adrian_pic Postat Ianuarie 17, 2019 Partajează Postat Ianuarie 17, 2019 Pentru buzunar GM70 este varianta de compromis intre putere obtinuta si bani investiti. Soclurile sunt mai rare (ma refer la cele rusesti nu chinezarii). Link spre comentariu
xdanx Postat Ianuarie 20, 2019 Autor Partajează Postat Ianuarie 20, 2019 (editat) Am gasit ultimul upgrade a lui J.Leven dar nu da si valorile pieselor, nu stiu de ce. 20Watt Single Ended 300B Amplifier The entire circuit has been optimized for natural sound colors, stable spatial imaging and resolution of the finest sound structures and the new adapted drivers have significantly reduced distortions. The design is by Dipl. Ing. J. Leven from Deutschand. The operating point of the 300B tubes is simple and precise, a mix of autobias and negative grid bias allows a precise, stable operating point of the end tubes. The connection of the LL1623 must be kept as shown in the circuit diagram; when using 4 or 8 Ohm loudspeakers, the LL1623 data sheet of Lundahl Transformers must be observed and the secondary connection should be connected accordingly. The circuitry of the transformer secondary side is shown in simplified form in the circuit diagram. The circuit has been tested on different loudspeakers and provides enough power to operate boxes with average efficiency. Editat Ianuarie 20, 2019 de xdanx Link spre comentariu
victordascalescu54 Postat Februarie 20, 2019 Partajează Postat Februarie 20, 2019 Arunca o privire si aici http://www.jogis-roehrenbude.de/Leserbriefe/Klaus-SE_H/Beschreibung-SE_H.htm Link spre comentariu
Toader Postat Februarie 21, 2019 Partajează Postat Februarie 21, 2019 On 1/17/2019 at 6:55 AM, Untold said: Cu tuburile in paralel, am citit si eu explicatiile de mai sus si cred ca este dificil...Nu v-ar multumi un 7-8W? Pentru apartament oricum e prea mult...eu ascult muzica pe un amplif de 1,5W si nu-l pot da la maxim... Mai cititi pe aici si mai vedeti si niste scheme: http://www.single-ended.com/we300bjames.htm Am avut si eu un SE cu 2A3.1,5 watt.La maxim nu te mai om cu persoana.Cel mai bun sunet avut.Boxe VTP de 90 db cu Ciare Link spre comentariu
xdanx Postat Februarie 22, 2019 Autor Partajează Postat Februarie 22, 2019 chestia e ca nu am ascultat pana acum un amplificator de 7-8w pe boxele mele si mi-e frica sa fie prea mica puterea. Daca e cineva prin Craiova cu un astfel de amplificator rog sa ma anunte. Link spre comentariu
Vizitator Postat Februarie 22, 2019 Partajează Postat Februarie 22, 2019 4 hours ago, xdanx said: chestia e ca nu am ascultat pana acum un amplificator de 7-8w pe boxele mele si mi-e frica sa fie prea mica puterea. Daca e cineva prin Craiova cu un astfel de amplificator rog sa ma anunte. T+A Criterion T120 nu prea merg bine pe SE_uri sub 10W. Au fost facute pentru amplificatoare cu siliciu, unde in anii '90 cca 100W era ceva obisnuit. Transmisionline_ul ala are nevoie de ceva putere sa arate ce poate. Link spre comentariu
Untold Postat Februarie 23, 2019 Partajează Postat Februarie 23, 2019 Acum 22 ore, xdanx a spus: chestia e ca nu am ascultat pana acum un amplificator de 7-8w pe boxele mele si mi-e frica sa fie prea mica puterea. Daca e cineva prin Craiova cu un astfel de amplificator rog sa ma anunte. Din foarte aproape de Craiova e Catalin Dumitrache, alias Dumitrache_S de pe forum, puteti vb cu el. Link spre comentariu
Vizitator viobio Postat Februarie 23, 2019 Partajează Postat Februarie 23, 2019 (editat) La 22.02.2019 la 10:52, xdanx a spus: chestia e ca nu am ascultat pana acum un amplificator de 7-8w pe boxele mele si mi-e frica sa fie prea mica puterea. Daca e cineva prin Craiova cu un astfel de amplificator rog sa ma anunte. Caracal https://www.audioweb.ro/anunturi/amplificatoare/lampi/amplificator-se-paralel-cu-6s4s/ Editat Februarie 23, 2019 de viobio Link spre comentariu
xdanx Postat Februarie 24, 2019 Autor Partajează Postat Februarie 24, 2019 Dar in conzluzie de ce este asa de rau sau riscant folosirea a doua 300B in paralel pe canal??? Link spre comentariu
Vizitator Postat Februarie 24, 2019 Partajează Postat Februarie 24, 2019 Pentru a folosi eficient doua tuburi in paralel ar trebui ca acestea sa aiba parametri identici. O pereche identica +/- 2% o gasesti, daca ai noroc, din cca. 20 tuburi. Pentru ca ai doua canale , logic, iti trebuie doua perechi identice, adica 4 tuburi identice +/- 2%, pe care cu mare noroc este posibil sa le gasesti masurand aproape o suta (100) sau mai multe. Link spre comentariu
victordascalescu54 Postat Februarie 24, 2019 Partajează Postat Februarie 24, 2019 1 oră în urmă, xdanx a spus: Dar in conzluzie de ce este asa de rau sau riscant folosirea a doua 300B in paralel pe canal??? eu cred, "parerea mea", ca 6c33c este o trioda lafel de "audiofila ca si 300b, dar cu un cost de1/10 si putere in SE de cel putin x2 Link spre comentariu
adrian_pic Postat Februarie 24, 2019 Partajează Postat Februarie 24, 2019 6c33c nu-i nici pe departe asa de liniara ca 300B. Ai graficul de mai sus, incearca sa gasesti (dar sigur nu poti) o dreapta de sarcina astfel incat sa poti sa o ataci in grila cu un semnal simetric si in anod sa ai tot semnal simetric. 6c33c necesita atac asimetric pentru a obtine un semnal cat de cat simetric. 300B a fost un tub special creat pentru audio. Este cel mai liniar (se pot folosi trafuri cu Ra diferit de pe la 2K pana peste 4,5K). Ai aici pdf-ul. http://www.tubebooks.org/tubedata/we300a_b.pdf pagina 4 vezi Ra-ul si la pagina 5 vezi graficul. Iti gadila retina graficul ala de la pagina 5. Link spre comentariu
xdanx Postat Februarie 24, 2019 Autor Partajează Postat Februarie 24, 2019 (editat) On 2/22/2019 at 12:12 AM, Toader said: Am avut si eu un SE cu 2A3.1,5 watt.La maxim nu te mai om cu persoana.Cel mai bun sunet avut.Boxe VTP de 90 db cu Ciare O sa cam renunt la ideea de doua 300B si o sa raman la unul in ciuda puterii mai mici. Am vazut o schema sugerata de userul Toader, pare interesanta, dar toate parca sunt la fel. Ca lampa de intrare foloseste EF86 pe care o am deja in PP-ulul meu (o lampa o am deja ) Editat Februarie 24, 2019 de xdanx Link spre comentariu
laur+ Postat Februarie 25, 2019 Partajează Postat Februarie 25, 2019 La 22.02.2019 la 10:52, xdanx a spus: chestia e ca nu am ascultat pana acum un amplificator de 7-8w pe boxele mele si mi-e frica sa fie prea mica puterea. Daca e cineva prin Craiova cu un astfel de amplificator rog sa ma anunte. Te pot ajuta eu cu asta. Rezolvam pe mp. Link spre comentariu
victordascalescu54 Postat Februarie 25, 2019 Partajează Postat Februarie 25, 2019 Probabil ca ar trebui sa nu ma bag....totusi pun o intrebare nevinovata tuturor colegilor care critica vehement tubul 6c33c....Ce experienta directa/practica aveti cu acest tub? si ce nu va place PRACTIC/EXPLICIT? o pura curiozitate care poate fi utila multora, Link spre comentariu
