Electronice diverse
cmariuss
Lista actualizata cu rezervarile:
@caragea punctul 205 a fost rezervat de okean mai devreme.
@leo177
541. Relee auto 7 bucati 12V/20A -10 lei.
542. Relee auto 8bucati 12V 40-60A - 15 lei.
533.Relee auto 20/40A si 70A -9 lei.
242 Vana gas Imergas - 3lei
445. Siguranta pentru amplificatoare auto MNC- 3 lei.
580. Modul alarma auto TP-1000PW 6 lei.
41. Drosere Vassloh/Schwabe 18-28W, sarma fi 0.30mm, 3 buc -15 lei.
594. Set 12 relee auto -15lei.
@sloop
 b) AMD K6/300AFR. Pret: 5 lei.
c) AMD K^/400AFR. Pret: 5 lei.
https://postimg.cc/SnzwQmhm
d) Pentium II. Pret: 5 lei.
https://postimg.cc/62BShRGQ
https://postimg.cc/SJHvvHz3
https://postimg.cc/BjDV9NT6
@electronistu89
 659. Placi de comanda recuperate din convertizoare de frecventa KEB: pret:
15lei.
https://imgur.com/ziusDUS
https://imgur.com/bN7YcYC
https://imgur.com/Pq8gwuQ
@sonic11
631. Transformator tv Sport 251, 30W secundar 17V. Pret: 17 lei.
https://imgur.com/vcghGtH
 649. Amplificator magnetofon Uvertura stereo (Unitra), finali BD354B.
Pret: 15 lei.
https://imgur.com/X2g0LVC
https://imgur.com/3UAhK03
 650. 2 tranzistori KT802A cu radiatoare. Pret: 10 lei.
https://imgur.com/R2AtWCG
https://imgur.com/Uy2xP3R
@hamatdumitru
 638.Punte de diode pentru Dacia, realizata cu 6 buc RA220
Pret: 9 lei.
https://imgur.com/NvIXzUC
@giliman66
489. Modul centrala termica Brahma -12 lei
 620. Placa recuperata dintro cafetiera. Pret: 6 lei.
https://imgur.com/1pI37IY
621. Pompa cafetiera OP01, 230V 49W. 2 min functionare/ 1 min repaus. Se
conecteaza cu furtune de 1/8". Pret: 8 lei.
https://imgur.com/JPG60Va
622. Sistem demontat dintro cafetiera format dintro electrovalva 230V 13.5VA.
Tmax- 120*C, P 0.1-3.5 bar, prsostat XP110, 2-6 bar, conectate intre ele cu un T
de 1/8". Pret: 12 lei.
https://imgur.com/vLp1KwQ
 625. Modem Compal CH7465UF codat pentru reteaua Vodofone, pentru
recuperare piese si carcase. Pret: 7 lei.
https://imgur.com/LSVB7BX
 @floop
502. Adaptor imprimanta Delta 30V/0.83A - 8 lei
540. Transformator cablaj 5VA/12V -8lei.
405. Bara dreptungiulara de aluminiu.
Dimesiune: 5.0cm x 2.5cm, si lungime de 43cm.
Greutate: 1.35 Kg. Pret: 25 lei.
https://postimg.cc/XZ56cBzr
https://postimg.cc/Hc4GFDHH
  @hixpp02
 608. Din dezmembrarea unui cd-player Denon DCD-590, cu transportul defect:
a) placa fara transformator !!!.CXA1372S, CXD2500AO,M5290P,RC4558P
(3buc),PCM61P (2buc),SM5841BP, CA5700C.
https://imgur.com/eIY21BI
https://imgur.com/ad5xEgR
https://imgur.com/Mx1XGpa
 b) Placa display Pret: 5 lei.
https://imgur.com/9hgImfO
 C) picioruse (4), diam 60 mm, inaltime 17.5 mm.
https://imgur.com/m0vfKwQ
Pret: 25 lei toate.
@okean
159. Mecanica deck Harman&Kardon CD91C, se vinde pentru piese. Pret: 9 lei.
https://imgur.com/HoHbwCJ
https://imgur.com/JfG2Kpo
204. Tuner amplituner siemens rs555, integrate LA1231, uPC1161C. Pret: 7 lei.
https://imgur.com/Ve20X5G
205. Placa amplificator phono, realizat cu LA3133. Pret: 7 lei.
https://imgur.com/AFD9gw9
209. Placa cu TCA440N. Pret: 3 lei.
https://imgur.com/w1jjZAm
206. Placa tuner sony gx511, integrate: LC7218, LA1851N, LA1235, RC4558P,
SAA6579T. Pret: Pret: 9 lei.
https://imgur.com/TeDldzw
https://imgur.com/QMc48vw
203. Mainboard amplituner Siemens  RS555. Pret: 8 lei
https://postimg.cc/VJGw0jNZ
https://postimg.cc/D4T336C0
https://postimg.cc/QKJG87Pb
198. Placa frontala cu display Sony GX511. Pret: 9 lei.
https://imgur.com/wh8Dlqe
200. Placa cu claviatura, amplituner Siemens RS555. Pret: 3 lei.
https://imgur.com/nvbTMN0
Se adauga:
674. Transformatoare Contactoare-Buzau, 63VA:
Secundar: 24 V.
Pret: 30 lei.
https://postimg.cc/47jChZ6S
https://postimg.cc/F1JXXdm5
https://postimg.cc/pmRwjsjR
675. Transformator de cablaj Thermowatt 20VA:
Sec 1: 24 V
Sec 2: 15 V (max 50mA)
Pret: 12 lei.
https://postimg.cc/w12SQD5J
676. Transformator 7VA
Secundar: 7V-0-7V
Pret: 8 lei.
https://postimg.cc/KRPX46R0
OK, nu am vazut ca era pus de colegul, am crezut ca dv. le-ati adaugat. Eram pe telefon in deplasare, n-a fost intentia mea sa ma bag peste, scuze!
Va rog puneti deoparte pt. mine 674 si 676
  • 3 săptămâni mai târziu...
Se adauga:
676. Kit placa baza socket 7 Elpina MB-586TX
130MB RAM, procesor Cyrix MII-233, 66MHz (cablu ventilatorului e taiat), placa
video S3Trio64+,2MB; placa audio AudioExcel AV511. L-am pornit asa cum se vede
in poze, mai multe n-am testat. Dau si sursa la nevoie, (are si capac).
Pret: 70 lei cu tot cu sursa.
https://postimg.cc/gnkWzjq6
https://postimg.cc/xX4FSTtY
https://postimg.cc/18tYTN0J
https://postimg.cc/WFRWhWBH
https://postimg.cc/CBjvDCYL
677. Un tv OLT 214B dezmembrat, functiona acum 15 ani cand l-am urcat in pod. Ce
se vede in poze.
Pret: 25 lei
https://postimg.cc/YLK5Bq2j
https://postimg.cc/JHN9rVtx
https://postimg.cc/4npCbtwc
https://postimg.cc/YhxJTH5q
https://postimg.cc/tsS8CzRK
https://postimg.cc/yJDtJSkk
https://postimg.cc/BLDzp953
https://postimg.cc/dZYxSHny
https://postimg.cc/sG4NFY00
https://postimg.cc/rdW6nrc7
https://postimg.cc/18bhrHxp
678. Set difuzoare TV 10W, 16 ohm , 12.5x5.5cm.
Pret: 12 lei.
https://postimg.cc/zLPN6rRR
679. Difuzor 5W, 16 ohm, 8.8x4.8cm.
Pret: 5 lei.
https://postimg.cc/xJw2j35f
680. Doua placute recuperate dintro centrala Ariston.
Pret: 8 lei.
https://postimg.cc/9RR2jnGg
https://postimg.cc/HVCgf3j3
681. Filtru EMI 250V 15A.
Pret: 7 lei.
https://postimg.cc/21rCBTD3
682. Transformator 20VA
Secundar 9,5V , 1.5A.
Pret: 12 lei.
https://postimg.cc/t1gyBT7j
683. Placuta transformator 30V 0,8VA, releu reed, 4xBC547B.
Pret: 9 lei.
https://postimg.cc/Mn5q0R65
684. Droser 6mH, 11 A, sarma 2mm.
Pret: 18 lei.
https://postimg.cc/bG6YPn4r
https://postimg.cc/WtqpRh8p
Se adauga:
685. Transformator sistem 5.1
Secundar 1: 12.5V-0-12.5V @3A
Secundar 2: 10.5V @ 0.500 A
Pret: 20 lei.
https://postimg.cc/8s1z9Mmz
686. Transformator incapsulat in rasina 20 VA
Secundar: 7.5 V cu priza la 5V
Pret: 13 lei.
https://postimg.cc/svxDDz8F
687.Transformator 3VA cu punte redresoare
Secundar: 3.5V @ 800mA
Pret: 6 lei.
https://postimg.cc/6456Zxpv
688. Disjuncoare 20A curba C, NOI, 8 buc.
Pret: 7 lei/buc.
https://postimg.cc/tZb4Xx0D
689. Doua Radiatoare aluminiu.
Pret: 3 lei.
https://postimg.cc/qzFBNYVN
690. Placuta amplificator recuperata dintru radiocasetofon auto. Finali
CD7377CD. Pret: 8 lei.
https://postimg.cc/ThC361tq
Va multumesc si eu.
Se adauga:
691. Pcb recuperat dintrun aparat medical; 7805, 3 IC cosmo 3023, 3tiristori BTA12-600B.
https://postimg.cc/YLpCP8bP
Pret: 7 lei.
692. Radiatoare aluminiu:
Pret: 4 lei buc.
https://postimg.cc/TyLGNBG1
https://postimg.cc/8sDcsPNb
https://postimg.cc/vcZmLq1g
693. Adaptor imprimanta hp -20W. +32V @583mA, +15V @533mA.
Pret: 12 lei.
https://postimg.cc/1gqXV88v
694. Sursa SMPS Braytron 25W, 12V @2A.
Pret: 17 lei.
https://postimg.cc/5Y5tpDqv
695. Din dezmembrarea unei combine Panasonic SA-CH64M
a) mecanica cu autoreverse. Pret: 12 lei.
https://postimg.cc/Lg6mD5sK
https://postimg.cc/HjpWdZ9Z
b) display VFD. Pret: 9 lei.
https://postimg.cc/bDRz1kp9
C) placa preamplificator, 5218A (mitsubishi), BH3854AF5, Bu4058CF,
BU2090F.Pret:5 lei.
https://postimg.cc/K4NzTSYh
https://postimg.cc/mtpgdYMd
d) antena AM. Pret: 5lei.
https://postimg.cc/KkhzPmLx
Rezervari fac pentru max 4 saptamani. Pentru clienti noi maxim 10 zile. S-au adunat
lucruri rezervate din februarie.
Se adauga:
696. Afisaj cu matrice LED multicolore (joc pacanele).Fabricat in Ungaria.
 PIC16F873A, GAL16VBD, 24LC64, MAx323N integrate din seria ULN, CD.
Dimensiuni afisaj: lungime 36 cm, latime 6 cm.
https://postimg.cc/BLTHXqLB
https://postimg.cc/yJSYfkv7
https://imgur.com/qnePyXp
https://imgur.com/zpuvWvw
https://imgur.com/XkP1QC4
Pret: 40 lei.
697. Adaptor 12V/5A. Pret: 15 lei.
https://postimg.cc/7fV9KNLn
https://postimg.cc/3W2nvh56
698. Autotransformator 500W. Produs in Belgia. Silentios.
Tensiuni: 0-100V-110V-220V.
Pret: 45 lei.
https://postimg.cc/dhGsMDz6
https://postimg.cc/Lh72nzSv
699. Transformator 70W. Secundar 24V. Pret: 30 lei.
https://postimg.cc/kB6McTsk
https://postimg.cc/TyGRTfx6
700. Transformator de inalta tensiune demontat dintrun arzator industrial Lamborghini
Coloreclima. Produce arc electric la o distanta de 20mm intre electrozi. Pret: 60 lei
https://postimg.cc/4nFNVD66
https://postimg.cc/3ktLxZ5x
https://postimg.cc/87pKG0YY
701.  Din dezmembrarea unui cuptor cu microunde
magntron - 18 lei
ventilator - 15 lei
condesator 0,90uF/ 2100V - 12 lei
https://postimg.cc/gallery/DyKrpV4/f97f7d72
Rog eu:
Pret: 40 lei.
