GMCD Postat August 13, 2022 Partajează Postat August 13, 2022 Va rog sa mai adaugati si: 260. LED driver Gelux model LD-361200-104L. Tensiune: 20-36V, 1050mA. Doua bucati, unul are cablu mai scurt. Pret: 10 lei bucata. - ambele 292. Filtru retea/suport doua sigurante. Pret: 3 lei. 333b.Placi invertoare back-light 24v40w2s(HIP0212A). Pret: 9 lei/buc. sau 15 lei ambele. - ambele 415: Placa AM-8661 Veryo, combina audio hi-fi, netestata: Se pot recupera: 2xTDA7266, TA2057N, 5buc 4558D, 7808, TC9422F. Pret: 9 lei. Va trimit pe mp datele de livrare. Link spre comentariu
Vittorino Postat August 13, 2022 Partajează Postat August 13, 2022 Va salut! Daca mai sunt valabile, sunt interesat de: 303. Telecomanda radio 27MHz, fara antena telescopica. Pret: 7 lei. https://postimg.cc/K167VN9Z https://postimg.cc/S2q6QKF3 304. Telecomanda infrarosu. Pret: 5 lei. https://postimg.cc/GHSxPrGT https://postimg.cc/8sZRDDyX 305. Telecomanda radio 27MHz, fara antena si capac bateri. Pret: 3 lei. https://postimg.cc/dLXGk6c8 https://postimg.cc/QBg7zr9b. 350. Transformator recuperat dintrun amplituner Denon PMA-715R. Secundar: 35V-0-35V Pret: 40 lei. https://postimg.cc/hJrdmjyP https://postimg.cc/MfcMgYWv https://postimg.cc/MX4jVgDR 354. Condensatori electrolitici Nichicon 10.000uF/56V. Pret: 14 lei perechea. https://postimg.cc/FfQycwhG https://postimg.cc/N9dm3MmP 384. Comutator 4 galeti si 10 poziti. Recuperat. URSS. Pret: 12 lei. https://postimg.cc/R6wdbfYn https://postimg.cc/9DNL4cTz https://postimg.cc/0KxngjgX 413: Placa radio sovietic VEF206. https://imgur.com/WQR7fft https://imgur.com/N7d2fbu Pret: 12 lei. 418. Transformator amplituner Delia: Pret: 30 lei. https://imgur.com/Y7FLG6T https://imgur.com/pW21KuE https://imgur.com/uive4Oq 420. Placa tuner (are si antena de ferita). Claviatura in stare buna. Pret: 12 lei. https://imgur.com/rX06vhL 421. Radiator Al amplificator final. Pret: 10 lei. https://imgur.com/Be8p7k0 https://imgur.com/FJHbiAH 422. Suport siguranta, intrerupator, conector jack 6.3mm, butoane potentiometre. Pret: 5lei. https://imgur.com/L5T1Ca Revin pe privat cu datele de contact. Multumesc mult. Link spre comentariu
cmariuss Postat August 16, 2022 Autor Partajează Postat August 16, 2022 Au mai ramas: 1. Tv Samsung UE32j4500AW, cu ecran spart, se da pentru piese: Barete LED-uri: V5DN-320SMO-R4 Pret: 22 lei 1.Mainboard: BN41-02360 Pret: 35 lei. https://imgur.com/a/iy4S5ZM 2. Mainboard Vestel 17MB62-1. Pret: 19 lei https://imgur.com/75Cf5hG 3. Barete Led D2GE-460SCA-R3 (5 buc)- 6 lei/buc. https://imgur.com/3COXrCZ 9. Cabluri Scart. Pret: 4 lei bucata. https://imgur.com/RSGqalj 15. Set manere pentru aparat, aluminiu, dimensiuni: lungime 22cm, latime 6cm, grosime 0.7-0.9cm. Pret: 15 lei. https://imgur.com/nzuRB4w 20. Difuzoare recuperate dintrun tv Thomson, 8 ohm, dimensiuni 20x5,5x2,5 - 6 lei. https://imgur.com/T5dnTZN 27. Cablu adaptor HP display/ DVI (nou). Pret: 7 lei. https://imgur.com/e5q2hGb 41. Drosere Vassloh/Schwabe 18-28W. Pret: 5 lei/buc. https://imgur.com/uLXZfAb 51. Docking Station HP2013. Se vinde ca defect. Fara cablu alimentare. Pret: 4 lei. https://imgur.com/IOpGY8z 67. Modul inalta tensiune dintrun copiator canon. Pret: 9 lei. https://imgur.com/4usBMHS https://imgur.com/NiIUhjC 94. Difuzoare (doua) recuperate dintro plasma. Impedanta 8 ohm, putere 10 W. Dimensiunile difuzorului: 13cm x 4,5 cm. Pret: 7 lei. https://imgur.com/W5Lk3oA 95. Tuner JS-6H2/121. Pret: 3 lei. https://imgur.com/0uqqKgq 115: HDD 3,5" Hitachi 160GB, testat si instalat Windows7. Pret: 20 lei. https://imgur.com/OdWCTHY 116: HDD 3,5" WD, 80 GB, testat. Pret: 15 lei. https://imgur.com/HT5lJxe 164. Memorii Ram, DDR2, 512Mb, testate. Pret: 3 lei ambele. https://imgur.com/j695ShP 216. Difuzoare BN96-02586A (Samsung 22" LE27T51B) 16 ohm, 5W. Pret: 7 lei. https://imgur.com/RgYGACS 217. Sursa tv Dong-Yang BN96-02580A Pret: 28 lei. https://imgur.com/tZRWUn0 Suruburi: 82. Surub M5 cu guler, torx T20, cote in poza de mai jos. Pret: 0.4 lei/ 100g sau 100 buc- 3 lei. Disponibile 3 kg. https://imgur.com/jATZ700 https://imgur.com/Wh2fXId 83. Surub pt plastic cu guler, torx T20, cote in poza de mai jos. Pret 0.5 lei/100g sau 100 buc- 1 lei. Disponibile 5 kg. https://imgur.com/G8eOpez https://imgur.com/npSbWoC 84. Suruburi pt plastic, torx T8, cote in poza de mai jos. Pret: 1000 buc- 1 leu. Disponibile 10 kg. https://imgur.com/Kodbtx9 https://imgur.com/EnEQ6Xe 85. Arcuri, cote in poza de mai jos. Pret: 2,5 lei/ 100g. Disponibile 100 g. https://imgur.com/fXSwir7 https://imgur.com/QKfSNQm 227. Sursa Plisch FMS-100 (recuperata dintrun aparat de masura/analiza semnal TV) Uin: 195- 265V, 47-63Hz, Putere = 250VA Tensiuni: 5V, 7,5V, -5V, -12V, 24V Realizata cu componente de calitate: Philips, Siemens, Motorola,Wima etc. Sursa a fost reparata o data in 2003 de Antena Hungaria Kft. Pret: 68 lei. https://imgur.com/J1LNTxB https://imgur.com/IPB11HQ https://imgur.com/oFZz2l9 https://imgur.com/x5b415j https://imgur.com/8XaEBLF https://imgur.com/yMpTrKt https://imgur.com/2uJ8xU0 https://imgur.com/n8O62DK https://imgur.com/fqdWvLC https://imgur.com/QBbTVui https://imgur.com/Jqpfgcc https://imgur.com/lDjYxh7 231. Set difuzoare tv Samsung UE32J4500AW, cod BN96-36052A, 6 ohm, 5VA. Pret: 8 lei. https://imgur.com/bEJ0l9M https://imgur.com/3fzEg0V 242. Vana gaz Sigma 845 (Vaillant). Pret: 7 lei. https://imgur.com/MprfpGO 245. Adaptoare Nokia ACP-7E (cu transformator). Nefolosite. 3,7V 355mA, 1,3 VA. Cablu ~ 2m. Disponibile 5 bucati. Pret: 4 lei/buc. https://imgur.com/q0myNA5 https://imgur.com/KVp2lq5 246. Adaptoare Nokia ACP-12E, nefolosite. 5,7 V, 800 mA. Cablu ~ 1.8 m. Disponibile 4 bucati. Pret: 4 lei/buc. https://imgur.com/WWHA3E3 254. Set difuzoare Viefu 30041403 (recuperate dintro plasma Vortex), 8 ohm, 12 W. Pret: 7 lei. https://imgur.com/k5ZW4Ot 255. Set difuzoare OHC 300772s1, 8 ohm, 5W. Pret: 7 lei. https://imgur.com/KZkRhK1 https://imgur.com/xxerTCC 264. Contoare electromagnetice SI-47. Doua bucati. Pret: 7 lei/buc. https://imgur.com/qTMsp21 268. Micro filtru DSL HWMF-140. Nou. Pret: 4 lei. https://imgur.com/iSX4t3y 276. Temporizator mecanic cuptor cu microunde: durata temp 30 min, contactele suporta 16A. Pret: 7 lei. https://imgur.com/oy1OyAI 277. Temporizator mecanic Combolo Milano (cuptor electric), durata temporizare 5min, contactele suporta 10A. Pret:5 lei. https://imgur.com/ONf3Esg https://imgur.com/ZB1G8ZG 278. Pompa cafetiera Ceme Italia, 240V, 47W. Pret: 6 lei. https://imgur.com/cG7RGK1 283. Sarma nichelina NiCr Nikrothal 80. Diametru 0.2 mm, rezistenta 35,80 ohm/m, temperatura max de lucru 1200*C, conductibilitate termica/100°C Wm-1C-1-15,0 Pret: 0.25 lei/m. https://postimg.cc/k6Bfxn4r https://postimg.cc/KKQHPqDT 284. Transformator 30VA: S1: 9V S2: 24V Pret: 15 lei. https://postimg.cc/5X9Xxvtq 286. Releu Sigma cu soclu. Pret: 12 lei. https://postimg.cc/23BvJ4q1 https://postimg.cc/Sntxkv3k 287. Releu Schrack ZG z60 720. Pret: 9 lei. https://postimg.cc/xcvmjn3Y https://postimg.cc/NyJmhD7H 288. Releu combina frigorifica General Electric. Pret: 4 lei https://postimg.cc/PvZwwjGW 289. Releu solid state Ahly asr-25dd Comanda: 3-32 Vcc. Sarcina: 25A, 5-20Vcc. Pret: 27 lei. https://postimg.cc/2155pDH0 https://postimg.cc/NL1Fmb9k 291. CD/ROM/DVD ROM laptop Toshiba SD-R2202. Pret: 3 lei. https://postimg.cc/fJf3n5MR https://postimg.cc/KKwjrHDJ 309. Placa copiator Canon, FG1-9283. Pret: 15 lei. https://postimg.cc/B8tjSf1m https://postimg.cc/87ZFgzsF https://postimg.cc/hhC3vHvH 313. Adaptor Panasonic 6V, 500mA. Pret: 5 lei. https://postimg.cc/PPGYSJ8T 315. Difuzoare 6 ohm/ 11W, model 378G0110567ydx, Philips 32PHT4201. Pret: 7 lei/perechea. https://postimg.cc/SJyNQbBc https://postimg.cc/ykv6krKt 320. Placa PCI -5 porturi USB. Pret: 3 lei https://postimg.cc/v4tv15TY 321. Placa Agilent 82350B, nu am reusit sa o instalez in win7, se vinde ca defecta. Pret:4 lei. https://postimg.cc/DW55N13j https://postimg.cc/Wtx8x2xv 324. Din dezmembrarea unui LED tv, Blaupunkt BN32H1032eeb, urmatoarele: 324a. Mainboard TP.MS 3663S.PB818 (t-con v320bj8-q01, si panel cx315dledm). Pret: 45 lei. https://postimg.cc/kDbM76H8 https://postimg.cc/mPbT3dgN https://postimg.cc/McHxNvRn https://postimg.cc/yWcKMqJy 324b. Set 2 barete LED, HL-00320A30-0601S-07A3.Pret: 19 lei. https://postimg.cc/tnW9kw6D https://postimg.cc/ZB1Tr4WC 324C. Set difuzoare 8ohm/11W, LE-32Z1 SPK CVR-R, PD-1908027. Pret: 12 lei. https://postimg.cc/N26wmThz 324d. Set picioruse. Pret: 7 lei. https://postimg.cc/yWcKMqJy 328. Releu Matsushita jh1a-ac220v Bobina: 220Vac Contact: 30A Pret: 12 lei. https://postimg.cc/9Rv60Mch 333. Componente din dezmembrarea unui tv Fujitsu Siemens Myrica VQ40-1. Toate componentele find in stare de functionare, problema tv-ului era sursa. 333a. Placa de baza Conrac + tuner Philips. Pret: 12 lei. https://postimg.cc/ctYZQ8vS https://postimg.cc/6759D3mr https://postimg.cc/ctYZQ8vS https://postimg.cc/0MybdZvq https://postimg.cc/CR0MsJC6 333c. Doua perchi difuzoare 4ohm/5watt, 9cm x 5cm, cu aparatoare din plastic. Pret: 9 lei/perechea. sau 15 lei ambele perechi. https://postimg.cc/4YXZ9yZD https://postimg.cc/7CV52dpV 334.Modul de control al turatiei al ventilatorului de racire pentru radiator de tip auto (Mercedes). Pret: 12 Lei. https://postimg.cc/FYbRMws4 339. HDD Seagate Barracuda 200GB (testat cu Data LifeGuard Diagnostics). Pret: 19 lei. https://postimg.cc/18myPYML 340. HDD Western Digital 160GB (WDdata lifeguard diagnostic).Pret: 15 lei https://postimg.cc/62vXYs5G 341. HDD Seagate Barracuda 80GB (testat cu Data LifeGuard Diagnostics). 2 bucati Pret:9 lei buc https://postimg.cc/K18hC38b https://postimg.cc/k2YPCM2b 343: Autotransformator Uretea=236V Igol=1,2A Prize la 160V, 72V, 32V Dimensiuni: L= 9,8cm, H=8,2cm, grosime pachet tole 5,4cm. Pret: 19 lei. https://postimg.cc/94MWxQXf https://postimg.cc/3k98CvT6 https://postimg.cc/5HRfDWjS https://postimg.cc/TKT2DcZg 358. PCB cu 32 mufe BNC. Pret: 8 lei. https://postimg.cc/dkXgtVrF 362. Ventilatoare Nidec Betav. Doua bucati C32957-58, 12V- 0,29A. Una bucata C34637-58, 12V- 0,13A. Pret: 10 lei toate. https://imgur.com/mFUdq3h 364. Sursa Server AC Bel 332W 5V@25A 12V@16A 5Vstb@3A ! un ventilator este crapat si are o pala rupta, dar functioneaza. Pret: 15 lei. https://imgur.com/unPF0QC https://imgur.com/YO6nOXv https://imgur.com/Jp0AF3M 370. Transformator cablaj 5,7 VA: Secundar: 19,1V 300mA https://postimg.cc/qzTDTT62 Pret: 8 lei. 372. Transformator de cablaj Thermowatt 8VA: Secundar 1: 24 V Secundar 2: 15 V https://postimg.cc/wRKf3Kf8 Pret: 12 lei. 382. Convertor DC/DC 60 W: Tensiune intrare: 18-36V Tensiune iesire: 5,0 V/ 12 A Pret: 27 lei https://postimg.cc/QB2SbSf3 https://postimg.cc/34hfhnmZ 385. Alarma auto Thunder Pret: 19 lei. https://postimg.cc/w3c3xtkV https://postimg.cc/kR9rhg6M 388. Set difuzoare 6ohm 8W, recuperate dintrun Vortex Led-32ck600. Pret: 7 lei. https://postimg.cc/1VHxx1wG 389. Alarma auto. Pret: 10 lei. https://postimg.cc/G4pD1GMM 392. Sursa VCR Panasonic Vek4875. Realizata cu STK5392. Tensiuni: 45V, 12V, 17V, 5V, -30V. Pret: 12 lei. https://postimg.cc/dZBhbVGP https://postimg.cc/7bVM8HHZ https://postimg.cc/mtg3TvkN 393. Placa de baza si modul comunicatie imprimanta Epson EU-96. Pret: 6 lei. https://postimg.cc/HJy4fbxq https://postimg.cc/R3kJf8v8 395. Convertor Scart-RCA/S-video. Pret: 5 lei. https://postimg.cc/Hj73qDJJ 396. Alarma auto KD500. Pret: 12 lei. https://postimg.cc/75w1CMHB https://postimg.cc/LgPkPxgW 397. Transformator de cablaj Hahn 10W: Secundar1: 22V - 380mA Secundar2: 29V - 6,6mA Pret: 8 lei. https://postimg.cc/d7W9ckK5 404. Modul alarma auto CL1300. Pret: 8 lei. https://postimg.cc/RWLRGpp5 405. Bare dreptungiulare de aluminiu. Dimesiune: 5.0cm x 2.5cm, si lungime de 43cm. Greutate: 1.35 Kg. Am patru bucati. Pret: 32 lei/buc. https://postimg.cc/XZ56cBzr https://postimg.cc/Hc4GFDHH 408. Transformator T1-V2F P=10 VA. Sec: 12V-0-12V Pret: 10 lei. https://imgur.com/C3BCXFF 411. Sursa ATX Delux 400W P4. Pret: 25lei. https://imgur.com/6aBit6B https://imgur.com/9MHzrkW https://imgur.com/EuZsFo5 412. Sursa in comutatie NYKO: Sec1: 24Vcc Sec2: 8Vcc Pret: 12 lei. https://imgur.com/3B6gASl 414: Placa UPS KP-201, incompleta se vinde ca defecta Se poate recupera: releee, 8 trenzistoare RFP50N06 (fairchild), LM324, ULN2004 etc Pret: 12 lei. https://imgur.com/qYBnzoN https://imgur.com/078Qpvn https://imgur.com/VDgZ5Ir https://imgur.com/loijVfv 416. Filtru EMi KPL3008: 275V 50Hz 16A Pret: 7 lei. https://imgur.com/Uuj85lD 417. Termostate industriale TehnoTrust Bistrita. Domeniu de temperatura 0-400*C. Butoanele potentiometrelor sunt rupte. Nu am senzori PT-100 sa le testez, se vand ca defecte: Pret: 18 lei buc sau ambele 35 lei. https://imgur.com/d20lTyc https://imgur.com/xaTj8tJ https://imgur.com/UVcinYS Link spre comentariu
GMCD Postat August 22, 2022 Partajează Postat August 22, 2022 Am primit coletul. Piesele au ajuns cu bine. Va multumesc pentru bonus. Link spre comentariu
cmariuss Postat August 31, 2022 Autor Partajează Postat August 31, 2022 Disponibile. Link spre comentariu
floob Postat Septembrie 1, 2022 Partajează Postat Septembrie 1, 2022 Bună ziua, Vă rog să-mi rezervați următoarele: 333c. Doua perchi difuzoare 4ohm/5watt, 9cm x 5cm, cu aparatoare din plastic. Pret: 9 lei/perechea. sau 15 lei ambele perechi. https://postimg.cc/4YXZ9yZD https://postimg.cc/7CV52dpV 404. Modul alarma auto CL1300. Pret: 8 lei. https://postimg.cc/RWLRGpp5 Mulțumesc deocamdată, vă dau detaliile în privat Link spre comentariu
floob Postat Septembrie 9, 2022 Partajează Postat Septembrie 9, 2022 Astăzi am primit coletul de la dvs. Totul este în regulă. Mulțumesc pentru bonusuri și toate cele bune! Link spre comentariu
leo177 Postat Octombrie 2, 2022 Partajează Postat Octombrie 2, 2022 Scuze am uitat de cele rezervate ..daca mai sunt disponibile..se pot trimite ? Link spre comentariu
cmariuss Postat Octombrie 10, 2022 Autor Partajează Postat Octombrie 10, 2022 Au mai ramas: 1. Tv Samsung UE32j4500AW, cu ecran spart, se da pentru piese: Barete LED-uri: V5DN-320SMO-R4 Pret: 22 lei 1.Mainboard: BN41-02360 Pret: 35 lei. https://imgur.com/a/iy4S5ZM 2. Mainboard Vestel 17MB62-1. Pret: 19 lei https://imgur.com/75Cf5hG 3. Barete Led D2GE-460SCA-R3 (3 buc)- 6 lei/buc. https://imgur.com/3COXrCZ 9. Cabluri Scart. Pret: 4 lei bucata. https://imgur.com/RSGqalj 15. Set manere pentru aparat, aluminiu, dimensiuni: lungime 22cm, latime 6cm, grosime 0.7-0.9cm. Pret: 15 lei. https://imgur.com/nzuRB4w 20. Difuzoare recuperate dintrun tv Thomson, 8 ohm, dimensiuni 20x5,5x2,5 - 6 lei. https://imgur.com/T5dnTZN 27. Cablu adaptor HP display/ DVI (nou). Pret: 7 lei. https://imgur.com/e5q2hGb 41. Drosere Vassloh/Schwabe 18-28W. Pret: 5 lei/buc. https://imgur.com/uLXZfAb 51. Docking Station HP2013. Se vinde ca defect. Fara cablu alimentare. Pret: 4 lei. https://imgur.com/IOpGY8z 67. Modul inalta tensiune dintrun copiator canon. Pret: 9 lei. https://imgur.com/4usBMHS https://imgur.com/NiIUhjC 94. Difuzoare (doua) recuperate dintro plasma. Impedanta 8 ohm, putere 10 W. Dimensiunile difuzorului: 13cm x 4,5 cm. Pret: 7 lei. https://imgur.com/W5Lk3oA 95. Tuner JS-6H2/121. Pret: 3 lei. https://imgur.com/0uqqKgq 115: HDD 3,5" Hitachi 160GB, testat si instalat Windows7. Pret: 20 lei. https://imgur.com/OdWCTHY 116: HDD 3,5" WD, 80 GB, testat. Pret: 15 lei. https://imgur.com/HT5lJxe 164. Memorii Ram, DDR2, 512Mb, testate. Pret: 3 lei ambele. https://imgur.com/j695ShP 216. Difuzoare BN96-02586A (Samsung 22" LE27T51B) 16 ohm, 5W. Pret: 7 lei. https://imgur.com/RgYGACS 217. Sursa tv Dong-Yang BN96-02580A Pret: 25 lei. https://imgur.com/tZRWUn0 Suruburi: 82. Surub M5 cu guler, torx T20, cote in poza de mai jos. Pret: 0.4 lei/ 100g sau 100 buc- 3 lei. Disponibile 1 kg. https://imgur.com/jATZ700 https://imgur.com/Wh2fXId 83. Surub pt plastic cu guler, torx T20, cote in poza de mai jos. Pret 0.5 lei/100g sau 100 buc- 1 lei. Disponibile 2 kg. https://imgur.com/G8eOpez https://imgur.com/npSbWoC 84. Suruburi pt plastic, torx T8, cote in poza de mai jos. Pret: 1500 buc- 1 leu. Disponibile 10 kg. https://imgur.com/Kodbtx9 https://imgur.com/EnEQ6Xe 85. Arcuri, cote in poza de mai jos. Pret: 2,5 lei/ 100g. Disponibile 100 g. https://imgur.com/fXSwir7 https://imgur.com/QKfSNQm 227. Sursa Plisch FMS-100 (recuperata dintrun aparat de masura/analiza semnal TV) Uin: 195- 265V, 47-63Hz, Putere = 250VA Tensiuni: 5V, 7,5V, -5V, -12V, 24V Realizata cu componente de calitate: Philips, Siemens, Motorola,Wima etc. Sursa a fost reparata o data in 2003 de Antena Hungaria Kft. Pret: 65 lei. https://imgur.com/J1LNTxB https://imgur.com/IPB11HQ https://imgur.com/oFZz2l9 https://imgur.com/x5b415j https://imgur.com/8XaEBLF https://imgur.com/yMpTrKt https://imgur.com/2uJ8xU0 https://imgur.com/n8O62DK https://imgur.com/fqdWvLC https://imgur.com/QBbTVui https://imgur.com/Jqpfgcc https://imgur.com/lDjYxh7 231. Set difuzoare tv Samsung UE32J4500AW, cod BN96-36052A, 6 ohm, 5VA. Pret: 7 lei. https://imgur.com/bEJ0l9M https://imgur.com/3fzEg0V 242. Vana gaz Sigma 845 (Vaillant). Pret: 5 lei. https://imgur.com/MprfpGO 245. Adaptoare Nokia ACP-7E (cu transformator). Nefolosite. 3,7V 355mA, 1,3 VA. Cablu ~ 2m. Disponibile 5 bucati. Pret: 4 lei/buc. https://imgur.com/q0myNA5 https://imgur.com/KVp2lq5 246. Adaptoare Nokia ACP-12E, nefolosite. 5,7 V, 800 mA. Cablu ~ 1.8 m. Disponibile 4 bucati. Pret: 4 lei/buc. https://imgur.com/WWHA3E3 254. Set difuzoare Viefu 30041403 (recuperate dintro plasma Vortex), 8 ohm, 12 W. Pret: 7 lei. https://imgur.com/k5ZW4Ot 255. Set difuzoare OHC 300772s1, 8 ohm, 5W. Pret: 7 lei. https://imgur.com/KZkRhK1 https://imgur.com/xxerTCC 264. Contoare electromagnetice SI-47. Doua bucati. Pret: 7 lei/buc. https://imgur.com/qTMsp21 268. Micro filtru DSL HWMF-140. Nou. Pret: 4 lei. https://imgur.com/iSX4t3y 276. Temporizator mecanic cuptor cu microunde: durata temp 30 min, contactele suporta 16A. Pret: 7 lei. https://imgur.com/oy1OyAI 277. Temporizator mecanic Combolo Milano (cuptor electric), durata temporizare 5min, contactele suporta 10A. Pret:5 lei. https://imgur.com/ONf3Esg https://imgur.com/ZB1G8ZG 278. Pompa cafetiera Ceme Italia, 240V, 47W. Pret: 5 lei. https://imgur.com/cG7RGK1 283. Sarma nichelina NiCr Nikrothal 80. Diametru 0.2 mm, rezistenta 35,80 ohm/m, temperatura max de lucru 1200*C, conductibilitate termica/100°C Wm-1C-1-15,0 Pret: 0.25 lei/m. https://postimg.cc/k6Bfxn4r https://postimg.cc/KKQHPqDT 284. Transformator 30VA: S1: 9V S2: 24V Pret: 15 lei. https://postimg.cc/5X9Xxvtq 286. Releu Sigma cu soclu. Pret: 12 lei. https://postimg.cc/23BvJ4q1 https://postimg.cc/Sntxkv3k 287. Releu Schrack ZG z60 720. Pret: 9 lei. https://postimg.cc/xcvmjn3Y https://postimg.cc/NyJmhD7H 288. Releu combina frigorifica General Electric. Pret: 4 lei https://postimg.cc/PvZwwjGW 289. Releu solid state Ahly asr-25dd Comanda: 3-32 Vcc. Sarcina: 25A, 5-20Vcc. Pret: 27 lei. https://postimg.cc/2155pDH0 https://postimg.cc/NL1Fmb9k 291. CD/ROM/DVD ROM laptop Toshiba SD-R2202. Pret: 3 lei. https://postimg.cc/fJf3n5MR https://postimg.cc/KKwjrHDJ 309. Placa copiator Canon, FG1-9283. Pret: 12 lei. https://postimg.cc/B8tjSf1m https://postimg.cc/87ZFgzsF https://postimg.cc/hhC3vHvH 313. Adaptor Panasonic 6V, 500mA. Pret: 5 lei. https://postimg.cc/PPGYSJ8T 315. Difuzoare 6 ohm/ 11W, model 378G0110567ydx, Philips 32PHT4201. Pret: 6 lei/perechea. https://postimg.cc/SJyNQbBc https://postimg.cc/ykv6krKt 320. Placa PCI -5 porturi USB. Pret: 3 lei https://postimg.cc/v4tv15TY 321. Placa Agilent 82350B, nu am reusit sa o instalez in win7, se vinde ca defecta. Pret: gratuit. https://postimg.cc/DW55N13j https://postimg.cc/Wtx8x2xv 324. Din dezmembrarea unui LED tv, Blaupunkt BN32H1032eeb, urmatoarele: 324a. Mainboard TP.MS 3663S.PB818 (t-con v320bj8-q01, si panel cx315dledm). Pret: 40 lei. https://postimg.cc/kDbM76H8 https://postimg.cc/mPbT3dgN https://postimg.cc/McHxNvRn https://postimg.cc/yWcKMqJy 324b. Set 2 barete LED, HL-00320A30-0601S-07A3.Pret: 17 lei. https://postimg.cc/tnW9kw6D https://postimg.cc/ZB1Tr4WC 324C. Set difuzoare 8ohm/11W, LE-32Z1 SPK CVR-R, PD-1908027. Pret: 12 lei. https://postimg.cc/N26wmThz 324d. Set picioruse. Pret: 7 lei. https://postimg.cc/yWcKMqJy 328. Releu Matsushita jh1a-ac220v Bobina: 220Vac Contact: 30A Pret: 12 lei. https://postimg.cc/9Rv60Mch 333. Componente din dezmembrarea unui tv Fujitsu Siemens Myrica VQ40-1. Toate componentele find in stare de functionare, problema tv-ului era sursa. 333a. Placa de baza Conrac + tuner Philips. Pret: 10 lei. https://postimg.cc/ctYZQ8vS https://postimg.cc/6759D3mr https://postimg.cc/ctYZQ8vS https://postimg.cc/0MybdZvq https://postimg.cc/CR0MsJC6 334.Modul de control al turatiei al ventilatorului de racire pentru radiator de tip auto (Mercedes). Pret: 10 Lei. https://postimg.cc/FYbRMws4 339. HDD Seagate Barracuda 200GB (testat cu Data LifeGuard Diagnostics). Pret: 19 lei. https://postimg.cc/18myPYML 340. HDD Western Digital 160GB (WDdata lifeguard diagnostic).Pret: 15 lei https://postimg.cc/62vXYs5G 341. HDD Seagate Barracuda 80GB (testat cu Data LifeGuard Diagnostics). 2 bucati Pret:9 lei buc https://postimg.cc/K18hC38b https://postimg.cc/k2YPCM2b 343: Autotransformator Uretea=236V Igol=1,2A Prize la 160V, 72V, 32V Dimensiuni: L= 9,8cm, H=8,2cm, grosime pachet tole 5,4cm. Pret: 17 lei. https://postimg.cc/94MWxQXf https://postimg.cc/3k98CvT6 https://postimg.cc/5HRfDWjS https://postimg.cc/TKT2DcZg 358. PCB cu 32 mufe BNC. Pret: 7 lei. https://postimg.cc/dkXgtVrF 362. Ventilatoare Nidec Betav. Doua bucati C32957-58, 12V- 0,29A. Una bucata C34637-58, 12V- 0,13A. Pret: 10 lei toate. https://imgur.com/mFUdq3h 364. Sursa Server AC Bel 332W 5V@25A 12V@16A 5Vstb@3A ! un ventilator este crapat si are o pala rupta, dar functioneaza. Pret: 15 lei. https://imgur.com/unPF0QC https://imgur.com/YO6nOXv https://imgur.com/Jp0AF3M 370. Transformator cablaj 5,7 VA: Secundar: 19,1V 300mA https://postimg.cc/qzTDTT62 Pret: 8 lei. 372. Transformator de cablaj Thermowatt 8VA: Secundar 1: 24 V Secundar 2: 15 V https://postimg.cc/wRKf3Kf8 Pret: 12 lei. 382. Convertor DC/DC 60 W: Tensiune intrare: 18-36V Tensiune iesire: 5,0 V/ 12 A Pret: 27 lei https://postimg.cc/QB2SbSf3 https://postimg.cc/34hfhnmZ 385. Alarma auto Thunder Pret: 18 lei. https://postimg.cc/w3c3xtkV https://postimg.cc/kR9rhg6M 388. Set difuzoare 6ohm 8W, recuperate dintrun Vortex Led-32ck600. Pret: 7 lei. https://postimg.cc/1VHxx1wG 389. Alarma auto. Pret: 10 lei. https://postimg.cc/G4pD1GMM 392. Sursa VCR Panasonic Vek4875. Realizata cu STK5392. Tensiuni: 45V, 12V, 17V, 5V, -30V. Pret: 12 lei. https://postimg.cc/dZBhbVGP https://postimg.cc/7bVM8HHZ https://postimg.cc/mtg3TvkN 393. Placa de baza si modul comunicatie imprimanta Epson EU-96. Pret: 5 lei. https://postimg.cc/HJy4fbxq https://postimg.cc/R3kJf8v8 395. Convertor Scart-RCA/S-video. Pret: 5 lei. https://postimg.cc/Hj73qDJJ 396. Alarma auto KD500. Pret: 12 lei. https://postimg.cc/75w1CMHB https://postimg.cc/LgPkPxgW 397. Transformator de cablaj Hahn 10W: Secundar1: 22V - 380mA Secundar2: 29V - 6,6mA Pret: 8 lei. https://postimg.cc/d7W9ckK5 405. Bare dreptungiulare de aluminiu. Dimesiune: 5.0cm x 2.5cm, si lungime de 43cm. Greutate: 1.35 Kg. Am patru bucati. Pret: 30 lei/buc. https://postimg.cc/XZ56cBzr https://postimg.cc/Hc4GFDHH 411. Sursa ATX Delux 400W P4. Pret: 25lei. https://imgur.com/6aBit6B https://imgur.com/9MHzrkW https://imgur.com/EuZsFo5 412. Sursa in comutatie NYKO: Sec1: 24Vcc Sec2: 8Vcc Pret: 12 lei. https://imgur.com/3B6gASl 414: Placa UPS KP-201, incompleta se vinde ca defecta Se poate recupera: releee, 8 trenzistoare RFP50N06 (fairchild), LM324, ULN2004 etc Pret: 12 lei. https://imgur.com/qYBnzoN https://imgur.com/078Qpvn https://imgur.com/VDgZ5Ir https://imgur.com/loijVfv 416. Filtru EMi KPL3008: 275V 50Hz 16A Pret: 7 lei. https://imgur.com/Uuj85lD 417. Termostate industriale TehnoTrust Bistrita. Domeniu de temperatura 0-400*C. Butoanele potentiometrelor sunt rupte. Nu am senzori PT-100 sa le testez, se vand ca defecte: Pret: 17 lei buc sau ambele 30 lei. https://imgur.com/d20lTyc https://imgur.com/xaTj8tJ https://imgur.com/UVcinYS Link spre comentariu
cmariuss Postat Octombrie 16, 2022 Autor Partajează Postat Octombrie 16, 2022 Se adauga: 423. Sursa SMPS 2405 Intrare: 24Vca-90Vca (galben-rosu) Iesire: 24Vcc 550ma (negru-rosu) Pret: 15 lei. https://imgur.com/gilI2Ny https://imgur.com/l74NtE6 424. Placa recuperata dintro plasma Samsung Model: lj92-01336a. Se pot recupera 2x STTH60P03SW, 4x 5N3011, 2x 5N2008, 2 x 2SK3596, 2XFCU20A40, 3x 330uF/315v. https://imgur.com/D3oA3JD Pret: 20 lei. 425. Radiatoare aluminiu- 5 bucati: https://imgur.com/SrPf8nz https://imgur.com/PeuLcvD Pret: 15 lei toate. 426. Lampa 12V/4W (soclu baioneta), corp alama, capac crom. Se poate utiliza pentru iluminarea scalei la radio, iluminarea vu-metrelor cu ace, etc Pot face rost de mai multe. Pret: 12 lei/buc https://imgur.com/H4oPeLO https://imgur.com/FgNGxDi https://imgur.com/AaweLfD 427. Sticla scala radio pe lampi Minerva Cornette. https://imgur.com/a6MKoiM https://imgur.com/AstVy7F Pret: 30 lei. 428. Placa video Nvidia GeForce FX5500, 256MB. https://imgur.com/0Y76iI5 https://imgur.com/nbz0I6L Pret: 10 lei. 429. Rezistenta 650W incalzire cafetiera, cu termostat. https://imgur.com/2iCunrD Pret: 10 lei. Link spre comentariu
cmariuss Postat Octombrie 17, 2022 Autor Partajează Postat Octombrie 17, 2022 Se adauga: 430. Sine trenulet modelism: - sectiuni curbe 9-bucati - sectiuni drepte 3 bucati - ecartament 30mm - diatru exterir - 88 cm - diametru interior - 68 cm Pret: 18 lei. https://imgur.com/xVpl4aA https://imgur.com/BvW9Ics 431. Telecomanda Sharp Aquos -recuperata dintrun tv cu ecran spart Pret: 30 lei. https://imgur.com/OTDLisf 432. Sursa Tv Sharp CA0009WJN1 Tensiuni masurate: 9V, 12V Pret: 18 lei. https://imgur.com/ZTxFUuU 433.Amplificator 24~7F CI TA821Ah Intrare: RCA, Bluetooth,card TF Alimentare 230V Pret: 15 lei. https://imgur.com/ZTxFUuU https://imgur.com/qkMlanK https://imgur.com/FGw2tkI https://imgur.com/8daJI49 434. Sursa SMPS tv plasma Samsung,~ 250 W: Iesire: 12Vcc 24Vcc Pret: 27 lei. https://imgur.com/svc05to https://imgur.com/KuqNDLv https://imgur.com/oUri2dy Suport perete TV/monitor: Pret: 20 lei. https://imgur.com/9DhGT87 Link spre comentariu
cmariuss Postat Octombrie 20, 2022 Autor Partajează Postat Octombrie 20, 2022 Disponibile Link spre comentariu
cmariuss Postat Octombrie 23, 2022 Autor Partajează Postat Octombrie 23, 2022 Se adauga: 434. Casti telefonice: Primo -CT-3B, productie Japonia, 10 bucati. Impedanta: 780 ohm. Pret: 2,5 lei. https://imgur.com/0hmpJFJ 435. Casti telefonice: Primo DH-51, productie Japonia, 6 bucati. Impendanta: 290 ohm. Pret: 2,5 lei. https://imgur.com/hO1mFIJ 436. Tablite cupru cu grosimea de 0,5mm. Cu urmatoarele dimensiuni: a) 35 x 5 cm. Pret: 12 lei. https://imgur.com/Zu0Gzq8 b) 22,4 x 14. Pret: 12 lei. https://imgur.com/GAudIw1 c) 16 x 11 cm Pret: 9 lei. https://imgur.com/KSj4P3C d) 16 x 14 cm. Pret: 12 lei. https://imgur.com/cWwzRNZ e) 16 x 10 cm. Pret: 9 lei. https://imgur.com/LP4tiwe f) 20,5 x 10 cm. Pret: 14 lei. https://imgur.com/GQOWsBy g) 16 x 9 cm. Pret: 9 lei. https://imgur.com/Xd20iS4 h) 16 x 10 cm Pret: 9 lei. https://imgur.com/tFOO6qz i)17 x 15 cm forma eliptica. Pret: 12 lei. https://imgur.com/EZFmfhu j) 24 x 8/11.5 cm patrulater. Pret: 12 lei. https://imgur.com/1O3uosh 437. Condensatori Bosch (pentru compensarea factorului de putere a tuburilor florescente), 5,7uF/ 470Vca. Trei bucati disponibile. Pret: 3 lei/buc. https://imgur.com/BHWcIA9 438.Transformator 5W cu redresor: Ue= 36V, Punte diode realizata cu KY702F Pret: 12 lei. https://imgur.com/czA2C7B 439. Releu RP-102-3P Ua= 24Vcc, R= 346 ohm Contacte: 2x3, fara soclu. Pret: 20 lei. https://imgur.com/NKClW8K https://imgur.com/bGrPZ5h https://imgur.com/v3APLRq 440. Relee (doua) RP 92 Ua = 220Vca, R= 4410 ohm Contacte: 2x3, cu socluri. Pret: 20 lei/buc. https://imgur.com/kXEgFs1 https://imgur.com/ijfgFLZ https://imgur.com/1ExxIPf https://imgur.com/FB6vJtb https://imgur.com/aB8Gj6g 441. Acumulator Li-Ion, model: 8560, nou. Tensiune: 11.1V, 7800mAh, 87Wh. Pret: 70 lei. https://imgur.com/RWpiKNZ https://imgur.com/0Lw48gf 442. Acumulator Li-Ion, model: 6720, nou. Tensiune: 11,1V, 4400mAh, 49Wh. Pret: 50 lei. https://imgur.com/hdignDl https://imgur.com/Zk24eiE 443. Bobina inductie Dacia 1310, 1410 etc Noi. Primar: 10 ohm Secundar: 8800 ohm Am doua bucati: 20 lei/buc. https://imgur.com/k8ayzSC Link spre comentariu
cmariuss Postat Octombrie 24, 2022 Autor Partajează Postat Octombrie 24, 2022 Se adauga: 444. Carcasa deck Sony TC-V3: Dimensiuni: lungime 35cm, inaltime 10 cm, adancime 22 cm. Pret: 15 lei. https://imgur.com/esKLMVi https://imgur.com/DEwKjHC https://imgur.com/6QYTnzf 445. Siguranta fuzibila MNC pentru amplificatoare auto. Pret: 5 lei. https://imgur.com/433srrq 446. Radiatoare aluminiu recuperate din PC: a) radiator procesor - dimensiuni 12.5cm x 7cm x 4.5cm. Pret: 5 lei. https://imgur.com/zpz3zaI https://imgur.com/XmyuR0c b) radiator dimensiuni 10.5cm x 4,2cm x3.2 cm, talpa 4mm. Pret: 4 lei. https://imgur.com/wnFgtCB 447. Adaptor telefon (pentru priza UK) 4,5V-5,5 V, 500mA . Pret: 4 lei. https://imgur.com/8FZVIdS 448. Modul alarma auto SPAL AS-90. Pret: 9 lei. https://imgur.com/O06QcqL https://imgur.com/Fl2flAH 449. Kit Amplificator recuperat si testat, dintrun amplituner Siemens RS-555. Contine transformatorul de alimentare, redresorul, amplificatorul realizat cu circuite hibride STK086,si radiatorul de racire.Pret: 90 lei. https://imgur.com/QJHz90j https://imgur.com/UI4f02J https://imgur.com/9KAkEAh https://imgur.com/ZHQDxC8 https://imgur.com/tTFit0T https://imgur.com/L0FjMzn https://imgur.com/cjeqRee https://imgur.com/r5mUxtD Link spre comentariu
cmariuss Postat Octombrie 26, 2022 Autor Partajează Postat Octombrie 26, 2022 Se adauga: 449. Transformator recuperat dintrun magnetofon Tesla CM-130: Tensiuni: sec1:12V-0-12V - 3A sec2: 27V, 500mA Pret: 30 lei. https://imgur.com/LMDpAky https://imgur.com/zyNlTJa 450. Motor recuperat dintrun magnetofon Tesla CM-130. Pret: 35 lei. https://imgur.com/9tdxJE8 https://imgur.com/JfJ1ueU https://imgur.com/xwh3V4g Transformatorul si motorul de magnetofon se pot da si la pachet, pretul find in cazul acesta 55 lei. 451. Transformator 7W: Secundar: 14,5 V, 300mA. Pret: 12 lei. https://imgur.com/Nm423Mg 452. Relee industriale RP-92, 2 x 3 contacte. Tensiune de alimentare: 42V 50Hz, 220 Ohm, cu socluri, doua bucati. Pret: 20 lei/buc. https://imgur.com/fy5qwJ6 https://imgur.com/fDEM118 Link spre comentariu
