valahul Postat Februarie 5, 2019 Partajează Postat Februarie 5, 2019 Buna seara. Mi-am luat azi de la piata niste boxe phillips, aratau foarte bine, imi plac mult, dar cand am ajuns acasa si am dar jos panza de pe ele, cauciucul care tine difuzoarele de bass, situat la exteriorul acestuia era copt si... inexistent. Tweeterele sunt ok, au si filtre. Cam asa arata pe spate, au fost de 4 ohmi. Acum daca tot le-am luat, vreau sa le inlocuiesc difuzoarele. M-am oprit la modelele de mai jos, is undeva la 110 lei bucata, dar nu stiu de care sa pun, iar daca pun de 8 ohmi, initial au fost de 4, trebuie schimbate si filtrele? Monacor SP-200PA Difuzor Monacor SP-200PA Diametru (inch): 8 Putere maxima (W): 200 Putere garantata (W): 100 Raspuns in frecventa (Hz): 30-4000 Sensibilitate (dB): 91 Impedanta (Ohm): 8 Greutate (kg): 1.3 Unitate vinzare: buc file:///C:/Users/Valahul/Desktop/sp-200pa.pdf DIFUZOR HIFI MONACOR SP-202E Hi-fi bass-midrange speaker, 50 W, 4 Ω Multi-purpose speaker Foam surround Replacement speaker for closed speaker systems Impedance (Z) 4 Ω Frequency range f3-6,000 Hz Resonant frequency (fs) 51 Hz Power rating 50 W Peak music power output 100 W Sensitivity 93 dB/W/m Suspension compl. (Cms) 0.62 mm/N Moving mass (Mms) 15 g Mech. Q factor (Qms) 4.5 Electr. Q factor (Qes) 0.81 Total Q factor (Qts) 0.69 Equivalent volume (Vas) 39 l DC resistance (Re) 3.85 Ω Force factor (BxL) 4.86 Tm Voice coil induct. (Le) 0.6 mH Voice coil diameter Ø 25.5 mm Voice coil former aluminium Linear excursion (XMAX) ± 2.5 mm Eff. cone area (Sd) 210 cm2 Magnet weight 570 g Mounting cutout Ø 183mm Mounting depth 82mm Mounting hole diameter Ø 192 mm Dimensions Ø 202 mm x 82 mm Outside diameter Ø 202 mm Width Ø 202 mm Depth 82 mm Admiss. ambient temp. 0-40 °C Weight 1.39 kg Sales unit 1 Type of speaker 8" Diametru (inch): 8 Putere maxima (W): 100 Putere garantata (W): 50 Raspuns in frecventa (Hz): 30-6000 Sensibilitate (dB): 93 Impedanta (Ohm): 4 Greutate (kg): 1.39 Unitate vinzare: buc DIFUZOR UNIVERSAL BASS MONACOR SP-202PA Universal bass-midrange speaker, 50 W, 8 Ω For bass-midrange applications, also in power speaker systems. Impedance (Z)8 Ω Frequency rangef3-4,500 Hz Resonant frequency (fs)68 Hz Power rating50 W Peak music power output100 W Sensitivity91 dB/W/m Suspension compl. (Cms)0.2 mm/N Moving mass (Mms)18 g Mech. Q factor (Qms)2.33 Electr. Q factor (Qes)2.25 Total Q factor (Qts)1.1 Equivalent volume (Vas)12 l DC resistance (Re)7.4 Ω Force factor (BxL)5.6 Tm Voice coil induct. (Le)0.4 mH Voice coil diameterØ 25 mm Voice coil formeraluminium Linear excursion (XMAX)± 3 mm Eff. cone area (Sd)216 cm2 Magnet weight570 g Magnet diameterØ 100 mm Mounting cutoutØ 185 mm Mounting depth82 mm DimensionsØ 200 mm x 90 mm Outside diameterØ 200 mm WidthØ 200 mm Depth90 mm Admiss. ambient temp.0-40 °C Weight1.115 kg Packing unit1 Type of speaker8" Diametru (inch): 8 Putere maxima (W): 100 Putere garantata (W): 50 Raspuns in frecventa (Hz): 30-4500 Sensibilitate (dB): 91 Impedanta (Ohm): 8 Greutate (kg): 1.3 Link spre comentariu
valahul Postat Februarie 5, 2019 Autor Partajează Postat Februarie 5, 2019 Am comandat deja DIFUZOR HIFI MONACOR SP-202E. Se poate inchide. Link spre comentariu
sesebe Postat Februarie 5, 2019 Partajează Postat Februarie 5, 2019 Daca tot nu ai asteptat sa primesti un raspuns dece ai mai intrebat? Ai facut o simulare sa vezi cum se impaca parametrii de la acest difuzor cu volumul cutiei pe care o ai? Link spre comentariu
valahul Postat Februarie 6, 2019 Autor Partajează Postat Februarie 6, 2019 Am anulat comanda. Nu stiu daca sunt bune. Nu am facut simularea ca nu ma prea pricep. Acum oscilez intre acestea doua, nu inteleg de ce unul e mai scump doar cu 2 lei si are 70 w, iar unul doar 50 w. Cutia are dimensiunile 38 x 28 x 23 cm. Nu stiu pe care sa il iau, e pe doua cai boxa si are filtru, cred ca de 4 ohmi. Daca pun de 8 are ceva? DIFUZOR HIFI BASS-MEDII MONACOR SPM-205/4 Difuzor HiFi bass-medii Monacor SPM-205/4. Excellent replacement speakers of the same quality as from the original equipment manufacturer . Coated low-resonance paper cone . Long-term stable rubber surround . To be used preferably in closed or transmission line cabinets . Diametru (inch): 8 Putere maxima (W): 150 Putere garantata (W): 70 Raspuns in frecventa (Hz): 30-5000 Sensibilitate (dB): 89 Impedanta (Ohm): 4 SAU DIFUZOR HIFI MONACOR SP-202E Hi-fi bass-midrange speaker, 50 W, 4 Ω Multi-purpose speaker Foam surround Replacement speaker for closed speaker systems Impedance (Z)4 Ω Frequency rangef3-6,000 Hz Resonant frequency (fs)51 Hz Power rating50 W Peak music power output100 W Sensitivity93 dB/W/m Suspension compl. (Cms)0.62 mm/N Moving mass (Mms)15 g Mech. Q factor (Qms)4.5 Electr. Q factor (Qes)0.81 Total Q factor (Qts)0.69 Equivalent volume (Vas)39 l DC resistance (Re)3.85 Ω Force factor (BxL)4.86 Tm Voice coil induct. (Le)0.6 mH Voice coil diameterØ 25.5 mm Voice coil formeraluminium Linear excursion (XMAX)± 2.5 mm Eff. cone area (Sd)210 cm2 Magnet weight570 g Mounting cutoutØ 183mm Mounting depth82mm Mounting hole diameterØ 192 mm DimensionsØ 202 mm x 82 mm Outside diameterØ 202 mm WidthØ 202 mm Depth82 mm Admiss. ambient temp.0-40 °C Weight1.39 kg Sales unit1 Type of speaker8" Diametru (inch): 8 Putere maxima (W): 100 Putere garantata (W): 50 Raspuns in frecventa (Hz): 30-6000 Sensibilitate (dB): 93 Impedanta (Ohm): 4 Greutate (kg): 1.39 Vad ca ultimul are striri, celalalt nu. Link spre comentariu
sesebe Postat Februarie 6, 2019 Partajează Postat Februarie 6, 2019 Eu nu am ascultat nici unul din difuzoarele alea dar cineva de încredere mi-a spus ca nu-s grozave mai ales dacă nu se "pupa" cu incinta. Pe de alta parte, greu ai sa găsești difuzoare bune la un preț asa de mic. Cauta un simulator de incinte online, incarcă datele difuzorului care te interesează și volumul cutiei și vezi ce-ți iese. Link spre comentariu
valahul Postat Februarie 6, 2019 Autor Partajează Postat Februarie 6, 2019 Mersi, sesebe. Incerc sa caut online sa vad ce o iesi. Link spre comentariu
sesebe Postat Februarie 6, 2019 Partajează Postat Februarie 6, 2019 Nu ai specificat daca sint dimensiunile exterioare sau cele interioare pt ca volumul intern este necesar. Nu ai specificat daca sint bass reflex sau compres (cutie inchisa). Uite, verifica cu acest calculator de exemplu: http://www.micka.de/en/index.php#ideal Am facut o simulare pt difuzorl pe care l-ai comandat initial si iti spune clar ca nu se poate folosi in cutie inchisa iar eu cred ca boxele initiale erau compres. Link spre comentariu
valahul Postat Februarie 6, 2019 Autor Partajează Postat Februarie 6, 2019 (editat) Bozele le-am luat din piata, cu 50 lei bucata. Sunau binisor, dar cand le-am desfacut, suspensia la un difuzor lipsea, iar celalalr era de alt tip, cred ca unul a fost inlocuit. Bozele arata bine, cutia, de aia as inlocui difuzoarele. Dimensiunile cutiei sunt 38 x 28 x 23, si e pe doua cai, inchisa ermetic. Scrie pe ea Phillips HIFI. Nu stiu ce difuzoare sa iau. https://imgur.com/a/5tR2nz0 https://imgur.com/a/3Z6Qf3e Editat Februarie 6, 2019 de valahul Link spre comentariu
maxente Postat Februarie 6, 2019 Partajează Postat Februarie 6, 2019 Pune alte suspensii la difuzoarele vechi daca bobina nu e coapta. Gasesti aici pe forum oameni care sa ti le faca daca nu te pricepi la mestereala. Te complici cu alte difuzoare in locul lor. Link spre comentariu
valahul Postat Februarie 6, 2019 Autor Partajează Postat Februarie 6, 2019 Dar sunt diferite difuzoarele, pun o poza cu ele, ca le-am scos afara, ca nu am avut de lucru, asta e. Eu am crezut ca daca e coapta suspensia, e gata difuzorul. Boxele cu panza din fata arata foarte bine, is si grele, cam 6 kg una. De unde sa stiu cand le-am luat din piata... culmea ca sunau bune si asa... dar cand am dat panzele jos... supriza. Nu stiu ce difuzoare sa iau. https://imgur.com/a/y8Tjf1W Link spre comentariu
valahul Postat Februarie 6, 2019 Autor Partajează Postat Februarie 6, 2019 (editat) Multumesc pentru raspunsuri. Trebuie avut in vedere ca nu sunt specialist, incerc sa repar boxele alea. Acum, am gasit la cineva doua difuzoare bass JBL scoase dintr-o pereche de boxe hls 810, plus filtrele cu 170 lei. Ma gandesc ca or fi bune. Oi vedea cand in vin. Am zis sa schimb si filtrele, avand in vedere ca vechile difuzoare erau pe 4 ohmi. Tweeterele raman cele de la boxa, ele nu cred ca au rezistenta si conteaza daca filtru este pe 4 sau 8. Problema e ca boxele de la care provin difuzoarele au bassreflex, au o gaura in spate si ale mele sunt inchise. Au ceva difuzoarele care provin de la boxe cu bassreflex daca le pun pe incinta inchisa? Dupa ce le schimb vineri, ca vineri imi ajung, o sa pun poze si parerea mea cum merg, oricum nu va fi o parere avizata, dar tot imi dau seama daca imi plac sau nu. O sa le pun pe un Luxman L190 si dupa pe un Tehnics SU- V 500. Nu le pot compara decat cu ce am mai bun eu, Denon 655R plus Magnat monitor supreme 802. Editat Februarie 6, 2019 de valahul Link spre comentariu
q_acdc Postat Februarie 6, 2019 Partajează Postat Februarie 6, 2019 (editat) Spm 205 în 19L și 24L cu material fono canta bine! (incinta închisă) Editat Februarie 6, 2019 de q_acdc Link spre comentariu
valahul Postat Februarie 6, 2019 Autor Partajează Postat Februarie 6, 2019 (editat) Acum 15 minute, q_acdc a spus: Spm 205 în 19L și 24L cu material fono canta bine! (incinta închisă) Acum daca imi traduci si ce inseamna... (am inteles, e unul din difuzoarele puse de mine in primul post... dar se zicea aici ca nu is grozave... de aia am luat JBL-urile alea, iar l sunt litrii... gata, m-am prins)., Material fono de ala nu stiu de unde fac rost, stau intr-un orasel departe de civilizatie... La 80 kw e primul magazin cu audio... pot improviza cu ceva? Sa iau de pe net iar dau pe transport o tona de bani. Daca ar fi undeva cu trasport decent... si de care e recomandat sa iau? Editat Februarie 6, 2019 de valahul Link spre comentariu
q_acdc Postat Februarie 6, 2019 Partajează Postat Februarie 6, 2019 Ce ai în interiorul incintei. Link spre comentariu
valahul Postat Februarie 6, 2019 Autor Partajează Postat Februarie 6, 2019 Acum parca un pic imi pare rau ca nu am luat Spm 205... erau 230 ambele... si noi. Oi vedea cum canta si jbl-urile... Link spre comentariu
