Electronice diverse
cmariuss
Lista reactualizata. Preturi reduse:
 1. Tv Samsung UE32j4500AW, cu ecran spart, se da pentru piese:
Barete LED-uri: V5DN-320SMO-R4 Pret: 30 lei
Mainboard: BN41-02360 Pret: 40 lei.
https://imgur.com/a/iy4S5ZM
 2. Mainboard Vestel 17MB62-1. Pret: 25 lei
https://imgur.com/75Cf5hG
3. Barete Led D2GE-460SCA-R3 (7 buc)- 7 lei/buc.
https://imgur.com/3COXrCZ
 4. Placa Home cinema Sanyo DVM 2600, lipsesc finalii audio. Pret: 7 lei.
https://imgur.com/jvIgaER
8. Placa intrari mixer Behringer Pro-dx626. Pret: 6 lei.
https://imgur.com/NLH5rX1
 9. Cabluri Scart. Pret: 4 lei bucata.
https://imgur.com/RSGqalj
15. Set manere pentru aparat, aluminiu, dimensiuni: lungime 22cm, latime 6cm, grosime 0.7-
0.9cm. Pret: 16 lei.
https://imgur.com/nzuRB4w
  16. Set manere pentru transport, rabatabile, talpa aluminiu, manere din Cr, talpa 12x4cm,
maner 12x7.5cm.Pret: 20lei.
https://imgur.com/ye8f1Wh
20. Difuzore recuperate dintrun tv Thomson, 8 ohm, dimensiuni 20x5,5x2,5 - 9 lei.
https://imgur.com/T5dnTZN
 21. Doua cuti metalice, provin din amplificatoare CATV, dimensiuni 23x18x3. Pret: 8 lei/buc.
https://imgur.com/OJBR2ls
https://imgur.com/amBBkGE
 23. Doua Ventilatoare Sunon Magleev. Pret: 5lei/buc.
https://imgur.com/wyfzO0P
 24. Memorii EEprom ceramice, 24 buc, 1 lei/buc sau 18 lei toate.
https://imgur.com/FC3ztDs
27. Cablu adaptor HP display/ DVI (nou). Pret: 9 lei.
https://imgur.com/e5q2hGb
38. Simulator centura siguranta auto Cygnetic. Pret: 9 lei.
https://imgur.com/YGj4CIP
 41. Drosere Vassloh/Schwabe 18-28W. Pret: 5 lei/buc.
https://imgur.com/uLXZfAb
42. Radiatoare provenite dintro unitate Mac ProG5. Unul dintre radiatoare e putin dezcentrat, dupa cum se poate vedea
in poze. Dimensiuni: talpa Cu 17x9 cm, grosime talpa 6+6 mm, inaltime radiator 13,5cm. Pret: 19 ambele.
https://imgur.com/Nfpvhkb
https://imgur.com/QVvXRdA
51. Docking Station HP2013. Se vinde ca defect. Fara cablu alimentare. Pret: 7 lei.
https://imgur.com/IOpGY8z
 60. Placa invertor 1000VA/32Vcc. Pret: 10 lei.
https://imgur.com/9REt98m
67. Modul inalta tensiune dintrun copiator canon. Pret: 10 lei.
https://imgur.com/4usBMHS
https://imgur.com/NiIUhjC
 75. TomTom Link. Pret: 3 lei.
https://imgur.com/KbF5eiF
76. Module imprimanta Epson, modul alimentare in comutatie+ partea de comanda a motoarelor pas-cu-pas,
2xLB1847, 2xSMA4033(sanken). Pret: 5 lei.
https://imgur.com/MFLhL9X
https://imgur.com/vHdVFWl
91. Placa cu ~250 LED-uri recuperata dintru copiator. Pret: 6 lei.
https://imgur.com/9qmkSpR
 94. Difuzoare (doua) recuperate dintro plasma. Impedanta 8 ohm, putere 10 W. Dimensiunile difuzorului: 13cm x 4,5
cm. Pret: 8 lei.
https://imgur.com/W5Lk3oA
95. Tuner JS-6H2/121. Pret: 3 lei.
https://imgur.com/0uqqKgq
105. Placa video PC 64Mb/32Mb AGP:
Pret: 4 lei.
https://imgur.com/1jlhw4D
https://imgur.com/cRwUd2Q
110. Moduli dublu-tiristor URSS, MTT-63-10-4. Am 6 bucati.
Pret: 25 lei/buc.
https://imgur.com/WBa4zoU
115: HDD 3,5" Hitachi 160GB, testat si instalat Windows7. Pret: 22 lei.
https://imgur.com/OdWCTHY
116: HDD 3,5" WD, 80 GB, testat. Pret: 15 lei.
https://imgur.com/HT5lJxe
119: Sasiu monitor LG Flatron L194WS-SF. Monitorul s-a dezmebrat din cauza ecranului spart. Pret: 7 lei.
https://imgur.com/LPp3EYE
https://imgur.com/kkjrPTE
https://imgur.com/w1bAdHV
159. Mecanica deck Harman&Kardon CD91C, se vinde pentru piese. Pret: 9 lei.
https://imgur.com/HoHbwCJ
https://imgur.com/JfG2Kpo
 163. Hardisk Samsung HD160JJ 160GB, testat, si instalat Windows 7. Pret: 23 lei.
https://imgur.com/4U36JvC
164. Memorii Ram, DDR2, 512Mb, testate. Pret: 2 lei/buc.
https://imgur.com/j695ShP
171. Sursa in comutatie DPPB-10077B, realizata cu KA 1M0880. Tensiuni: 26V, 12V, 5V, 3V3, -27V. Pret: 9 lei.
https://imgur.com/ZLVkj9E
177. Transformator recuperat dintrun cd player Technics SL-PD8. Tensiuni: 16V, 9V, 4V. Pret: 7 lei.
https://imgur.com/lWabH9T
193. Set condensatori electrolitici 6800uF/ 50V Nippon Chemicon Audio. Pret: 15 lei.
https://imgur.com/NtUr0GW
 195. Transformator 8 VA. Tensiune: 18 V. Pret: 5 lei.
https://imgur.com/HHny31L
196. Radiator aluminiu. Dimensiune: lungime 23 cm, inaltime 5 cm, adancime 6 cm. Pret: 17 lei.
https://imgur.com/1tNONU8
https://imgur.com/YNYp4JG
 201. Placa soft-start. Pret: 3 lei.
https://imgur.com/IG959ut
https://imgur.com/9Hfs3u8
 216. Difuzoare BN96-02586A (Samsung 22" LE27T51B) 16 ohm, 5W. Pret: 12 lei.
https://imgur.com/RgYGACS
217. Sursa tv Dong-Yang BN96-02580A Pret: 35 lei.
https://imgur.com/tZRWUn0
Suruburi:
82. Surub M5 cu guler, torx T20, cote in poza de mai jos. Pret: 0.5 lei/ 100g sau 100 buc- 4 lei. Disponibile 7 kg.
https://imgur.com/jATZ700
https://imgur.com/Wh2fXId
83. Surub pt plastic cu guler, torx T20, cote in poza de mai jos. Pret 0.5 lei/100g  sau 100 buc- 1 lei. Disponibile 23 kg.
https://imgur.com/G8eOpez
https://imgur.com/npSbWoC
84. Suruburi pt plastic, torx T8, cote in poza de mai jos. Pret: 0.3 leu /100g sau 700 buc-  1 leu. Disponibile 38 kg.
https://imgur.com/Kodbtx9
https://imgur.com/EnEQ6Xe
85. Arcuri, cote in poza de mai jos. Pret: 2,5 lei/ 100g. Disponibile 300 g.
https://imgur.com/fXSwir7
https://imgur.com/QKfSNQm
221. Relee auto Iveco, 12V 10 A. Pret: 6 lei toate.
https://imgur.com/WeNk55u
 223. Modul afisaj-comanda logica-microprocesor-sintetizator PLL Siemens RS555. Integrate S867, TC5017,Ba612,
BA618, MC14049,MC14081 etc. Pret: 15 lei
https://imgur.com/Hz3JbyH
https://imgur.com/ZBYN4pI
 227. Sursa Plisch FMS-100 (recuperata dintrun aparat de masura/analiza semnal TV)
Uin: 195- 265V, 47-63Hz, Putere = 250VA
Tensiuni: 5V, 7,5V, -5V, -12V, 24V
Realizata cu componente de calitate: Philips, Siemens, Motorola,Wima etc.
Sursa a fost reparata o data in 2003 de Antena Hungaria Kft.
Pret: 85 lei.
https://imgur.com/J1LNTxB
https://imgur.com/IPB11HQ
https://imgur.com/oFZz2l9
https://imgur.com/x5b415j
https://imgur.com/8XaEBLF
https://imgur.com/yMpTrKt
https://imgur.com/2uJ8xU0
https://imgur.com/n8O62DK
https://imgur.com/fqdWvLC
https://imgur.com/QBbTVui
https://imgur.com/Jqpfgcc
https://imgur.com/lDjYxh7
231. Set difuzoare tv Samsung UE32J4500AW, cod BN96-36052A, 6 ohm, 5VA. Pret: 12 lei.
https://imgur.com/bEJ0l9M
https://imgur.com/3fzEg0V
237. Miliampermetru de panou. Pret: 9 lei.
https://imgur.com/sAk2x3I
https://imgur.com/p9vpAmi
242. Vana gaz Sigma 845 (Vaillant). Pret: 9 lei.
https://imgur.com/MprfpGO
 245. Adaptoare Nokia ACP-7E (cu transformator). Nefolosite.
3,7V 355mA, 1,3 VA. Cablu ~ 2m. Disponibile 8 bucati. Pret: 4 lei/buc.
https://imgur.com/q0myNA5
https://imgur.com/KVp2lq5
246. Adaptoare Nokia ACP-12E, nefolosite.
5,7 V, 800 mA. Cablu ~ 1.8 m. Disponibile 18 bucati. Pret: 4 lei/buc.
https://imgur.com/WWHA3E3
254. Set difuzoare Viefu 30041403 (recuperate dintro plasma Vortex), 8 ohm, 12 W. Pret: 8 lei.
https://imgur.com/k5ZW4Ot
 255. Set difuzoare OHC 300772s1, 8 ohm, 5W. Pret: 8 lei.
https://imgur.com/KZkRhK1
https://imgur.com/xxerTCC
 256. Lot 9 sigurante auto Pacific 20-50 A. Pret: 7 lei.
https://imgur.com/fqGuwq6
 257. Lot 6 relee Kuhne 114A4-24Vac1, bobina 24Vac, contacte 4x2. Pret: 15 lei.
https://imgur.com/6YX1H8M
258. Lot 5 relee: 2 relee Omron auto, 12V, 20A; 1 releu Finder 24Vcc, 5A 250V; 1 releu Omron bobina 24 Vcc; 1
releu Matsushita bobina 100Vac. Pret: 10 lei.
https://imgur.com/Jq27paO
260. LED driver Gelux model LD-361200-104L. Tensiune: 20-36V, 1050mA. Doua bucati, unul are cablu mai scurt.
Pret: 15 lei bucata.
https://imgur.com/rhgNZBv
https://imgur.com/wykPaSb
262. Adaptor laptop Toshiba 45 watt PA32P3U-1ACA, 15 V, 3 A. Cablu: 2x2m. Pret: 20 lei.
https://imgur.com/SWuLuny
https://imgur.com/JMLTqrn
264. Contoare electromagnetice SI-47. Doua bucati. Pret: 9lei/buc.
https://imgur.com/qTMsp21
266. Alarma auto Thor. Pret: 8 lei.
https://imgur.com/FzgIzkt
268. Micro filtru DSL HWMF-140. Nou. Pret: 7 lei.
https://imgur.com/iSX4t3y
273. Modul clima auto, se pot recupera ecran LCD, microventilator, BTS132, BTS62121, BTS113A etc. Pret: 3 lei.
https://imgur.com/lH4jl3d
276. Temporizator mecanic cuptor cu microunde: durata temp 30 min, contactele suporta 16A. Pret: 8 lei.
https://imgur.com/oy1OyAI
277. Temporizator mecanic Combolo Milano (cuptor electric), durata temporizare 5min, contactele suporta 10A. Pret: 5 lei.
https://imgur.com/ONf3Esg
https://imgur.com/ZB1G8ZG
278. Pompa cafetiera Ceme Italia, 240V, 47W. Pret: 7 lei.
https://imgur.com/cG7RGK1
281. Transformatoare 100W ABB si-tr 100 230/12 kxv. Doua bucati. Pentru lampi halogen.
Secundar: 11,5 V/ 8A.
Pret: 17lei/buc.
https://postimg.cc/v4tqyqjK
https://postimg.cc/mPsX0fdM
282. Bobina inductie Dacia 1310/1410. Producator IAEA Sfantu Gheorghe.
Pret: 17 lei.
https://postimg.cc/HJS6cJT4
https://postimg.cc/V5JVtFrS
283. Sarma nichelina NiCr Nikrothal 80.
Diametru 0.2 mm, rezistenta 35,80 ohm/m, temperatura max de lucru 1200*C, conductibilitate termica/100°C Wm-
1C-1-15,0
Pret: 0.4 lei/m.
https://postimg.cc/k6Bfxn4r
https://postimg.cc/KKQHPqDT
284. Transformator 30VA:
S1: 9V
S2: 24V
Pret: 15 lei.
https://postimg.cc/5X9Xxvtq
285. Placa cafetiera Saeco. Pret: 7 lei.
https://postimg.cc/HrTyVR6M
286. Releu Sigma cu soclu. Pret: 15 lei.
https://postimg.cc/23BvJ4q1
https://postimg.cc/Sntxkv3k
287. Releu Schrack ZG z60 720. Pret: 10 lei.
https://postimg.cc/xcvmjn3Y
https://postimg.cc/NyJmhD7H
288. Releu combina frigorifica General Electric. Pret: 7lei
https://postimg.cc/PvZwwjGW
289. Releu solid state Ahly asr-25dd
Comanda: 3-32 Vcc. Sarcina: 25A, 5-20Vcc.
Pret: 45 lei.
https://postimg.cc/2155pDH0
https://postimg.cc/NL1Fmb9k
290. Cablu imprimanta HP, 1,5m, USB tip A/ USB tipB. Pret: 9 lei.
https://postimg.cc/Pvkq0vcD
291. CD/ROM/DVD ROM laptop Toshiba SD-R2202. Pret: 3 lei.
https://postimg.cc/fJf3n5MR
https://postimg.cc/KKwjrHDJ
292. Filtru retea/ suport  doua sigurante. Pret: 3lei.
https://postimg.cc/hfsG3j0J
293. Placa TV tuner ATI. Pret: 3 lei.
https://postimg.cc/1nVgkQ3k
300. Relee auto 12 V/ 40 A. Pret: 9 lei toate.
https://postimg.cc/mhjwD7rw
301. Relee auto de semnalizare. Pret: 9 lei toate.
https://postimg.cc/Fdgx0LVh
03. Telecomanda radio 27MHz, fara antena telescopica. Pret: 7 lei.
https://postimg.cc/K167VN9Z
https://postimg.cc/S2q6QKF3
304. Telecomanda infrarosu. Pret: 5 lei.
https://postimg.cc/GHSxPrGT
https://postimg.cc/8sZRDDyX
305. Telecomanda radio 27MHz, fara antena si capac bateri. Pret: 3 lei.
https://postimg.cc/dLXGk6c8
https://postimg.cc/QBg7zr9b.
09. Placa copiator Canon, FG1-9283. Pret: 18 lei.
https://postimg.cc/B8tjSf1m
https://postimg.cc/87ZFgzsF
https://postimg.cc/hhC3vHvH
310. Sursa in comutatie Wei-Ya, model wy-15ca1. Dimensiuni 16cm x 12cm x 5cm
 Tensiuni/curenti 5V/ 9A, 12V/ 4A, 24V 2.2A. Pret: 30 lei.
https://postimg.cc/LJ2fMWTW
https://postimg.cc/p9dFmn3Y
https://postimg.cc/YL2K7Mv9
311. Sursa DVD-Player Sony dvp-ns300 (HS- 13S0E). Tensiuni 12V, 3,3V. Pret: 6 lei.
https://postimg.cc/rDj4y9Zw
312. Adaptor Xing-Yang 12V 1,5A. Pret: 7 lei.
https://postimg.cc/s1G5P7xT
313. Adaptor Panasonic 6V, 500mA. Pret: 5 lei.
https://postimg.cc/PPGYSJ8T
314. Adaptor laptop Toshiba PA2450U (fara mufa !), 15V, 3A. Pret: 12 lei.
https://postimg.cc/zbKXvzDF
315. Difuzoare 6 ohm/ 11W, model 378G0110567ydx, Philips 32PHT4201. Pret: 7 lei/perechea.
https://postimg.cc/SJyNQbBc
https://postimg.cc/ykv6krKt
320. Placa PCI -5 porturi USB. Pret: 4 lei
https://postimg.cc/v4tv15TY
321. Placa Agilent 82350B, nu am reusit sa o instalez in win7, se vinde ca defecta. Pret: 7 lei.
https://postimg.cc/DW55N13j
https://postimg.cc/Wtx8x2xv
322. Radiator Aluminu. Dimensiuni 26.5cm x 24.5cm x 2.7cm, grosime talpa 0,9 cm. Pret: 40 lei.
https://postimg.cc/3dPqjj32
https://postimg.cc/cttm6jg2
https://postimg.cc/CBQ7hY1b
324. Din dezmembrarea unui LED tv, Blaupunkt BN32H1032eeb, urmatoarele:
324a. Mainboard TP.MS 3663S.PB818 (t-con v320bj8-q01, si panel cx315dledm). Pret: 80 lei.
https://postimg.cc/kDbM76H8
https://postimg.cc/mPbT3dgN
https://postimg.cc/McHxNvRn
https://postimg.cc/yWcKMqJy
324b. Set 2 barete LED, HL-00320A30-0601S-07A3.Pret: 25 lei.
https://postimg.cc/tnW9kw6D
https://postimg.cc/ZB1Tr4WC
324C. Set difuzoare 8ohm/11W, LE-32Z1 SPK CVR-R, PD-1908027. Pret: 20 lei.
https://postimg.cc/N26wmThz
324d. Set picioruse. Pret: 10 lei.
@zoltanh vi le-am rezervat.
@leo177
poz91
Poze mai detaliate. Din pacate s-a ratacit un afisaj GL9N04 (Sharp). Va dau placa gratuit, daca mai luati cate ceva sa merite mersul la posta.
https://postimg.cc/YvbTg8t8
https://postimg.cc/D8Q9fnD9
https://postimg.cc/TLWsz6gH
https://postimg.cc/hXSHfNRf
https://postimg.cc/jW1935w7
Se adauga:
325.Transformator ecranat T 1080 ~ 50VA
Secundar 1: 15V-0-15V
Secundar 2: 65V
Pret: 23 lei.
https://postimg.cc/30GHFGtN
https://postimg.cc/svRFRvnP
326.Transformator 100VA, turnat in plastic, pe alocuri plasticul a crapat.
Secundar: 24V
Pret: 20 lei.
https://postimg.cc/grh95vKk
https://postimg.cc/K3SWFH5c
327. Releu RL30/3ES/C recuperat din celebrele dozatoare de suc TEC din anii 90'.
Pret: 10 lei.
https://postimg.cc/zVkQZpH5
https://postimg.cc/LJ6bHfjP
https://postimg.cc/tYbcM8T2
328. Releu Matsushita jh1a-ac220v
Bobina: 220Vac
Contact: 30A
Pret: 12 lei.
https://postimg.cc/9Rv60Mch
329. O pereche de tranzistori recuperati Sanken 2SA1215/2SC2921
Pret: 25 lei.
https://postimg.cc/vDfjXGQ4
Salut, cumpar urmatoarele :
Buna,
Am primit pachetul. Totul a fost impachetat cu grija si atentie. Cele trimise sunt conforme cu descrierea. Recomand cu incredere pentru seriozitate, comunicare fluenta si promptitudine.
Multumesc mult pentru cadouri.
Sarbatori Fericite!
  • 3 săptămâni mai târziu...
La multi ani !
Rezervarile de anul trecut raman valabile.
Se adauga:
330: Transformator 10W, secundar 17V in gol. Pret: 9 lei.
https://postimg.cc/N9CLNTG2
331: Placa centrala termica Immergas Dimms09.Transformatorul are urmatoaerele tensiuni: 2x21V 0.21A. 180V 5mA. Pret: 15 lei.
https://postimg.cc/ThhKKkQV
https://postimg.cc/LqNsXf1Q
332: Radiator Aluminiu cu dimensiuni 25cmx13cmx40cm, talpa 3mm (recuperat dintro sursa smps tv). Pret: 5 lei.
https://postimg.cc/JDsRzFmt
https://postimg.cc/D8k775Ny
333. Componente din dezmembrarea unui tv Fujitsu Siemens Myrica VQ40-1. Toate componentele find in stare de functionare, problema tv-ului era sursa.
333a. Placa de baza Conrac + tuner Philips. Pret: 20 lei.
https://postimg.cc/ctYZQ8vS
https://postimg.cc/6759D3mr
https://postimg.cc/0MybdZvq
https://postimg.cc/CR0MsJC6
333b.Placi invertoare back-light 24v40w2s(HIP0212A). Pret: 18 lei/buc. sau 30lei ambele.
https://postimg.cc/MnJHrzw5
https://postimg.cc/gwYJm4n6
https://postimg.cc/GTBt6297
333c. Doua perchi difuzoare 4ohm/5watt, 9cm x 5cm, cu aparatoare din plastic. Pret: 12 lei/perechea. sau  20 lei ambele perechi.
https://postimg.cc/4YXZ9yZD
https://postimg.cc/7CV52dpV
334.Modul de control al turatiei al ventilatorului de racire pentru radiator de tip auto (Mercedes). Pret: 20 Lei.
https://postimg.cc/FYbRMws4
335.Releu auto.  Contactele suporta ~100A. Pret: 9 lei.
https://postimg.cc/6yF7CdT8
82/ 100 buc
83/daca este 1 leu ,,100 buc vreau 500 buc
84/700 buc 1 leu?
335
300
301
281 ,,30 le ambele le dati ?
va rog faceti un calcul
la punctul 84 sa mi specificati daca 700 buc este 1 leu
  • 2 săptămâni mai târziu...
