Vizitator bert allen Postat Octombrie 9, 2018 Partajează Postat Octombrie 9, 2018 Hello, I am using wireless pressure sensor which I want to interface with ESP8266 to send the sensor readings to firebase but as it is using Xbee module (as transmitter as well as receiver). Any best suggestion to make this sensor work with ESP8266 will be much helpful. Link spre comentariu
nico_2010 Postat Octombrie 9, 2018 Partajează Postat Octombrie 9, 2018 (editat) Hello and welcome to this forum! If I understand well, the sensor works with Xbee module? Because only in this manner it became wireless, otherwise it is wired sensor. Did you activate pull-up resistor for I2C bus? Did you check if the sensor works with this scketch: https://github.com/ControlEverythingCommunity/MS5803-02BA/blob/master/Arduino/MS5803_02BA.ino If the answer is YES then you have to use Arduino IDE with ESP boards installed to make it work. Editat Octombrie 9, 2018 de nico_2010 Link spre comentariu
Vizitator bert allen Postat Octombrie 12, 2018 Partajează Postat Octombrie 12, 2018 Hey, Thanks for the reply the actual problem is this kind sensor is comes with a sensor package which is actually connected via Xbee module which NCD delivered to the industry where I am working. Also with the wireless pressure sensor package, they sent the zigmo router https://store.ncd.io/product/900hp-s3b-long-range-wireless-mesh-modem-with-usb-interface/ for receiving the values so any idea in what way I should connect the router with ESP8266 and send the values to Firebase ? Link spre comentariu
Vizitator bert allen Postat Octombrie 12, 2018 Partajează Postat Octombrie 12, 2018 and yes this sensor is connecting with Xbee module, I am able interface this sensor with the Github code you provide but need help for 1. The further connection with ESP8266 2. How to send the sensor data of wireless sensor to Firebase. Link spre comentariu
