SE cu 300B
xdanx
Vizitator viobio
https://www.tube-town.net/ttstore/Transformer/Outputtransformer/Audio-SE/Hammond-1628SEA::3210.html
48H !
https://www.tube-town.net/ttstore/Transformer/Outputtransformer/Audio-SE/Hammond-1630SEA::3212.html
42H!
Acum 3 ore, xdanx a spus:
nu stiu exact, ma intereseaza raport calitate pret si apoi vedem daca avem si bani. Daca aveam banet comandam de mult doua Tamura si terminam povestea dar as vrea ceva mai jos.
http://www.acoustic-dimension.com/tamura/tamura-output-transformers-single-ended.htm
E cam mucuț Tamura ăla .....prietenii știu ....de ce .....:scarpin
Editat de viobio
La 1630SEA ma gandisem si eu. Dar am citit ca 300B ar suna mai bine pe 2500k primar adica Hammond 1627SEA. IN schema lui Toader era un traf cu comutator pt priza la 2500k si 3500k. Asa ar fi ideal dar de unde traf de ala.
Part Number
Audio
Watts
Primary
Ultra-Linear
40% Primary
Tap
Secondary
Impedance
(Ohms)
Hipot
Test
(VRMS)
Weight
(lbs.)
Impedance
(Ohms)
Max. DC
Bias
Inductance
1640SEA
30
1,250
200 ma.
14 Henrys Yes
4-8-16
2,000
11
1627SEA
30
2,500
160 ma.
20 Henrys Yes
4-8-16
2,000
11
1630SEA
30 3,500 135 ma. 42 Henrys Yes 4-8-16 2,000 11
1628SEA
30
5,000
120 ma.
48 Henrys Yes
4-8-16
2,000
11
1642SE
75 5,000 300 ma. 53 Henrys No 4-8-16
3,500
28
1629SEA
30
6,500
100 ma.
55 Henrys Yes
4-8-16
2,000
11
1638SEA
30 10,000 90 ma. 88 Henrys No 4-8-16
2,000
11
Vizitator viobio
Acum 12 minute, xdanx a spus:
Part Number
Audio
Watts
Primary
Ultra-Linear
40% Primary
Tap
Secondary
Impedance
(Ohms)
Hipot
Test
(VRMS)
Weight
(lbs.)
Impedance
(Ohms)
Max. DC
Bias
Inductance
1640SEA
30
1,250
200 ma.
14 Henrys Yes
4-8-16
2,000
11
1627SEA
30
2,500
160 ma.
20 Henrys Yes
4-8-16
2,000
11
1630SEA
1628SEA
30
5,000
120 ma.
48 Henrys Yes
4-8-16
2,000
11
1642SE
3,500
28
1629SEA
30
6,500
100 ma.
55 Henrys Yes
4-8-16
2,000
11
1638SEA
2,000
11
Asta cu " am citit că " vă omoară pe mulți , parcă tu ai avea urechile ălui sau incintele lui , nici dracu nu știe cum se va auzi până nu il faci .
Vezi....de asta devin irascibil sau deveneam ,pentru că voi citiți tot felul de texte , vreți mură in gură , aveți părerea că alții de pe afară le știu pe toate , cel mai bun exemplu este cu Tamura ăla ......care este mult mai prost decat un Edcor sau Hammond ......dar ....nu ..... sună bine și dă bine pe carcasă ..... că este Tamura .
Dacă ești atent si dibaci , te uiți ce scrie in tabel in dreptul lui 1630SEA .....te prinzi tu ....
Editat de viobio
  Mai studiati si acest proiect:
http://diyaudioprojects.com/Tubes/300B-SET-Amplifier/
De la HAMMOND cel mai potrivit este 1630SEA,acum nu stiu daca inductanta de 42H este data la acel curent DC de 135mA sau in gol,oricum daca luam in calcul raportul calitate pret cred ca este cel mai convenabil.
   Mai jos o  schema interesanta care este facuta cu un transformator de iesire asa cum v-ati dorit: 2K5 sau 3K5 dar si un komutator pe bucla de NFB,pare ceva frumsos si serios ,nu?
   Daca pentru tubul de intrare mai gasiti si un EF806 chiar ca o sa aveti un SE cu 300B  adevarat!
Editat de LMOlimpiu
Initial aceasta schema o studiasem si imi placea mai ales din faptul comutatoarelor pe NFB si pe traf primar. Asteptam o confirmare ca schema este ok. DAR:
Cum acel traf este ori greu de gasit ori scump o sa raman pe 3500k Hammond
Apoi nu stiu cum este mai ok sa atac 300B: cu doua lampi cum este mai sus si sa am si comutator pe NFB sau cu o lampa gen 6SN7 unde numai am reactie si e mai simpla si poate mai OK asa.
     Viorel o sa zica sa incerc ambele variante. Eu nu am nici infrastructura nici aparatele necesare sa fac tot felul de teste. Asa ca de asta stresez pe toata lumea pana gasesc un compromis. De asta sunt si forumurile poate...
  TIN cont de toate sugestiile venite de la cei care au experienta si au construit zeci de aplificatoare si le multumesc pe aceasta cale.
2 minutes ago, xdanx said:
**************************************************** Asa ca de asta stresez pe toata lumea pana gasesc un compromis. De asta sunt si forumurile poate...
  Nu este niciun stres !...schema  chinezeasca  cea la  BEZDZ are in atacul lui 300B o pentoda care are o impedanta de iesire mai mica comparativ cu trioda din 6SN7 (6N8S) asadar reprezinta un etaj de atac mai bun,schema japoneza are in atac un SRPP care pe langa faptul ca asigura un semnal simetric pentru G1 la 300B are si o impedanta mica comparativ tot cu o trioda din 6SN7 dar si un THD mult mai mic.Daca veti utiliza NFB sau nu,asta tine numai de "sensibilitatea" urechilor audiofililor,NFB nu are cum sa faca rau si in plus nu cred ca doua componente din bucla NFB ar ridica costul investitiei atat de mult,nu?!?!
    Banuiesc ca schema care are in atac doar doua triode 6SN7 a fost realizata poate de mai multi sau chiar foarte multi constructori amatori si asta datorita simplitatii ei,dar...nici prea simplu nu prea este bine,parerea mea!
Acum 5 minute, LMOlimpiu a spus:
...ce mai corect si colegial sfat, sa tii cont .
Vizitator viobio
Acum 2 ore, xdanx a spus:
Pune 1630SEA  dacă nu cântă ..... accept să mă înjuri in acest topic , m-am jucat eu cu  două trafuri si doua 300B General Electric .
Asta m-am si decis iar domnul Valderama mi-a sugerat o firma unde sunt mai ieftine.
Am niste kt-uri la vanzare, cand le vand mai bun bani si iau un 300B Genalex, apoi cand gasesc 150 euro o sa cumpar traful. Pana atunci adun informatii, fac sursa, wumetrul, desenez carcasa, fire, socluri, ce de sunt... Si o sa fie monobloc :scarpin
