cmariuss Postat Ianuarie 28, 2023 Autor Partajează Postat Ianuarie 28, 2023 Se adauga: 522. Procesoare a) Intel Quad Core Q9400 2.66GHz/6M/1333/05A Pret: 30 lei b) Intel Pentium 4 2.80GHz/1M/800 Pret: 10 lei. c) AMD Semprom DDA2400UT3D Pret: 5lei https://imgur.com/twXMKzE 523. Incinta acustica 2 cai, sovietica, in stare buna, sunet clar si fara distorsiuni, difuzor diam 18cm. Dimensiuni Incinta: 36cm inaltime X 26cm latime X 12cm adancime. Pret: 25lei. https://imgur.com/59pAo40 https://imgur.com/kJEuNE4 https://imgur.com/0YOltSP https://imgur.com/Ndh7xYq Link spre comentariu
nostromo Postat Ianuarie 28, 2023 Partajează Postat Ianuarie 28, 2023 522. Procesoare a) Intel Quad Core Q9400 2.66GHz/6M/1333/05A Pret: 30 lei Il vreau eu ! Link spre comentariu
carageae Postat Ianuarie 28, 2023 Partajează Postat Ianuarie 28, 2023 523. Incinta acustica 2 cai, sovietica, in stare buna, sunet clar si fara Asta o vreau eu. Link spre comentariu
cmariuss Postat Ianuarie 30, 2023 Autor Partajează Postat Ianuarie 30, 2023 incinta acustica rezervata dl-lui Caragea Au mai ramas: 1. Tv Samsung UE32j4500AW, cu ecran spart, se da pentru piese: Barete LED-uri: V5DN-320SMO-R4 Pret: 20 lei 1.Mainboard: BN41-02360 Pret: 32 lei. https://imgur.com/a/iy4S5ZM 2. Mainboard Vestel 17MB62-1. Pret: 17 lei https://imgur.com/75Cf5hG 3. Barete Led D2GE-460SCA-R3 (3 buc)- 5 lei/buc. https://imgur.com/3COXrCZ 9. Cabluri Scart. Pret: 4 lei bucata. https://imgur.com/RSGqalj 20. Difuzoare recuperate dintrun tv Thomson, 8 ohm, dimensiuni 20x5,5x2,5 - 5 lei. https://imgur.com/T5dnTZN 41. Drosere Vassloh/Schwabe 18-28W. Pret: 5 lei/buc. https://imgur.com/uLXZfAb 51. Docking Station HP2013. Se vinde ca defect. Fara cablu alimentare. Pret: 3 lei. https://imgur.com/IOpGY8z 67. Modul inalta tensiune dintrun copiator canon. Pret: 9 lei. https://imgur.com/4usBMHS https://imgur.com/NiIUhjC 95. Tuner JS-6H2/121. Pret: 3 lei. https://imgur.com/0uqqKgq 115: HDD 3,5" Hitachi 160GB, testat si instalat Windows7. Pret: 18 lei. https://imgur.com/OdWCTHY 116: HDD 3,5" WD, 80 GB, testat. Pret: 15 lei. https://imgur.com/HT5lJxe 164. Memorii Ram, DDR2, 512Mb, testate. Pret: 3 lei ambele. https://imgur.com/j695ShP 217. Sursa tv Dong-Yang BN96-02580A Pret: 22 lei. https://imgur.com/tZRWUn0 Suruburi: 453.Surub M10 brunat, grupa 8.8, cu lungimea 30mm. Pret: 0,50 lei/buc. https://imgur.com/zari9xb 82. Surub M5 cu guler, torx T20, cote in poza de mai jos. Pret: 0.35 lei/ 100g sau 100 buc- 2.5 lei. Disponibile 1 kg. https://imgur.com/jATZ700 https://imgur.com/Wh2fXId 83. Surub pt plastic cu guler, torx T20, cote in poza de mai jos. Pret 0.5 lei/100g sau 100 buc- 1 lei. Disponibile 5 kg. https://imgur.com/G8eOpez https://imgur.com/npSbWoC 84. Suruburi pt plastic, torx T8, cote in poza de mai jos. Pret: 1500 buc- 1 leu. Disponibile 10 kg. https://imgur.com/Kodbtx9 https://imgur.com/EnEQ6Xe 85. Arcuri, cote in poza de mai jos. Pret: 2,5 lei/ 100g. Disponibile 100 g. https://imgur.com/fXSwir7 https://imgur.com/QKfSNQm 227. Sursa Plisch FMS-100 (recuperata dintrun aparat de masura/analiza semnal TV) Uin: 195- 265V, 47-63Hz, Putere = 250VA Tensiuni: 5V, 7,5V, -5V, -12V, 24V Realizata cu componente de calitate: Philips, Siemens, Motorola,Wima etc. Sursa a fost reparata o data in 2003 de Antena Hungaria Kft. Pret: 60 lei. https://imgur.com/J1LNTxB https://imgur.com/IPB11HQ https://imgur.com/oFZz2l9 https://imgur.com/x5b415j https://imgur.com/8XaEBLF https://imgur.com/yMpTrKt https://imgur.com/2uJ8xU0 https://imgur.com/n8O62DK https://imgur.com/fqdWvLC https://imgur.com/QBbTVui https://imgur.com/Jqpfgcc https://imgur.com/lDjYxh7 242. Vana gaz Sigma 845 (Vaillant). Pret: 3 lei. https://imgur.com/MprfpGO 246. Adaptoare Nokia ACP-12E, nefolosite. 5,7 V, 800 mA. Cablu ~ 1.8 m. Disponibile 2 bucati. Pret: 4 lei/buc. https://imgur.com/WWHA3E3 254. Set difuzoare Viefu 30041403 (recuperate dintro plasma Vortex), 8 ohm, 12 W. Pret: 5 lei. https://imgur.com/k5ZW4Ot 255. Set difuzoare OHC 300772s1, 8 ohm, 5W. Pret:5 lei. https://imgur.com/KZkRhK1 https://imgur.com/xxerTCC 264. Contoare electromagnetice SI-47. Doua bucati. Pret: 6 lei/buc. https://imgur.com/qTMsp21 268. Micro filtru DSL HWMF-140. Nou. Pret: 4 lei. https://imgur.com/iSX4t3y 276. Temporizator mecanic cuptor cu microunde: durata temp 30 min, contactele suporta 16A. Pret: 5 lei. https://imgur.com/oy1OyAI 283. Sarma nichelina NiCr Nikrothal 80. Diametru 0.2 mm, rezistenta 35,80 ohm/m, temperatura max de lucru 1200*C, conductibilitate termica/100°C Wm-1C-1-15,0 Pret: 0.20 lei/metru liniar. https://postimg.cc/k6Bfxn4r https://postimg.cc/KKQHPqDT 284. Transformator 30VA: S1: 9V S2: 24V Pret: 14 lei. https://postimg.cc/5X9Xxvtq 286. Releu Sigma cu soclu. Pret: 12 lei. https://postimg.cc/23BvJ4q1 https://postimg.cc/Sntxkv3k 287. Releu Schrack ZG z60 720. Pret: 9 lei. https://postimg.cc/xcvmjn3Y https://postimg.cc/NyJmhD7H 288. Releu combina frigorifica General Electric. Pret: 4 lei https://postimg.cc/PvZwwjGW 291. CD/ROM/DVD ROM laptop Toshiba SD-R2202. Pret: 2 lei. https://postimg.cc/fJf3n5MR https://postimg.cc/KKwjrHDJ 324. Din dezmembrarea unui LED tv, Blaupunkt BN32H1032eeb, urmatoarele: 324a. Mainboard TP.MS 3663S.PB818 (t-con v320bj8-q01, si panel cx315dledm). Pret: 30 lei. https://postimg.cc/kDbM76H8 https://postimg.cc/mPbT3dgN https://postimg.cc/McHxNvRn https://postimg.cc/yWcKMqJy 324b. Set 2 barete LED, HL-00320A30-0601S-07A3.Pret: 15 lei. https://postimg.cc/tnW9kw6D https://postimg.cc/ZB1Tr4WC 324d. Set picioruse. Pret: 5 lei. https://postimg.cc/yWcKMqJy 328. Releu Matsushita jh1a-ac220v Bobina: 220Vac Contact: 30A Pret: 12 lei. https://postimg.cc/9Rv60Mch 333. Componente din dezmembrarea unui tv Fujitsu Siemens Myrica VQ40-1. Toate componentele find in stare de functionare, problema tv-ului era sursa. 333a. Placa de baza Conrac + tuner Philips. Pret: 8 lei. https://postimg.cc/ctYZQ8vS https://postimg.cc/6759D3mr https://postimg.cc/ctYZQ8vS https://postimg.cc/0MybdZvq https://postimg.cc/CR0MsJC6 340. HDD Western Digital 160GB (WDdata lifeguard diagnostic).Pret: 15 lei https://postimg.cc/62vXYs5G 341. HDD Seagate Barracuda 80GB (testat cu Data LifeGuard Diagnostics). 2 bucati Pret:9 lei buc https://postimg.cc/K18hC38b https://postimg.cc/k2YPCM2b 362. Ventilatoare Nidec Betav. Doua bucati C32957-58, 12V- 0,29A. Una bucata C34637-58, 12V- 0,13A. Pret: 8 lei toate. https://imgur.com/mFUdq3h 385. Alarma auto Thunder Pret: 15 lei. https://postimg.cc/w3c3xtkV https://postimg.cc/kR9rhg6M 389. Alarma auto. Pret: 9 lei. https://postimg.cc/G4pD1GMM 393. Placa de baza si modul comunicatie imprimanta Epson EU-96. Pret: 4 lei. https://postimg.cc/HJy4fbxq https://postimg.cc/R3kJf8v8 395. Convertor Scart-RCA/S-video. Pret: 5 lei. https://postimg.cc/Hj73qDJJ 396. Alarma auto KD500. Pret: 12 lei. https://postimg.cc/75w1CMHB https://postimg.cc/LgPkPxgW 405. Bare dreptungiulare de aluminiu. Dimesiune: 5.0cm x 2.5cm, si lungime de 43cm. Greutate: 1.35 Kg. Am trei bucati. Pret: 27 lei/buc. https://postimg.cc/XZ56cBzr https://postimg.cc/Hc4GFDHH 412. Sursa in comutatie NYKO: Sec1: 24Vcc Sec2: 8Vcc Pret: 10 lei. https://imgur.com/3B6gASl 417. Termostate industriale TehnoTrust Bistrita. Domeniu de temperatura 0-400*C. Butoanele potentiometrelor sunt rupte. Nu am senzori PT-100 sa le testez, se vand ca defecte: Pret: 15 lei buc sau ambele 28 lei. https://imgur.com/d20lTyc https://imgur.com/xaTj8tJ https://imgur.com/UVcinYS 423. Sursa SMPS 2405 Intrare: 24Vca-90Vca (galben-rosu) Iesire: 24Vcc 550ma (negru-rosu) Pret: 12 lei. https://imgur.com/gilI2Ny https://imgur.com/l74NtE6 426. Lampa 12V/4W (soclu baioneta), corp alama, capac crom. Se poate utiliza pentru iluminarea scalei la radio, iluminarea vu-metrelor cu ace, etc Pot face rost de mai multe. Pret: 9 lei/buc https://imgur.com/H4oPeLO https://imgur.com/FgNGxDi https://imgur.com/AaweLfD 427. Sticla scala radio pe lampi Minerva Cornette. https://imgur.com/a6MKoiM https://imgur.com/AstVy7F Pret: 25 lei. 429. Rezistenta 650W incalzire cafetiera, cu termostat. https://imgur.com/2iCunrD Pret: 7 lei. 430. Sine trenulet modelism: - sectiuni curbe 9-bucati - sectiuni drepte 3 bucati - ecartament 30mm - diatru exterir - 88 cm - diametru interior - 68 cm Pret: 10 lei. https://imgur.com/xVpl4aA https://imgur.com/BvW9Ics 432. Sursa Tv Sharp CA0009WJN1 Tensiuni masurate: 9V, 12V Pret: 18 lei. https://imgur.com/ZTxFUuU 434. Casti telefonice: Primo -CT-3B, productie Japonia, 6 bucati. Impedanta: 780 ohm. Pret: 2 lei. https://imgur.com/0hmpJFJ 435. Casti telefonice: Primo DH-51, productie Japonia, 4 bucati. Impendanta: 290 ohm. Pret: 2lei. https://imgur.com/hO1mFIJ 436. Tablite cupru cu grosimea de 0,5mm. Cu urmatoarele dimensiuni: a) 35 x 5 cm. Pret: 9 lei. https://imgur.com/Zu0Gzq8 c) 16 x 11 cm Pret: 7 lei. https://imgur.com/KSj4P3C d) 16 x 14 cm. Pret: 9 lei. https://imgur.com/cWwzRNZ e) 16 x 10 cm. Pret: 8 lei. https://imgur.com/LP4tiwe f) 20,5 x 10 cm. Pret: 11 lei. https://imgur.com/GQOWsBy g) 16 x 9 cm. Pret: 8 lei. https://imgur.com/Xd20iS4 h) 16 x 10 cm Pret: 8 lei. https://imgur.com/tFOO6qz i)17 x 15 cm forma eliptica. Pret: 9 lei. https://imgur.com/EZFmfhu j) 24 x 8/11.5 cm patrulater. Pret: 9 lei. https://imgur.com/1O3uosh 439. Releu RP-102-3P Ua= 24Vcc, R= 346 ohm Contacte: 2x3, fara soclu. Pret: 19 lei. https://imgur.com/NKClW8K https://imgur.com/bGrPZ5h https://imgur.com/v3APLRq 440. Relee (doua) RP 92 Ua = 220Vca, R= 4410 ohm Contacte: 2x3, cu socluri. Pret: 19 lei/buc. https://imgur.com/kXEgFs1 https://imgur.com/ijfgFLZ https://imgur.com/1ExxIPf https://imgur.com/FB6vJtb https://imgur.com/aB8Gj6g 441. Acumulator Li-Ion pentru laptop, model: 8560, nou. Tensiune: 11.1V, 7800mAh, 87Wh. Pret: 55 lei. https://imgur.com/RWpiKNZ https://imgur.com/0Lw48gf 445. Siguranta fuzibila MNC pentru amplificatoare auto. Pret: 3 lei. https://imgur.com/433srrq 447. Adaptor telefon (pentru priza UK) 4,5V-5,5 V, 500mA . Pret: 3 lei. https://imgur.com/8FZVIdS 448. Modul alarma auto SPAL AS-90. Pret: 8 lei. https://imgur.com/O06QcqL https://imgur.com/Fl2flAH 450. Motor recuperat dintrun magnetofon Tesla CM-130. Pret: 30 lei. https://imgur.com/9tdxJE8 https://imgur.com/JfJ1ueU https://imgur.com/xwh3V4g 452. Relee industriale RP-92, 2 x 3 contacte. Tensiune de alimentare: 42V 50Hz, 220 Ohm, cu socluri, doua bucati. Pret: 19 lei/buc. https://imgur.com/fy5qwJ6 https://imgur.com/fDEM118 454. Adaptor pentru laptop Dell,nou, inlocuitor, model LD-065/334/195/011, mufa 7,4x5.0 well 19,5V 3,34A 65W Pret: 65lei. https://imgur.com/Nz312Pf https://imgur.com/5YuPfy3 https://imgur.com/KhqCJVh https://imgur.com/u9jj1SR 455. Adaptor nou LW-090/462/195/002 inlocuitor pentru Dell Inspiron 3147 3148 3152 3153 3157 3158 3162 3164 3168 3179 Dell Latitude 7202 3379 7350 E5450 19,5V 4,62A 90W Pret: 55 lei. https://imgur.com/Z3Sz7NC https://imgur.com/iwt4aQC https://imgur.com/qr9HXxP 456. Adaptor nou, inlocuitor pentru laptop Lenovo ND-A065W2002250,pentru ideapad 100 / ideapad 110 / 310 / Yoga 510 / B50 / AIR12 AIR13 AIR15. Conector: 4.0x1,7mm. 20V 2,25A 45W. Pret: 50lei. https://imgur.com/nSQ5Jkf https://imgur.com/Ge7UTMH https://imgur.com/h345Zb9 https://imgur.com/2QFTySW https://imgur.com/DwGbNSR 467. Memorii PC DDR2 -512MB. Pret: 3 lei/buc. https://imgur.com/3m300N6 469. Memorii PC DDR2 - 1GB. Pret: 7lei/buc. https://imgur.com/WtKXRBp 470. Led driver 100W, tensiune 27-36V, 3000mA. IP65. Pret: 40lei. https://imgur.com/SLMKrVZ 472. Telecomanda Siemens-Fujitsu. Pentru TV LCD Fujitsu Siemens Myrica VQ40- 1.Pret: 7 lei. https://imgur.com/grYYsWS 473. Vu-metre fara cadran, cel din stanga e cu acul pe centru, dar are acul deformat. Pret: 9 lei toate trei. https://imgur.com/j9Uw7Ar 474.Placa controler electronic pentru pompe de caldura. Mai are in componenta un transformator 10W, 12V 0.600A, un releu bipolar cu bobina 230V, contacte 35A, un senzor de temperatura, un conensator 4uF/450V, cabluri aferente. Din pacate ii lipseste displayul. Mai multe informati pe situl producatorului, cu google translate http://gzjsdz.com/KS1.htm Pret: 22 lei. https://imgur.com/lg1bfYR https://imgur.com/VuI6JGe https://imgur.com/Y0tzqsy https://imgur.com/Ra80Wdv https://imgur.com/DGScxqA 477. Lupa convergenta,menisc convergent,diametru 100mm, grosime 30mm, distanta focala 10 cm, putin ciobita la margine, in mod normal nu afecteaza cu nimic. Pret: 15lei. https://imgur.com/zLtM30B https://imgur.com/MSohlEZ 481. Releu Relog 24V, IP40, 4perechi de contacte.Pret: 12lei. https://postimg.cc/2LqCQqXB https://postimg.cc/3WWr56JJ 482.Jetoniera Comestro RM5evolution, pentru aparate de cafea, sau pentru alte aplicatii. Caracteristici: Viteza de acceptare: 3 monede/secunda Diametru monede acceptate: 16 ÷ 31.5 Grosime monede acceptate: pana la 3,3 mm Dimensiuni ( LxHx W): 89 x 102 x 46,4 Greutate: 185 g Temperatura operare: 0 °C ÷ 55 °C 3 perechi de senzori inductivi care sunt folositi pentru a procesa 6 parametrii diferiti in ceea ce priveste materialele si masa 3 perechi de senzori optici pentru a determina diametrul monedelor Dispozitiv mecanic anti-phishing Dispozitiv electronic anti-phishing Sistem automat de compensare a senzorilor optici pentru variații de temperatura, tensiune și iluminat. https://postimg.cc/PpVtvbKj Pret: 15 lei. 483.Mp3 player auto Akai CA010A-1011U Pret: 30 lei. https://imgur.com/vSXVAKK https://imgur.com/9BhjARd 486. Sursa in comutatie Ue= 12V - 3A Pret: 12 lei. https://imgur.com/uL1ZVwA 488. Adaptor Philips 7W 13V- 400mA, cablu are lungime 2.5m. Pret: 12lei. https://imgur.com/fjaQP1k https://imgur.com/cO86KTm 491. Tastatura laptop Chicoby mp-10h96f06886, folosita, netestata. Pret: 5lei. https://imgur.com/oj0zbeC https://imgur.com/JT5DQeW 492. Tastatura laptop NSK-DV0BC 1D pentru Dell Latitude E6420 US, folosita, netestata. Pret: 5lei. https://imgur.com/O8eLzGZ https://imgur.com/lmnzt3x 496. Adaptor AllView Tx1 Quasar, 5V- 2000mA. Pret: 12lei. https://imgur.com/6AbBC8S 498. Placa baza Asrock G31-M7 TE, se da cu doua memorii Ram DDR2 1GB, Procesor Intel DualCore 3.0 GHz. Pret: 50lei. https://imgur.com/2HaOGK4 https://imgur.com/fPKn8ii 488. Adaptor Philips 7W 13V- 400mA, cablu are lungime 2.5m. Pret: 12lei. https://imgur.com/fjaQP1k https://imgur.com/cO86KTm 499. Actuatoare automatizare porti Hanning K88-136. Doua bucati. Unul dintre el nu are carcasa completa ! Alimentare: 220V-240Vca, 50Hz, 1,2A Putere: 250W Cursa maxima: 20cm Comanda pneumatica Pret: 75 lei ambele. https:/imgur.com/2Djilhl https://imgur.com/kuRfJ4H https://imgur.com/iE0s4aO https://imgur.com/hyPKYxx https://imgur.com/vFWY6sr https://imgur.com/YpLhOyU https://imgur.com/7dUEVmF https://imgur.com/b4ZdPoC https://imgur.com/OYh66Dy 501. Rezistenta incalzire acvarii. Resunn rh-9000. Putere. 75W. temperatura reglabila intre 21 si 32*C. Pret: 22lei. https://imgur.com/vaZ7EIE https://imgur.com/WRs77ZS https://imgur.com/uLHHGjZ 502. Adaptor imprimanta Delta. Ue= 30V - 0.83A Pret: 12 lei. https://imgur.com/yOq1wEv 503. Placa imprimanta Lexmark z55 Pret: 4 lei. https://imgur.com/zLrVzY2 504. Cablu imprimanta pentru portul paralel- 1,5m. Pret: 9 lei. https://imgur.com/Gu7GgUj 505. Modul control, iluminare si ventilator recuperat dintro cab de dus. Tranzistoarele sunt 2SA8050, relee se alimentaza la 12V. Pret: 6 lei. https://imgur.com/ZZ7QIoS https://imgur.com/2YjP7nU https://imgur.com/1zkeeHR 506. Lupa biconcava simetrica. Diametru: 10cm, grosime max 2cm, grosime minima 0.5cm. Are cateva mici ciobituri pe margine. Pret: 15 lei. https://imgur.com/okQ3Gtb 507. HDD Seagate 80GB PC interfata S-ata, are instalat windows XP Pret: 12lei https://imgur.com/MptLAFn 508. HDD Seagate 80GB PC, interfata S-ata, fara OS. Pret: 9 lei. https://imgur.com/lsa5lbI 509. Din dezmembrarea unui magnetofon Rostov 105, urmatoarele componente mecanice. Nu au urme de oxidare, rugina sau deformari mecanice (nu mai am alte componente din mag). a) sasiu https://imgur.com/GZuOb4d b) Panouri laterale https://imgur.com/8M2loT9 c) Capacele spate https://imgur.com/RQOcwrb https://imgur.com/isPKLp8 Pret: 25 lei toate. 510: Memorii laptop: 1) Memorie laptop 64MB, PC100,133MHz, SDRAM- Pret: 4 lei. 2) Memorie laptop 512MB, PC133, 133MHz, SDRAM- Pret: 5lei. 3) Memorie laptop Samsung 512MB, DDR2, PC2-4200S, 533MHZ. Pret: 10lei. 4) Memorie laptop Good RAM, 1GB, PC2-5300, DDR2. Pret: 10lei. 5) Memorie laptop Kingston, 256MB, PC133, SDRAM. Pret: 5lei. 6) Memorie laptop Samsung, 1GB, PC2-6400, 667MHz, DDR2: Pret: 15lei. 7) Memorie laptop Monya, 1GB, PC2-5300-555, DDR2. Pret: 15lei. 8) Memorie laptop Hynix 2GB, PC3-12800s DDR3. Pret: 25 lei. 9) Memorie laptop Samsung 2GB, PC3-10600s DDR3. Pret: 25lei. 10)Memorie laptop Samsung 2GB, PC3-8500s DDR3. Pret: 25lei. https://imgur.com/dSpQkWO https://imgur.com/wspNz9W https://imgur.com/ESA9ZoZ https://imgur.com/PAB3ng4 https://imgur.com/jrUlO1W https://imgur.com/8WzJNwZ 511. Placa video pc NVidia GeForce FX5500 256MB DDR+DVI+TV Out Pret: 15 lei. https://imgur.com/zbkuuo9 https://imgur.com/sBNiCMu 512. Cablu de alimentare amplificatoare auto Hama, cu siguranta de putere- lungime 5m. Pret: 18lei. https://imgur.com/o1axFlI 515. Procesoare PC: a) Intel Pentium D915 2.80GHz/4M/800/05A pret: 20 lei. b) Intel Celeron 2.80GHz/256/533 Pret: 15 lei. c) Intel Celeron D 2.40GHz/128/400 Pret: 12 lei. https://imgur.com/fogfv5x d) Intel Pentium 4 2.80GHz/1M/800 Pret: 10 lei. e) AMD Semprom DDA2400UT3D Pret: 5lei https://imgur.com/twXMKzE f. Procesor Intel Pentium Dual Core E2220 2,40GHz/1M/800/06 SLA8W Pret: 15 lei. https://imgur.com/DwGbNSR g. Procesoare Intel Pentium Dual Core 1,60 GHz/1M/800/06 SLA93 Doua bucati. Pret: 12 lei/buc. https://imgur.com/DwGbNSR h. Procesoare Intel Celeron D 336 SL7TW, SL8H9 2,80 GHz/256/533/04A Doua bucati Pret: 10 lei/buc. https://imgur.com/DwGbNSR i. Procesor Intel P4 2,80GHz/1M/800/04A SL7PR Pret: 15 lei. https://imgur.com/DwGbNSR j. Procesor P4 3,06GHz/1M/800 SL7J6 Pret: 15 lei https://imgur.com/DwGbNSR k. Procesor P4 3,20GHz/1M/800 SL7J7 Pret:12 lei. https://imgur.com/DwGbNSR l. Procesor P4 2,80GHz/1M/533 SL7PK Pret: 15 lei. https://imgur.com/DwGbNSR 467. Memorii PC DDR2 -512MB. Pret: 2 lei/buc. https://imgur.com/3m300N6 516. HDD Seagate Barracuda 160GB, pc, s-ata Are instalat Windows 7 Ultimate. Pret: 15 lei. https://imgur.com/w8rD21N 517.Doua Memorii PC TakeMS 512MB, DDR2-800-CL5. Pret: 5 lei ambele. https://imgur.com/oV6c79v 518. Cooler procesor. Pret: 7 lei. https://imgur.com/g0Ua9Jl 519. Placa alimentare tV LG 26LG3000, serie 715T3181-1 Tensiuni: 5Vcc, 0-3A; 12Vcc- 0.1-1.5A; 24Vcc- 0.1- 4A. Pret: 18 lei. https://imgur.com/01T8uXG https://imgur.com/8No8wN1 https://imgur.com/FoeELHo 520. Placa electronica Brahma Micro 350.R01 pentru Brahma digit Pret: 22lei. Rominstal o vinde cu 2250lei... https://imgur.com/Cs5GS0h https://imgur.com/4LO6gpk 521. Placa electronica Brahma. Transformatorul are 10VA, tensiune 2x9V. Pret: 12lei. https://imgur.com/rPBpG4M https://imgur.com/hVUl8tl Link spre comentariu
nostromo Postat Februarie 1, 2023 Partajează Postat Februarie 1, 2023 Vanzator serios , recomand cu incredere ! Link spre comentariu
cmariuss Postat Februarie 3, 2023 Autor Partajează Postat Februarie 3, 2023 (editat) Se adauga: 524. Transformator 30VA (fabrica "acustica" Budapesta: Sec1: 22V sec2: 6.3V sec3: 7.2V sec4: 9.6V Dimensiuni: 65mm X 65mm, grosime pachet 27mm. Pret:25lei. https://imgur.com/qcQdJ6Z https://imgur.com/nnBnTpG 525.Transformator Tam Radio, alimenta o combina cu STK4132II Sec 1: 2x18V partea de forta Sec2: 2x10V Sec3: 6.3V Dimensuni: 70mm X 60mm, grosime pachet 50mm. Pret: 38lei. https://imgur.com/SQDWIdC https://imgur.com/ZQRnxCR 526: Transformator ETP1070-33EAj, alimenta o combina cu STK4141V sec1: 2x25V partea de forta sec2: 2x17V sec3: 5V Dimensiuni: 70mm X 60mm, grosime pachet 50mm. Pret: 38lei https://imgur.com/ZaC7Bg3 https://imgur.com/q61jntq https://imgur.com/k1rWjZ0 527. Transformator sonerie 10W: sec1: 5V sec2: 8V Pret: 10 lei. https://imgur.com/uEmflPD https://imgur.com/waIEK33 528. Difuzor Nokia HFS-12, 8ohm cu sistem de prindere cu suruburi M5. Dimensiuni: 7.2cm X 6.2cm, adancime 4cm. Se aude clar. Pret: 12 lei. https://imgur.com/Bbhluuf https://imgur.com/Lj1WAQQ https://imgur.com/JEK5OBs 529. Modul AW03C, separa si distribuie semnalul de la o antena auto, spre radio si spre telefon. Pret: 12 lei https://imgur.com/zNqMxKT https://imgur.com/dXEQnia 530. Procesor Intel Celeron 2.80GHz/512/800/06 Pret: 9 lei. https://imgur.com/PkAXT3l 531. Procesor Intel Pentium D 3.00GHz/4M/800/05A Pret: 15 lei. https://imgur.com/PkAXT3l 532. Placa recuperata dintrun radio/cd-player auto. Final Philips 70058AB, echivalent cu TDA8587J plus radiator. Pret: 15lei. https://imgur.com/hPX0JXj https://imgur.com/3XPq9GH https://imgur.com/GkNdwqA 533.Set relee auto, 20/40A si 70A. Pret: 9lei. https://imgur.com/0r3DyzA Editat Februarie 3, 2023 de cmariuss Link spre comentariu
carageae Postat Februarie 3, 2023 Partajează Postat Februarie 3, 2023 Traful 524 il vreau eu Link spre comentariu
cmariuss Postat Februarie 7, 2023 Autor Partajează Postat Februarie 7, 2023 Traful 524 retinut. Se adauga: 534. Placa de baza ASUS P5KPL-AM SE Procesor Intel dual core 2.80GHZ. 2GB RAM. Pret: 50 lei. https://imgur.com/Nm5zyny https://imgur.com/GBi6lbZ https://imgur.com/wj1mHQo https://imgur.com/GHx5WYQ 535. HDD PC WD 250GB s-ata, are instalat win xp. Testat cu WD lifeguard Pret: 25lei. https://imgur.com/EtA6JAs 536. Placa video GeForce FX5200P, 128MB, iesire DDR1, DVI si TV. Pret: 15 lei. https://imgur.com/rP1O8UM https://imgur.com/ZWnguBT 537. Adaptor imprimanta Canon K30353. Ue= 24Vcc- 0.63A. Pret: 12 lei. https://imgur.com/9WxpJg5 538. Diverse placute electronice recuperate din doua auto Mitsubishi Carina si Ford Focus MK1. Pret: 9 lei toate. https://imgur.com/EhSSJ5t https://imgur.com/55X7wp7 https://imgur.com/2VqrwYo https://imgur.com/2iT8ynv https://imgur.com/NZcqWlx Link spre comentariu
cmariuss Postat Februarie 8, 2023 Autor Partajează Postat Februarie 8, 2023 Se adauga: 539. Transformator de cablaj 2.2VA Primar: 400V Secundar: 9V 245mA Pret: 10 lei https://imgur.com/5z60Op9 540. Transformator de cablaj 5VA Secundar: 12V Pret: 8 lei. https://imgur.com/7MCbowo 541. Set 7 relee auto 12v/20A Pret: 10 lei toate. https://imgur.com/qQII900 542. Set 8 relee auto 12V/40-60A Pret: 15 lei toate. https://imgur.com/vObgvlo 543. Placuta 4 borne. Pret: 6 lei. https://imgur.com/omO3ANt Link spre comentariu
leo177 Postat Februarie 9, 2023 Partajează Postat Februarie 9, 2023 541 si 542 rezervatile pt mine Link spre comentariu
cmariuss Postat Februarie 9, 2023 Autor Partajează Postat Februarie 9, 2023 Le-am rezervat, chiar ma gândeam ca v-ar trebui. Mai am am și 533.Set relee auto, 20/40A si 70A. Pret: 9lei. https://imgur.com/0r3DyzA Link spre comentariu
cmariuss Postat Februarie 9, 2023 Autor Partajează Postat Februarie 9, 2023 Se adauga: 544. Transformator 190VA provine din dezmembrarea unui amplituner Sony STR GX511 Primar: 110V, 230V Secundar 1: (de forta): 38V-0-38V Secundar 2: 17V-0-17V Secundar 3: 3.8V Dimensiuni: lungime 8.8cm, inaltime 7.4cm, grosime pachet tole 5.2cm Pret: 50lei. https://imgur.com/AagMuKf https://imgur.com/6zA7hZu https://imgur.com/gisDqvV https://imgur.com/1ZCQYqC 545. HDD WD 200GB S-ata, Windows8, in lb maghiara, testat. Pret: 20 lei. https://imgur.com/aEeSV9n 546. Procesoare PC: a) Intel Dual core 6300 1.80GHz/2M/1066/06 Pret: 10 lei. b) AMD Athlon64 X2 Dual core AD04000IAA5DD 2.1GHz/512/1066 Pret: 20 lei. c) AMD Athlon64 ADA3000DAA4BW 1.80GHz/512/1066 Pret: 12lei. https://imgur.com/DiHr3nu Link spre comentariu
yo9hrb Postat Februarie 9, 2023 Partajează Postat Februarie 9, 2023 Acum 6 minute, cmariuss a spus: Se adauga: 544. Transformator 190VA provine din dezmembrarea unui amplituner Sony STR GX511 Primar: 110V, 230V Secundar 1: (de forta): 38V-0-38V Secundar 2: 17V-0-17V Secundar 3: 3.8V Dimensiuni: lungime 8.8cm, inaltime 7.4cm, grosime pachet tole 5.2cm Pret: 50lei. https://imgur.com/AagMuKf https://imgur.com/6zA7hZu https://imgur.com/gisDqvV https://imgur.com/1ZCQYqC Secundarul de 3.8V ar putea furniza 1A? Link spre comentariu
cmariuss Postat Februarie 9, 2023 Autor Partajează Postat Februarie 9, 2023 Acum 2 ore, yo9hrb a spus: Secundarul de 3.8V ar putea furniza 1A? Secundarul de 3.8V este bobinat cu sarma CuEm 0.40 diametru. Link spre comentariu
yo9hrb Postat Februarie 10, 2023 Partajează Postat Februarie 10, 2023 E prea mic pentru ce imi trebuie mie. Spor la vanzare. Link spre comentariu
