Diverse electronice, electrice mecanice
gelu_b
  • Răspunsuri 266
  • gelu_b
    233
  • GMCD
    6
  • mihaighe
  • grosu99
Lista valabila astazi, 01.09.2019.
5. Transformator dintr-un aparat sovietic cu multiple tensiuni in secundar (sectiune: 9 cm2; miez in forma de U; foarte bine izolat) ... 30 lei
http://i63.tinypic.com/v7tcwg.jpg
http://i65.tinypic.com/288cvm0.jpg
http://i64.tinypic.com/1pxdua.jpg
9. Teaser electrosocuri autoaparare (nu-l mai tine acumulatorul intern, se incarca direct la 220Vca - nu mai am cablul sau de alimentare; se livreaza impreuna cu un cartus nefolosit) ... 20 lei
http://i68.tinypic.com/dzieyu.jpg
16. Set de doua dulii wireless (nefolosite, fara telecomanda) ... 10 lei
http://i67.tinypic.com/2yvmebk.jpg
17. Balast electronic 2 x 18W, absolut nou (in cutia sa, nefolosit), 1 buc., 10 lei
http://i57.tinypic.com/2wnwkxv.jpg
21. Triunghi reflectorizant Bosch, mare ... 25 lei
http://i68.tinypic.com/120kmqt.jpg
23. Suport auto pt. telefon mobil (prindere in grila de aerisire), nou ... 10 lei
http://i66.tinypic.com/v8h741.jpg
24. Trepied foto ... 50 lei
http://i66.tinypic.com/20as7q0.jpg
32. Set role mici pt. mobila ... 10 lei
http://i65.tinypic.com/6hj1j4.jpg
33. Set role mari pt. mobila ... 10 lei
http://i65.tinypic.com/2vim6pf.jpg
37. Termostat/Controller de temperatura (gama de lucru: -55C ... +120C; nou in tzipla; 5 buc. disponibile) ... 25 lei
http://i68.tinypic.com/wr1fn4.jpg
40. Baza /emitator radio wireless pt. casti Panasonic ... 20 lei
http://i68.tinypic.com/dny7p0.jpg
46. Condensatori 1 uF/275Vac (Philips, noi) ... 1 leu/buc (am mai multe buc.)
http://i64.tinypic.com/33bd3bd.jpg
49. CI DS8880N HV decoder BCD to 7 segments (pt. tuburi cu descarcare in gaze), 3 buc ... 15 lei toate
http://i68.tinypic.com/m3i0y.jpg
50. CI amplificatoare operationale de zgomot mic: 2 buc. OP292GP + 2 buc. OP297GP + 1 buc. OP497GP (componente vintage originale Analog Devices) ... 30 lei toate
http://i63.tinypic.com/rr4mjk.jpg
51. Bobine soc mari (disponibile 5 buc.) ... 1 leu / buc.
http://i65.tinypic.com/5197js.jpg
52. Bobine soc mici ... 5 lei / 10 buc. (mai sunt doua pachete de 10 buc.)
http://i63.tinypic.com/2dl8hz.jpg
58. CD de colectie cu jocuri erotice pt. calculatoare Spectrum/HC (netestat) ... 10 lei
http://i68.tinypic.com/hx4wec.jpg
http://i64.tinypic.com/2i918j6.jpg
64. Condensatori electrolitici 3300 uF/16V ... 1 leu/buc.
http://i64.tinypic.com/y2ag7.jpg
67. Carcasa metalica 20 x 5.5 x 9 cm - exclusiv baza (este din fier, cu panoul frontal prevazut cu fereastra din plexiglas, cu baza extinsa care are 4 picioruse de cauciuc, ideala pt. aparate realizate in regim de hobby) ... 20 lei
http://i67.tinypic.com/2roqlnq.jpg
http://i64.tinypic.com/2h4j43m.jpg
68. Lot 11 potentiometre multitura (recuperate, curatate) ... 5 lei toate
http://i68.tinypic.com/t0mgwo.jpg
69. Lot intrerupatoare de panou automatizari cu iluminare ... 20 lei toate
http://i64.tinypic.com/rvvy4o.jpg
70. Lot de 30 buc. socluri sigurante mari (6 x 30 mm) ... 15 lei
http://i68.tinypic.com/x37ozt.jpg
71. Lot de 30 buc. socluri sigurante mici (5 x 20 mm) - inca un lot disponibil ... 15 lei/lot
http://i67.tinypic.com/rm0k02.jpg
72. Inele abrazive de slefuire Proxxon - 1 pachet  ... 5 lei
http://i65.tinypic.com/15ko5g.jpg
77. Set de 6 freze pentru prelucrat materiale nemetalice sau materiale metalice neferoase (cu ax de 3 mm) ... 20 lei/setul (mai am un set)
http://i68.tinypic.com/f9p9b7.jpg
82. Tiristor IPRS model T3N6P (600V/3A, capsula TO-220) ... 1 leu / buc.
http://i68.tinypic.com/2a69lrb.jpg
83. Tranzistori IPRS SDT9307 (npn, 87w/7.5A, similar cu 2N3055) ... 2 lei / buc.
http://i64.tinypic.com/287gc5w.jpg
84. Tranzistori IPRS SDT9309 (npn, 87w/2A, similar cu 2N3055) ... 2 lei / buc.
http://i63.tinypic.com/2cz7vwo.jpg
90. Cca. 500 buc. condensatori rusesti 47nF (am mai multe pungi)   ...  10 lei
http://i67.tinypic.com/x3ilw9.jpg
92. Condensatori IPRS 10000uF/63V ... 4 buc / 20 lei toti
http://i68.tinypic.com/jv58rb.jpg
96. Cca. 500 condensatoare diverse IPRS, IPEE (NOS) ... 10 lei
http://i66.tinypic.com/ofr3fq.jpg
101. Pachet cca.1000 buc. rezistente diverse valori (RPM, MLT, chimice) / sunt disponibile mai multe pungi ... 10 lei
http://i68.tinypic.com/iyiryf.jpg
102. Tranzistori IPRS BD183 (npn, 150W, 15A, TO-3)  ... 3 lei / buc.
http://i68.tinypic.com/2rw14l2.jpg
103. Tranzistori IPRS SDT9308 (npn, 87W, 60V, 2A, TO-3 / similar cu 2N3055) ... 2 lei / buc.
http://i67.tinypic.com/10nvlvs.jpg
104. CI Microelectronica MMC3166-8 (circuit integrat specializat pt. sonerie muzicala / canta "Happy Birthday To You")  ... 6 lei
http://i66.tinypic.com/2w5pzkp.jpg
106. Tranzistori BU931Z (de comutatie, 125W, 350V, 20A) ... 9 buc / 25 lei toti
http://i68.tinypic.com/o7rjwj.jpg
108. Balast electronic 40w ... 10 lei
http://i66.tinypic.com/rc94if.jpg
110. Potentiometri multitura 470 ohm / 1k / 10k (Polonia)  ... 0,5 lei/buc.
http://i67.tinypic.com/2z51vm9.jpg
http://i64.tinypic.com/517ayv.jpg
114. Tranzistori IPRS de putere / comutatie din seria BU  ... 2 lei / buc.
http://i64.tinypic.com/v58sr8.jpg
117. CI BE555 - IPRS  ... 1 leu / buc.
http://i65.tinypic.com/ap6zd.jpg
118. CI ROB74 - ICSITE (Amplificator operational de zgomot redus) ... 1 leu / buc.
http://i65.tinypic.com/ru4mmt.jpg
119. CI LM339 - IPRS (Comparator quadruplu)  ... 1 leu / buc.
http://i66.tinypic.com/x3z1h.jpg
120. Condensatori electrolitici 10uF/63V - ARCOTRONICS  ... lot de 100 buc. - 10 lei (mai am un lot)
http://i66.tinypic.com/15wzdkz.jpg
124. Condensatori cu tantal CFT - Iasi  10uF/35V; 33uF/35V  ... 10 lei pachetul de 25 buc.
http://i63.tinypic.com/i2ksbm.jpg
http://i63.tinypic.com/33z4e92.jpg
129. Tranzistori rusesti KT818G (medie putere/pnp/60W/90V/10A - TO-220)  ... 1 leu / buc.
http://i65.tinypic.com/fa1tso.jpg
130. Tranzistori IPRS 2N5492 medie putere (npn/50W/65V/7A - TO-220)  ...  1 leu / buc.
http://i65.tinypic.com/2rf4lyu.jpg
131. Tranzistori IPRS BU406 medie putere (npn/60W/400V/10A - TO-220) ... 2 lei / buc.
http://i67.tinypic.com/r0plhh.jpg
132. Tranzistori IPRS BD651 medie putere (npn/60W/120V/8A - TO-220)  ... 1 leu / buc.
http://i66.tinypic.com/16bzjva.jpg
133. Tranzistori IPRS BD135 medie putere (npn/15W/45V/1,5A - TO-126)  ... 10 lei / 20 buc. (mai sunt doua pungi)
http://i68.tinypic.com/35901n9.jpg
134. Tranzistori IPRS BD136 medie putere (pnp/12,5W/80V/1,5A - TO-126)  ... 10 lei / 20 buc.
http://i65.tinypic.com/2drgmiv.jpg
135. Tranzistori IPRS BF469 medie putere (npn/10W/250V/0,1A - TO-126)  ... 10 lei / 10 buc. (ultima punga)
http://i67.tinypic.com/2v1m255.jpg
136. Tranzistori IPRS 2N2906/2N2907 de comutatie (pnp/0,4W/60V/0,6A - TO-18) ... 10 lei / 25 buc.
http://i66.tinypic.com/3096mfr.jpg
138. Tranzistori IPRS DVN307 mica putere (pnp/0,3W/45V/0,1A)  ... 10 lei / 30 buc.
http://i68.tinypic.com/259ed7t.jpg
145. Diode Zener seria DZ (IPRS) diverse valori - 5 lei / pachetul de 20 buc.
http://i66.tinypic.com/33l16bb.jpg
146. Punti redresoare seria 1PM (IPRS) ... 5 lei / pachet de 10 buc.
http://i68.tinypic.com/110979i.jpg
147. Punti redresoare seria 3PM (IPRS) ... 1 leu / buc.
http://i68.tinypic.com/4lptnt.jpg
149. Rezistente de putere URSS (diverse valori)  ... 1 leu / buc.
http://i68.tinypic.com/2nv6ko6.jpg
151.  Diode redresoare de putere 10/16A  (IPRS)  ... 5 lei / 10 buc.
http://i65.tinypic.com/ubg9w.jpg
152. Diode diverse (stabilizatoare - PL, redresoare) IPRS ... 5 lei / 20 buc.
http://i68.tinypic.com/m7x1u1.jpg
154.  Rezistente de mare putere    ...  5 lei / buc.
Mai am urmatoarele cantitati: 4,7 kohm - 2 buc;  100 ohm - 25 buc.;   12 kohm - mai multe
http://i66.tinypic.com/9st28p.jpg
157. Inductante SMD de 15uH  …  5 lei lotul de 10 buc.
http://i64.tinypic.com/29x748.jpg
159. Condensatori MKT 0,1uF/250Vac ARCOTRONICS (13 x 10 x 4 mm, 10 mm intre terminale) ... lot de 100 buc / 10 lei
http://i67.tinypic.com/290ycub.jpg
160. Sigurante fuzibile de mare putere ETI CH14X51 40A/500Vac ... 8 buc. / 25 lei
http://i66.tinypic.com/2qbg8ax.jpg
163. Stabilizatoare de tensiune BA7805 -  IPRS  ... 2 lei / buc
http://i63.tinypic.com/o6zk3b.jpg
164. Tranzistori vintage WN401 - Motorola (low noise J-FET) ... 1 leu / buc.
http://i66.tinypic.com/2s1adr7.jpg
166. Varistori JVR 7N391K si JVR 14N471K (cca. 50 buc.) ... 10 lei
http://i67.tinypic.com/3090e2r.jpg
167. Diode stabilizatoare de tensiune (Zenner) de putere - 10A (IPRS) (10DZ15; 10DZ27; 10DZ56; 10DZ68)  ... 10 lei (pachet de 20 buc.)
http://i63.tinypic.com/ru5kb6.jpg
http://i64.tinypic.com/23v0wsw.jpg
170. Tranzistori IPRS inalta frecventa BF200 (npn/30V/0,02A/650MHz)  ... 1 leu / buc. (pachet de 10 buc.)
http://i67.tinypic.com/jzz68n.jpg
172. Tranzistori de semnal mic BC327 (pnp/45V/0,8A/0,6w)  ... 10 lei (pachet de 20 buc.)
http://i63.tinypic.com/dg6rfm.jpg
173. Tranzistori de semnal mic BC250/251/252 (pnp/45V/0,1A/0,35w)  ... 10 lei (pachet de 20 buc.)
http://i64.tinypic.com/1zdbx0.jpg
174. Tranzistori IPRS de putere 2N5496 (npn/70V/7A/50w)  ... 1 leu / buc.  (pachet de 10 buc.)
http://i65.tinypic.com/2napvcx.jpg
175. Tranzistori IPRS de comutatie 2N2219 (npn/50V/0,8A/0,8w)  ... 10 lei (pachet de 20 buc.)
http://i66.tinypic.com/2hqbfrd.jpg
176. Tranzistori IPRS de comutatie /zgomot redus BCY79 (pnp/45V/0,1A/0,34w)  ... 10 lei (pachet de 25 buc.)
http://i66.tinypic.com/2cdcv2o.jpg
177. Tranzistori IPRS AF de zgomot mic BC416 (pnp/45V/0,1A/0,5w)  ... 10 lei (pachet de 15 buc.)
http://i63.tinypic.com/29yju51.jpg
178. Tranzistori IPRS de putere Darlington BD681A (npn/100V/4A/10w) ... 10 lei (pachet de 10 buc.)
http://i68.tinypic.com/2lntk7s.jpg
179. Tranzistori IPRS inalta frecventa BF115 (npn/30V/0,03A/0,145w) ... 10 lei (pachet de 10 buc.)
http://i66.tinypic.com/2nswaqb.jpg
180. Tranzistori IPRS medie putere BSV16 (pnp/60V/1A/5w) ... 10 lei (pachet de 15 buc.)
http://i63.tinypic.com/vfy4cn.jpg
181. Tranzistori IPRS inalta tensiune BF259 (npn/270V/0,1A/5w)  ... 10 lei (pachet de 10 buc.)
http://i63.tinypic.com/2ag99hu.jpg
182. Tranzistori IPRS comutatie BSW22 (pnp/25V/0,2A/0,3w) ... 10 lei (pachet de 15 buc.)
http://i64.tinypic.com/2di3ktv.jpg
183. Rezistente de putere
1-3W: 0,25 lei / buc;   5-7W: 0,5 lei/buc;  8 -16W: 1 leu/buc (in fotografiile atasate sunt date valorile disponibile)
http://i68.tinypic.com/2dubj8m.jpg
http://i63.tinypic.com/sfvza1.jpg
http://i65.tinypic.com/m9rrxj.jpg
http://i66.tinypic.com/5uguut.jpg
184. Pereche triac + diac pt. control tensiune de retea TB6N3+DC44 (300V, 6A) IPRS  ... 3 lei / perechea
http://i66.tinypic.com/10qkl0k.jpg
185. Tiristor Tesla KT711 (300V, 15A) ... 3 lei / buc. (12 buc. disponibile)
http://i66.tinypic.com/3480exj.jpg
186. Tiristor rapid IPRS T16R3 (300V, 25A) ... 3 lei / buc. (8 buc. disponibile)
http://i65.tinypic.com/sbuf14.jpg
187. Tranzistori IPRS BC516 - Darlington, amplificare mare (pnp/30V/1A/0,6w) ... 1 leu / buc.
http://i63.tinypic.com/1rdyr8.jpg
188. Tranzistori IPRS BC517 - Darlington, amplificare mare (npn/30V/1,2A/0,6w) ... 1 leu / buc.
http://i63.tinypic.com/291dphx.jpg
189. Tranzistori IPRS BC556 - zgomot redus, AF (pnp/65V/0,1A/0,5w) ... 1 leu / buc.
http://i66.tinypic.com/2luzy2r.jpg
Comanda minima este de 50 de lei.
Lista valabila astazi, 02.09.2019.
Editat de gelu_b
