PROFILE VESTEL LCD DE REPARARE 17MBXX
Acum 31 minute, yokoono a spus:
Panelul are ceva echivalenta Vestel ?.
inca nu am gasit pentru 17mb110p 6870c-0442b cod ves31....
dar am sa caut daca nu rezolv,ca trebuie sa fie un cod ves31 si penntru alte 17mbxx
momentan il chinui cu niste profile
Va multumesc
on a telefunken with main 17MB55 damaged, I've changed the main with a 17MB110
tv works, but image isn't good
looking for panel bin files
main 17MB110 panel VES400UNDS-2D-N03
Acum 22 ore, yabbadabbadoo a spus:
I have for VES400UNDS-2D-N11 and  VES400UNVS-2D-N03.
Acum 23 ore, yabbadabbadoo a spus:
post the picture with the image, also post pq file, and say what exactly is wrong with the image? it is turned, it is solarized, and I can edit pq files for you
La 11.02.2023 la 12:24, iuliantv a spus:
this main 17MB110 is set for the panel VES400UNDS-2D-N11
with panel VES400UNDS-2D-N03, image is knurled and shaky, as you can see in the photo
downloadpq.mb110 attached
note
searching on internet, it seems that the tcon can be fitted also on panel VES400UNDS-2D-N02 and VES400UNVS-2D-N02
downloadpq.mb110.zip
i.mi pare rau dar la dv nu cred ca e vorba de setari display,acolo cred ca e vorba de ceva hardware,ceva componente smd in zona lvds placamama,ce tebuiesc inlaturate,sau mutate...sau banda lvds t.con mainboard defecta,ori display defect
I'm sorry, but I don't think it's about the display settings, I think it's about some hardware, some smd components in the lvds area of the motherboard, which are removed or moved... or the lvds t.con mainboard strip defective, or defective display
Editat de iuliantv
Acum 17 minute, iuliantv a spus:
https://files.fm/u/kqj58de35
e singura optiune ce apare pentru lvds in afara de cea originala postata de dv
it's the only option that appears for lvds apart from the original one posted by you
Acum 13 minute, Florinel TV a spus:
Mai sigur display defect
asa pare ,dar totusi ,poate are noroc si totusi e altceva,tot la un vestel am avut si eu o manifestare identica,tot cu un mainboard defect,mb95 parca,i.am pus un 17mb82,un 17mb110, la fel se manifesta
ce e ciudat,ca il foloseam la nevoie sa testez mainboarduri ce le pun in vanzare,si la o placa chinezeasca cred ca din varianta msd.309- msd306,am reusit sa,i fac imaginea ok din service,dar imaginea nu se pastra ok,decat cand schimbam acea optiune,deci pentru cateva secunde era ok,dupå care revenea ,de aceea ma duce gåndul ca totusi e incompatibilitate hardware sau un defect display remediabil
dupå ceva timp am reusit sa calc pe coltul ramei si sa sparg displayul,era sprizinit de perete långa altele,nu am plåns mult,ca oricum era zgåriat,era de probe,de mentionat ca era tot samsung,
Acum 1 oră, yabbadabbadoo a spus:
note
downloadpq.mb110.zip 92 kB · 3 descărcări
For VES400UNVS-2D-N03
17MB110 panel VES400UNVS-2D-N03.rar
  • 2 săptămâni mai târziu...
La 13.02.2023 la 10:38, yabbadabbadoo a spus:
note
downloadpq.mb110.zip 92 kB · 8 descărcări
No offence..... but maybe you can change your profile name first if you want if you can and if will fits you, them I might help you. Here is not a joke like in cartoons.
Editat de raileanu
