horn 3 cai
arcgotic
La 15.05.2020 la 10:14, arcgotic a spus:
Da, dar efectul ce il aud e legat cred de faptul ca raspunsul la o incinta rotunjita nu are zig-zag-ul ala in raspuns
https://www.diyaudio.com/forums/multi-way/303155-roundovers-post6016988.html
poti sa masori? De curiozitate intreb. Ca simulatorul si mie imi arata ceva, dar nu stiu cat e de real.
La 15.05.2020 la 12:54, arcgotic a spus:
M-am uitat pe link-ul ala dar nu inteleg ce vor sa zica
The second most important upgrade is proper speaker spacers and gasketing. These two parts work in concert with each other to further eliminate the speaker’s soundwaves from interacting with each other to create more cancelled out sound. When a speaker is correctly installed into a door it is mated up to the grill and gasketed to insure that sound is only being played into the cabin of the vehicle. When a speaker is installed with a basic install, it is often mounted at the same level as the door frame and is not gasketed so sound is allowed to bounce around in between the door frame and the door panel creating areas where sound can be cancelled out."
mi se pare ceva ulei de sherpishor..
Nu inteleg e ti se pare ulei de sarpe. E ok ce zice omul. Presupun ca e vb de o usa de masina, adica niste tabla ambutisata in care daca ciocanesti cu ceva vezi ca suna in toate felurile. Ca nu toata lumea conduce maybach cu o tona de antifon pe usa.
Deci poate e o idee buna sa pui o bariera anti vibratii intre sasiul difuzorului si tabla din usa.
Editat de Sharky
La asta ma refer "These two parts work in concert with each other to further eliminate the speaker’s soundwaves from interacting with each other to create more cancelled out sound"
Ori textul original a fost in alta limba decat engleza, si in traducere s-a incurcat ceva, nu inteleg faza cu "canceled out sound
Cand ai o cutie goala si masori raspunsul, varfurile si golurile de unde crezi ca apar? Cat ajunta garnitura aia nu stiu, dar in mod sigur nu e ok sa transmiti vibratii spre tabla masinii.
  • 5 luni mai târziu...
Pana se face sistemul pe 3 cai am mai experimentat cu hornurile de medie ce le-am facut acum cativa ani.
Tractrix de la 250hz. Difuzorul folosit e Visaton FRS8M.
Inalte horn Sica Q07015A cu driver Sica CD60.38/N92.
Bas cutie inchisa cu un 12" no name.
Crossover activ la 250,6000.
Suna bine, doar ca sweet spot e mic, 1-2 locuri pe canapea. Si midbasul si basul nu se ridica la nivelul mediei ca si calitate. Trebuie sa mai experimentez alt fel de solutie, poate un horn front loaded..
La 18.05.2020 la 11:11, arcgotic a spus:
Se refera la sunetul pe care il aud pietonii:rade::rade:
  • 2 săptămâni mai târziu...
Am masurat hornul si facut un cross rapid la 300hz si 1800hz. Suna bine sa ai tot de la 300hz in sus dintr-un singur punct.
https://ibb.co/N3qkSK8 - frs5x 2serie 2paralel si driverul de 1""
https://ibb.co/tLGhyMv  - doar frs5x 2serie 2paralel dupa cross si eq
https://ibb.co/2jxnJTn  - doar frs5x 2serie 2paralel fara cross fara eq
https://ibb.co/MPtxFNp - pozitionarea nu e cea mai buna, sunt cam departate boxele una de alta, trebuie sa mut PCul
https://ibb.co/tptbL0y
Editat de arcgotic
add info
  • 3 săptămâni mai târziu...
La acest tip de horn cat conteaza pozitia difuzoarelor? Adica am inteles ca se pastreaza o anumita distanta intre ele in functie de frecventa de taiere. Si inca o intrebare, suprafata gaurii de intrare la mid-bas cum se calculeaza? In functie de ce parametri?
In primul post sunt detalii de la Danley citire legate de unde se dau gaurile functie de frecventa de taiere dorita.
Suprafata gurii am simulat-o in Hornresp. Se calculeaza in functie de mai multe, sunt niste formule dar acum la indemana nu le am.
Ce pot sa zic e ca solutia asta e superba.. sa ai de la 300hz totul dint-un loc.. dupa ce am aplicat si liniarizare de faza, e ultra curat tot. Suna foarte bine.
  • 4 luni mai târziu...
Am mai adaugat o cale. 4 cai acum, Beta 15 basi in U frame, sus panou cu 2x Faital pro 10fe200, si hornul B52 sinergizat cu 4xFRS5x si un driver 1"
Cross 80/ 300/ 1800
Suna binisor.
Frumos, ai cu ce te juca, nu gluma, si imi place ca faci totul in timp, nu proiecte dinalea de-a gata in 2 saptamani in care filtru e facut pe graba intr-o dupamasa dar suna extrem de bine. :)
N-au decat sa arate ca dracu, pana nu suna bine ce rost are sa te apuci de mobila?
ASta pare un proiect serios, nu labareala estetico-audiofila. Omul lucreaza cu adevarat la ce scrie in titlu, bravo lui.
Nu le finisez ca stiu ca tot testez, le schimb.. :))
Dar ne bucuram amandoi de sunet, muzica si filme, si seara cand ai doar o lumina ambientala in spate chiar nu vezi diferenta.
Sunetul e bun peste tot in camera, asta e cel mai mare avantaj la boxele astea.
Pentru cine poate face cross la driverul de inalte pe la 2k sau mai mult, va recomand driverul Sica CD78.26/245
Este foarte bun, mai ales la banii la care e. Are bobina de 1" si fata de driverele cu bobina mai mare chiar e diferenta, chiar mare.. la finete, detalii..
Alt driver bun bun este BMS 4524, l-am avut si era bun si el, dar tot asa trebuia taiat sus, poate chiar mai sus de 2k.
https://sica.it/prodotto/cd-78-26-245/
