Electronice diverse
cmariuss
Se adauga:
92. Transformator P14112 produs in USA, recuperat din aparatura medicala:
-primar: 230V
-secundar: 12V sarma bobinaj ~ 1mm.
grosime pachet 37mm.
Pret: 30 lei.
https://imgur.com/S8S4Sae
https://imgur.com/v5W2LrY
93. P14113 produs in USA, recuperat din aparatura medicala:
-primar: 230 V
-secundar 1: 7V sarma ~0.6 mm
-secundar 2: 12 V sarma ~0,6 mm
Pret: 20 lei.
https://imgur.com/gJDuWTk
https://imgur.com/plBZ2Z8
94. Difuzoare (doua) recuperate dintro plasma. Impedanta 8 ohm, putere 10 W. Dimensiunile difuzorului: 13cm x 4,5
cm. Pret: 10 lei.
https://imgur.com/W5Lk3oA
95. Tuner JS-6H2/121. Pret: 4 lei.
https://imgur.com/0uqqKgq
96. Multimetru sovietic MP-12. Defect. Ii lipseste doar capacul bateriei. Pret: 7 lei.
https://imgur.com/7aAm4ps
Se adauga:
97. Amplituner Delia. Functional pe benzile UL, UM, si UUS. Pe US1 si US2 nu receptionez nimic. Are antena cadru
exterioara. Nu are capacele inferior si superior. Lipseste aparatoare de plastic a antenei de ferita. Claviaturile
functionaza corect, amplificare in parametrii, fara distorsiuni. Pret: 75 lei.
https://imgur.com/KF2PCJS
https://imgur.com/oRZGJ2N
https://imgur.com/597ykH1
https://imgur.com/9YOhjHY
98. Amplificator Delia. Functional pe benzile UL si UM. Pe UUS nu receptionez nimic, dar fosnetul specific benzii
exista. Are decodor si pe banda vest. Pe US1 si US2 nu receptionez nimic.  Claviaturile functioneaza corect.
Amplificare fara distorsiuni, fasait suparator. Frontal prezinta zgarieturi si lovituri dupa cum se poate vedea in poze. Pret: 75 lei.
https://imgur.com/eTDsD8G
https://imgur.com/3q49hIt
https://imgur.com/aCTtiN1
https://imgur.com/6VTPnK2
99. Sursa PC 240W, Dell- L240AS-00, silentioasa. testata. Pret: 20 lei.
https://imgur.com/2JviPfb
https://imgur.com/lhZKKwj
100. Set transformatoare recuperate din surse in comutatie. Pret: 7 lei/ toate.
https://imgur.com/6AOBuSY
Editat de cmariuss
Se adauga:
101. Transformator magnetofon Tesla CM150:
Sec1: 12 V/ 3A
Sec2: 12V/ 3A
Sec3:  27 V/ 0,5A
Pret: 30 lei.
https://imgur.com/5QMIOEI
102: Transformator cadre recuperat dintrun tv Rubin
Pret: 9 lei.
https://imgur.com/V1TvZL8
103. Transformator toroidal 20 VA:
secundar: 17 V
Pret: 15 lei.
https://imgur.com/LpOquzt
104. Contor electromagnetic, se alimenteaza la 24Vcc. Pret: 9 lei.
https://imgur.com/yroFVcx
105. Placa video PC 64Mb/32Mb AGP:
Pret: 5 lei.
https://imgur.com/1jlhw4D
https://imgur.com/cRwUd2Q
106. Set difuzoare 8 ohm/1-5W r.m.s Pret: 5 lei ambele.
https://imgur.com/eNnWMku
Au mai ramas:
 1. Tv Samsung UE32j4500AW, cu ecran spart, se da pentru piese:
Barete LED-uri: V5DN-320SMO-R4 Pret: 50 lei
Mainboard: BN41-02360 Pret: 70 lei.
https://imgur.com/a/iy4S5ZM
 2. Mainboard Vestel 17MB62-1. Pret: 40 lei
https://imgur.com/75Cf5hG
3. Barete Led D2GE-460SCA-R3 (7 buc)- 9 lei/buc.
https://imgur.com/3COXrCZ
 4. Placa Home cinema Sanyo DVM 2600, lipsesc finalii audio. Pret: 12 lei.
https://imgur.com/jvIgaER
 5. Placa recuperata dintrun sistem 5.1 Sony, cu c.i. CXD9750L. Pret: 12 lei.
https://imgur.com/Iq8MtGe
 6 . Modul amplificare cu BT8207. Pret: 7 lei.
https://imgur.com/3HafO6V
 8. Placa intrari mixer Behringer Pro-dx626. Pret: 9 lei.
https://imgur.com/NLH5rX1
 9. Cabluri Scart. Pret: 5 lei bucata.
https://imgur.com/RSGqalj
  10.Ventilatoare PC: 5 lei bucata randul de sus, 4 lei buc randul de jos.
https://imgur.com/0YAtUrk
 11.Diverse module la 2 lei bucata:
https://photos.app.goo.gl/4ZwVNyg2YRFC4AGB7
  12. Diverse module la 5 lei bucata:
https://photos.app.goo.gl/rzmyAWbhQn36H1m67
 13.Diverse module la 7 lei bucata:
https://photos.app.goo.gl/pFHD2JAmezcRK3kE7
 14.Diverse module la 15 lei bucata:
https://photos.app.goo.gl/9VEJGBSff82DdWhv7
  15. Set manere pentru aparat, aluminiu, dimensiuni: lungime 22cm, latime 6cm, grosime 0.7-
0.9cm. Pret: 18 lei.
https://imgur.com/nzuRB4w
  16. Set manere pentru transport, rabatabile, talpa aluminiu, manere din Cr, talpa 12x4cm,
maner 12x7.5cm.Pret: 25lei.
https://imgur.com/ye8f1Wh
17. Cablu S-video/S-video - 1metru. Pret: 3 lei.
https://imgur.com/KbIQU1z
 18. Cablu S-video/ RCA    - 1metru. Pret: 3 lei.
https://imgur.com/03yOcmO
 19. Amplificator 5.1 realizat cu DDX-2060. Pret: 12 lei.
https://imgur.com/XfoDk4w
 20. Difuzore recuperate dintrun tv Thomson, 8 ohm, dimensiuni 20x5,5x2,5 - 12 lei.
https://imgur.com/T5dnTZN
 21. Doua cuti metalice, provin din amplificatoare CATV, dimensiuni 23x18x3. Pret: 12 lei/buc.
https://imgur.com/OJBR2ls
https://imgur.com/amBBkGE
22. Motor pick-up sovietic. Pret: 5 lei.
https://imgur.com/IwYHfXA
23. Doua Ventilatoare Sunon Magleev. Pret: 5lei/buc.
https://imgur.com/wyfzO0P
 24. Memorii EEprom ceramice, 24 buc, 1 lei/buc sau 20 lei toate.
https://imgur.com/FC3ztDs
 25. Cabluri alimentare PC/ monitor etc (noi). Lungime: 1,8m. 5 bucati disponibile. Pret: 8 lei/buc.
https://imgur.com/wDYpNzg
  26. Cablu  DVI/ DVI (noi). 3 bucati disponibile. Lungime: 1,8m. Pret: 8 lei/buc.
https://imgur.com/D63veZ1
 27. Cablu adaptor HP display/ DVI (noi). Doua bucati disponibile. Pret: 12 lei/buc.
https://imgur.com/e5q2hGb
28. O pereche tranzistori Sanken 2SA1215/2SC2921. Pret: 35 lei perechea.
https://imgur.com/BVS2T4g
 29. Programator electronic cuptor microunde. Pret: 5 lei.
https://imgur.com/OrEZ6r2
 30. Set difuzoare 2 cai Blaupunkt GTx 542. Putere nominala: 30W, impedanta 4 ohm, diametru 13cm. Pret: 40 lei.
https://imgur.com/nKApLCx
https://imgur.com/RrQrWKl
31. Radiator Al: dimensiuni: 26,5cm x 24,5cm x 2,7cm. Talpa: 0,9 cm.Pret: 47 lei.
https://ibb.co/qRtKSmm
https://ibb.co/XpQWBC0
 32. Relee 24V. Pret: 4 lei/buc.
https://ibb.co/9yDfQHR
https://ibb.co/024x9mQ
33. Relee Wehrle 24V, 10/20 A. Pret: 8 lei toate.
https://ibb.co/bJ0Gbm5
34. Relee Wehrle 24V, 10/20 A. Pret: 8 lei toate.
37. Adaptor imprimanta Lexmark: 30V/ 400mA. Pret: 4 lei.
https://imgur.com/tuvGAWe
38. Simulator centura siguranta auto Cygnetic. Pret: 15 lei.
https://imgur.com/YGj4CIP
40. Transformator Atesc Tg Mures: 18VA, U- 24V. Pret: 10 lei.
https://imgur.com/lTbgsw1
41. Drosere Vassloh/Schwabe 18-28W. Pret: 5 lei/buc.
https://imgur.com/uLXZfAb
42. Radiatoare provenite dintro unitate Mac ProG5. Unul dintre radiatoare e putin dezcentrat, dupa cum se poate vedea in poze. Dimensiuni: talpa Cu 17x9 cm, grosime talpa 6+6 mm, inaltime radiator 13,5cm. Pret: 27 ambele.
https://imgur.com/Nfpvhkb
https://imgur.com/QVvXRdA
43. Condesator recuperat dintrun cuptor cu microunde: 0,91uF/2100V. Pret: 8 lei.
https://imgur.com/G4mP60t
43. Lot de placute, comenzi electronice aflate pe volane (BMW, Volvo, WV). Pret: 15 lei tot lotul.
https://imgur.com/At2XFGO
47. Module castetofon rusesc. Corector de ton realizat cu K157UD2A, amplificator si preamplificator. Pret: 15 lei toate.
https://imgur.com/YLRimxF
https://imgur.com/5rST3BQ
https://imgur.com/NEQ53Pn
https://imgur.com/lMhxadW
49. Motor Tesla CM150. Pret: 20 lei.
https://imgur.com/SbQRKpA
51. Docking Station HP2013. Se vinde ca defect. Fara cablu alimentare. Pret: 15 lei.
https://imgur.com/IOpGY8z
55. Placa afisaj DVD player. gratis.
https://imgur.com/onBND7s
56. Placa copiator Epson. Pret: 2lei.
https://imgur.com/iElP9dB
58. Placi scaner Konika-Minolta. Pret: 4 lei ambele.
https://imgur.com/1Ndo0Ag
60. Placa invertor 1000VA/32Vcc. Pret: 17 lei.
https://imgur.com/9REt98m
67. Modul inalta tensiune dintrun copiator canon. Pret: 15lei.
https://imgur.com/4usBMHS
https://imgur.com/NiIUhjC
69. Alarma auto Thor: Pret: 7lei.
https://imgur.com/OHJcIpK
70. Modul alarma auo EagleMaster. Pret: 12 lei.
https://imgur.com/aMvvwHu
71. Releu combina frigorifica General Electric. Pret: 5 lei.
https://imgur.com/JMBvxkT
75. TomTom Link. Pret: 5 lei.
https://imgur.com/KbF5eiF
76. Module imprimanta Epson, modul alimentare in comutatie+ partea de comanda a motoarelor pas-cu-pas, 2xLB1847, 2xSMA4033(sanken). Pret: 9 lei.
https://imgur.com/MFLhL9X
https://imgur.com/vHdVFWl
79. Lot diode redresoare SY202 Fairchild, 200V, 0.95 A. Pret: 5 lei tot lotul.
https://imgur.com/KtaQp9p
80. Surub M3, torx T15, cote in poza de mai jos. Pret: 5 lei/100g sau 100 buc- 5 lei. Disponibile 1 kg.
https://imgur.com/YQCFJHW
https://imgur.com/SzeQgRs
81. Surub M5, torx T25, cote in poza de mai jos. Pret: 2 lei/100g sau 100- 5 lei. Disponibile 3 kg.
https://imgur.com/aI3PzTU
https://imgur.com/COjoRV6
82. Surub M5 cu guler, torx T20, cote in poza de mai jos. Pret: 1,5 lei/ 100g sau 100 buc 12 lei. Disponibile 9 kg.
https://imgur.com/jATZ700
https://imgur.com/Wh2fXId
83. Surub pt plastic cu guler, torx T20, cote in poza de mai jos. Pret 2 lei/100g  sau 100 buc- 3 lei. Disponibile 23 kg.
https://imgur.com/G8eOpez
https://imgur.com/npSbWoC
84. Suruburi pt plastic, torx T8, cote in poza de mai jos. Pret: 1 leu /100g sau 250 buc- 1 leu. Disponibile 39 kg.
https://imgur.com/Kodbtx9
https://imgur.com/EnEQ6Xe
85. Arcuri, cote in poza de mai jos. Pret: 3 lei/ 100g. Disponibile 500g.
https://imgur.com/fXSwir7
https://imgur.com/QKfSNQm
91. Placa cu ~250 LED-uri recuperata dintru copiator. Pret: 9 lei.
https://imgur.com/9qmkSpR
-primar: 230V
Pret: 30 lei.
-primar: 230 V
Pret: 20 lei.
94. Difuzoare (doua) recuperate dintro plasma. Impedanta 8 ohm, putere 10 W. Dimensiunile difuzorului: 13cm x 4,5 cm. Pret: 10 lei.
95. Tuner JS-6H2/121. Pret: 3 lei.
https://imgur.com/a/YHeMJdZ
97. Amplituner Delia. Functional pe benzile UL, UM, si UUS. Pe US1 si US2 nu receptionez nimic. Are antena cadru exterioara. Nu are capacele inferior si superior.
Lipseste aparatoare de plastic a antenei de ferita. Claviaturile functionaza corect, amplificare in parametrii, fara distorsiuni. Pret: 70 lei.
98. Amplificator Delia. Functional pe benzile UL si UM. Pe UUS nu receptionez nimic, dar fosnetul specific benzii exista. Are decodor si pe banda vest. Pe US1 si
US2 nu receptionez nimic.  Claviaturile functioneaza corect. Amplificare fara distorsiuni,  fara fasait suparator. Frontal prezinta zgarieturi si lovituri dupa cum se poate vedea in poze. Pret: 70 lei.
secundar: 17 V
Pret: 15 lei.
Pret: 9 lei.
Pret: 5 lei.
Pot face rezarvari pana pe 8 ianuarie.
Trmit prin Posta Romana, ramburs sau cu plata in cont, Prioripost, sau Fancourier.
Vor mai urma si altele.
Editat de cmariuss
Va rog sa rezervati pentru mine:
43. Condensator recuperat dintrun cuptor cu microunde: 0,91uF/2100V. Pret: 8 lei.
80. Surub M3, torx T15, cote in poza de mai jos. Pret: 100 buc- 5 lei. - 1 lot de 100 buc.
81. Surub M5, torx T25, cote in poza de mai jos. Pret:  100- 5 lei. - 1 lot de 100 buc.
Pe masura ce veti mai pune si alte piese la vanzare, va voi comunica pe care le doresc sa le adaugati la lista.
Va multumesc!
  • 5 săptămâni mai târziu...
Se adauga:
107. Difuzoare auto BMW LPB-160, Impedanta: 4 ohm, diametru 160 mm. Se aud clar, membranele in stare f buna,
fara urma de imbatranire vizibila. Pret: 30 lei.
https://imgur.com/tuEtn66
108. Sursa pc RaidMax KY-600atx. Putere: 500 W. Testata. Am schimbat doi condensatori electrolitici umflati. Doua ventilatoare.
Conectori: 2 x SATA, 6 x Molex, 20+4pin placa de baza,4+4-pin CPU
Tensiuni/Curenti: 3.3V 28A, 5V 38A,12 V 22A, -5V 0.5A, -12V 0.8A, 5Vsb 2.0A.
Pret: 40 lei.
https://imgur.com/mREVaRu
https://imgur.com/Dbrcroi
109. Sursa PC Xilence XP-420. Putere: 420 W. Testata.
 Conectori: 20+4 Pin, 4 pin12V, 6 pin PCIe, 2x SATA,4x 4pin HDD.
Tensiuni/ Curenti: +3.3V 28A, +5V 27A, +12V1 13A, +12V2 14A, -12V 0.8A, +5Vsb 2.0A.
Pret: 40 lei.
https://imgur.com/FHYKZmO
https://imgur.com/VURePVH
110. Moduli dublu-tiristor URSS, MTT-63-10-4. Am 6 bucati. Cine ii ia pe toti ii dau si radiatorul gratuit, vezi pct 31.
Pret: 30 lei/buc.
https://imgur.com/WBa4zoU
111. Sursa SMPS SX03911-G realizat cu componente de calitate: Matsushita si Nippon Chemi-con. Tensiuni iesire:
12V, 5V.  Provine dintrun recorder hiprid Toho TRM-10C. Pret: . 15 lei.
https://imgur.com/vY4sVFK
https://imgur.com/L5YKaMG
112. Placute diverse recuperate din acelasi recorder hibrid Toho TRM-10C. Pret: 10 lei toate.
https://imgur.com/SF7zqkp
113. Filtru EMI Timonta FKSR 2-55-1/I, cu intrerupator si suport pentru sigurante fuzibile. Pret: 5 lei.
https://imgur.com/kyRaELN
https://imgur.com/ru6PQ6X
114. Placa pcb recuperata dintru bord Opel Astra, contine 50 LED-uri. Pret: 3 lei.
https://imgur.com/LCr7i2k
https://imgur.com/yGt5qw8
Editat de cmariuss
  • 3 săptămâni mai târziu...
Se adauga:
115: HDD 3,5" Hitachi 160GB, testat si instalat Windows7. Pret: 35 lei.
https://imgur.com/OdWCTHY
116: HDD 3,5" WD, 80 GB, testat. Pret: 25 lei.
https://imgur.com/HT5lJxe
117: 2 placute PCB, provin dezmembrarea unui dispozitiv de cuplare si decuplare a transformatoarelor de sudura. pret: 12 lei ambele.
https://imgur.com/ohHZ9Vp
https://imgur.com/8E8OwWk
118: Modul recperat dintro centrala termica Brahma cm-32. Pret: 7 lei.
https://imgur.com/0GDhlgc
119: Sasiu monitor LG Flatron L194WS-SF. Monitorul s-a dezmebrat din cauza ecranului spart. Pret: 15 lei.
https://imgur.com/LPp3EYE
https://imgur.com/kkjrPTE
https://imgur.com/w1bAdHV
120: Transformatoare (doua) avand sectiunea 2,4x4 cm. Secundar 1: 12 V, Secundar 2: 24 V, bobinat cu CuEm 0.8.
Pret: 9 lei buc.
https://imgur.com/LfUrvTI
121. Transformator avand sectiunea 2,8x4,2cm. Secundar 1: 12 V, Secundar 2: 92 V, bobinat cu CuEm 0.8. Se da impreuna cu stabilizatorul realizat cu TL783C (netestat). Pret: 30 lei.
https://imgur.com/lbkpCwU
https://imgur.com/PH1yrfh
https://imgur.com/qV200Lx
Editat de cmariuss
