Electronice diverse
cmariuss
Am facut tuturor rezervarile.
Mai jos se afla lista reactualizata cu ce a mai ramas.
Se Adauga:
336. Kit placa de baza Siemens-Fujitsu Esprimo E5730, procesor Intel dual core 3.16GHz, 3GB RAM, Sursa Fujitsu Hp 250 (Cablurile sunt cam scurte).Pret:50lei
https://postimg.cc/Fkk7yCwP
https://postimg.cc/1gRXC3LV
https://postimg.cc/TykwZX67
https://postimg.cc/PN0LXh80
https://postimg.cc/G948n99k
https://postimg.cc/XGzry61G
337: Sursa PC FSP 300-60PLN (300W). Pret:12 lei
https://postimg.cc/nXJCmk2k
https://postimg.cc/q62pBPPd
338. Sursa PC Q Tehnology QT-01300 R300 (300W). Pret: 10lei.
https://postimg.cc/JDf1Lrdq
339. HDD Seagate Barracuda 200GB (testat cu Data LifeGuard Diagnostics).Pret: 20lei.
https://postimg.cc/18myPYML
340. HDD Western Digital 160GB (WDdata lifeguard diagnostic).Pret:15 lei
https://postimg.cc/62vXYs5G
341. HDD Seagate Barracuda 80GB (testat cu Data LifeGuard Diagnostics). 2 bucati Pret:1 lei buc
https://postimg.cc/K18hC38b
https://postimg.cc/k2YPCM2b
342. Doua Coolere procesoare Intel. Pret: 9 lei
https://postimg.cc/kVNN8GWV
 Lista reactualizata.
 1. Tv Samsung UE32j4500AW, cu ecran spart, se da pentru piese:
Barete LED-uri: V5DN-320SMO-R4 Pret: 30 lei
Mainboard: BN41-02360 Pret: 40 lei.
https://imgur.com/a/iy4S5ZM
 2. Mainboard Vestel 17MB62-1. Pret: 25 lei
https://imgur.com/75Cf5hG
3. Barete Led D2GE-460SCA-R3 (7 buc)- 7 lei/buc.
https://imgur.com/3COXrCZ
 4. Placa Home cinema Sanyo DVM 2600, lipsesc finalii audio. Pret: 7 lei.
https://imgur.com/jvIgaER
8. Placa intrari mixer Behringer Pro-dx626. Pret: 6 lei.
https://imgur.com/NLH5rX1
 9. Cabluri Scart. Pret: 4 lei bucata.
https://imgur.com/RSGqalj
15. Set manere pentru aparat, aluminiu, dimensiuni: lungime 22cm, latime 6cm, grosime 0.7-
0.9cm. Pret: 16 lei.
https://imgur.com/nzuRB4w
  16. Set manere pentru transport, rabatabile, talpa aluminiu, manere din Cr, talpa 12x4cm,
maner 12x7.5cm.Pret: 20lei.
https://imgur.com/ye8f1Wh
20. Difuzore recuperate dintrun tv Thomson, 8 ohm, dimensiuni 20x5,5x2,5 - 8 lei.
https://imgur.com/T5dnTZN
27. Cablu adaptor HP display/ DVI (nou). Pret: 8 lei.
https://imgur.com/e5q2hGb
38. Simulator centura siguranta auto Cygnetic. Pret: 7 lei.
https://imgur.com/YGj4CIP
 41. Drosere Vassloh/Schwabe 18-28W. Pret: 5 lei/buc.
https://imgur.com/uLXZfAb
42. Radiatoare provenite dintro unitate Mac ProG5. Unul dintre radiatoare e putin dezcentrat, dupa cum se poate vedea
in poze. Dimensiuni: talpa Cu 17x9 cm, grosime talpa 6+6 mm, inaltime radiator 13,5cm. Pret: 17 ambele.
https://imgur.com/Nfpvhkb
https://imgur.com/QVvXRdA
51. Docking Station HP2013. Se vinde ca defect. Fara cablu alimentare. Pret: 6 lei.
https://imgur.com/IOpGY8z
67. Modul inalta tensiune dintrun copiator canon. Pret: 10 lei.
https://imgur.com/4usBMHS
https://imgur.com/NiIUhjC
 94. Difuzoare (doua) recuperate dintro plasma. Impedanta 8 ohm, putere 10 W. Dimensiunile difuzorului: 13cm x 4,5
cm. Pret: 8 lei.
https://imgur.com/W5Lk3oA
95. Tuner JS-6H2/121. Pret: 3 lei.
https://imgur.com/0uqqKgq
110. Moduli dublu-tiristor URSS, MTT-63-10-4. Am 6 bucati.
Pret: 25 lei/buc.
https://imgur.com/WBa4zoU
115: HDD 3,5" Hitachi 160GB, testat si instalat Windows7. Pret: 20 lei.
https://imgur.com/OdWCTHY
116: HDD 3,5" WD, 80 GB, testat. Pret: 15 lei.
https://imgur.com/HT5lJxe
119: Sasiu monitor LG Flatron L194WS-SF. Monitorul s-a dezmebrat din cauza ecranului spart. Pret: 7 lei.
https://imgur.com/LPp3EYE
https://imgur.com/kkjrPTE
https://imgur.com/w1bAdHV
 163. Hardisk Samsung HD160JJ 160GB, testat, si instalat Windows 7. Pret: 23 lei.
https://imgur.com/4U36JvC
164. Memorii Ram, DDR2, 512Mb, testate. Pret: 2 lei/buc.
https://imgur.com/j695ShP
171. Sursa in comutatie DPPB-10077B, realizata cu KA 1M0880. Tensiuni: 26V, 12V, 5V, 3V3, -27V. Pret: 9 lei.
https://imgur.com/ZLVkj9E
177. Transformator recuperat dintrun cd player Technics SL-PD8. Tensiuni: 16V, 9V, 4V. Pret: 7 lei.
https://imgur.com/lWabH9T
 195. Transformator 8 VA. Tensiune: 18 V. Pret: 5 lei.
https://imgur.com/HHny31L
196. Radiator aluminiu. Dimensiune: lungime 23 cm, inaltime 5 cm, adancime 6 cm. Pret: 17 lei.
https://imgur.com/1tNONU8
https://imgur.com/YNYp4JG
 201. Placa soft-start. Pret: 3 lei.
https://imgur.com/IG959ut
https://imgur.com/9Hfs3u8
 216. Difuzoare BN96-02586A (Samsung 22" LE27T51B) 16 ohm, 5W. Pret: 10 lei.
https://imgur.com/RgYGACS
217. Sursa tv Dong-Yang BN96-02580A Pret: 35 lei.
https://imgur.com/tZRWUn0
Suruburi:
82. Surub M5 cu guler, torx T20, cote in poza de mai jos. Pret: 0.5 lei/ 100g sau 100 buc- 4 lei. Disponibile 4 kg.
https://imgur.com/jATZ700
https://imgur.com/Wh2fXId
83. Surub pt plastic cu guler, torx T20, cote in poza de mai jos. Pret 0.5 lei/100g  sau 100 buc- 1 lei. Disponibile 18 kg.
https://imgur.com/G8eOpez
https://imgur.com/npSbWoC
84. Suruburi pt plastic, torx T8, cote in poza de mai jos. Pret: 0.3 leu /100g sau 700 buc-  1 leu. Disponibile 35 kg.
https://imgur.com/Kodbtx9
https://imgur.com/EnEQ6Xe
85. Arcuri, cote in poza de mai jos. Pret: 2,5 lei/ 100g. Disponibile 200 g.
https://imgur.com/fXSwir7
https://imgur.com/QKfSNQm
221. Relee auto Iveco, 12V 10 A. Pret: 5 lei toate.
https://imgur.com/WeNk55u
 227. Sursa Plisch FMS-100 (recuperata dintrun aparat de masura/analiza semnal TV)
Uin: 195- 265V, 47-63Hz, Putere = 250VA
Tensiuni: 5V, 7,5V, -5V, -12V, 24V
Realizata cu componente de calitate: Philips, Siemens, Motorola,Wima etc.
Sursa a fost reparata o data in 2003 de Antena Hungaria Kft.
Pret: 80 lei.
https://imgur.com/J1LNTxB
https://imgur.com/IPB11HQ
https://imgur.com/oFZz2l9
https://imgur.com/x5b415j
https://imgur.com/8XaEBLF
https://imgur.com/yMpTrKt
https://imgur.com/2uJ8xU0
https://imgur.com/n8O62DK
https://imgur.com/fqdWvLC
https://imgur.com/QBbTVui
https://imgur.com/Jqpfgcc
https://imgur.com/lDjYxh7
231. Set difuzoare tv Samsung UE32J4500AW, cod BN96-36052A, 6 ohm, 5VA. Pret: 12 lei.
https://imgur.com/bEJ0l9M
https://imgur.com/3fzEg0V
237. Miliampermetru de panou. Pret: 9 lei.
https://imgur.com/sAk2x3I
https://imgur.com/p9vpAmi
242. Vana gaz Sigma 845 (Vaillant). Pret: 9 lei.
https://imgur.com/MprfpGO
 245. Adaptoare Nokia ACP-7E (cu transformator). Nefolosite.
3,7V 355mA, 1,3 VA. Cablu ~ 2m. Disponibile 8 bucati. Pret: 4 lei/buc.
https://imgur.com/q0myNA5
https://imgur.com/KVp2lq5
246. Adaptoare Nokia ACP-12E, nefolosite.
5,7 V, 800 mA. Cablu ~ 1.8 m. Disponibile 18 bucati. Pret: 4 lei/buc.
https://imgur.com/WWHA3E3
254. Set difuzoare Viefu 30041403 (recuperate dintro plasma Vortex), 8 ohm, 12 W. Pret: 8 lei.
https://imgur.com/k5ZW4Ot
 255. Set difuzoare OHC 300772s1, 8 ohm, 5W. Pret: 8 lei.
https://imgur.com/KZkRhK1
https://imgur.com/xxerTCC
 256. Lot 9 sigurante auto Pacific 20-50 A. Pret: 7 lei.
https://imgur.com/fqGuwq6
 257. Lot 6 relee Kuhne 114A4-24Vac1, bobina 24Vac, contacte 4x2. Pret: 15 lei.
https://imgur.com/6YX1H8M
260. LED driver Gelux model LD-361200-104L. Tensiune: 20-36V, 1050mA. Doua bucati, unul are cablu mai scurt.
Pret: 15 lei bucata.
https://imgur.com/rhgNZBv
https://imgur.com/wykPaSb
262. Adaptor laptop Toshiba 45 watt PA32P3U-1ACA, 15 V, 3 A. Cablu: 2x2m. Pret: 20 lei.
https://imgur.com/SWuLuny
https://imgur.com/JMLTqrn
264. Contoare electromagnetice SI-47. Doua bucati. Pret: 9lei/buc.
https://imgur.com/qTMsp21
266. Alarma auto Thor. Pret: 8 lei.
https://imgur.com/FzgIzkt
268. Micro filtru DSL HWMF-140. Nou. Pret: 7 lei.
https://imgur.com/iSX4t3y
276. Temporizator mecanic cuptor cu microunde: durata temp 30 min, contactele suporta 16A. Pret: 8 lei.
https://imgur.com/oy1OyAI
277. Temporizator mecanic Combolo Milano (cuptor electric), durata temporizare 5min, contactele suporta 10A. Pret: 5 lei.
https://imgur.com/ONf3Esg
https://imgur.com/ZB1G8ZG
278. Pompa cafetiera Ceme Italia, 240V, 47W. Pret: 7 lei.
https://imgur.com/cG7RGK1
283. Sarma nichelina NiCr Nikrothal 80.
Diametru 0.2 mm, rezistenta 35,80 ohm/m, temperatura max de lucru 1200*C, conductibilitate termica/100°C Wm-
1C-1-15,0
Pret: 0.4 lei/m.
https://postimg.cc/k6Bfxn4r
https://postimg.cc/KKQHPqDT
284. Transformator 30VA:
S1: 9V
S2: 24V
Pret: 15 lei.
https://postimg.cc/5X9Xxvtq
286. Releu Sigma cu soclu. Pret: 15 lei.
https://postimg.cc/23BvJ4q1
https://postimg.cc/Sntxkv3k
287. Releu Schrack ZG z60 720. Pret: 10 lei.
https://postimg.cc/xcvmjn3Y
https://postimg.cc/NyJmhD7H
288. Releu combina frigorifica General Electric. Pret: 7lei
https://postimg.cc/PvZwwjGW
289. Releu solid state Ahly asr-25dd
Comanda: 3-32 Vcc. Sarcina: 25A, 5-20Vcc.
Pret: 45 lei.
https://postimg.cc/2155pDH0
https://postimg.cc/NL1Fmb9k
291. CD/ROM/DVD ROM laptop Toshiba SD-R2202. Pret: 3 lei.
https://postimg.cc/fJf3n5MR
https://postimg.cc/KKwjrHDJ
292. Filtru retea/ suport  doua sigurante. Pret: 3lei.
https://postimg.cc/hfsG3j0J
303. Telecomanda radio 27MHz, fara antena telescopica. Pret: 7 lei.
https://postimg.cc/K167VN9Z
https://postimg.cc/S2q6QKF3
304. Telecomanda infrarosu. Pret: 5 lei.
https://postimg.cc/GHSxPrGT
https://postimg.cc/8sZRDDyX
305. Telecomanda radio 27MHz, fara antena si capac bateri. Pret: 3 lei.
https://postimg.cc/dLXGk6c8
https://postimg.cc/QBg7zr9b.
309. Placa copiator Canon, FG1-9283. Pret: 18 lei.
https://postimg.cc/B8tjSf1m
https://postimg.cc/87ZFgzsF
https://postimg.cc/hhC3vHvH
310. Sursa in comutatie Wei-Ya, model wy-15ca1. Dimensiuni 16cm x 12cm x 5cm
 Tensiuni/curenti 5V/ 9A, 12V/ 4A, 24V 2.2A. Pret: 30 lei.
https://postimg.cc/LJ2fMWTW
https://postimg.cc/p9dFmn3Y
https://postimg.cc/YL2K7Mv9
311. Sursa DVD-Player Sony dvp-ns300 (HS- 13S0E). Tensiuni 12V, 3,3V. Pret: 6 lei.
https://postimg.cc/rDj4y9Zw
313. Adaptor Panasonic 6V, 500mA. Pret: 5 lei.
https://postimg.cc/PPGYSJ8T
315. Difuzoare 6 ohm/ 11W, model 378G0110567ydx, Philips 32PHT4201. Pret: 7 lei/perechea.
https://postimg.cc/SJyNQbBc
https://postimg.cc/ykv6krKt
320. Placa PCI -5 porturi USB. Pret: 4 lei
https://postimg.cc/v4tv15TY
321. Placa Agilent 82350B, nu am reusit sa o instalez in win7, se vinde ca defecta. Pret: 7 lei.
https://postimg.cc/DW55N13j
https://postimg.cc/Wtx8x2xv
322. Radiator Aluminu. Dimensiuni 26.5cm x 24.5cm x 2.7cm, grosime talpa 0,9 cm. Pret: 40 lei.
https://postimg.cc/3dPqjj32
https://postimg.cc/cttm6jg2
https://postimg.cc/CBQ7hY1b
324. Din dezmembrarea unui LED tv, Blaupunkt BN32H1032eeb, urmatoarele:
324a. Mainboard TP.MS 3663S.PB818 (t-con v320bj8-q01, si panel cx315dledm). Pret: 80 lei.
https://postimg.cc/kDbM76H8
https://postimg.cc/mPbT3dgN
https://postimg.cc/McHxNvRn
https://postimg.cc/yWcKMqJy
324b. Set 2 barete LED, HL-00320A30-0601S-07A3.Pret: 25 lei.
https://postimg.cc/tnW9kw6D
https://postimg.cc/ZB1Tr4WC
324C. Set difuzoare 8ohm/11W, LE-32Z1 SPK CVR-R, PD-1908027. Pret: 20 lei.
https://postimg.cc/N26wmThz
324d. Set picioruse. Pret: 10 lei.
 328. Releu Matsushita jh1a-ac220v
Bobina: 220Vac
Contact: 30A
Pret: 12 lei.
https://postimg.cc/9Rv60Mch
329. O pereche de tranzistori recuperati Sanken 2SA1215/2SC2921
Pret: 25 lei.
https://postimg.cc/vDfjXGQ4
 332: Radiator Aluminiu cu dimensiuni 25cmx13cmx40cm, talpa 3mm (recuperat dintro sursa smps tv). Pret: 5 lei.
https://postimg.cc/JDsRzFmt
https://postimg.cc/D8k775Ny
333. Componente din dezmembrarea unui tv Fujitsu Siemens Myrica VQ40-1. Toate componentele find in stare de functionare, problema tv-ului era sursa.
333a. Placa de baza Conrac + tuner Philips. Pret: 20 lei.
https://postimg.cc/ctYZQ8vS
https://postimg.cc/6759D3mr
https://postimg.cc/0MybdZvq
https://postimg.cc/CR0MsJC6
333b.Placi invertoare back-light 24v40w2s(HIP0212A). Pret: 18 lei/buc. sau 30lei ambele.
https://postimg.cc/MnJHrzw5
https://postimg.cc/gwYJm4n6
https://postimg.cc/GTBt6297
333c. Doua perchi difuzoare 4ohm/5watt, 9cm x 5cm, cu aparatoare din plastic. Pret: 12 lei/perechea. sau  20 lei ambele perechi.
https://postimg.cc/4YXZ9yZD
https://postimg.cc/7CV52dpV
334.Modul de control al turatiei al ventilatorului de racire pentru radiator de tip auto (Mercedes). Pret: 20 Lei.
https://postimg.cc/FYbRMws4
  • 2 săptămâni mai târziu...
Se adauga:
343: Autotransformator
Uretea=236V Igol=1,2A
Prize la 160V, 72V, 32V
Dimensiuni: L= 9,8cm, H=8,2cm, grosime pachet tole 5,4cm. Pret: 27 lei.
https://postimg.cc/94MWxQXf
https://postimg.cc/3k98CvT6
https://postimg.cc/5HRfDWjS
https://postimg.cc/TKT2DcZg
344. Componente dintrun UPS-placa si transformator. Pret: 15 lei.
https://postimg.cc/nscL612p
https://postimg.cc/4mVntynk
345. Amplificator auto Harman&Kardon, realizat cu TDA8463Q (3bucati). Pret: 17 lei.
https://postimg.cc/QVBF803M
https://postimg.cc/4nrmmVfQ
346. Alarma auto KE-03, realizata cu EM78P1156NPJ. Pret: 7 lei.
https://postimg.cc/wynTRYpj
347. TV tuner easy tv Philips SAA713XHL (PAL B/G) pe Win XP. Pret: 5 lei.
https://postimg.cc/qNGRbF81
348. Relee auto:
3 bucati Ford 30A
1 bucata VW 30A
1 bucata Ford 20A
Pret: 7 lei.
https://postimg.cc/pmK82kKj
349. Module ECU autobuze Scania. Contine: 18 IC BTS410F, CD40528, CD40518, HD6413003F16,HC2733,
BS62LV256SI-70, LM2937ET. Am doua bucati: 20 lei.
https://postimg.cc/p9xjy8B6
350. Transformator recuperat dintrun Denon PMA-715R.
Secundar: 35V-0-35V
Pret: 50 lei.
https://postimg.cc/hJrdmjyP
https://postimg.cc/MfcMgYWv
https://postimg.cc/MX4jVgDR
351. Adaptor Chicony 19V/ 2,1A - 40W. Pret: 12 lei.
https://postimg.cc/1g9gySmx
352. Tranzistori Sanken 2SB1560/2SD2390, originali, 2 perechi. Pret: 15 perechea.
https://postimg.cc/sMPQFxR9
https://postimg.cc/HJ4Qt3xm
353. Tranzistori AD152, recuperati 2 bucati. Pret: 5 ambi.
https://postimg.cc/MM3fsLJC
354. Condensatori electrolitici Nichicon
10.000uF/56V. Pret: 20 lei perechea.
https://postimg.cc/FfQycwhG
https://postimg.cc/N9dm3MmP
Editat de cmariuss
Doresc sa cumpar:
-344Componente dintrun UPS-placa si transformator. Pret: 15 lei.
-346Alarma auto KE-03, realizata cu EM78P1156NPJ. Pret: 7 lei.
-349
Module ECU autobuze Scania. Contine: 18 IC BTS410F, CD40528, CD40518,HD6413003F16,HC2733,
Multumesc.
La 13.12.2021 la 18:05, Tanase Ion a spus:
Traful ecranat de la pozitia 325 il vreau eu va rog sa mil rezervati
325.Transformator ecranat T 1080 ~ 50VA
Secundar 1: 15V-0-15V
Secundar 2: 65V
Pret: 23 lei.
https://postimg.cc/30GHFGtN
https://postimg.cc/svRFRvnP
Imi cer scuze am avut mai multe nebunii pe cap si am uitat de aceasta rezervare, mai este valabila? La acest tip de traf mai aveti perechea chiar daca este si ars? In special capacele sunt interesat ptr tipul de tola E75 miar fi necesare 2 perechi de capace ptr E75, multumuesc frumos cu stima si respect o noapte cat mai buna, astept un mp sa stabilim cu adresa de livrare.
Editat de Tanase Ion
Lista reactualizata, si o reducere de preturi:
Barete LED-uri: V5DN-320SMO-R4 Pret: 25 lei
Mainboard: BN41-02360 Pret: 35 lei.
 2. Mainboard Vestel 17MB62-1. Pret: 20 lei
3. Barete Led D2GE-460SCA-R3 (7 buc)- 6 lei/buc.
0.9cm. Pret: 15 lei.
20. Difuzore recuperate dintrun tv Thomson, 8 ohm, dimensiuni 20x5,5x2,5 - 7 lei.
38. Simulator centura siguranta auto Cygnetic. Pret: 5 lei.
cm. Pret: 7 lei.
Pret: 22 lei/buc.
119: Sasiu monitor LG Flatron L194WS-SF. Monitorul s-a dezmebrat din cauza ecranului spart. Pret: 6 lei.
171. Sursa in comutatie DPPB-10077B, realizata cu KA 1M0880. Tensiuni: 26V, 12V, 5V, 3V3, -27V. Pret: 8 lei.
177. Transformator recuperat dintrun cd player Technics SL-PD8. Tensiuni: 16V, 9V, 4V. Pret: 6 lei.
196. Radiator aluminiu. Dimensiune: lungime 23 cm, inaltime 5 cm, adancime 6 cm. Pret: 15 lei.
 216. Difuzoare BN96-02586A (Samsung 22" LE27T51B) 16 ohm, 5W. Pret: 8 lei.
217. Sursa tv Dong-Yang BN96-02580A Pret: 30 lei.
Suruburi:
82. Surub M5 cu guler, torx T20, cote in poza de mai jos. Pret: 0.5 lei/ 100g sau 100 buc- 4 lei. Disponibile 3 kg.
83. Surub pt plastic cu guler, torx T20, cote in poza de mai jos. Pret 0.5 lei/100g  sau 100 buc- 1 lei. Disponibile 5 kg.
84. Suruburi pt plastic, torx T8, cote in poza de mai jos. Pret: 0.3 leu /100g sau 700 buc-  1 leu. Disponibile 10 kg.
221. Relee auto Iveco, 12V 10 A. Pret: 4 lei toate.
Pret: 75 lei.
231. Set difuzoare tv Samsung UE32J4500AW, cod BN96-36052A, 6 ohm, 5VA. Pret: 9 lei.
237. Miliampermetru de panou. Pret: 8 lei.
242. Vana gaz Sigma 845 (Vaillant). Pret: 8 lei.
3,7V 355mA, 1,3 VA. Cablu ~ 2m. Disponibile 5 bucati. Pret: 4 lei/buc.
5,7 V, 800 mA. Cablu ~ 1.8 m. Disponibile 10 bucati. Pret: 4 lei/buc.
254. Set difuzoare Viefu 30041403 (recuperate dintro plasma Vortex), 8 ohm, 12 W. Pret: 7 lei.
 255. Set difuzoare OHC 300772s1, 8 ohm, 5W. Pret: 7 lei.
Pret: 12 lei bucata.
264. Contoare electromagnetice SI-47. Doua bucati. Pret: 7 lei/buc.
268. Micro filtru DSL HWMF-140. Nou. Pret: 5 lei.
276. Temporizator mecanic cuptor cu microunde: durata temp 30 min, contactele suporta 16A. Pret: 7 lei.
5 lei.
278. Pompa cafetiera Ceme Italia, 240V, 47W. Pret: 6 lei.
1C-1-15,0
Pret: 0.3 lei/m.
S1: 9V
S2: 24V
Pret: 15 lei.
286. Releu Sigma cu soclu. Pret: 12 lei.
287. Releu Schrack ZG z60 720. Pret: 9 lei.
288. Releu combina frigorifica General Electric. Pret: 5 lei
Pret: 40 lei.
309. Placa copiator Canon, FG1-9283. Pret: 15 lei.
 Tensiuni/curenti 5V/ 9A, 12V/ 4A, 24V 2.2A. Pret: 25 lei.
311. Sursa DVD-Player Sony dvp-ns300 (HS- 13S0E). Tensiuni 12V, 3,3V. Pret: 5 lei.
321. Placa Agilent 82350B, nu am reusit sa o instalez in win7, se vinde ca defecta. Pret: 5 lei.
324a. Mainboard TP.MS 3663S.PB818 (t-con v320bj8-q01, si panel cx315dledm). Pret: 75 lei.
324C. Set difuzoare 8ohm/11W, LE-32Z1 SPK CVR-R, PD-1908027. Pret: 15 lei.
324d. Set picioruse. Pret: 9 lei.
Bobina: 220Vac
Contact: 30A
Pret: 12 lei.
333a. Placa de baza Conrac + tuner Philips. Pret: 18 lei.
333b.Placi invertoare back-light 24v40w2s(HIP0212A). Pret: 15 lei/buc. sau 25 lei ambele.
333c. Doua perchi difuzoare 4ohm/5watt, 9cm x 5cm, cu aparatoare din plastic. Pret: 10 lei/perechea. sau  17 lei
ambele perechi.
334.Modul de control al turatiei al ventilatorului de racire pentru radiator de tip auto (Mercedes). Pret: 17 Lei.
339. HDD Seagate Barracuda 200GB (testat cu Data LifeGuard Diagnostics).Pret: 19 lei.
341. HDD Seagate Barracuda 80GB (testat cu Data LifeGuard Diagnostics). 2 bucati Pret:10 lei buc
342. Doua Coolere procesoare Intel. Pret: 9 lei ambele
Dimensiuni: L= 9,8cm, H=8,2cm, grosime pachet tole 5,4cm. Pret: 25 lei.
345. Amplificator auto Harman&Kardon, realizat cu TDA8463Q (3bucati). Pret: 15 lei.
   348. Relee auto:
3 bucati Ford 30A
1 bucata VW 30A
1 bucata Ford 20A
Pret: 7 lei.
Secundar: 35V-0-35V
Pret: 45 lei.
351. Adaptor Chicony 19V/ 2,1A - 40W. Pret: 10 lei.
353. Tranzistori AD152 (IPRS), recuperati 2 bucati. Pret: 4 ambi.
10.000uF/56V. Pret: 17 lei perechea.
Editat de cmariuss
Se adauga:
355. Sursa SMPS ealizata cu TL494 Netcom SRC-8PS (Linetron Arad)- alimenta cateva amplificatoare CATV:
Tensiuni: 18V, 24V, 44V.
Pret: 20 lei.
https://postimg.cc/4n0XmJsm
https://postimg.cc/3km8sPMW
https://postimg.cc/LY6mZ5JZ
356. Receptor pentru microfoane wireless WVNGR WG2189, fara antenele telescopice si cablu alimentare, netestat.
Se poate folosi pentru VU-metre si carcasa. Pret: 15 lei.
https://postimg.cc/y3DBvGX1
https://postimg.cc/t19jLJtm
https://postimg.cc/ftLhRPPc
357. Bobina inductie pentru Dacia 1300,1310. Productie Bulgaria, nefolosita. Pret: 15 lei.
https://postimg.cc/r0nMGT4Z
358. PCB cu 32 mufe BNC. Pret: 12lei.
https://postimg.cc/dkXgtVrF
@ovidiugrigore multumesc pentru atentionare.
Se adauga:
359. Minicompresor 12V. Pret: 15 lei.
https://imgur.com/h8XMKuy
https://imgur.com/NzfSnxU
360. Modul Petri-Lehr Steering Wheel reemote control. Este un sistem care ajuta soferul cu un anumit grad de handicap
 sa aiba un acces mai facil la comenzile masinii. Lipsesc senzorii infrarosu. Se vinde asa cum este. Pret: 20 lei.
https://imgur.com/gV385u5
https://imgur.com/JIXQZFf
https://imgur.com/IuzohRz
https://imgur.com/3dOGUUt
https://imgur.com/vhO1dyN
361. Adaptor Samsung 14V, 1,786A (25W). Pret: 12 lei.
https://imgur.com/1cY85Vt
362. Ventilatoare Nidec Betav. Doua bucati C32957-58, 12V- 0,29A. Una bucata C34637-58, 12V- 0,13A. Pret:
12lei toate.
https://imgur.com/mFUdq3h
363. Placuta Belim.Se alimenteaza la 230V. Tranzistoarele sunt BC237.CI-ul LM358. Din butonul portocaliu se
schimba sensul de turatie al micromorului (12V). Pret: 5 lei.
https://imgur.com/w9xPyx5
https://imgur.com/xZRkOZZ
364. Sursa Server AC Bel 332W
5V@25A
12V@16A
5Vstb@3A
! un ventilator este crapat si are o pala rupta, dar functioneaza. Pret: 22 lei.
https://imgur.com/unPF0QC
https://imgur.com/YO6nOXv
https://imgur.com/Jp0AF3M
