cmariuss Postat Martie 19, 2020 Autor Partajează Postat Martie 19, 2020 Se adauga: 47. Radiator Al: dimensiuni: 26,5cm x 24,5cm x 2,7cm. Talpa: 0,9 cm.Pret: 60 lei. https://ibb.co/qRtKSmm https://ibb.co/XpQWBC0 48. Cateva module (interconectabile) Burkert recuperate dintru autobuz Neoplan: Pret: 4 lei/ buc, sau 15 lei toate. https://ibb.co/DMvrfYF https://ibb.co/sJbbnY3 https://ibb.co/Sfqwzym https://ibb.co/5T7J2C8 https://ibb.co/vhnccPg https://ibb.co/HYjDkx2 49. Relee 24V. Pret: 5 lei/buc. https://ibb.co/9yDfQHR https://ibb.co/024x9mQ 50. Relee Wehrle 24V, 10/20 A. Pret: 8 lei toate. https://ibb.co/bJ0Gbm5 50. Module diverse: Pret: 4 lei/buc. https://ibb.co/7KLdS24 https://ibb.co/5kPyB9j https://ibb.co/4s8Vsz1 51. Modul ECU Bosch ( autobuz Neoplan). Pret: 15 lei. https://ibb.co/X49LSQZ 52. Radiator cu doua punti redresoare Motorola BYW 66 (600V, 35A). Pret: 20 lei. https://ibb.co/Vx2zKqJ 53. Cooler+ ventilator Intel. Pret: 5 lei. https://ibb.co/SVQQzvZ 54. Punte redresoare RA 120. Pret: 12 lei. https://ibb.co/HYJw4Y1 55. Modul soft-start, recuperat dintru sistem 5.1 Philips. Pret: 7 lei. https://ibb.co/nBTkwRT 56. Stabilizator de tensiune cu uA723 (incomplet) + un tranzistor 2N3055. Pret: 5 lei. https://ibb.co/R6xgNMH 57. Amplificator mono 50W recuperat dintrun RIM Organist E, finali 2N3055, si BDX 18. Pret: 15 lei. https://ibb.co/b7VbNn6 https://ibb.co/wJvFs88 Link spre comentariu
cmariuss Postat Martie 24, 2020 Autor Partajează Postat Martie 24, 2020 S-au dat: 48, 52, 53, 54, 57. Restul disponibile. Link spre comentariu
cmariuss Postat Martie 29, 2020 Autor Partajează Postat Martie 29, 2020 Disponibile. Link spre comentariu
cmariuss Postat Aprilie 13, 2020 Autor Partajează Postat Aprilie 13, 2020 1. Tv Samsung UE32j4500AW, cu ecran spart, se da pentru piese: Barete LED-uri: V5DN-320SMO-R4 Pret: 50 lei Mainboard: BN41-02360 Pret: 70 lei. https://imgur.com/a/iy4S5ZM 2. Mainboard Vestel 17MB62-1. Pret: 30 lei https://imgur.com/75Cf5hG 3. Barete Led D2GE-460SCA-R3 (7 buc)- 9 lei/buc. https://imgur.com/3COXrCZ 4. Placa Home cinema Sanyo DVM 2600, lipsesc finalii audio. Pret: 10 lei. https://imgur.com/jvIgaER 5. Placa recuperata dintrun sistem 5.1 Sony, cu c.i. CXD9750L. Pret: 10 lei. https://imgur.com/Iq8MtGe 6 . Modul amplificare cu BT8207. Pret: 8 lei. https://imgur.com/3HafO6V 8. Placa intrari mixer Behringer Pro-dx626.Pret: 9 lei. https://imgur.com/NLH5rX1 9. Adaptoare. Pret: 5-15 lei. https://imgur.com/a/q7z377r 10. Sursa Videorecorder Panasonic HS950. Pret: 7 lei. https://imgur.com/Y7ZYKZK 11. Sursa Konika Minolta: tensiuni: 24V @5.5A, 5.2V @2A, 10V@ 0.1 A. Pret: 27 lei. https://photos.app.goo.gl/CocA7G6RH61mp16J7 https://imgur.com/NS4HxQl 12. Sursa Imprimanta Canon 24V @ 670mA Pret: 7 lei. https://photos.app.goo.gl/9JyRS8pswkpMGGJH9 https://imgur.com/U1lf6t4 13. Surse comutatie : 3.3V 1.5A, 5Vstab 0.3A, 5V 2.0A, 5.7V 1.2A, 12Vstab 0.7A, doua bucati. Pret: 5 lei/buc https://photos.app.goo.gl/hJ8jaMDpCUiuvFek8 16. Cabluri Scart .Pret: 5 lei bucata. https://imgur.com/RSGqalj 17.Ventilatoare PC: 7 lei bucata randul de sus, 4 lei buc randul de jos. https://imgur.com/0YAtUrk 18.Diverse module la 2 lei bucata: https://photos.app.goo.gl/4ZwVNyg2YRFC4AGB7 19. Diverse module la 5 lei bucata: https://photos.app.goo.gl/rzmyAWbhQn36H1m67 20.Diverse module la 7 lei bucata: https://photos.app.goo.gl/pFHD2JAmezcRK3kE7 21.Diverse module la 15 lei bucata: https://photos.app.goo.gl/9VEJGBSff82DdWhv7 22. Set manere pentru aparat, aluminiu, dimensiuni: lungime 22cm, latime 6cm, grosime 0.7- 0.9cm. Pret: 18 lei. https://imgur.com/nzuRB4w 23. Set manere pentru transport, rabatabile, talpa aluminiu, manere din Cr, talpa 12x4cm, maner 12x7.5cm.Pret: 25lei. https://imgur.com/ye8f1Wh 24. Cablu audio (High Resolution OFC audio Cable) RCA pentru amplificator auto+ fir remote,lungime 5m, mufe aurite. Pret: 18 lei. https://imgur.com/iyslwL9 25. Cablu S-video/S-video - 1metru. Pret: 3 lei. https://imgur.com/KbIQU1z 26. Cablu S-video/ RCA - 1metru. Pret: 3 lei. https://imgur.com/03yOcmO 27. Adaptor Verifone: 12V-2A. Pret: 10lei. https://imgur.com/6IunL6p 28. Adaptor Samsung 14V- 1.07A, si 14V 1.78A. Pret: 9 lei bucata. https://imgur.com/PVIjyGa https://imgur.com/jxojHnw 29. Amplificator 5.1 realizat cu DDX-2060. Pret: 12 lei. https://imgur.com/XfoDk4w 30. Difuzore recuperate dintrun tv Thomson, 8 ohm, dimensiuni 20x5,5x2,5 - 12 lei. https://imgur.com/T5dnTZN 32. Doua cuti metalice, provin din amplificatoare CATV, dimensiuni 23x18x3. Pret: 12 lei/buc. https://imgur.com/OJBR2ls https://imgur.com/amBBkGE 33. Doua motoare pick-up. Pret: 5 lei/buc. https://imgur.com/IwYHfXA https://imgur.com/ufmPZx0 34. Doua Ventilatoare Sunon Magleev. Pret: 5lei/buc. https://imgur.com/wyfzO0P 37. Memorii EEprom ceramice, 24 buc, 1.5 lei/buc sau 25 lei toate. https://imgur.com/FC3ztDs 38. Sursa PC Delux DLP-27C 500 W. Conectori: 1x 20+4 pin ATX 12V,1x 4+4 pin ATX 12V (CPU), 1x 6 pin PCI-Express (placa video), 3x SATA, 3x 4 pin Molex, 1x FDD,ventilator: 1x 120 mm. Pret: 35 lei. https://imgur.com/582MpJf 39. Sursa PC DeLux ATX-450-P4, ventilator 1x 80mm. Conectori:1 x 20+4 Pin ATX, 1 x ATX 4 Pin, 1 x FDD, 2 x Molex, 2 x SATA Pret: 25 lei. https://imgur.com/1z2xN3Z 40. Cabluri alimentare PC/ monitor etc (noi). Lungime: 1,8m. 5 bucati disponibile. Pret: 8 lei/buc. https://imgur.com/wDYpNzg 41. Cablu DVI/ DVI (noi). 3 bucati disponibile. Lungime: 1,8m. Pret: 8 lei/buc. https://imgur.com/D63veZ1 42. Cablu adaptor HP display/ DVI (noi). Doua bucati disponibile. Pret: 15 lei/buc. https://imgur.com/e5q2hGb 43. O pereche tranzistori Sanken 2SA1215/2SC2921. Pret: 35 lei perechea. https://imgur.com/BVS2T4g 44. Programator electronic cuptor microunde. Pret: 5 lei. https://imgur.com/OrEZ6r2 45. Ventilatoare recuperate din surse PC. Cele 3 ventilatoare SuperFan sunt practic noi. Pret: 7lei/buc. https://imgur.com/0K7QSsB 46. Set difuzoare 2 cai Blaupunkt GTx 542. Putere nominala: 30W, impedanta 4 ohm, diametru 13cm. Pret: 40 lei. https://imgur.com/nKApLCx https://imgur.com/RrQrWKl 47. Radiator Al: dimensiuni: 26,5cm x 24,5cm x 2,7cm. Talpa: 0,9 cm.Pret: 55 lei. https://ibb.co/qRtKSmm https://ibb.co/XpQWBC0 49. Relee 24V. Pret: 4 lei/buc. https://ibb.co/9yDfQHR https://ibb.co/024x9mQ 50. Relee Wehrle 24V, 10/20 A. Pret: 8 lei toate. https://ibb.co/bJ0Gbm5 50. Module diverse: Pret: 4 lei/buc. https://ibb.co/7KLdS24 https://ibb.co/5kPyB9j https://ibb.co/4s8Vsz1 51. Modul ECU Bosch ( autobuz Neoplan). Pret: 12 lei. https://ibb.co/X49LSQZ 55. Modul soft-start, recuperat dintru sistem 5.1 Philips. Pret: 7 lei. https://ibb.co/nBTkwRT 56. Stabilizator de tensiune cu uA723 (incomplet) + un tranzistor 2N3055. Pret: 5 lei. https://ibb.co/R6xgNMH Link spre comentariu
cmariuss Postat Aprilie 21, 2020 Autor Partajează Postat Aprilie 21, 2020 Disponibile Link spre comentariu
cmariuss Postat Aprilie 27, 2020 Autor Partajează Postat Aprilie 27, 2020 diponibile Link spre comentariu
cmariuss Postat Mai 4, 2020 Autor Partajează Postat Mai 4, 2020 20 % reducere la toate produsele. Link spre comentariu
mihaighe Postat Mai 20, 2020 Partajează Postat Mai 20, 2020 8. Amplificator CATV Techline, 47-630 MHZ, 25dB. Pret: 15 lei. https://imgur.com/6TTuaoX mai este valabil? Link spre comentariu
cmariuss Postat Mai 20, 2020 Autor Partajează Postat Mai 20, 2020 Nu mai este disponibil. Link spre comentariu
BUGHIU Postat Mai 27, 2020 Partajează Postat Mai 27, 2020 (editat) Acestea va rog sa-mi spuneti le mai aveti la vanzare : ''1. Tv Samsung UE32j4500AW, cu ecran spart, se da pentru piese: Barete LED-uri: V5DN-320SMO-R4 Pret: 50 lei Mainboard: BN41-02360 Pret: 70 lei. Eventual ,daca mai stiti ,codul panelului dvs spart ? Al meu este : CY-JJ032AGHVEV Editat Mai 27, 2020 de BUGHIU Link spre comentariu
cmariuss Postat Mai 29, 2020 Autor Partajează Postat Mai 29, 2020 Se adauga: 57. Radiator procesor. Dimensiuni: 125mm lungime, 82mm latime, talpa 12+ 6mm, aripioare 60 mm. Pret: 10lei. https://imgur.com/pgFmmYy 58. Tuner Alps, nu mai stiu de la ce aparat provin. Pret: 9lei. https://imgur.com/F9mX6BN 59. Adaptor imprimanta Lexmark: 30V/ 400mA. Pret: 4 lei. https://imgur.com/tuvGAWe 60. Simulator centura siguranta auto Cygnetic. Pret: 15 lei. https://imgur.com/YGj4CIP 61. Transformator TAM (provine dintro imprimanta matriciala). Pret: 15 lei. U1: 36V CuEm ~0,8mm U2: 9V CuEm ~0,5mm U3: 10V CuEm ~0,8mm https://imgur.com/J06ahWz 62. Transformator sovietic TC20-6L, 15V-0-15V/ 1A. Pret: 7 lei. https://imgur.com/DJScQcW 63. Transformator Atesc Tg Mures: 18VA, U- 24V. Pret: 10 lei. https://imgur.com/lTbgsw1 64. Drosere Vassloh/Schwabe 18-28W. Pret: 5 lei/buc. https://imgur.com/uLXZfAb Link spre comentariu
Zoltanh Postat Mai 29, 2020 Partajează Postat Mai 29, 2020 Am urmatoarea lista: -poz 11 Sursa Konika Minolta: tensiuni: 24V @5.5A, 5.2V @2A, 10V@ 0.1 A - 27Ron -poz 12 Sursa Imprimanta Canon 24V @ 670mA - 7Ron -poz 13 Surse comutatie : 3.3V 1.5A, 5Vstab 0.3A, 5V 2.0A, 5.7V 1.2A, 12Vstab 0.7A, doua bucati - amandoua 2x5Ron/buc - 10Ron -poz 27 Adaptor Verifone - 10Ron -poz 38 Sursa PC Delux DLP-27C 500 W. Conectori: 1x 20+4 pin ATX 12V,1x 4+4 pin ATX 12V (CPU), 1x 6 pin PCI-Express (placa video), 3x SATA, 3x 4 pin Molex, 1x FDD,ventilator: 1x 120 mm.- 35 Ron -poz 45 Ventilatoare recuperate din surse PC. Cele 3 ventilatoare SuperFan sunt practic noi - toate 7, 7X5Ron/buc - 35Ron Toatal 124Ron, ofer 120 Ron plus transport. Va rog sa-mi confirmati si sa-mi spuneti cum procedam. Multumesc. Link spre comentariu
