -20 lei -ventilator 120mm 18V -8 lei -sulfat de cupru(piatra vanata)~800g -8 lei -ESR-meter, realizat de colegul @iora, in perfecta stare, foarte putin utilizat, afisaj albastru -120 lei Link spre comentariu
Spitfire Postat August 18, 2019 Autor Partajează Postat August 18, 2019 -caserola suruburi amestecate(M2/M3/M4/M5) diverse lungimi, total 1,6 kg -16 lei -lot 10 condensatori MKP X2 0,22uF/250V~ -5 lei -lot 10 condensatori MKP X2 0,47uF/250V~ -5 lei Rezervate pentru Dl. cristi7521, restul, valabil. Link spre comentariu
Spitfire Postat August 20, 2019 Autor Partajează Postat August 20, 2019 sus............................. Link spre comentariu
Spitfire Postat August 21, 2019 Autor Partajează Postat August 21, 2019 -lot 8 microprocesoare de colectie (R80186-1978; D8088-1982; D8086-Intel `78-`79; Z80ACPU;N80L286-8/S 1982; N80186-1978; Siemens SAB80286-16-N 1991; Intel P8052AH-1980) -32 lei. -lot 8 tranzistori mosfet 14N50F -24 lei. - lot 4 condensatori Rubycon snap-in 120uF/400V, testati ESR=0 ohmi -10 lei -lot 4 condensatori 680uF/200V snap-in inaltime redusa -10 lei -lot 5 condensatori 470uF/200V -10 lei -alimentator 5V/2,5A, foarte buna calitate(Cisco) -20 lei -lot 10 casti(difuzoare) recuperate din telefoane mobile -3 lei -relee diverse -11 buc. 10 lei tot -relee Reed 3 buc-9 lei -lot bride cupru masiv 240mmp, 120mmp, 95 mmp, 70 mmp -10 lei -siguranta automata 25A Moeller -10 lei - lot mufe TV noi -5 lei -lot lampi vapori Hg pt. aparat bronzat, noi, nefolosite, doua de 400W, a treia de 800W-10 lei. -tub UV blacklight Regen 4W(nou)-6 lei -drossel tuburi fluorescente 40W Electrofar -5 lei -drossel 18/20W tuburi fluorescente nou, neutilizat -6 lei -CPU socket AM2 AMD Sempron SDD3000IAA3CN TDP35W -5 lei -placa PCI 5 porturi USB, testata OK -8 lei -HDD Seagate 160GB SATA testat ok, fara bad-uri-~7000 de ore functionare -20 lei -ventilator 120mm 18V -8 lei -sulfat de cupru(piatra vanata)~800g -8 lei -ESR-meter, realizat de colegul @iora, in perfecta stare, foarte putin utilizat, afisaj albastru -120 lei Link spre comentariu
Spitfire Postat August 22, 2019 Autor Partajează Postat August 22, 2019 sus......................... Link spre comentariu
Spitfire Postat August 23, 2019 Autor Partajează Postat August 23, 2019 sus................................ Link spre comentariu
Spitfire Postat August 24, 2019 Autor Partajează Postat August 24, 2019 -lot 8 microprocesoare de colectie (R80186-1978; D8088-1982; D8086-Intel `78-`79; Z80ACPU;N80L286-8/S 1982; N80186-1978; Siemens SAB80286-16-N 1991; Intel P8052AH-1980) -32 lei. -lot 8 tranzistori mosfet 14N50F -24 lei. -lot 9 izolatori silicon tranzistori TO3 -4 lei - lot 4 condensatori Rubycon snap-in 120uF/400V, testati ESR=0 ohmi -10 lei -lot 4 condensatori 680uF/200V snap-in inaltime redusa -10 lei -lot 5 condensatori 470uF/200V -10 lei -alimentator 5V/2,5A, foarte buna calitate(Cisco) -20 lei -lot 10 casti(difuzoare) recuperate din telefoane mobile -3 lei -relee diverse -11 buc. 10 lei tot -relee Reed 3 buc-9 lei -lot bride cupru masiv 240mmp, 120mmp, 95 mmp, 70 mmp -10 lei -siguranta automata 25A Moeller -10 lei - lot mufe TV noi -5 lei -lot lampi vapori Hg pt. aparat bronzat, noi, nefolosite, doua de 400W, a treia de 800W-10 lei. -tub UV blacklight Regen 4W(nou)-6 lei -drossel tuburi fluorescente 40W Electrofar -5 lei -drossel 18/20W tuburi fluorescente nou, neutilizat -6 lei -CPU socket AM2 AMD Sempron SDD3000IAA3CN TDP35W -5 lei -placa PCI 5 porturi USB, testata OK -8 lei -HDD Seagate 160GB SATA testat ok, fara bad-uri-~7000 de ore functionare -20 lei -ventilator 120mm 18V -8 lei -sulfat de cupru(piatra vanata)~800g -8 lei -ESR-meter, realizat de colegul @iora, in perfecta stare, foarte putin utilizat, afisaj albastru -120 lei Link spre comentariu
Spitfire Postat August 25, 2019 Autor Partajează Postat August 25, 2019 -lot 8 microprocesoare de colectie (R80186-1978; D8088-1982; D8086-Intel `78-`79; Z80ACPU;N80L286-8/S 1982; N80186-1978; Siemens SAB80286-16-N 1991; Intel P8052AH-1980) -32 lei. -lot 8 tranzistori mosfet 14N50F -24 lei. -lot 9 izolatori silicon tranzistori TO3 -4 lei - lot 4 condensatori Rubycon snap-in 120uF/400V, testati ESR=0 ohmi -10 lei -lot 4 condensatori 680uF/200V snap-in inaltime redusa -10 lei -lot 5 condensatori 470uF/200V -10 lei -lot 160 condensatori ceramici, diverse valori - 8lei -alimentator 5V/2,5A, foarte buna calitate(Cisco) -20 lei -lot 10 casti(difuzoare) recuperate din telefoane mobile -3 lei -relee diverse -11 buc. 10 lei tot -relee Reed 3 buc-9 lei -lot bride cupru masiv 240mmp, 120mmp, 95 mmp, 70 mmp -10 lei -siguranta automata 25A Moeller -10 lei - lot mufe TV noi -5 lei -lot lampi vapori Hg pt. aparat bronzat, noi, nefolosite, doua de 400W, a treia de 800W-10 lei. -tub UV blacklight Regen 4W(nou)-6 lei -drossel tuburi fluorescente 40W Electrofar -5 lei -drossel 18/20W tuburi fluorescente nou, neutilizat -6 lei -CPU socket AM2 AMD Sempron SDD3000IAA3CN TDP35W -5 lei -placa PCI 5 porturi USB, testata OK -8 lei -HDD Seagate 160GB SATA testat ok, fara bad-uri-~7000 de ore functionare -20 lei -ventilator 120mm 18V -8 lei -sulfat de cupru(piatra vanata)~800g -8 lei -ESR-meter, realizat de colegul @iora, in perfecta stare, foarte putin utilizat, afisaj albastru -120 lei Link spre comentariu
Spitfire Postat August 26, 2019 Autor Partajează Postat August 26, 2019 sus................................ Link spre comentariu
Spitfire Postat August 27, 2019 Autor Partajează Postat August 27, 2019 sus................................... Link spre comentariu
Spitfire Postat August 28, 2019 Autor Partajează Postat August 28, 2019 -lot 8 tranzistori mosfet 14N50F -24 lei. -lot 9 izolatori silicon tranzistori TO3 -4 lei - lot 4 condensatori Rubycon snap-in 120uF/400V, testati ESR=0 ohmi -10 lei -lot 4 condensatori 680uF/200V snap-in inaltime redusa -10 lei -lot 5 condensatori 470uF/200V -10 lei -lot 160 condensatori ceramici, diverse valori - 8lei -alimentator 5V/2,5A, foarte buna calitate(Cisco) -20 lei -lot 10 casti(difuzoare) recuperate din telefoane mobile -3 lei -relee diverse -11 buc. 10 lei tot -relee Reed 3 buc-9 lei -lot bride cupru masiv 240mmp, 120mmp, 95 mmp, 70 mmp -10 lei -siguranta automata 25A Moeller -10 lei - lot mufe TV noi -5 lei -lot lampi vapori Hg pt. aparat bronzat, noi, nefolosite, doua de 400W, a treia de 800W-10 lei. -tub UV blacklight Regen 4W(nou)-6 lei -drossel tuburi fluorescente 40W Electrofar -5 lei -drossel 18/20W tuburi fluorescente nou, neutilizat -6 lei -CPU socket AM2 AMD Sempron SDD3000IAA3CN TDP35W -5 lei -lot 8 microprocesoare de colectie (R80186-1978; D8088-1982; D8086-Intel `78-`79; Z80ACPU;N80L286-8/S 1982; N80186-1978; Siemens SAB80286-16-N 1991; Intel P8052AH-1980) -32 lei. -placa PCI 5 porturi USB, perfecta stare -8 lei -unitate floppy externa pe USB perfecta stare+10 dischete noi -15 lei -HDD Seagate 160GB SATA testat ok, fara bad-uri-~7000 de ore functionare -20 lei -ventilator 120mm 18V -8 lei -sulfat de cupru(piatra vanata)~800g -8 lei -ESR-meter, realizat de colegul @iora, in perfecta stare, foarte putin utilizat, afisaj albastru -120 lei Link spre comentariu
Spitfire Postat August 29, 2019 Autor Partajează Postat August 29, 2019 Cei 8 tranzistori mosfet 14N50F rezervati, restul valabil. Link spre comentariu
Spitfire Postat August 30, 2019 Autor Partajează Postat August 30, 2019 Unitatea floppy rezervata, restul disponibil. Link spre comentariu
Spitfire Postat August 31, 2019 Autor Partajează Postat August 31, 2019 sus.............................. Link spre comentariu
