NodeMCU
Untold
Va salut.
Mi-am luat si eu un nodeMCU sa-mi fac o automatizare pt lumini si intampin o problema: nu reusesc sa-l conectez din serial monitor din IDE...
I-am instalat driverul pt C340G, il vad in device manager, am descarcat si aplicatia pe telefon insa, cum am zi, nu reusesc sa-l conectez ca sa-i vad IP-ul...Ma poate ajta cineva?
In tutuorialul de pe youtube pe care l-am vazut, in serial monitor dupa 3-4 puncte aparea conected to....si arata si IP-ul. La mine nu se intampla asta, deci e cum ati spus, nu se conecteaza la wi-fi. Mai jos codul pe care l-am scris in nodeMCU si link-ul de unde am luat proiectul:
  1. //Visit www.roboshala.com for more details on NodeMCU and other projects.
    #include <ESP8266WiFi.h>
    const char* ssid = "CPH1613"; // SSID i.e. Service Set Identifier is the name of your WIFI
    const char* password = "12345678"; // Your Wifi password, in case you have open network comment the whole statement.
    int R1=D1; // GPIO13 or for NodeMCU you can directly write D7
    int R2=D2;
    int R3=D3;
    int R4=D4;
    WiFiServer server(80); // Creates a server that listens for incoming connections on the specified port, here in this case port is 80.
    void setup() {
    Serial.begin(115200);
    delay(10);
    pinMode(R1, OUTPUT);
    pinMode(R2, OUTPUT);
    pinMode(R3, OUTPUT);
    pinMode(R4, OUTPUT);
    digitalWrite(R1,HIGH);
    digitalWrite(R2,HIGH);
    digitalWrite(R3,HIGH);
    digitalWrite(R4,HIGH);
    // Connect to WiFi network
    Serial.println();
    Serial.println();
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
    while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected");
    // Start the server
    server.begin();
    Serial.println("Server started");
    // Print the IP address
    Serial.print("Use this URL to connect: ");
    Serial.print("http://");
    Serial.print(WiFi.localIP()); //Gets the WiFi shield's IP address and Print the IP address of serial monitor
    Serial.println("/");
    void loop() {
    // Check if a client has connected
    WiFiClient client = server.available();
    if (!client) {
    return;
    // Wait until the client sends some data
    Serial.println("new client");
    while(!client.available()){
    delay(1);
    // Read the first line of the request
    String request = client.readStringUntil('\r');
    Serial.println(request);
    client.flush();
    // Match the request
    if (request.indexOf("/Relay1On") != -1) {
    digitalWrite(R1,LOW);
    client.println("HTTP/1.1 200 OK");
    client.println("Content-Type: text/html");
    client.println("");
    client.println("<!DOCTYPE HTML>");
    client.println("<html>");
    client.println("Relay 1 is ON");
    client.println("</html>");
    client.stop();
    delay(1);
    if (request.indexOf("/Relay1Off") != -1) {
    digitalWrite(R1, HIGH);
    client.println("");
    client.println("Relay 1 is OFF");
    client.stop();
    delay(1);
    if (request.indexOf("/Relay2On") != -1) {
    digitalWrite(R2,LOW);
    client.println("");
    client.println("Relay 2 is ON");
    client.stop();
    delay(1);
    if (request.indexOf("/Relay2Off") != -1) {
    digitalWrite(R2, HIGH);
    client.println("");
    client.println("Relay 2 is OFF");
    client.stop();
    delay(1);
    if (request.indexOf("/Relay3On") != -1) {
    digitalWrite(R3,LOW);
    client.println("");
    client.println("Relay 3 is ON");
    client.stop();
    delay(1);
    if (request.indexOf("/Relay3Off") != -1) {
    digitalWrite(R3, HIGH);
    client.println("");
    client.println("Relay 3 is OFF");
    client.stop();
    delay(1);
    if (request.indexOf("/Relay4On") != -1) {
    digitalWrite(R4,LOW);
    client.println("");
    client.println("Relay 4 is ON");
    client.stop();
    delay(1);
    if (request.indexOf("/Relay4Off") != -1) {
    digitalWrite(R4, HIGH);
    client.println("");
    client.println("Relay 4 is OFF");
    client.stop();
    delay(1);
https://www.roboshala.com/wifi-home-automation/
Editat de nico_2010
Codul a fost formatat
Data viitoare poti posta codul aici ex: https://pastebin.com/c3Lvb3pX , scriptul forumului observ ca nu stie sa restranga codul sau nu ai folosit formatarea pentru cod. :rade:
Acum nu am posibilitatea sa testez pe ESP-ul meu dar sper ca datele de conectarea la reteaua WiFi sunt corecte. Adica routerul la care vrei sa te conectezi wireless are acest SSID sI parola:
Altfel ESP-ul nu are cum sa stie la ce retea WIFI trebuie sa se conecteze si ce parola are respectiva retea.
Editat de Stefan.
Nu prea inteleg....in fine, node-ul genereaza (daca ma exprim bine) si el o retea wi-fi, am conectat laptop-ul la ea, dar acelasi rezultat...n-am lucrat pana acum cu Arduino, sunt 0! Eu am net de la UPC, ar trebui sa modific sketch-ul cu ssid-ul si pass routerului UPC?
Editat de Untold
Din bruma de engleza pe care o stiu eu inteleg asa:
char* ssid = "CPH1613"; // SSID i.e. Service Set Identifier is the name of your WIFI  - SSID este numele WiFi-ului (router din casa) tau ex: UPC Wi-Free
const char* password = "12345678"; // Your Wifi password, in case you have open network comment the whole statement. - Parola ta WiFi, in cazul in care nu ai parola la WiFi trebuie ca linia asta sa o comenztezi // elimini.
Nu stiu de ce ESP-ul tau functioneaza si in mod AP, drept dovata existenta retelei WiFi cu numele Farylink_9F93F7, dar scrie in loc de CPH1613 si 12345678 datele de la WIFI-ul tau.
Editat de Stefan.
Da, Node-ul se conecteaza la un router si primeste un IP in LAN, de exemplu 192.168.0.2.  Cand in cod definesti "WifiServer" el de fapt asculta la request-uri prin reteaua LAN pe ip-ul primit deci daca pe laptop in browser accesezi  192.168.0.2/test/1 tu vei putea citi ca string in cod "/test/1". De acolo trebuie sa iti faci o lista de parametrii sa treci prin ele cu un "switch" sau if/else si sa faci ceva in functie de ce parametrii ai primit.
Am mai testat si am concluzionat urmatoarele: aplicatia de pe tel merge partial, in sensul ca, pe serial monitor imi zice rel1 on, rel1 off, etc...pe tel insa nu primesc raspuns de la node...in mod sigur e de vina telefonul care are o versiune de Android f veche (2.36) si nu suporta toate caracteristicile necesare), ar trebui ca butonul de on sa se inverzeasca sau ceva ca sa-mi confirme ca rel respectiv e on, nu? Alta problema e ca doar pt rel 4 mi se aprinde ledul de pe nodeMCU la on si se stinge la off...
Incearca de pe calculator sa accesez din orice browser (Chrome, Friefox, etc..)  urmatorul link  http://192.168.0.80/Relay1On   si vezi ce se intampla, daca am interpretat corect codul ar trebuii sa iti apara o pagina alba in care sa scrie "Relay 1 is ON". In cazul in care apare atunci aplicatia / telefonul este de vina, daca tot nu apare atunci poate fi si de la codul din Node
Editat de Bandi Szasz
Vad ca ai definite 4 relee, incearca firmware-ul espurna, instructiunile in al 2-lea link, este gata facut, si mai are si multe chestii in plus:
https://github.com/xoseperez/espurna/releases/download/1.12.6/espurna-1.12.6-itead-sonoff-4ch.bin
sau
https://github.com/xoseperez/espurna/releases/download/1.12.6/espurna-1.12.6-nodemcu-lolin.bin
instructiuni: (in loc de /dev/ttyUSB0 scrii COM4)
https://github.com/xoseperez/espurna/wiki/Binaries
Editat de deejay2k1
typo
  • 5 săptămâni mai târziu...
