Vizitator Postat Ianuarie 28, 2019 Partajează Postat Ianuarie 28, 2019 (editat) 22 hours ago, Marian Roman said: Multumesc, dar am rezolvat! Cum??? Editat Ianuarie 28, 2019 de Vizitator Link spre comentariu
Vizitator Dragan Stefanovic Postat Septembrie 2, 2019 Partajează Postat Septembrie 2, 2019 If anyone could help with dump from the EMMC or at least with the first 500MB from the emmc with the recovery partition i will be more than happy . Thank you Link spre comentariu
marianbinu Postat Septembrie 26, 2019 Partajează Postat Septembrie 26, 2019 La 26.01.2019 la 10:48, Geo2017 a spus: e vrajeala?? ce tot vorbim aici?? s-au vreti fiserul din EMMC?? 056: eMMC OCR: C0FF8080 057: eMMC CID: 90014A484147326505030C6A112C93 058: eMMC CSD: D02701320F5903FFFFFFFFEF8A4040 059: Chip ID:4A010090,Chip Name:HAG2e 060: Chip Size: User=1024MB,Boot1=Boot2=0KB,RPMB=0KB. 061: D:\_TV\Sony\H26M52103FMR_ISP_5219\H26M52103FMR_ISP_5219 062: Start reading chip...... 063: .EXT_CSDRead successful, file saved. 064: .BOOT1Read successful, file saved. 065: .BOOT2Read successful, file saved. 066: .RPMBRead successful, file saved. 067: .Start to read the user area data and save, large capacity, please be patient ... ... 068: Buffer data checksum: 16bits_0x0000 Ј¬32bits_0x00000000 : 069: The data is read and verified successfully. 070: Elapsed time: 625.4 secondsЈ¬average speed of 3433781 bytes/sec. 071: >------------------------------------OK---------------------------------------< Salutare! Merge scris fara sa scoti integratul de pe placa? Link spre comentariu
nello Postat Noiembrie 3, 2019 Partajează Postat Noiembrie 3, 2019 La 27.01.2019 la 14:36, Marian Roman a spus: Multumesc, dar am rezolvat! Salut. ne spui cum ai rezolvat? Link spre comentariu
Marian Roman Postat Noiembrie 3, 2019 Autor Partajează Postat Noiembrie 3, 2019 1 oră în urmă, nello a spus: Salut. ne spui cum ai rezolvat? in cazul meu nu era vorba de nicio problema de soft (se pare ca nu-si terminase de facut update-ul). l-am lasat cam 45 de minute conectat la internet, dupa care a pornit normal... Link spre comentariu
kyeremeh Postat Martie 24, 2022 Partajează Postat Martie 24, 2022 On 1/25/2019 at 8:13 PM, Geo2017 said: yes I was wrong .. if you have and you know how to write EMMC H26M52103FMR I will send you the files .... i have the programmer so if you can send me the firmware's KD-55X9005C KD-55X8000C IT IS SONY TV'S Link spre comentariu
kyeremeh Postat Martie 24, 2022 Partajează Postat Martie 24, 2022 On 1/25/2019 at 9:11 PM, attilaa0 said: Can someone help to get sony tv firmware kd-55x9005c kd-55x8000c i want the EMMC FIRMWARES Link spre comentariu
