Electronice diverse
cmariuss
Au mai ramas:
1. Tv Samsung UE32j4500AW, cu ecran spart, se da pentru piese:
Barete LED-uri: V5DN-320SMO-R4 Pret: 18 lei
3. Barete Led D2GE-460SCA-R3 (3 buc)- 4 lei/buc.
https://imgur.com/3COXrCZ
20. Difuzoare recuperate dintrun tv Thomson, 8 ohm, dimensiuni 20x5,5x2,5
- 4 lei.
https://imgur.com/T5dnTZN
 41. Drosere Vassloh/Schwabe 18-28W. Pret: 5 lei/buc.
https://imgur.com/uLXZfAb
67. Modul inalta tensiune dintrun copiator canon. Pret: 9 lei.
https://imgur.com/4usBMHS
https://imgur.com/NiIUhjC
 115: HDD 3,5" Hitachi 160GB, testat si instalat Windows7. Pret: 15 lei.
https://imgur.com/OdWCTHY
116: HDD 3,5" WD, 80 GB, testat. Pret: 10 lei.
https://imgur.com/HT5lJxe
217. Sursa tv Dong-Yang BN96-02580A Pret: 18 lei.
https://imgur.com/tZRWUn0
Suruburi:
453.Surub M10 brunat, grupa 8.8, cu lungimea 30mm. Pret: 0,30 lei/buc.
https://imgur.com/zari9xb
82. Surub M5 cu guler, torx T20, cote in poza de mai jos. Pret: 0.30 lei/ 100g
sau 100 buc- 2.5 lei. Disponibile 1 kg.
https://imgur.com/jATZ700
https://imgur.com/Wh2fXId
83. Surub pt plastic cu guler, torx T20, cote in poza de mai jos. Pret 0.5
lei/100g  sau 100 buc- 1 lei. Disponibile 5 kg.
https://imgur.com/G8eOpez
https://imgur.com/npSbWoC
84. Suruburi pt plastic, torx T8, cote in poza de mai jos. Pret: 1500 buc-  1
leu.
Disponibile 10 kg.
https://imgur.com/Kodbtx9
https://imgur.com/EnEQ6Xe
85. Arcuri, cote in poza de mai jos. Pret: 2,5 lei/ 100g. Disponibile 100 g.
https://imgur.com/fXSwir7
https://imgur.com/QKfSNQm
 227. Sursa Plisch FMS-100 (recuperata dintrun aparat de masura/analiza semnal
TV)
Uin: 195- 265V, 47-63Hz, Putere = 250VA
Tensiuni: 5V, 7,5V, -5V, -12V, 24V
Realizata cu componente de calitate: Philips, Siemens, Motorola,Wima etc.
Sursa a fost reparata o data in 2003 de Antena Hungaria Kft.
Pret: 57 lei.
https://imgur.com/J1LNTxB
https://imgur.com/IPB11HQ
https://imgur.com/oFZz2l9
https://imgur.com/x5b415j
https://imgur.com/8XaEBLF
https://imgur.com/yMpTrKt
https://imgur.com/2uJ8xU0
https://imgur.com/n8O62DK
https://imgur.com/fqdWvLC
https://imgur.com/QBbTVui
https://imgur.com/Jqpfgcc
https://imgur.com/lDjYxh7
246. Adaptoare Nokia ACP-12E, nefolosite.
5,7 V, 800 mA. Cablu ~ 1.8 m. Disponibile 2 bucati. Pret: 4 lei/buc.
https://imgur.com/WWHA3E3
254. Set difuzoare Viefu 30041403 (recuperate dintro plasma Vortex), 8 ohm, 12
W. Pret: 4 lei.
https://imgur.com/k5ZW4Ot
 255. Set difuzoare OHC 300772s1, 8 ohm, 5W. Pret:4 lei.
https://imgur.com/KZkRhK1
https://imgur.com/xxerTCC
264. Contoare electromagnetice SI-47. Doua bucati. Pret: 5 lei/buc.
https://imgur.com/qTMsp21
268. Micro filtru DSL HWMF-140. Nou. Pret: 4 lei.
https://imgur.com/iSX4t3y
276. Temporizator mecanic cuptor cu microunde: durata temp 30 min, contactele
suporta 16A. Pret: 5 lei.
https://imgur.com/oy1OyAI
283. Sarma nichelina NiCr Nikrothal 80.
Diametru 0.2 mm, rezistenta 35,80 ohm/m, temperatura max de lucru 1200*C,
conductibilitate termica/100°C Wm-1C-1-15,0
Pret: 0.20 lei/metru liniar.
https://postimg.cc/k6Bfxn4r
https://postimg.cc/KKQHPqDT
284. Transformator 30VA:
S1: 9V
S2: 24V
Pret: 13 lei.
https://postimg.cc/5X9Xxvtq
286. Releu Sigma cu soclu. Pret: 12 lei.
https://postimg.cc/23BvJ4q1
https://postimg.cc/Sntxkv3k
287. Releu Schrack ZG z60 720. Pret: 9 lei.
https://postimg.cc/xcvmjn3Y
https://postimg.cc/NyJmhD7H
288. Releu combina frigorifica General Electric. Pret: 4 lei
https://postimg.cc/PvZwwjGW
324. Din dezmembrarea unui LED tv, Blaupunkt BN32H1032eeb, urmatoarele:
324b. Set 2 barete LED, HL-00320A30-0601S-07A3.Pret: 10 lei.
https://postimg.cc/tnW9kw6D
https://postimg.cc/ZB1Tr4WC
324d. Set picioruse. Pret: 5 lei.
https://postimg.cc/yWcKMqJy
328. Releu Matsushita jh1a-ac220v
Bobina: 220Vac
Contact: 30A
Pret: 10 lei.
https://postimg.cc/9Rv60Mch
333. Componente din dezmembrarea unui tv Fujitsu Siemens Myrica VQ40-1. Toate
componentele find in stare de functionare, problema tv-ului era sursa.
333a. Placa de baza Conrac + tuner Philips. Pret: 8 lei.
https://postimg.cc/ctYZQ8vS
https://postimg.cc/6759D3mr
https://postimg.cc/0MybdZvq
https://postimg.cc/CR0MsJC6
340. HDD Western Digital 160GB (WDdata lifeguard diagnostic).Pret: 12 lei
https://postimg.cc/62vXYs5G
341. HDD Seagate Barracuda 80GB (testat cu Data LifeGuard Diagnostics). 2 bucati
Pret: 8 lei buc
https://postimg.cc/K18hC38b
https://postimg.cc/k2YPCM2b
362. Ventilatoare Nidec Betav. Doua bucati C32957-58, 12V- 0,29A. Una bucata
C34637-58, 12V- 0,13A. Pret: 7 lei toate.
https://imgur.com/mFUdq3h
 385. Alarma auto Thunder
Pret: 14 lei.
https://postimg.cc/w3c3xtkV
https://postimg.cc/kR9rhg6M
 389. Alarma auto. Pret: 9 lei.
https://postimg.cc/G4pD1GMM
393.  Placa de baza si modul comunicatie imprimanta Epson EU-96. Pret: 3 lei.
https://postimg.cc/HJy4fbxq
https://postimg.cc/R3kJf8v8
395. Convertor Scart-RCA/S-video. Pret: 5 lei.
https://postimg.cc/Hj73qDJJ
396. Alarma auto KD500. Pret: 12 lei.
https://postimg.cc/75w1CMHB
https://postimg.cc/LgPkPxgW
 405. Bara dreptungiulara de aluminiu. Dimesiune: 5.0cm x 2.5cm, si lungime de
43cm.
Greutate: 1.35 Kg. Pret: 25 lei.
https://postimg.cc/XZ56cBzr
https://postimg.cc/Hc4GFDHH
412. Sursa in comutatie NYKO:
Sec1: 24Vcc
Sec2: 8Vcc
Pret: 9 lei.
https://imgur.com/3B6gASl
 423. Sursa SMPS 2405
Intrare: 24Vca-90Vca (galben-rosu)
Iesire:  24Vcc 550ma (negru-rosu)
Pret: 10 lei.
https://imgur.com/gilI2Ny
https://imgur.com/l74NtE6
426. Lampa 12V/4W (soclu baioneta), corp alama, capac crom. Se poate utiliza
pentru iluminarea scalei la radio, iluminarea vu-metrelor cu ace, etc Pot face
rost de mai multe. Pret: 8 lei/buc
https://imgur.com/H4oPeLO
https://imgur.com/FgNGxDi
https://imgur.com/AaweLfD
427. Sticla scala radio pe lampi Minerva Cornette.
https://imgur.com/a6MKoiM
https://imgur.com/AstVy7F
Pret: 25 lei.
429. Rezistenta 650W incalzire cafetiera, cu termostat.
https://imgur.com/2iCunrD
Pret: 5 lei.
 430. Sine trenulet modelism:
- sectiuni curbe 9-bucati
- sectiuni drepte 3 bucati
- ecartament 30mm
- diatru exterir - 88 cm
- diametru interior - 68 cm
Pret: 8 lei.
https://imgur.com/xVpl4aA
https://imgur.com/BvW9Ics
432. Sursa Tv Sharp CA0009WJN1
Tensiuni masurate: 9V, 12V
Pret: 15 lei.
https://imgur.com/ZTxFUuU
 434. Casti telefonice:
Primo -CT-3B, productie Japonia, 6 bucati.
Impedanta: 780 ohm.
Pret: 2 lei.
https://imgur.com/0hmpJFJ
435. Casti telefonice:
Primo DH-51, productie Japonia, 4 bucati.
Impendanta: 290 ohm.
Pret: 2lei.
https://imgur.com/hO1mFIJ
436. Tablite cupru cu grosimea de 0,5mm. Cu urmatoarele dimensiuni:
a)  35 x 5 cm. Pret: 8 lei.
https://imgur.com/Zu0Gzq8
c)  16 x 11 cm Pret: 6 lei.
https://imgur.com/KSj4P3C
d)  16 x 14 cm. Pret: 8 lei.
https://imgur.com/cWwzRNZ
e)  16 x 10 cm. Pret: 7 lei.
https://imgur.com/LP4tiwe
f)  20,5 x 10 cm. Pret: 10 lei.
https://imgur.com/GQOWsBy
g)  16 x 9 cm. Pret: 7 lei.
https://imgur.com/Xd20iS4
h) 16 x 10 cm Pret: 7 lei.
https://imgur.com/tFOO6qz
i)17 x 15 cm forma eliptica. Pret: 8 lei.
https://imgur.com/EZFmfhu
j)  24 x 8/11.5 cm patrulater. Pret: 8 lei.
https://imgur.com/1O3uosh
439. Releu RP-102-3P
Ua= 24Vcc, R= 346 ohm
Contacte: 2x3, fara soclu.
Pret: 15 lei.
https://imgur.com/NKClW8K
https://imgur.com/bGrPZ5h
https://imgur.com/v3APLRq
440. Relee (doua) RP 92
Ua = 220Vca, R= 4410 ohm
Contacte: 2x3, cu socluri.
Pret: 15 lei/buc.
https://imgur.com/kXEgFs1
https://imgur.com/ijfgFLZ
https://imgur.com/1ExxIPf
https://imgur.com/FB6vJtb
https://imgur.com/aB8Gj6g
441. Acumulator Li-Ion pentru laptop, model: 8560, nou. Tensiune: 11.1V,
7800mAh, 87Wh. Pret: 50 lei.
https://imgur.com/RWpiKNZ
https://imgur.com/0Lw48gf
447. Adaptor telefon (pentru priza UK)
4,5V-5,5 V, 500mA . Pret: 2 lei.
https://imgur.com/8FZVIdS
448. Modul alarma auto SPAL AS-90. Pret: 8 lei.
https://imgur.com/O06QcqL
https://imgur.com/Fl2flAH
452. Relee industriale RP-92, 2 x 3 contacte.
Tensiune de alimentare: 42V 50Hz, 220 Ohm, cu socluri, doua bucati.
Pret: 15 lei/buc.
https://imgur.com/fy5qwJ6
https://imgur.com/fDEM118
454. Adaptor pentru laptop Dell,nou, inlocuitor, model LD-065/334/195/011, mufa
7,4x5.0 well
19,5V 3,34A 65W Pret: 55 lei.
https://imgur.com/Nz312Pf
https://imgur.com/5YuPfy3
https://imgur.com/KhqCJVh
https://imgur.com/u9jj1SR
456. Adaptor nou, inlocuitor pentru laptop Lenovo ND-A065W2002250,pentru
ideapad 100 / ideapad 110 / 310 / Yoga 510 / B50 / AIR12 AIR13 AIR15. Conector:
4.0x1,7mm.
20V 2,25A 45W. Pret: 50lei.
https://imgur.com/nSQ5Jkf
https://imgur.com/Ge7UTMH
https://imgur.com/h345Zb9
https://imgur.com/2QFTySW
https://imgur.com/DwGbNSR
 467. Memorii PC DDR2 -512MB. Pret: 2 lei/buc.
https://imgur.com/3m300N6
https://imgur.com/j695ShP
https://imgur.com/oV6c79v
469. Memorii PC DDR2 - 1GB. Pret: 5 lei/buc.
https://imgur.com/WtKXRBp
470. Led driver 100W, tensiune 27-36V, 3000mA. IP65. Pret: 32 lei.
https://imgur.com/SLMKrVZ
472. Telecomanda Siemens-Fujitsu. Pentru TV LCD Fujitsu Siemens Myrica VQ40-
1.Pret: 5 lei.
https://imgur.com/grYYsWS
 474.Placa controler electronic pentru pompe de caldura. Mai are in componenta
untransformator 10W, 12V 0.600A, un releu bipolar cu bobina 230V, contacte 35A,
un
senzor de temperatura, un conensator 4uF/450V, cabluri aferente. Din pacate ii
lipseste displayul.
Mai multe informati pe situl producatorului, cu google translate
http://gzjsdz.com/KS1.htm
Pret: 18 lei.
https://imgur.com/lg1bfYR
https://imgur.com/VuI6JGe
https://imgur.com/Y0tzqsy
https://imgur.com/Ra80Wdv
https://imgur.com/DGScxqA
477. Lupa convergenta,menisc convergent,diametru 100mm, grosime 30mm, distanta
focala 10 cm, putin ciobita la margine, in mod normal nu afecteaza cu nimic.
Pret: 13 lei.
https://imgur.com/zLtM30B
https://imgur.com/MSohlEZ
481. Releu Relog 24V, IP40, 4perechi de contacte.Pret: 12lei.
https://postimg.cc/2LqCQqXB
https://postimg.cc/3WWr56JJ
482.Jetoniera Comestro RM5evolution, pentru aparate de cafea, sau pentru alte
aplicatii. Caracteristici:
    Viteza de acceptare: 3 monede/secunda
    Diametru monede acceptate: 16 ÷ 31.5
    Grosime monede acceptate: pana la 3,3 mm
    Dimensiuni ( LxHx W): 89 x 102 x 46,4
    Greutate: 185 g
    Temperatura operare: 0 °C ÷ 55 °C
    3 perechi de senzori inductivi care sunt folositi pentru a procesa 6
parametrii diferiti in ceea ce priveste materialele si masa
    3 perechi de senzori optici  pentru a determina diametrul monedelor
    Dispozitiv mecanic anti-phishing
    Dispozitiv electronic anti-phishing
    Sistem automat de compensare a senzorilor optici pentru varia?ii de
temperatura, tensiune ?i iluminat.
https://postimg.cc/PpVtvbKj
Pret: 10 lei.
486. Sursa in comutatie
Ue= 12V - 3A
Pret: 9 lei.
https://imgur.com/uL1ZVwA
 488. Adaptor Philips 7W 13V- 400mA, cablu are lungime 2.5m. Pret: 10 lei.
https://imgur.com/fjaQP1k
https://imgur.com/cO86KTm
491. Tastatura laptop Chicony mp-10h96f06886, folosita, netestata. Pret: 5lei.
https://imgur.com/oj0zbeC
https://imgur.com/JT5DQeW
492. Tastatura laptop NSK-DV0BC 1D pentru Dell Latitude E6420 US, folosita,
https://imgur.com/O8eLzGZ
https://imgur.com/lmnzt3x
496. Adaptor AllView Tx1 Quasar, 5V- 2000mA. Pret: 10 lei.
https://imgur.com/6AbBC8S
498. Placa baza Asrock G31-M7 TE, se da cu doua memorii Ram DDR2 1GB,
Procesor Intel DualCore 3.0 GHz. Pret: 45 lei.
https://imgur.com/2HaOGK4
https://imgur.com/fPKn8ii
  488. Adaptor Philips 7W 13V- 400mA, cablu are lungime 2.5m. Pret: 9 lei.
 499. Actuatoare automatizare porti Hanning  K88-136. Doua bucati. Unul dintre
el nu are carcasa completa !
Alimentare: 220V-240Vca, 50Hz, 1,2A
Putere: 250W
Cursa maxima: 20cm
Comanda pneumatica
Pret: 65 lei ambele.
https:/imgur.com/2Djilhl
https://imgur.com/kuRfJ4H
https://imgur.com/iE0s4aO
https://imgur.com/hyPKYxx
https://imgur.com/vFWY6sr
https://imgur.com/YpLhOyU
https://imgur.com/7dUEVmF
https://imgur.com/b4ZdPoC
https://imgur.com/OYh66Dy
 501. Rezistenta incalzire acvarii. Resunn rh-9000. Putere. 75W. temperatura
reglabila intre 21 si 32*C.
Pret: 18 lei.
https://imgur.com/vaZ7EIE
https://imgur.com/WRs77ZS
https://imgur.com/uLHHGjZ
503. Placa imprimanta Lexmark z55
Pret: 2 lei.
https://imgur.com/zLrVzY2
505. Modul control, iluminare si ventilator recuperat dintro cab de dus.
Tranzistoarele sunt 2SA8050, relee se alimentaza la 12V.
Pret: 5 lei.
https://imgur.com/ZZ7QIoS
https://imgur.com/2YjP7nU
https://imgur.com/1zkeeHR
506. Lupa biconcava simetrica. Diametru: 10cm, grosime max 2cm, grosime minima
0.5cm. Are cateva mici ciobituri pe margine. Pret: 12 lei.
https://imgur.com/okQ3Gtb
507. HDD Seagate 80GB PC interfata S-ata, are instalat windows XP
Pret: 8 lei
https://imgur.com/MptLAFn
508. HDD Seagate 80GB PC, interfata S-ata, fara OS.
Pret: 8 lei.
https://imgur.com/lsa5lbI
 509. Din dezmembrarea unui magnetofon Rostov 105, urmatoarele componente
mecanice. Nu au urme de oxidare, rugina sau deformari mecanice (nu mai am alte
componente din mag).
a) sasiu
https://imgur.com/GZuOb4d
b) Panouri laterale
https://imgur.com/8M2loT9
c) Capacele spate
https://imgur.com/RQOcwrb
https://imgur.com/isPKLp8
Pret: 18 lei toate.
510: Memorii laptop:
1) Memorie laptop 64MB, PC100,133MHz, SDRAM- Pret: 3 lei.
2) Memorie laptop 512MB, PC133, 133MHz, SDRAM- Pret: 4 lei.
3) Memorie laptop Samsung 512MB, DDR2, PC2-4200S, 533MHZ. Pret: 8 lei.
4) Memorie laptop Good RAM, 1GB, PC2-5300, DDR2. Pret: 8 lei.
5) Memorie laptop Kingston, 256MB, PC133, SDRAM. Pret: 7 lei.
6) Memorie laptop Samsung, 1GB, PC2-6400, 667MHz, DDR2: Pret: 12 lei.
7) Memorie laptop Monya, 1GB, PC2-5300-555, DDR2. Pret: 12 lei.
8) Memorie laptop Hynix 2GB, PC3-12800s DDR3. Pret: 18 lei.
9) Memorie laptop Samsung 2GB, PC3-10600s DDR3. Pret: 18 lei.
10)Memorie laptop Samsung 2GB, PC3-8500s  DDR3. Pret: 18 lei.
https://imgur.com/dSpQkWO
https://imgur.com/wspNz9W
https://imgur.com/ESA9ZoZ
https://imgur.com/PAB3ng4
https://imgur.com/jrUlO1W
https://imgur.com/8WzJNwZ
511. Placa video pc NVidia GeForce FX5500 256MB
DDR+DVI+TV Out
Pret: 12 lei.
https://imgur.com/zbkuuo9
https://imgur.com/sBNiCMu
512. Cablu de alimentare amplificatoare auto Hama, cu siguranta de putere-
lungime 5m. Pret: 17 lei.
https://imgur.com/o1axFlI
 515. Procesoare PC:
a) Intel Pentium D915
2.80GHz/4M/800/05A
pret: 15 lei.
b) Intel Celeron
2.80GHz/256/533
Pret: 12 lei.
c) Intel Celeron D
2.40GHz/128/400
Pret: 8 lei.
https://imgur.com/fogfv5x
 d) Intel Pentium 4
2.80GHz/1M/800
Pret: 7 lei.
e) AMD Semprom DDA2400UT3D
Pret: 3 lei
https://imgur.com/twXMKzE
 f. Procesor Intel Pentium Dual Core E2220
2,40GHz/1M/800/06 SLA8W
Pret: 10 lei.
g. Procesoare  Intel Pentium Dual Core
1,60 GHz/1M/800/06 SLA93
Doua bucati. Pret: 10 lei/buc.
h. Procesoare Intel Celeron D 336 SL7TW, SL8H9
2,80 GHz/256/533/04A
Doua bucati Pret: 7 lei/buc.
i. Procesor Intel P4
2,80GHz/1M/800/04A SL7PR
Pret: 10 lei.
j. Procesor P4
3,06GHz/1M/800 SL7J6
Pret: 12 lei
k. Procesor P4
3,20GHz/1M/800 SL7J7
Pret: 8 lei.
l. Procesor P4
2,80GHz/1M/533  SL7PK
Pret: 10 lei.
516. HDD Seagate Barracuda 160GB, pc, s-ata
Are instalat Windows 7 Ultimate.
Pret: 12 lei.
https://imgur.com/w8rD21N
518. Cooler procesor.
Pret: 7 lei.
https://imgur.com/g0Ua9Jl
519. Placa alimentare tV LG 26LG3000, serie 715T3181-1
Tensiuni: 5Vcc, 0-3A; 12Vcc- 0.1-1.5A; 24Vcc- 0.1- 4A.
Pret: 18 lei.
https://imgur.com/01T8uXG
https://imgur.com/8No8wN1
https://imgur.com/FoeELHo
 525.Transformator Tam Radio, alimenta o combina cu STK4132II
Sec 1: 2x18V partea de forta
Sec2: 2x10V
Sec3: 6.3V
Dimensuni: 70mm X 60mm, grosime pachet 50mm.
Pret: 33 lei.
https://imgur.com/SQDWIdC
https://imgur.com/ZQRnxCR
528. Difuzor Nokia HFS-12, 8ohm cu sistem de prindere cu suruburi M5.
Dimensiuni: 7.2cm X 6.2cm, adancime 4cm. Se aude clar.
Pret: 9 lei.
https://imgur.com/Bbhluuf
https://imgur.com/Lj1WAQQ
https://imgur.com/JEK5OBs
529. Modul AW03C, separa si distribuie semnalul de la o antena auto, spre radio
si spre telefon.
Pret: 5 lei
https://imgur.com/zNqMxKT
https://imgur.com/dXEQnia
530. Procesor Intel Celeron
2.80GHz/512/800/06
Pret: 7 lei.
https://imgur.com/PkAXT3l
531. Procesor Intel Pentium D
3.00GHz/4M/800/05A
Pret: 10 lei.
532. Placa recuperata dintrun radio/cd-player auto. Final Philips 70058AB,
echivalent cu TDA8587J plus radiator.
Pret: 9 lei.
https://imgur.com/hPX0JXj
https://imgur.com/3XPq9GH
https://imgur.com/GkNdwqA
 534. Placa de baza ASUS P5KPL-AM SE
Procesor Intel dual core 2.80GHZ. 2GB RAM.
Pret: 45 lei.
https://imgur.com/Nm5zyny
https://imgur.com/GBi6lbZ
https://imgur.com/wj1mHQo
https://imgur.com/GHx5WYQ
535. HDD PC WD 250GB s-ata, are instalat win xp. Testat cu WD lifeguard
Pret: 20 lei.
https://imgur.com/EtA6JAs
536. Placa video GeForce FX5200P, 128MB, iesire DDR1, DVI si TV.
Pret: 12 lei.
https://imgur.com/rP1O8UM
https://imgur.com/ZWnguBT
537. Adaptor imprimanta Canon K30353. Ue= 24Vcc- 0.63A.
Pret: 8 lei.
https://imgur.com/9WxpJg5
538. Diverse placute electronice recuperate din doua auto Mitsubishi Carina si
Ford Focus MK1.
Pret: 6 lei toate.
https://imgur.com/EhSSJ5t
https://imgur.com/55X7wp7
https://imgur.com/2VqrwYo
https://imgur.com/2iT8ynv
https://imgur.com/NZcqWlx
 539. Transformator de cablaj 2.2VA
Primar: 400V
Secundar: 9V 245mA
Pret: 8 lei
https://imgur.com/5z60Op9
545. HDD WD 200GB S-ata, Windows8, in lb maghiara, testat.
Pret: 18 lei.
https://imgur.com/aEeSV9n
546. Procesoare PC:
a) Intel Dual core 6300
1.80GHz/2M/1066/06
Pret: 8 lei.
b) AMD Athlon64 X2 Dual core AD04000IAA5DD
2.1GHz/512/1066
Pret: 15 lei.
c) AMD Athlon64  ADA3000DAA4BW
1.80GHz/512/1066
Pret: 10 lei.
https://imgur.com/DiHr3nu
Pret: 18 lei.
546. Procesoare PC:
1.80GHz/2M/1066/06
Pret: 8 lei.
2.1GHz/512/1066
Pret: 15 lei.
1.80GHz/512/1066
Pret: 10 lei.
 546. Sursa PC A-Line LC-8500TX Pmax=480W
Conectori: 1 conector 20 pini, procesor 4 pini, 6 conectori molex, 1 conector
floppy disk. Pret: 10 lei.
https://imgur.com/Y1DgQsh
547. Ventilator Sursa cu gratar de protectie, 12x12cm, 12 V 0.3A. Pret: 5 lei.
https://imgur.com/S6DJphJ
https://imgur.com/kfAi9TY
548. HDD HP DG72A4951, 72 GB, recuperate dintrun server, netestate, se vand ca
defecte. Pret: 15 lei toate.
https://imgur.com/GpYTZpX
550. Droser bobinat cu sarma ~0.7mm, 2,2 ohm 58.8mH. Pret: 5 lei.
https://imgur.com/5BsRytN
https://imgur.com/1J9wSxy
556.Transformator de cablaj Kriwan
P=8VA, Sec1 23V 100mA, sec2 11V 20 mA
Pret: 10 lei.
https://imgur.com/3ZQzIq6
557.Led driver 20W:
AC: 85-265Vac
DC: 54-68Vdc 300mA
Pret: 12 lei.
https://imgur.com/34Mytom
558. Lot sigurante auto 70, 40 si 20 A Ford Focus
Pret: 7 lei.
https://imgur.com/XFNTzff
559. Adaptor Moso
AC: 100-240Vac
DC: 9V 3.5A
Pret: 15 lei.
https://imgur.com/FMBTmtv
560. Miez transformator toroidal Diemen Efiter 250VA:
Dimensiuni: D= 9cm, d=4.5 cm, h= 5cm Sectiune: 10.4 cmp.
Pret: 15 lei.
https://imgur.com/NqJGBYY
562. Procesoare:
https://imgur.com/Szl5wQM
a) AMD Athlon 64 X2 dual core
AD04200IAA5CU
2.2GHz/512/1000
Pret: 12 lei.
b) AMD Athlon 64 X2 dual core
ADA6000IAA6CZ
3.0GHz/1M/1000
Pret: 15 lei.
c) AMD Sempron
 SDX140HBK13GQ
2.7/1M/2000
Pret: 7 lei.
d) AMD Athlon
AXDA2000DUT3C
1.667GHz/256/266
Pret: 3lei.
e) Intel Celeron D
3.2Ghz/512/533/06
Pret: 10 lei
f) Intel Celeron D
3.20GHZ/256/533/04A
Pret: 10 lei.
g) Intel Celeron D
3.06GHz/256/533/04A
Pret: 10 lei.
h) Intel Celeron D dual core
2.93GHz/3M/1066/06
Pret: 15 lei.
i)Intel Celeron D
2.66GHz/256/533/04A
Pret: 7 lei.
563. Placa Centrala termica Thermowatt CMP1 MI/FFI
- pentru recuperare piese. Transformator 10W, 24V.
Pret: 12 lei.
https://imgur.com/iwbt7Gl
https://imgur.com/lZiGBqk
564. Set difuzoare recuperate dintro unirate PC 486,
RS 248-331, impedanta 8ohm, P= 1.5Wrms.
Pret: 7lei.
https://imgur.com/fVQH9knhttps://imgur.com/fVQH9kn
565. Transport/cd-player recuperat dintru radio-cd auto Pioeneer DEH-4700MP, cu
finalii arsi.
Pret: 10 lei.
https://imgur.com/bXsDf0Q
https://imgur.com/YaXarod
569. Transformator 45VA:
Sec1: 11.5V-0-11.5V 1A
Sec2: 9V            1.8A
Sec3: 12V           0.25A
Pret: 17 lei.
https://imgur.com/47sQj9y
https://imgur.com/p6NFjNP
570. Adaptor laptop Sony Vaio
fara conector !!!
19.5V 3.3A
Pret: 15 lei.
https://imgur.com/fuFWunO
https://imgur.com/bGv5B7x
572. Transformator 21V, 20VA.
Pret: 12 lei.
https://imgur.com/vU1Mxqc
573. Transformator 12V, 20VA.
Pret: 12 lei.
https://imgur.com/HG28t6M
577. Radio-cd auto VW 200. Nu am codul, trebuie decodat. Nu s-a umblat inauntru,
are sigiliu din fabrica.
Pret: 30 lei.
https://imgur.com/bNSOOZ1
https://imgur.com/AvCgeoJ
https://imgur.com/TLJPS2Q
https://imgur.com/MsCqCFf
579. Relee auto BMW (4bucati)
Pret: 8 lei toate
https://imgur.com/6oE4rVL
580. Modul alarma auto TP-1000PW
Pret: 6 lei.
https://imgur.com/dHKJPGY
581. Procesor Intel pentium pro KB80521EX200 SY032 256k + radiator.
Pret: 100 lei
https://imgur.com/Mv8KgMR
https://imgur.com/vO1UwBN
582: Procesor Texas Instruments 486DX2-80.
Pret: 25 lei.
https://imgur.com/9RXczPn
583.  Procesoare PC:
a) Intel i5 core 3.30GHz
Pret: 35 lei.
https://imgur.com/PIA0a3T
b) Amd Athlon 64 X2
AD048001AA50G
Pret: 15 lei.
https://imgur.com/8gfqXoF
c) AMD Athlon 64 X2
AD04400IAA5D0
Pret: 12 lei.
d) AMD Athlon
ADH1640IAA4DP
Pret: 9lei.
Seara buna. Retineti, va rog,
582. Procesor Texas Instruments 486DX2-80.
562. Procesoare:
d) AMD Athlon
AXDA2000DUT3C
1.667GHz/256/266
Pret: 3lei.
defecte..
Editat de vlad751
Se aduaga:
583. Procesoare PC:
e) Amd Sempron SDA 2500 AI03BX
Pret: 9 lei
f) Pentium 4 3.0GHz/2M/800/04A
Pret: 9 lei.
g) Celeron D 2.53GHz/256/533/04A
Pret: 5 lei.
h) Pentium D 2,80GHz/4M/800/05A
Pret: 12 lei.
584. Transformator 30W;
sec 1: 9V-0-9V sarma fi 0.6mm
sec 2: 12V sarma fi 0.25mm
Pret: 12 lei.
https://imgur.com/GI3n5T7
585. Placute recuperate dintrun convertor industrial
Pret: 10 lei ambele.
https://imgur.com/0yiKolX
https://imgur.com/2tZiXyy
586. HDD S-ata Maxtor 250GB, are instalat Windows 7
Pret: 20 lei.
https://imgur.com/PWi9zpK
587. HDD-uri laptop IDE
IBM 20GB
Hitachi 40GB
Nu am cum sa le testez.
https://imgur.com/cTe7S4J
588. Ecran laptop 14" Samsung LTN140KT07
Pret: 50 lei.
https://imgur.com/nNMcxIh
https://imgur.com/gS1GGVR
Se poate combina si cu:
Editat de cmariuss
S-au facut rezervarile.
Se adauga:
589. Grup 4 condesatori electrolitici RDE Elko Rauh II A, 10.000 uF, trei la 25V
si unul la 40V. Pret: 25 lei.
https://imgur.com/NRNgqod
https://imgur.com/nGdhLFO
https://imgur.com/Uhyu8mf
590. Sursa in comutatie Dell AC290EM-01
Putere 290 W
Tensiuni: 12V 14.06A, 12V 16.0A, 12Vstab 1.67A
Pret: 15 lei.
https://imgur.com/X5lDgpm
https://imgur.com/p5Ah9i1
https://imgur.com/4OG0T3n
591. PCB cu integrate din seria  HCF, MC, LM, LF, sub radiator se afla un
TDA2020, 2XLM342.
Pret: 10 lei.
https://imgur.com/ZCZvnGT
592. PCB cu tiristori T.I., 2N6059, CA3140E, LM307N, 1N5401.
Pret: 12 lei
https://imgur.com/y8uifMN
593. PCB cu matrice led, lipsesc doua matrici, PIC16F873A, GAL16VBD, 24LC64,
MAx323N integrate din seria ULN, CD.
Pret: 15 lei.
https://imgur.com/dcRlg45
https://imgur.com/kNDqzbN
https://imgur.com/XkP1QC4
https://imgur.com/qnePyXp
https://imgur.com/zpuvWvw
594. Set 12 relee auto 12V/20A
Pret: 15 lei.
https://imgur.com/b9Fismj
595. Set sigurante auto 40A.
Pret: 5 lei.
https://imgur.com/18C9l9D
Editat de cmariuss
Doresc sa cumpar:
TDA2020, 2XLM342.
Pret: 10 lei.
Pret: 12 lei
593. PCB cu matrice led, lipsesc doua matrici, PIC16F873A, GAL16VBD, 24LC64, MAx323N integrate din seria ULN, CD.
Pret: 15 lei.
