Ceas cu display LED 8x8 dot matrix si modul DS3231
Kreator
în acest caz, scuze ! Eu m-am uitat în postul tău unde ai compilat cu succes pe 1825 - de acolo de altfel am luat și mărimea programului .
@fratello
incearca codul de mai jos. Mie mi-a compilat
program Ceas_MAX7219_PIC1827
' Declarations section
Const cnfgww As Byte = %11010000         'Adress  for write DS3231
Const cnfgwr As Byte = %11010001         'Adress  for read  DS3231
const MAX7219_TEST as byte =0x0F
const MAX7219_BRIGHTNESS as byte  = 0x0A
const MAX7219_SCAN_LIMIT as byte  = 0x0B
const MAX7219_DECODE_MODE as byte = 0x09
const MAX7219_SHUTDOWN as byte    = 0x0C
const mxbt As Byte[11]    =(0, 23, 59, 31, 12, 99, 59, 23, 59, 15, 1)           ' max value
const mnbt As Byte[11]    =(0,  0,  0,  1,  1,  0,  0,  0,  0,  0, 0)           ' min value
const stadrs As Byte[11]  =(0,  0x02, 0x01,  0x04,  0x05, 0x06,
                                0x00, 0x09,  0x08,  0x0B, 0x0D)                 ' Adress data RTC
const alfabet as byte [16] [8]= (( 30,  63,  51,  51,  51,  51,  63,  30),      '0
                                 (  6,  14,  30,   6,   6,   6,   6,  15),      '1
                                 ( 30,  63,  35,   6,  12,  24,  63,  63),      '2
                                 ( 30,  63,  35,  14,  14,  35,  63,  30),      '3
                                 (  6,  14,  30,  54,  54,  63,   6,  15),      '4
                                 ( 62,  63,  48,  62,  51,   3,  63,  30),      '5
                                 ( 30,  63,  48,  62,  51,  51,  63,  30),      '6
                                 ( 63,  63,   3,   6,  12,  12,  12,  12),      '7
                                 ( 30,  63,  51,  30,  51,  51,  63,  30),      '8
                                 ( 30,  63,  51,  51,  31,   3,  63,  30),      '9
                                 (  0,   0,   0,   0,   0,   0,   0,   0),      'blank
                                 (  0,   3,   3,   0,   0,   3,   3,   0),      'dp
                                 (120, 124,  68,  64,  64,  68, 124, 120),      'C
                                 ( 56, 109, 109, 109,  57,   1,   1,   0),      '`
                                 ( 62,  63,  51,  62,  51,  51,  63,  62),      'B
                                 (  0,   0,  27,  31,  28,  24,  24,  24))      'r
Dim CS as sbit at RB3_bit                                   'Chip Select pin for MAX7219
CS_Direction as sbit at TRISB3_bit
Dim Soft_I2C_Sda as sbit at RB6_bit                         'SDA pin for DS3231
Dim Soft_I2C_Scl as sbit at RB7_bit                         'SCL pin for DS3231
Dim Soft_I2C_Sda_Direction as sbit at TRISB6_bit
Dim Soft_I2C_Scl_Direction as sbit at TRISB7_bit
Dim i,j, x, y, yy, bright, m, s_, z_, u, dp, str as byte
Dim k, k0, k1, k4, k5, al as byte
Dim flgal, flsh, x0, x1, x5, flgint, pflgint as bit
Dim ma, sa, za, uua, utmp, ztmp, stmp, ltmp, rtmp, mtmp as byte[8]
Dim dsp, th_dsp, h_dsp as byte[32]
Dim s0, s1, m0, m1, h0, h1, ah0, ah1, am0, am1 As Byte
Dim d0, d1, mo0, mo1, y0, y1, th0, th1, br1, br0 As Byte
Dim btset, btmod, btvar, btmp, grc As Byte
sub function I2CR(dim byref adress as byte)  as byte     ' Read value from RTC
    Soft_I2C_Start()                                     ' Issue start signal
    Soft_I2C_Write(cnfgww)                               ' Address DS3221 datasheet
    Soft_I2C_Write(adress)                               ' Go to adresa
    Soft_I2C_Start()                                     ' Issue repeated start signal
    Soft_I2C_Write(cnfgwr)                               ' Address for reading R/W=1
    result = Soft_I2C_Read(0)                            ' Read with NAK
    Soft_I2C_Stop()                                      ' Stop
end sub
sub procedure I2CW(dim adress, value as byte)            ' Write value in TRC
    Soft_I2C_Write(value)                                ' Write valoare
end sub
sub procedure read_RTC()       ' Read some data from RTC
    btmp=0x00
    btmp=I2CR(btmp)            'sec
    s0 = btmp Mod 16
    s1 = btmp / 16
    btmp=0x01
    btmp=I2CR(btmp)            'min
    m0 = btmp Mod 16
    m1 = btmp / 16
    btmp=0x02
    btmp=I2CR(btmp)            'hour
    h0 = btmp Mod 16
    h1 = btmp / 16
    btmp=0x04
    btmp=I2CR(btmp)            'day
    d0 = btmp Mod 16
    d1 = btmp / 16
    btmp=0x05
    btmp=I2CR(btmp)            'mounth
    mo0 = btmp Mod 16
    mo1 = btmp / 16
    btmp=0x06
    btmp=I2CR(btmp)            'year
    y0 = btmp Mod 16
    y1 = btmp / 16
    btmp=0x08
    btmp=I2CR(btmp)            'almin
    am0 = btmp Mod 16
    am1 = btmp / 16
    btmp=0x09
    btmp=I2CR(btmp)            'alhour
    ah0 = btmp Mod 16
    ah1 = btmp / 16
    btmp=0x11
    btmp=I2CR(btmp)            'temp
    th0 = btmp Mod 10
    th1 = btmp / 10
    btmp=0x0B
    bright=I2CR(btmp)          ' brightness
    br0 = bright Mod 16
    br1 = bright / 16
    btmp=0x0C
    al=I2CR(btmp)              ' set alarm On/Off
    btmp=0x0F
    btmp=I2CR(btmp)            ' flag alarm
    flgal=btmp.0
    btmp=0x0D
    btmp=I2CR(btmp)            ' Temperature On/Off
    grc=btmp
end sub
sub procedure maxCMD (dim address, value as byte) ' Send command to MAX7219
    CS = 0
    for i = 0 to 3
        SPI_Write(address)        '// Send address.
        SPI_Write(value)          '// Send the value.
    next i
    CS = 1
end sub
sub procedure max7219_init()           ' Initialize MAX7219
    maxCMD(MAX7219_TEST, 0x01)         ' Test mode
    maxCMD(MAX7219_TEST, 0x00)         ' Finish test mode
    maxCMD(MAX7219_DECODE_MODE, 0x00)  ' Disable BCD mode
    maxCMD(MAX7219_BRIGHTNESS, bright) ' Use lowest intensity
    maxCMD(MAX7219_SCAN_LIMIT, 0x0f)   ' Scan all digits
    maxCMD(MAX7219_SHUTDOWN, 0x01)     ' Turn on chip
end sub
'Prepare hour data
 sub procedure prepare_to_show_hour(dim m, s_, z_, u, dp1, al1 as byte)
     for  i = 0 to 7
          ma[i]  = alfabet[m] [i]
          sa[i]  = alfabet[s_] [i]
          za[i]  = alfabet[z_] [i]
          uua[i] = alfabet[u] [i]
     next i
     for i = 0 to 7
         utmp[i]=uua[i]
     next i
     for i = 0 to 7
         utmp[i].7 =za[i].0
     next i
     for i = 0 to 7
         ztmp[i]=za[i]>>1
     next i
     for i = 0 to 7
         ztmp[i].6 = alfabet[10 + dp1] [i]. 0
         ztmp[i].7 = alfabet[10 + dp1] [i]. 1
     next i
    for i = 0 to 7
         stmp[i]=sa[i]<<1
     next i
     for i = 0 to 7
         mtmp[i]=ma[i]
     next i
     mtmp[0].7=al1
     for i = 0 to 7
         h_dsp[i]    = utmp[i]
         h_dsp[i+8]  = ztmp[i]
         h_dsp[i+16] = stmp[i]
         h_dsp[i+24] = mtmp[i]
     next i
end sub
'Prepare Temperature data
sub procedure prepare_to_show_temp(dim z_, u as byte)
     for  i = 0 to 7
     next i
     for i = 0 to 7
         mtmp[i] = za[i] >>1
     next i
     for i = 0 to 7
         stmp[i]=uua[i]
     next i
     for i = 0 to 7
         stmp[i].7 =za[i].5
     next i
     for i = 0 to 7
         ztmp[i] = alfabet[13] [i]
     next i
     for i = 0 to 7
         utmp[i] = alfabet[12] [i] <<1
     next i
     for i = 0 to 7
         th_dsp[i]    = utmp[i]
         th_dsp[i+8]  = ztmp[i]
         th_dsp[i+16] = stmp[i]
         th_dsp[i+24] = mtmp[i]
     next i
end sub
sub procedure temp2hour         'Scroll from temperature to hour
     for i = 0 to 7
         th_dsp[i+24] = th_dsp[i+24] << 1
         th_dsp[i+24].0 = th_dsp[i+16].7
         th_dsp[i+16] = th_dsp[i+16] << 1
         th_dsp[i+16].0 = th_dsp[i+8].7
         th_dsp[i+8] = th_dsp[i+8] << 1
         th_dsp[i+8].0 = th_dsp[i].7
         th_dsp[i] = th_dsp[i] << 1
         th_dsp[i].0 = h_dsp[24+i].7
         h_dsp[i+24] = h_dsp[i+24] << 1
         h_dsp[i+24].0 = h_dsp[i+16].7
         h_dsp[i+16] = h_dsp[i+16] << 1
         h_dsp[i+16].0 = h_dsp[i+8].7
         h_dsp[i+8] = h_dsp[i+8] << 1
         h_dsp[i+8].0 = h_dsp[i].7
         h_dsp[i] = h_dsp[i] << 1
     next i
     for i = 0 to 31
         dsp[i] = th_dsp[i]
     next i
end sub
sub procedure hour2temp                  'Scrool from hour to temperature
     for i = 0 to 7
         h_dsp[i].0 = th_dsp[24+i].7
     next i
     for i = 0 to 31
         dsp[i] = h_dsp[i]
     next i
end sub
sub procedure up_down()                  'Procedure for Button Up or Button Down
    if x0 = 1 then
       if btset = 6 then
          I2CW(btmod, 0)
       else
          btvar = I2CR(btmod)
          btvar = bcd2dec(btvar)
          if btvar = mnbt[btset] Then
             btvar = mxbt[btset]
          else
             btvar = btvar - 1
          end if
          I2CW(btmod, dec2bcd(btvar))
       end if
       x0 = 0
    end if
    if x1 = 1 then
       if btset = 6 then
          I2CW(btmod, 0)
       else
          btvar = I2CR(btmod)
          if btvar = mxbt[btset] Then
             btvar = mnbt[btset]
          else
             btvar = btvar + 1
          end if
       end if
       x1 = 0
    end if
end sub
sub procedure prepare_2_show_data        ' Prepare data for send to MAX7219
     for i = 0 to 31
         dsp[i] = h_dsp[i]
     next i
end sub
sub procedure send_2_display()           ' Send data to MAX7219
    for i = 0 to 7
        CS = 0                           ' Begin transfer.
        SPI_Write(i+1)                   ' Send address.
        SPI_Write(dsp[i+24])             ' Send the value.
        SPI_Write(dsp[i+16])             ' Send the value.
        SPI_Write(dsp[i+8])              ' Send the value.
        SPI_Write(dsp[i])                ' Send the value.
        CS = 1                           ' Finish transfer.
   next i
end sub
sub procedure show_data()                ' Show received data
    prepare_2_show_data
    send_2_display()
end sub
sub procedure alarm                      ' Buzz if PORTC1 = 1
    PORTB.1 =flgal and al.0 and PORTA.2
end sub
sub procedure init_main()
    OSCCON =  %11111111    '  MCU clock at 16 MHz
    ANSELA  = %00000000    '  All I/O pins of the PORTA are configured as digital
    ANSELB  = %00000000    '  All I/O pins of the PORTC are configured as digital
    CM1CON0 = %00000000    '  Disbale comparator
    CM2CON0 = %00000000    '  Disbale comparator
    TRISA   = %11111111    '  PORTA All Inputs
    TRISB   = %00000000    '  PORTC All Outputs
    APFCON0.SDO1SEL = 0
    APFCON0.SS1SEL  = 0
    INTCON.GIE   = 1       '  Enables all unmasked interrupts
    INTCON.PEIE  = 0       '  Disables all peripheral interrupts
    INTCON.T0IE  = 1       '  Enables the TMR0 interrupt
    INTCON.INTE  = 1       '  Enables the RA2/INT external interrupt
    INTCON.IOCIE = 0       '  Disables the PORTA change interrupt
    INTCON.T0IF  = 0       '  TMR0 register did not overflow
    INTCON.INTF  = 0       '  The RA2/INT external interrupt did not occur
    INTCON.IOCIF = 0       '  None of the PORTA <5:0> pins have changed state
    OPTION_REG.WUE    = 0  '  PORTA pull-ups are enabled by individual port latch values
    OPTION_REG.INTEDG = 0  '  Interrupt on rising/falling edge of RA2/INT pin
    OPTION_REG.T0CS   = 0  '  set Timer0 clock source to internal
    OPTION_REG.T0SE   = 1  '  Increment on high-to-low transition on RA2/T0CKI pin
    OPTION_REG.PSA    = 0  '  asign prescaler to Timer 0
    OPTION_REG.PS2    = 1  '  asign prescaler value
    OPTION_REG.PS1    = 1  '  asign prescaler value
    OPTION_REG.PS0    = 1  '  asign prescaler value
    WPUA = %00111111       '  Pull-ups PORTA to be enabled
    SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV4, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH)
    Soft_I2C_Init()         ' Initialize I2C module
    SPI1_Init()             ' Initialize SPI module
    btmp=0xB                ' Set brtightness adress
    bright=I2CR(btmp)       ' Read brtightness value
    grc=0                    ' Read Temp_On/Off value
    btmp=0xC                ' Set alarm on/off adress
    al=I2CR(btmp)           ' Read alarm on/off value
    max7219_init()          ' Initialize MAX7219 module
    PORTB.1 = 0             ' Do not start alarm on start_up
    I2CW(0xA,%10000000)     ' Alarm when hours, minutes, and seconds match
    I2CW(0x0E,0)            ' Square wave is output on the INT/SQW pin
    TRISB.1 = 0             ' Because SPI1_Init make PORTC1 as input
    str = 0
    j = 0
    y = 0
    k = 0
    x = 0
    x0 = 0
    x1 = 0
    x5 = 0
    flgint = 0
    pflgint = 0
    flgal = 0
    dp = 0
    btset = 0
    CS=1
end sub
sub procedure Interrupt()  iv 0x0004 ics ICS_AUTO
    if INTCON.INTF = 1 then
        flgint = not flgint
        OPTION_REG.INTEDG = not OPTION_REG.INTEDG
        dp.0 = not dp.0
        k = k + 1
        if k = 23 then k = 0 end if
        INTCON.INTF = 0
    End if
    if INTCON.T0IF = 1 then
       TMR0 = 61
       if flgal and al.0 and porta.2 then
       end if
       y = y + 1
       if y = 20  then flsh = not flsh  y = 0 end if
      ' buton mod
      if Button(PORTA, 4, 1, 1) then
         k4 = 255
      end if
      if k4 and Button(PORTA, 4, 1, 0) then
         btset = btset + 1
         if btset= 11 then  btset= 0 end if
         btmod = stadrs[btset]
         k4 = 0
      end if
      ' Button Up
      if btset <> 0 then
         if Button(PORTA, 0, 1, 1) then
            k0 = 255
         end if
         if k0 and Button(PORTA, 0, 1, 0) then
            k0 = 0
            x0 = 1
         end if
      end if
      ' Button Down
      if btset <> 0 then
         if Button(PORTA, 1, 1, 1) then
            k1 = 255
         end if
         if k1 and Button(PORTA, 1, 1, 0) then
            k1 = 0
            x1 = 1
         end if
      end if
     ' Button Al On/Off
      if Button(PORTA, 5, 1, 1) then
         k5 = 255
      end if
      if k5 and Button(PORTA, 5, 1, 0) then
         x5 = 1
         k5 = 0
      end if
      INTCON.T0IF = 0
    End if
end sub
main:
'   Main program
    delay_ms(100)
    init_main()
    while TRUE
        select case btset
               case 0   ' show alt hour & temperature
                    if flgint <> pflgint then
                       pflgint = flgint
                       read_RTC()
                       prepare_to_show_hour(h1, h0, m1, m0, dp, al )
                       prepare_to_show_temp(th1, th0)
                       if grc = 1 then
                          if k<=16 then
                             if k=16 then
                                dp = 1
                                for yy = 0 to 31
                                    hour2temp
                                    send_2_display()
                                    delay_ms(30)
                                    alarm()
                                next yy
                             else
                                prepare_2_show_data
                                send_2_display()
                                alarm()
                             end if
                          else
                             if k=22 then
                                dp = 1
                                for yy = 0 to 31
                                    temp2hour
                                    send_2_display()
                                    delay_ms(30)
                                    alarm()
                                next yy
                             else
                                for i = 0 to 31
                                    dsp[i] = th_dsp[i]
                                next i
                                send_2_display()
                                alarm()
                             end if
                          end if
                       else
                          show_data
                          alarm()
                       end if
                    end if
               case 1
                    read_RTC()
                    if flsh = 0 then
                       h1 = 10
                       h0 = 10
                    end if
                    prepare_to_show_hour(h1, h0, m1, m0,  1, 0 )
                    show_data()
                    up_down()
               case 2
                    read_RTC()
                    if flsh = 0 then
                       m1 = 10
                       m0 = 10
                    end if
                    show_data()
                    up_down()
               case 3
                    read_RTC()
                    if flsh = 0 then
                       d1 = 10
                       d0 = 10
                    end if
                    prepare_to_show_hour(d1, d0, mo1, mo0,  0, 0 )
                    show_data()
                    up_down()
                case 4
                    read_RTC()
                    if flsh = 0 then
                       mo1 = 10
                       mo0 = 10
                    end if
                    show_data()
                    up_down()
               case 5
                    read_RTC()
                    if flsh = 0 then
                       y1 = 10
                       y0 = 10
                    end if
                    prepare_to_show_hour(2, 0, y1, y0,  0, 0 )
                    show_data()
                    up_down()
               case 6
                    read_RTC()
                    if flsh = 0 then
                       s1 = 10
                       s0 = 10
                    end if
                    prepare_to_show_hour(10, 10, s1, s0,  1, 0 )
                    show_data()
                    up_down()
               case 7
                    read_RTC()
                    if flsh = 0 then
                       ah1 = 10
                       ah0 = 10
                    end if
                    prepare_to_show_hour(ah1, ah0, am1, am0,  1, 1 )
                    show_data()
                    up_down()
              case 8
                    read_RTC()
                    if flsh = 0 then
                       am1 = 10
                       am0 = 10
                    end if
                    show_data()
                    up_down()
               case 9
                    read_RTC()
                     if flsh = 0 then
                       br1 = 10
                       br0 = 10
                    end if
                    prepare_to_show_hour(14, 15, br1, br0,  1, 0 )
                    show_data()
                    up_down()
                    read_RTC()
                    maxCMD(MAX7219_BRIGHTNESS, bcd2dec(bright))
               case 10
                    read_RTC()
                    if flsh = 0 then
                       grc = 10
                    end if
                    prepare_to_show_hour(13, 12, 0, grc,  1, 0 )
                    show_data()
                    up_down()
        end select
        if x5 = 1 then
           x5 = 0
           if al <> 0 then
              al = 0
           else
               al = 1
           end if
           while not k5.0
                 show_data()
           wend
           I2CW(0xc,dec2bcd(al))   ' Alarm On/Off
           I2CW(0xf,dec2bcd(0x0))  ' Clear alarm flag
        end if
        alarm()
    wend
end.
Mii de multumiri ! A compilat si la mine !
...acum nu mai am nicio scuza, trebuie sa-l fac ! Revin cu update. Duminica frumoasa !
Editat de fratello
LE : Sper ca am inteles bine si schema.
Salutare ,vreau sa fac si eu ceasul asta ,nu stiu precis ce varianta de PIC o sa aleg ,va rog ,daca vreti ,sa puneti si hexurile la 1825 si 1827.N-am cu ce sa compilez codurile respective...
Poate mai sunt si alti doritori!
le
pana una alta am facut tot eu niste incercari,daca le puteti verifica ...
1825.hex 1827.hex
Editat de nel65
@fratello
schema corectata
Ceas1827Max7219.thumb.jpg.9a5b26113ba6b9bebf8dc1e9641c57c7.thumb.jpg.2109abab6896aa692ec37ac01e8ea92e.jpg
Programul corectat
end sub
end sub
    btmp=0x00
    s0 = btmp Mod 16
    s1 = btmp / 16
    btmp=0x01
    m0 = btmp Mod 16
    m1 = btmp / 16
    btmp=0x02
    h0 = btmp Mod 16
    h1 = btmp / 16
    btmp=0x04
    d0 = btmp Mod 16
    d1 = btmp / 16
    btmp=0x05
    mo0 = btmp Mod 16
    mo1 = btmp / 16
    btmp=0x06
    y0 = btmp Mod 16
    y1 = btmp / 16
    btmp=0x08
    am0 = btmp Mod 16
    am1 = btmp / 16
    btmp=0x09
    ah0 = btmp Mod 16
    ah1 = btmp / 16
    btmp=0x11
    th0 = btmp Mod 10
    th1 = btmp / 10
    btmp=0x0B
    br0 = bright Mod 16
    br1 = bright / 16
    btmp=0x0C
    btmp=0x0F
    flgal=btmp.0
    btmp=0x0D
    grc=btmp
end sub
    CS = 0
    for i = 0 to 3
    next i
    CS = 1
end sub
end sub
'Prepare hour data
     for  i = 0 to 7
     next i
     for i = 0 to 7
         utmp[i]=uua[i]
     next i
     for i = 0 to 7
         utmp[i].7 =za[i].0
     next i
     for i = 0 to 7
         ztmp[i]=za[i]>>1
     next i
     for i = 0 to 7
     next i
    for i = 0 to 7
         stmp[i]=sa[i]<<1
     next i
     for i = 0 to 7
         mtmp[i]=ma[i]
     next i
     mtmp[0].7=al1
     for i = 0 to 7
         h_dsp[i]    = utmp[i]
     next i
end sub
     for  i = 0 to 7
     next i
     for i = 0 to 7
         mtmp[i] = za[i] >>1
     next i
     for i = 0 to 7
         stmp[i]=uua[i]
     next i
     for i = 0 to 7
         stmp[i].7 =za[i].5
     next i
     for i = 0 to 7
     next i
     for i = 0 to 7
     next i
     for i = 0 to 7
         th_dsp[i]    = utmp[i]
     next i
end sub
     for i = 0 to 7
     next i
     for i = 0 to 31
         dsp[i] = th_dsp[i]
     next i
end sub
     for i = 0 to 7
     next i
     for i = 0 to 31
         dsp[i] = h_dsp[i]
     next i
end sub
    if x0 = 1 then
       if btset = 6 then
          I2CW(btmod, 0)
       else
          btvar = I2CR(btmod)
             btvar = mxbt[btset]
          else
             btvar = btvar - 1
          end if
       end if
       x0 = 0
    end if
    if x1 = 1 then
       if btset = 6 then
          I2CW(btmod, 0)
       else
          btvar = I2CR(btmod)
             btvar = mnbt[btset]
          else
             btvar = btvar + 1
          end if
       end if
       x1 = 0
    end if
end sub
     for i = 0 to 31
         dsp[i] = h_dsp[i]
     next i
end sub
    for i = 0 to 7
   next i
end sub
    prepare_2_show_data
    send_2_display()
end sub
end sub
    APFCON0.SDO1SEL = 0
    APFCON0.SS1SEL  = 0
    WPUA = %11111111       '  Pull-ups PORTA to be enabled
    TRISB.1 = 0             ' Because SPI1_Init make PORTB1 as input
    str = 0
    j = 0
    y = 0
    k = 0
    x = 0
    x0 = 0
    x1 = 0
    x5 = 0
    flgint = 0
    pflgint = 0
    flgal = 0
    dp = 0
    btset = 0
    CS=1
end sub
        flgint = not flgint
        dp.0 = not dp.0
        k = k + 1
        INTCON.INTF = 0
    End if
       TMR0 = 61
       if flgal and al.0 and portb.0 then
       end if
       y = y + 1
      ' buton mod
         k4 = 255
      end if
         btset = btset + 1
         k4 = 0
      end if
      ' Button Up
      if btset <> 0 then
            k0 = 255
         end if
            k0 = 0
            x0 = 1
         end if
      end if
      ' Button Down
      if btset <> 0 then
            k1 = 255
         end if
            k1 = 0
            x1 = 1
         end if
      end if
     ' Button Al On/Off
      if Button(PORTA, 2, 1, 1) then
         k5 = 255
      end if
      if k5 and Button(PORTA, 2, 1, 0) then
         x5 = 1
         k5 = 0
      end if
      INTCON.T0IF = 0
    End if
end sub
main:
'   Main program
    delay_ms(100)
    init_main()
    while TRUE
        select case btset
                       pflgint = flgint
                       read_RTC()
                       if grc = 1 then
                          if k<=16 then
                             if k=16 then
                                dp = 1
                                for yy = 0 to 31
                                    hour2temp
                                    send_2_display()
                                    delay_ms(30)
                                    alarm()
                                next yy
                             else
                                prepare_2_show_data
                                send_2_display()
                                alarm()
                             end if
                          else
                             if k=22 then
                                dp = 1
                                for yy = 0 to 31
                                    temp2hour
                                    send_2_display()
                                    delay_ms(30)
                                    alarm()
                                next yy
                             else
                                for i = 0 to 31
                                    dsp[i] = th_dsp[i]
                                next i
                                send_2_display()
                                alarm()
                             end if
                          end if
                       else
                          show_data
                          alarm()
                       end if
                    end if
               case 1
                    read_RTC()
                    if flsh = 0 then
                       h1 = 10
                       h0 = 10
                    end if
                    show_data()
                    up_down()
               case 2
                    read_RTC()
                    if flsh = 0 then
                       m1 = 10
                       m0 = 10
                    end if
                    show_data()
                    up_down()
               case 3
                    read_RTC()
                    if flsh = 0 then
                       d1 = 10
                       d0 = 10
                    end if
                    show_data()
                    up_down()
                case 4
                    read_RTC()
                    if flsh = 0 then
                       mo1 = 10
                       mo0 = 10
                    end if
                    show_data()
                    up_down()
               case 5
                    read_RTC()
                    if flsh = 0 then
                       y1 = 10
                       y0 = 10
                    end if
                    show_data()
                    up_down()
               case 6
                    read_RTC()
                    if flsh = 0 then
                       s1 = 10
                       s0 = 10
                    end if
                    show_data()
                    up_down()
               case 7
                    read_RTC()
                    if flsh = 0 then
                       ah1 = 10
                       ah0 = 10
                    end if
                    show_data()
                    up_down()
              case 8
                    read_RTC()
                    if flsh = 0 then
                       am1 = 10
                       am0 = 10
                    end if
                    show_data()
                    up_down()
               case 9
                    read_RTC()
                     if flsh = 0 then
                       br1 = 10
                       br0 = 10
                    end if
                    show_data()
                    up_down()
                    read_RTC()
               case 10
                    read_RTC()
                    if flsh = 0 then
                       grc = 10
                    end if
                    show_data()
                    up_down()
        end select
        if x5 = 1 then
           x5 = 0
           if al <> 0 then
              al = 0
           else
               al = 1
           end if
           while not k5.0
                 show_data()
           wend
        end if
        alarm()
    wend
end.
 @nel65
hex pt 1825 Varianta cu DS 18B20
Ceas_MAX7219_PIC1825.hex
Multumesc frumos !
...OSCCON insa nu cred ca poate avea valoarea %11111111 pt PIC16F1827 ... Am ales din Mikrobasic optiunea de "internal osc", frecventa 32 MHz si am comentat in cod linia OSCCON. E OK asa ?
LE. In PicBasic Pro folosesc asa pt acest PIC :
DEFINE OSC 32
OSCCON= %11110000       'PLL enabled, Internal osc
Daca modific OSCCON in codul postat, imi da eroare la compilare (?!?).
Editat de fratello
LE
Stiu ca poate nu e locul potrivit...dar matricea mea cred ca are o problema ! Am incercat toate tutorialele gasite (Hello World, MERT, etc, etc) cu Arduino Uno si Arduino Nano si nu am obtinut decat matrice stinsa sau matrice aprinsa complet !!! Uneori doar cate o matrice din cele 4 aprinsa ....
Cum as putea verifica daca este OK matricea ??? Multumesc.
Despre 16F1827 ...
Am facut cablajul, am programat PIC-ul ... din pacate cu 1 eroare : "Error writing config area: written 1613, read 1EFF".
Bineinteles, ceasul nu functioneaza :(
Am incercat :
- modificare OSCCAL in cod %11110000 (pt 32 MHz)
- comentare linia OSCCAL
- valoari de 8, 16, 32 MHz pentru "Frequency".
Compilarea reuseste, de fiecare data, fara erori ... dar programarea, de fiecare data, da aceeasi eroare !
Sugestii ? Multumesc !!
Nu cred că e acolo problema - eroarea e generată de faptul că biții care nu pot fi scriși din ConfigWord2 sunt citiți ca ”1”  deci cuvântul s-a scris bine dar este citit greșit la verificare .
Programatorul scrie 0x1613 . Locația de memorie are biți care vor da la citire ”1” indiferent ce ai încerca să scrii peste ei  - corespunzând cu 0x08EC .
Făcând ”OR” între astea rezultă 0x1EFF !
Caută deci în altă parte cauza nefuncționării.
Revin cu update :
-OSCCAL %11111000 (8 Mhz)
-programare cu clona Pickit2, in loc de OpenProg (care dadea eroarea de mai sus).
Acum ceasul porneste. Arata ora, data, secunde, alarma, bright...dar la temperatura este o eroare....
Daca apas 1 data pe butonul de MODE, nu mai pot reveni la functionare normala ... merge in bucla setarea tuturor parametrilor (ca in clip).
cand esti in meniul temperaturii seteaza sa apara 01 in loc de 0 si artefactul ala , vezi ca ai mai mult de dat din butoane ,si va arata temperatura , cand este 00 nu arata , se seteaza cu butoanele + si -
Editat de Florian Ciobanu
completare
