Stefan Postat Ianuarie 20, 2019 Partajează Postat Ianuarie 20, 2019 (editat) Asa cum spune si titlul cumpar sonda de curent pentru osciloscop, moetoda de masura noninvaziva. Principalele caracteristici: - pret mai mic ca al celor din magazin https://www.testequity.com/products/4311/ sau https://www.digikey.ro/product-detail/en/teledyne-lecroy/CP030/CP030-ND/3961349 - banda de la CC la minim 25KHz - domeniul de masura de la cat mai jos posibil (ordinul mA) pana la 10A (maxim 30A) - deschiderea clestelui nu conteaza cat e de mica, firele au sectiune mica. Nu imi trebuie pentru sursele in comutatie, daca la asta va ganditi, dar nu strica daca o sa-l folosesc si la asta candva. Ma gandeam sa surubaresc UT210E-le dar inca nu ma indur sa-l gauresc pentru 400Hz Editat Ianuarie 20, 2019 de Stefan. Link spre comentariu
sesebe Postat Ianuarie 20, 2019 Partajează Postat Ianuarie 20, 2019 https://www.aliexpress.com/item/2017-High-Quality-Original-Hantek-CC-65-AC-DC-Multimeter-Current-Clamp-Meter-with-BNC-Connector/32802165036.html?ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_319_317_10696_453_10084_454_10083_433_10618_431_10304_10307_10820_10301_10821_537_536_5736111_5736011_10059_10884_10887_100031_321_322_10103,searchweb201603_45,ppcSwitch_0&algo_expid=3b08d89d-d2dc-41b3-b292-ad7e70e5ba15-1&algo_pvid=3b08d89d-d2dc-41b3-b292-ad7e70e5ba15&transAbTest=ae803_3 https://www.aliexpress.com/item/CP-01A-150KHz-AC-Current-Probe-Current-For-Oscilloscope-Sensitivity/32859679240.html?ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_319_317_10696_453_10084_454_10083_433_10618_431_10304_10307_10820_10301_10821_537_536_5736111_5736011_10059_10884_10887_100031_321_322_10103,searchweb201603_45,ppcSwitch_0&algo_expid=3b08d89d-d2dc-41b3-b292-ad7e70e5ba15-5&algo_pvid=3b08d89d-d2dc-41b3-b292-ad7e70e5ba15&transAbTest=ae803_3 https://www.aliexpress.com/item/CP-02B-Current-Probe-Can-Connect-To-Oscilloscope-Low-Battery-Indication/32953458835.html?ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_319_317_10696_453_10084_454_10083_433_10618_431_10304_10307_10820_10301_10821_537_536_5736111_5736011_10059_10884_10887_100031_321_322_10103,searchweb201603_45,ppcSwitch_0&algo_expid=86e18f49-8c93-4eec-bf89-e0b2c1b9542a-15&algo_pvid=86e18f49-8c93-4eec-bf89-e0b2c1b9542a&transAbTest=ae803_3 https://www.alibaba.com/product-detail/PT710-C-current-probe-oscilloscope-probe_1518017549.html https://www.alibaba.com/product-detail/Current-Probe-PT710-D-Max-Sensitivity_60299461038.html Link spre comentariu
Stefan Postat Ianuarie 20, 2019 Autor Partajează Postat Ianuarie 20, 2019 (editat) Ma gandeam ca mai vinde cineva ceva prin Romania, pe alea de la ali... le stiu si probabail tot pe chinezi ii fac cu bani. Merci si mai tin anuntul cateva zile. Editat Ianuarie 20, 2019 de Stefan. Link spre comentariu
sesebe Postat Ianuarie 21, 2019 Partajează Postat Ianuarie 21, 2019 (editat) Am niste sonde defecte. Eu nu am reusit sa le repar dar daca vrei sa te bagi iti pot da sa te joci. Electronica este testata (am schimbat toti operationalii) si cred ca elementul HALL e distrus pt ca mi se duc in saturatie operationalii. Partea digitala controlata de osciloscop am dezactivat-o. Au fost fortate la curenti de cel putin 10-50 de ori mai mari decit maximul specificat. Senzorul este turnat in rasina si nu cred ca se poate demonta fara a-l distruge complet electric. Editat Ianuarie 21, 2019 de sesebe 1 Link spre comentariu
q_acdc Postat Ianuarie 21, 2019 Partajează Postat Ianuarie 21, 2019 Acum 12 ore, Stefan. a spus: Ma gandeam ca mai vinde cineva ceva prin Romania, pe alea de la ali... le stiu si probabail tot pe chinezi ii fac cu bani. Merci si mai tin anuntul cateva zile. Pentru Hantek găsești distribuitor în 'București. Link spre comentariu
Stefan Postat Ianuarie 21, 2019 Autor Partajează Postat Ianuarie 21, 2019 Am primit o oferta de sonda si astazi mă decid dacă o iau, nu e chiar așa sensibila cum credeam. @sesebe daca chiar nu ai ce face cu o bucata îmi poți trimite sa ma uit și eu (îmi poți trimite PM cu cheltuielile și metoda de trimitere). Pentru AC nu folosește bobina pe miezul de ferita? Link spre comentariu
sesebe Postat Ianuarie 21, 2019 Partajează Postat Ianuarie 21, 2019 Acum 3 ore, Stefan. a spus: Am primit o oferta de sonda si astazi mă decid dacă o iau, nu e chiar așa sensibila cum credeam. @sesebe daca chiar nu ai ce face cu o bucata îmi poți trimite sa ma uit și eu (îmi poți trimite PM cu cheltuielile și metoda de trimitere). Pentru AC nu folosește bobina pe miezul de ferita? Teoretic da dar eu nu am reusit sa idenific care sint pinii de la bobina. Capul de masura are un conector cu minim10 pini cu pas 1.27mm pe 2 rinduri (nu-mi mai amintesc exact) si defapt sint mai multe bobine, cel putin 2, una pt citire si una de compensare. Prin cea de compensare se introduce o componenta de DC-joasa frecventa inversata pt a anula componenta de DC din curentul masurat pt a minimiza riscul de saturatie a miezului. Intre 4 (sau 6) pini este conectat senzorul Hall dar masurind pe acel conector nu am reusit sa identific care si cum sint alocati pinii. Am sa le caut si daca le gasesc iti dau de veste. Link spre comentariu
Vizitator Postat Ianuarie 21, 2019 Partajează Postat Ianuarie 21, 2019 Sesebe, poate depistezi bobina cu un multitester si combinatii de pini doi cate doi. Ce ramane pot fi senzorii Hall. Link spre comentariu
Stefan Postat Ianuarie 23, 2019 Autor Partajează Postat Ianuarie 23, 2019 Astazi mi-a sosit o sonda de la @maxente dar inca mai caut daca aveti ceva bun si ieftin si cu sensibilitate de macar 1mV/1mA banda >25KHz (daca exista asa ceva ) Link spre comentariu
sesebe Postat Ianuarie 23, 2019 Partajează Postat Ianuarie 23, 2019 Acum 55 minute, Stefan. a spus: Astazi mi-a sosit o sonda de la @maxente dar inca mai caut daca aveti ceva bun si ieftin si cu sensibilitate de macar 1mV/1mA banda >25KHz (daca exista asa ceva ) Nu prea exista cu sensibilitate asa de ridicata. Iti spun asta direct de la sursa pt ca si noi cautam la servici asa ceva si am avut discutii directe cu marii producatori de osciloscoape (ex: Techtronics, LeCroy, Agilent) si nu au. Mai exact exista citeva variante cu sensibilitate de 1mA/div (1mA/2mV) dar sint extrem de scumpe - peste 3000-5000E si sint si dedicate pt anumite osciloscoape (interfata de control). Pt masurarea de curenti asa de mici toti au sugerat masurare pe shunt si amplificare cu amplificator diferential dedicat. Toate sondele cu sensibilitate mai buna de 1mA/div sint astfel realizate. Link spre comentariu
Stefan Postat Ianuarie 23, 2019 Autor Partajează Postat Ianuarie 23, 2019 Nu imi spune de LeCroy ca m-am uitat la cateva sonde si mi-a pierit cheful, e adevarat ca sunt scule profi si nu se adreseaza end user-ului dar sunt mai scumpe ca osciloscopul meu. Cred ca metoda cu shunt e mai buna dar vroiam ceva non invaziv pentru ca e mult mai rapid pe teren, merge pana la urma si deconectarea firului. Link spre comentariu
gauss Postat Ianuarie 23, 2019 Partajează Postat Ianuarie 23, 2019 (editat) https://www.peaktech.de/productdetail/kategorie/TrueRMS_stromzangenmessgeraete_mit_DMM/produkt/peaktech-4350.html Clampmetre pentru curenti reziduali ... Un exemplu la repezeala , sant cativa producatori care au scule de genul . Cu cat mai scumpe ... cu atat mai bune . P.S . personal folosesc Fluke 80i-110S DC/AC Current Probe de la Fluke . Nu sant ieftine ... dar isi fac treaba . http://www.myflukestore.ca/pdfs/cache/www.myflukestore.ca/fluke/current_probe/80i_110s/datasheet/fluke_80i_110s_current_probe_datasheet.pdf Editat Ianuarie 23, 2019 de gauss Link spre comentariu
sesebe Postat Ianuarie 23, 2019 Partajează Postat Ianuarie 23, 2019 (editat) Metoda cu shunt are citeva probleme dintre care cea mai importanta o reprezinta rejectia de mod comun care trebuie sa fie foarte buna pina la frecvente de ordinul zecilor-sutelor de Megahertz-i ceea ce-i foarte foarte dificil. Bun, acum depinde si de aplicatie pt ca daca nu ai tranzitii rapide de tensiune suprapuse pe firul pe care faci masuratoarea nu mai este asa critica ejectia asta la frecvente mari. Ca sa cresti sensibilitatea de masura se poate utiliza "multiplicarea curentului" prin treceea prin sonda a firului de mai multe ori. Ex: daca masori 1mA punind 10 spire pe sonda vei citi 10mA dar adaugi inductanta ceea ce de multe ori nu ai voie. Acum 30 minute, Stefan. a spus: Nu imi spune de LeCroy ca m-am uitat la cateva sonde si mi-a pierit cheful, e adevarat ca sunt scule profi si nu se adreseaza end user-ului dar sunt mai scumpe ca osciloscopul meu. ................. Lasa ca nici cu cei de la Techtronics nu-s mi-e rusine, la multe accesorii pt oscilosscop (sonde de exemplu) au preturi chiar mai mari ca LeCroy . La Agilent/Keysight nu m-am interesat. Oricum sondele lor sint dedicate sa lucreze numai cu osciloscoapele lor. Ps: astea sint bune dar cred ca te rupe la bani: http://www.iti.iwatsu.co.jp/en/products/accessories/current_prb_e.html Editat Ianuarie 23, 2019 de sesebe Link spre comentariu
Stefan Postat Ianuarie 23, 2019 Autor Partajează Postat Ianuarie 23, 2019 @gauss am UT210E si desi marca nu e mare renume masoara decent pentru cat a costat. @sesebe nu imi trebuie ceva chiar asa Wide bandwidth - DC to 100 MHz (SS-250)/DC to 50 MHz (SS-240A) Link spre comentariu
sesebe Postat Ianuarie 23, 2019 Partajează Postat Ianuarie 23, 2019 (editat) @Stefan Cred ca nimeni nu are nevoie de o banda asa de mare DAR banda mare vine la pachet cu slew-rate mare de care ai neaparata nevoie daca vrei sa faci masuratori precise in SMPS-uri. Mai exact rise-time trebuie sa fie cit mai mic cu putinta (max zeci de nanosecunde). Sondele de calitate au rise time sub 4nsec. Editat Ianuarie 23, 2019 de sesebe Link spre comentariu
