Electronice diverse
cmariuss
489 rezervat dl @giliman66
Se adauga:
494. Unitate Floppy Disk 3.5".Pret: 4lei.
https://imgur.com/6FSRzHN
https://imgur.com/oAfkpDa
495. Mini casette recorder SonyM-2000. La prima vedere are curelele largite. Se
da ca defect. Alimentare exterioara 9V. Pret: 15lei.
https://imgur.com/UcI7AeC
https://imgur.com/HU44CYO
https://imgur.com/6nRDjOj
https://imgur.com/LKgD3Zb
https://imgur.com/3GGCrD4
496. Adaptor AllView Tx1 Quasar, 5V- 2000mA. Pret: 12lei.
https://imgur.com/6AbBC8S
497. Placa de baza Intel Socket 7, netestata din lipsa de sursa. Pret: 5 lei.
https://imgur.com/FZnSd4C
https://imgur.com/NlbmKvS
498. Placa baza Asrock G31-M7 TE, se da cu doua memorii Ram DDR2 1GB,
Procesor Intel DualCore 3.0 GHz. Pret: 50lei.
https://imgur.com/2HaOGK4
https://imgur.com/fPKn8ii
Au mai ramas:
 1. Tv Samsung UE32j4500AW, cu ecran spart, se da pentru piese:
Barete LED-uri: V5DN-320SMO-R4 Pret: 20 lei
1.Mainboard: BN41-02360 Pret: 32 lei.
https://imgur.com/a/iy4S5ZM
 2. Mainboard Vestel 17MB62-1. Pret: 17 lei
https://imgur.com/75Cf5hG
3. Barete Led D2GE-460SCA-R3 (3 buc)- 5 lei/buc.
https://imgur.com/3COXrCZ
 9. Cabluri Scart. Pret: 4 lei bucata.
https://imgur.com/RSGqalj
20. Difuzoare recuperate dintrun tv Thomson, 8 ohm, dimensiuni 20x5,5x2,5 - 5
lei.
https://imgur.com/T5dnTZN
 41. Drosere Vassloh/Schwabe 18-28W. Pret: 5 lei/buc.
https://imgur.com/uLXZfAb
51. Docking Station HP2013. Se vinde ca defect. Fara cablu alimentare. Pret: 3
lei.
https://imgur.com/IOpGY8z
67. Modul inalta tensiune dintrun copiator canon. Pret: 9 lei.
https://imgur.com/4usBMHS
https://imgur.com/NiIUhjC
95. Tuner JS-6H2/121. Pret: 3 lei.
https://imgur.com/0uqqKgq
 115: HDD 3,5" Hitachi 160GB, testat si instalat Windows7. Pret: 18 lei.
https://imgur.com/OdWCTHY
116: HDD 3,5" WD, 80 GB, testat. Pret: 15 lei.
https://imgur.com/HT5lJxe
164. Memorii Ram, DDR2, 512Mb, testate. Pret: 3 lei ambele.
https://imgur.com/j695ShP
217. Sursa tv Dong-Yang BN96-02580A Pret: 22 lei.
https://imgur.com/tZRWUn0
Suruburi:
82. Surub M5 cu guler, torx T20, cote in poza de mai jos. Pret: 0.35 lei/ 100g
sau 100 buc- 2.5 lei. Disponibile 1 kg.
https://imgur.com/jATZ700
https://imgur.com/Wh2fXId
83. Surub pt plastic cu guler, torx T20, cote in poza de mai jos. Pret 0.5
lei/100g  sau 100 buc- 1 lei. Disponibile 2 kg.
https://imgur.com/G8eOpez
https://imgur.com/npSbWoC
84. Suruburi pt plastic, torx T8, cote in poza de mai jos. Pret: 1500 buc-  1
leu.
Disponibile 10 kg.
https://imgur.com/Kodbtx9
https://imgur.com/EnEQ6Xe
85. Arcuri, cote in poza de mai jos. Pret: 2,5 lei/ 100g. Disponibile 100 g.
https://imgur.com/fXSwir7
https://imgur.com/QKfSNQm
 227. Sursa Plisch FMS-100 (recuperata dintrun aparat de masura/analiza semnal
TV)
Uin: 195- 265V, 47-63Hz, Putere = 250VA
Tensiuni: 5V, 7,5V, -5V, -12V, 24V
Realizata cu componente de calitate: Philips, Siemens, Motorola,Wima etc.
Sursa a fost reparata o data in 2003 de Antena Hungaria Kft.
Pret: 60 lei.
https://imgur.com/J1LNTxB
https://imgur.com/IPB11HQ
https://imgur.com/oFZz2l9
https://imgur.com/x5b415j
https://imgur.com/8XaEBLF
https://imgur.com/yMpTrKt
https://imgur.com/2uJ8xU0
https://imgur.com/n8O62DK
https://imgur.com/fqdWvLC
https://imgur.com/QBbTVui
https://imgur.com/Jqpfgcc
https://imgur.com/lDjYxh7
231. Set difuzoare tv Samsung UE32J4500AW, cod BN96-36052A, 6 ohm, 5VA.
Pret: 5 lei.
https://imgur.com/bEJ0l9M
https://imgur.com/3fzEg0V
242. Vana gaz Sigma 845 (Vaillant). Pret: 4 lei.
https://imgur.com/MprfpGO
246. Adaptoare Nokia ACP-12E, nefolosite.
5,7 V, 800 mA. Cablu ~ 1.8 m. Disponibile 2 bucati. Pret: 4 lei/buc.
https://imgur.com/WWHA3E3
254. Set difuzoare Viefu 30041403 (recuperate dintro plasma Vortex), 8 ohm, 12
W. Pret: 5 lei.
https://imgur.com/k5ZW4Ot
 255. Set difuzoare OHC 300772s1, 8 ohm, 5W. Pret:5 lei.
https://imgur.com/KZkRhK1
https://imgur.com/xxerTCC
264. Contoare electromagnetice SI-47. Doua bucati. Pret: 6 lei/buc.
https://imgur.com/qTMsp21
268. Micro filtru DSL HWMF-140. Nou. Pret: 4 lei.
https://imgur.com/iSX4t3y
276. Temporizator mecanic cuptor cu microunde: durata temp 30 min, contactele
suporta 16A. Pret: 5 lei.
https://imgur.com/oy1OyAI
283. Sarma nichelina NiCr Nikrothal 80.
Diametru 0.2 mm, rezistenta 35,80 ohm/m, temperatura max de lucru 1200*C,
conductibilitate termica/100°C Wm-1C-1-15,0
Pret: 0.20 lei/metru liniar.
https://postimg.cc/k6Bfxn4r
https://postimg.cc/KKQHPqDT
284. Transformator 30VA:
S1: 9V
S2: 24V
Pret: 14 lei.
https://postimg.cc/5X9Xxvtq
286. Releu Sigma cu soclu. Pret: 12 lei.
https://postimg.cc/23BvJ4q1
https://postimg.cc/Sntxkv3k
287. Releu Schrack ZG z60 720. Pret: 9 lei.
https://postimg.cc/xcvmjn3Y
https://postimg.cc/NyJmhD7H
288. Releu combina frigorifica General Electric. Pret: 4 lei
https://postimg.cc/PvZwwjGW
291. CD/ROM/DVD ROM laptop Toshiba SD-R2202. Pret: 2 lei.
https://postimg.cc/fJf3n5MR
https://postimg.cc/KKwjrHDJ
320. Placa PCI -5 porturi USB. Pret: 3 lei
https://postimg.cc/v4tv15TY
324. Din dezmembrarea unui LED tv, Blaupunkt BN32H1032eeb, urmatoarele:
324a. Mainboard TP.MS 3663S.PB818 (t-con v320bj8-q01, si panel cx315dledm).
Pret: 30 lei.
https://postimg.cc/kDbM76H8
https://postimg.cc/mPbT3dgN
https://postimg.cc/McHxNvRn
https://postimg.cc/yWcKMqJy
324b. Set 2 barete LED, HL-00320A30-0601S-07A3.Pret: 15 lei.
https://postimg.cc/tnW9kw6D
https://postimg.cc/ZB1Tr4WC
324C. Set difuzoare 8ohm/11W, LE-32Z1 SPK CVR-R, PD-1908027. Pret: 8 lei.
https://postimg.cc/N26wmThz
324d. Set picioruse. Pret: 5 lei.
328. Releu Matsushita jh1a-ac220v
Bobina: 220Vac
Contact: 30A
Pret: 12 lei.
https://postimg.cc/9Rv60Mch
333. Componente din dezmembrarea unui tv Fujitsu Siemens Myrica VQ40-1. Toate
componentele find in stare de functionare, problema tv-ului era sursa.
333a. Placa de baza Conrac + tuner Philips. Pret: 8 lei.
https://postimg.cc/ctYZQ8vS
https://postimg.cc/6759D3mr
https://postimg.cc/0MybdZvq
https://postimg.cc/CR0MsJC6
340. HDD Western Digital 160GB (WDdata lifeguard diagnostic).Pret: 15 lei
https://postimg.cc/62vXYs5G
341. HDD Seagate Barracuda 80GB (testat cu Data LifeGuard Diagnostics). 2 bucati
Pret:9 lei buc
https://postimg.cc/K18hC38b
https://postimg.cc/k2YPCM2b
362. Ventilatoare Nidec Betav. Doua bucati C32957-58, 12V- 0,29A. Una bucata
C34637-58, 12V- 0,13A. Pret: 8 lei toate.
https://imgur.com/mFUdq3h
382. Convertor DC/DC 60 W:
Tensiune intrare: 18-36V
Tensiune iesire: 5,0 V/ 12 A
Pret: 22 lei
https://postimg.cc/QB2SbSf3
https://postimg.cc/34hfhnmZ
 385. Alarma auto Thunder
Pret: 15 lei.
https://postimg.cc/w3c3xtkV
https://postimg.cc/kR9rhg6M
388. Set difuzoare 6ohm 8W, recuperate dintrun Vortex Led-32ck600.
Pret: 5 lei.
https://postimg.cc/1VHxx1wG
 389. Alarma auto. Pret: 9 lei.
https://postimg.cc/G4pD1GMM
393.  Placa de baza si modul comunicatie imprimanta Epson EU-96. Pret: 4 lei.
https://postimg.cc/HJy4fbxq
https://postimg.cc/R3kJf8v8
395. Convertor Scart-RCA/S-video. Pret: 5 lei.
https://postimg.cc/Hj73qDJJ
396. Alarma auto KD500. Pret: 12 lei.
https://postimg.cc/75w1CMHB
https://postimg.cc/LgPkPxgW
 405. Bare dreptungiulare de aluminiu. Dimesiune: 5.0cm x 2.5cm, si lungime de
43cm.
Greutate: 1.35 Kg. Am patru bucati. Pret: 27 lei/buc.
https://postimg.cc/XZ56cBzr
https://postimg.cc/Hc4GFDHH
412. Sursa in comutatie NYKO:
Sec1: 24Vcc
Sec2: 8Vcc
Pret: 10 lei.
https://imgur.com/3B6gASl
417. Termostate industriale TehnoTrust Bistrita. Domeniu de temperatura 0-400*C.
Butoanele potentiometrelor sunt rupte. Nu am senzori PT-100 sa le testez, se
vand ca defecte:
Pret: 16 lei buc sau ambele 30 lei.
https://imgur.com/d20lTyc
https://imgur.com/xaTj8tJ
https://imgur.com/UVcinYS
 423. Sursa SMPS 2405
Intrare: 24Vca-90Vca (galben-rosu)
Iesire:  24Vcc 550ma (negru-rosu)
Pret: 13 lei.
https://imgur.com/gilI2Ny
https://imgur.com/l74NtE6
426. Lampa 12V/4W (soclu baioneta), corp alama, capac crom. Se poate utiliza
pentru iluminarea scalei la radio, iluminarea vu-metrelor cu ace, etc Pot face
rost de mai multe. Pret: 10 lei/buc
https://imgur.com/H4oPeLO
https://imgur.com/FgNGxDi
https://imgur.com/AaweLfD
427. Sticla scala radio pe lampi Minerva Cornette.
https://imgur.com/a6MKoiM
https://imgur.com/AstVy7F
Pret: 25 lei.
429. Rezistenta 650W incalzire cafetiera, cu termostat.
https://imgur.com/2iCunrD
Pret: 7 lei.
 430. Sine trenulet modelism:
- sectiuni curbe 9-bucati
- sectiuni drepte 3 bucati
- ecartament 30mm
- diatru exterir - 88 cm
- diametru interior - 68 cm
Pret: 10 lei.
https://imgur.com/xVpl4aA
https://imgur.com/BvW9Ics
432. Sursa Tv Sharp CA0009WJN1
Tensiuni masurate: 9V, 12V
Pret: 18 lei.
https://imgur.com/ZTxFUuU
 434. Casti telefonice:
Primo -CT-3B, productie Japonia, 6 bucati.
Impedanta: 780 ohm.
Pret: 2 lei.
https://imgur.com/0hmpJFJ
435. Casti telefonice:
Primo DH-51, productie Japonia, 4 bucati.
Impendanta: 290 ohm.
Pret: 2lei.
https://imgur.com/hO1mFIJ
436. Tablite cupru cu grosimea de 0,5mm. Cu urmatoarele dimensiuni:
a)  35 x 5 cm. Pret: 10 lei.
https://imgur.com/Zu0Gzq8
c)  16 x 11 cm Pret: 7 lei.
https://imgur.com/KSj4P3C
d)  16 x 14 cm. Pret: 10 lei.
https://imgur.com/cWwzRNZ
e)  16 x 10 cm. Pret: 8 lei.
https://imgur.com/LP4tiwe
f)  20,5 x 10 cm. Pret: 12 lei.
https://imgur.com/GQOWsBy
g)  16 x 9 cm. Pret: 8 lei.
https://imgur.com/Xd20iS4
h) 16 x 10 cm Pret: 8 lei.
https://imgur.com/tFOO6qz
i)17 x 15 cm forma eliptica. Pret: 10 lei.
https://imgur.com/EZFmfhu
j)  24 x 8/11.5 cm patrulater. Pret: 10 lei.
https://imgur.com/1O3uosh
439. Releu RP-102-3P
Ua= 24Vcc, R= 346 ohm
Contacte: 2x3, fara soclu.
Pret: 19 lei.
https://imgur.com/NKClW8K
https://imgur.com/bGrPZ5h
https://imgur.com/v3APLRq
440. Relee (doua) RP 92
Ua = 220Vca, R= 4410 ohm
Contacte: 2x3, cu socluri.
Pret: 19 lei/buc.
https://imgur.com/kXEgFs1
https://imgur.com/ijfgFLZ
https://imgur.com/1ExxIPf
https://imgur.com/FB6vJtb
https://imgur.com/aB8Gj6g
441. Acumulator Li-Ion pentru laptop, model: 8560, nou. Tensiune: 11.1V,
7800mAh, 87Wh. Pret: 55 lei.
https://imgur.com/RWpiKNZ
https://imgur.com/0Lw48gf
442. Acumulator Li-Ion pentru laptop model: 6720, nou. Tensiune: 11,1V, 4400mAh,
49Wh.
Pret: 45 lei.
https://imgur.com/hdignDl
https://imgur.com/Zk24eiE
445. Siguranta fuzibila MNC pentru amplificatoare auto. Pret: 3 lei.
https://imgur.com/433srrq
447. Adaptor telefon (pentru priza UK)
4,5V-5,5 V, 500mA . Pret: 3 lei.
https://imgur.com/8FZVIdS
448. Modul alarma auto SPAL AS-90. Pret: 8 lei.
https://imgur.com/O06QcqL
https://imgur.com/Fl2flAH
 450. Motor recuperat dintrun magnetofon Tesla CM-130. Pret: 30 lei.
https://imgur.com/9tdxJE8
https://imgur.com/JfJ1ueU
https://imgur.com/xwh3V4g
452. Relee industriale RP-92, 2 x 3 contacte.
Tensiune de alimentare: 42V 50Hz, 220 Ohm, cu socluri, doua bucati.
Pret: 19 lei/buc.
https://imgur.com/fy5qwJ6
https://imgur.com/fDEM118
 453.Surub M10 brunat, grupa 8.8, cu lungimea 30mm. Pret: 0,65 lei/buc.
https://imgur.com/zari9xb
454. Adaptor pentru laptop Dell,nou, inlocuitor, model LD-065/334/195/011, mufa
7,4x5.0 well
19,5V 3,34A 65W Pret: 70lei.
https://imgur.com/Nz312Pf
https://imgur.com/5YuPfy3
https://imgur.com/KhqCJVh
https://imgur.com/u9jj1SR
455. Adaptor nou LW-090/462/195/002 inlocuitor pentru Dell Inspiron 3147 3148
3152 3153 3157 3158 3162 3164 3168 3179 Dell Latitude 7202 3379 7350 E5450
19,5V 4,62A  90W Pret: 60 lei.
https://imgur.com/Z3Sz7NC
https://imgur.com/iwt4aQC
https://imgur.com/qr9HXxP
456. Adaptor nou, inlocuitor pentru laptop Lenovo ND-A065W2002250,pentru
ideapad 100 / ideapad 110 / 310 / Yoga 510 / B50 / AIR12 AIR13 AIR15. Conector:
4.0x1,7mm.
20V 2,25A 45W. Pret: 55lei.
https://imgur.com/nSQ5Jkf
https://imgur.com/Ge7UTMH
https://imgur.com/h345Zb9
https://imgur.com/2QFTySW
 457. Procesoare  Intel Pentium Dual Core
1,60 GHz/1M/800/06 SLA93
Doua bucati. Pret: 12 lei/buc.
https://imgur.com/DwGbNSR
458. Procesor Intel Pentium Dual Core E2220
2,40GHz/1M/800/06 SLA8W
Pret: 15 lei.
459. Procesoare Intel Celeron D 336 SL7TW, SL8H9
2,80 GHz/256/533/04A
Doua bucati Pret: 10 lei/buc.
460. Procesor Intel P4
2,80GHz/1M/800/04A SL7PR
Pret: 15 lei.
462. Procesor P4
3,06GHz/1M/800 SL7J6
Pret: 15 lei
464. Procesor P4
3,20GHz/1M/800 SL7J7
Pret:12 lei.
466. Procesor P4
2,80GHz/1M/533  SL7PK
Pret: 15 lei.
 467. Memorii PC DDR2 -512MB. Pret: 3 lei/buc.
https://imgur.com/3m300N6
469. Memorii PC DDR2 - 1GB. Pret: 7lei/buc.
https://imgur.com/WtKXRBp
470. Led driver 100W, tensiune 27-36V, 3000mA. IP65. Pret: 45lei.
https://imgur.com/SLMKrVZ
472. Telecomanda Siemens-Fujitsu. Pentru TV LCD Fujitsu Siemens Myrica VQ40-
1.Pret: 9 lei.
https://imgur.com/grYYsWS
473. Vu-metre fara cadran, cel din stanga e cu acul pe centru, dar are acul
deformat. Pret: 9 lei toate trei.
https://imgur.com/j9Uw7Ar
 474.Placa controler electronic pentru pompe de caldura. Mai are in componenta
un
transformator 10W, 12V 0.600A, un releu bipolar cu bobina 230V, contacte 35A, un
senzor de temperatura, un conensator 4uF/450V, cabluri aferente. Din pacate ii
lipseste
displayul.
Mai multe informati pe situl producatorului, cu google translate
http://gzjsdz.com/KS1.htm
Pret: 25 lei.
https://imgur.com/lg1bfYR
https://imgur.com/VuI6JGe
https://imgur.com/Y0tzqsy
https://imgur.com/Ra80Wdv
https://imgur.com/DGScxqA
477. Lupa convergenta,menisc convergent,diametru 100mm, grosime 30mm, distanta
focala 10 cm, putin ciobita la margine, in mod normal nu afecteaza cu nimic.
Pret: 15lei.
https://imgur.com/zLtM30B
https://imgur.com/MSohlEZ
481. Releu Relog 24V, IP40, 4perechi de contacte.Pret: 12lei.
https://postimg.cc/2LqCQqXB
https://postimg.cc/3WWr56JJ
482.Jetoniera Comestro RM5evolution, pentru aparate de cafea, sau pentru alte
aplicatii. Caracteristici:
    Viteza de acceptare: 3 monede/secunda
    Diametru monede acceptate: 16 ÷ 31.5
    Grosime monede acceptate: pana la 3,3 mm
    Dimensiuni ( LxHx W): 89 x 102 x 46,4
    Greutate: 185 g
    Temperatura operare: 0 °C ÷ 55 °C
    3 perechi de senzori inductivi care sunt folositi pentru a procesa 6
parametrii diferiti in ceea ce priveste materialele si masa
    3 perechi de senzori optici  pentru a determina diametrul monedelor
    Dispozitiv mecanic anti-phishing
    Dispozitiv electronic anti-phishing
    Sistem automat de compensare a senzorilor optici pentru variații de
temperatura, tensiune și iluminat.
https://postimg.cc/PpVtvbKj
Pret: 20 lei.
483.Mp3 player auto Akai CA010A-1011U
Pret: 30 lei.
https://imgur.com/vSXVAKK
https://imgur.com/9BhjARd
486. Sursa in comutatie
Ue= 12V - 3A
Pret: 12 lei.
https://imgur.com/uL1ZVwA
487. Ceas bord recuperat dintrun Ford Mondeo
Pret; 9 lei.
https://imgur.com/eDKC9EF
 488. Adaptor Philips 7W 13V- 400mA, cablu are lungime 2.5m. Pret: 12lei.
https://imgur.com/fjaQP1k
https://imgur.com/cO86KTm
491. Tastatura laptop Chicoby mp-10h96f06886, folosita, netestata. Pret: 5lei.
https://imgur.com/oj0zbeC
https://imgur.com/JT5DQeW
492. Tastatura laptop NSK-DV0BC 1D pentru Dell Latitude E6420 US, folosita,
https://imgur.com/O8eLzGZ
https://imgur.com/lmnzt3x
493. Tastatura laptop NSK-DS0UC 1D pentru Dell Latitude E4310, folosita
nedestata. Pret: 5lei
https://imgur.com/D7mqRzJ
https://imgur.com/q8T8biL
  • 2 săptămâni mai târziu...
La multi ani !
Se adauga:
https://imgur.com/uLHHGjZ
499. Actuatoare automatizare porti Hanning  K88-136. Doua bucati. Unul dintre el
nu are carcasa completa !
Alimentare: 220V-240Vca, 50Hz, 1,2A
Putere: 250W
Cursa maxima: 20cm
Comanda pneumatica
Pret: 75 lei ambele.
https:/imgur.com/2Djilhl
https://imgur.com/kuRfJ4H
https://imgur.com/iE0s4aO
https://imgur.com/hyPKYxx
https://imgur.com/vFWY6sr
https://imgur.com/YpLhOyU
https://imgur.com/7dUEVmF
https://imgur.com/b4ZdPoC
https://imgur.com/OYh66Dy
500. Sursa in comutatie japoneza YEC (din dezmembrarea unei multifunctionale
xerox).
Alimentare 100-240Vca
Iesire: 5V 1A
        24V 2A
Pre: 17 lei.
https://imgur.com/XM64S2A
https://imgur.com/Yp3rnSv
https://imgur.com/lgnhEP9
501. Rezistenta incalzire acvarii. Resunn rh-9000. Putere. 75W. temperatura
reglabila intre 21 si 32*C.
Pret: 25lei.
https://imgur.com/vaZ7EIE
https://imgur.com/WRs77ZS
Se adauga:
502. Adaptor imprimanta Delta. Ue= 30V - 0.83A
Pret: 15 lei.
https://imgur.com/yOq1wEv
503. Placa imprimanta Lexmark z55
Pret: 4 lei.
https://imgur.com/zLrVzY2
504. Cablu imprimanta pentru portul paralel- 1,5m.
Pret: 10 lei.
https://imgur.com/Gu7GgUj
505. Modul control, iluminare si ventilator recuperat dintro cab de dus.
Tranzistoarele sunt 2SA8050, relee se alimentaza la 12V.
Pret: 7 lei.
https://imgur.com/ZZ7QIoS
https://imgur.com/2YjP7nU
https://imgur.com/1zkeeHR
506. Lupa biconcava simetrica. Diametru: 10cm, grosime max 2cm, grosime minima
0.5cm. Are cateva mici ciobituri pe margine. Pret: 15 lei.
https://imgur.com/okQ3Gtb
507. HDD Seagate 80GB PC interfata S-ata, are instalat windows XP
Pret: 12lei
https://imgur.com/MptLAFn
508. HDD Seagate 80GB PC, interfata S-ata, fara OS.
Pret: 9 lei.
https://imgur.com/lsa5lbI
Se adauga:
510: Memorii laptop:
1) Memorie laptop 64MB, PC100,133MHz, SDRAM- Pret: 4 lei.
2) Memorie laptop 512MB, PC133, 133MHz, SDRAM- Pret: 5lei.
3) Memorie laptop Samsung 512MB, DDR2, PC2-4200S, 533MHZ. Pret: 10lei.
4) Memorie laptop Good RAM, 1GB, PC2-5300, DDR2. Pret: 10lei.
5) Memorie laptop Kingston, 256MB, PC133, SDRAM. Pret: 5lei.
6) Memorie laptop Samsung, 1GB, PC2-6400, 667MHz, DDR2: Pret: 15lei.
7) Memorie laptop Monya, 1GB, PC2-5300-555, DDR2. Pret: 15lei.
8) Memorie laptop Hynix 2GB, PC3-12800s DDR3. Pret: 25 lei.
9) Memorie laptop Samsung 2GB, PC3-10600s DDR3. Pret: 25lei.
10)Memorie laptop Samsung 2GB, PC3-8500s  DDR3. Pret: 25lei.
https://imgur.com/dSpQkWO
https://imgur.com/wspNz9W
https://imgur.com/ESA9ZoZ
https://imgur.com/PAB3ng4
https://imgur.com/jrUlO1W
https://imgur.com/8WzJNwZ
511. Placa video pc NVidia GeForce FX5500 256MB
DDR+DVI+TV Out
Pret: 15 lei.
https://imgur.com/zbkuuo9
https://imgur.com/sBNiCMu
Se adauga:
512. Cablu de alimentare amplificatoare auto Hama, cu siguranta de putere-
lungime 5m. Pret: 20lei.
https://imgur.com/o1axFlI
513. Procesor AMD-K6-2/500AFX, 499.99MHz. Pret: 10lei.
https://imgur.com/iEBqvwq
514. Procesor Cyrix Cx486 DX2 66 + radiator, 66MHz. Pret: 20lei.
https://imgur.com/gdA4XHD
Editat de cmariuss
Se adauga:
515. Procesoare PC:
a) Intel Pentium D915
2.80GHz/4M/800/05A
pret: 20 lei.
b) Intel Celeron
2.80GHz/256/533
Pret: 15 lei.
c) Intel Celeron D
2.40GHz/128/400
Pret: 12 lei.
https://imgur.com/fogfv5x
516. HDD Seagate Barracuda 160GB, pc, s-ata
Are instalat Windows 7 Ultimate.
Pret: 15 lei.
https://imgur.com/w8rD21N
517.Doua Memorii PC TakeMS 512MB, DDR2-800-CL5.
Pret: 6 lei ambele.
https://imgur.com/oV6c79v
518. Cooler procesor.
Pret: 7 lei.
https://imgur.com/g0Ua9Jl
519. Placa alimentare tV LG 26LG3000, serie 715T3181-1
Tensiuni: 5Vcc, 0-3A; 12Vcc- 0.1-1.5A; 24Vcc- 0.1- 4A.
Pret: 20 lei.
https://imgur.com/01T8uXG
https://imgur.com/8No8wN1
https://imgur.com/FoeELHo
520. Placa electronica Brahma Micro 350.R01 pentru Brahma digit
Pret: 25lei. Rominstal o vinde cu 2250lei...
https://imgur.com/Cs5GS0h
https://imgur.com/4LO6gpk
521. Placa electronica Brahma.
Transformatorul are 10VA, tensiune 2x9V.
Pret: 12lei.
https://imgur.com/rPBpG4M
https://imgur.com/hVUl8tl
