timer too long and not read the button
jurevycius3
Hello, I want to help me with a problem, I have the code but not work in a correct mode (code is below). If I press the button ZS_1 and after 1 second I press the another button RB4_bit Relay_back doesn't work because the timer is too long in cycle. Please help me with another expression. Best regards !
 do{
                 if ((SZ_1 == 1)  ||  (RB1_bit == 1) || (RB2_bit == 1) || (RB3_bit == 1))
   {  Delay_ms(80);
                 Relay_front=1;
                  Delay_ms(10000);
                   Relay_front=0;
      else if ((RB4_bit == 1)  ||  (RB5_bit == 1))
                 Delay_ms(80);
                 Relay_back=1;
                  Delay_ms(10000);
                 Relay_back=0;
    } while(1);
  • Răspunsuri 8
  • jurevycius3
  • Mircea
  • bcristian
Maybe  "Delay_ms(80)" must be biger than 10000.
Try
 do{
   {  Delay_ms(200000);
                 Relay_front=1;
                  Delay_ms(10000);
                   Relay_front=0;
                 Delay_ms(200000);
                 Relay_back=1;
                  Delay_ms(10000);
                 Relay_back=0;
    } while(1);
Editat de Vizitator
In your code, you have to wait at least 10 seconds before you can do something on RB4 or RB5.
And the same 10 seconds until you can do something on SZ_, RB1... 3.
Editat de Thunderer
44 minutes ago, Fan Elforum said:
So, after a short search on google, I think this is the logic diagram of what you need.
You must change the green fields. 1000 ms=1sec.
ok....thanks !
https://randomnerdtutorials.com/why-you-shouldnt-always-use-the-arduino-delay-function/
Do not use delay() if your program handles user input, because delay() blocks the system (as far as your program logic is concerned), i.e. nothing happens during that time, not even checking that the user pressed some button.
What you should do instead is use state machine logic, i.e. something like:
int state = 0;
ulong stateStart, stateDuration;
while (1)
    ulong crtTime = millis();
    switch (state)
        case 0: // relay off, button not pressed
            if (button_pressed)
                state = 1;
                stateStart = crtTime;
                stateDuration = 80;
            break;
        case 1: // delay between button press and activating relay
            if (crtTime - stateDuration >= stateStart) // testing this way avoids the overflow error
                state = 2;
                stateDuration = 10000;
                relayState = 1; // relay on
            break;
        case 2: // relay on time
                state = 0;
                relayState = 0; // relay off
            break;
int state = 0;
while (1)
    switch (state)
            if (button_pressed)
                state = 1;
                stateDuration = 80;
            break;
                state = 2;
            break;
                state = 0;
            break;
I understood, thank you very much !
