dem3ntor Postat August 23, 2018 Partajează Postat August 23, 2018 Salut am o masina de spalat vase la care am gasit un releu defect, bobina intrerupta. are seria sje-s-112lmh. 12v, 10A am cautat exact modelul aceasta, dar nu se gaseste la noi. in foaia de catalog scrie "fluxthight" - si nu stiu ce vrea sa zica cu acest termen. Il pot inlocui cu un releu omron, 12v 7A? Acest releu, comanda la randul lui un contactor. Multumesc! Link spre comentariu
Nostalgic Postat August 23, 2018 Partajează Postat August 23, 2018 (editat) Se poate inlocui cu orice releu la 12v si sa suporte 10A. Se gasesc destule. Poate fi si de 7A. Editat August 23, 2018 de Nostalgic 1 Link spre comentariu
Taraxacus Postat August 25, 2018 Partajează Postat August 25, 2018 cred ca se poate si cu un releu auto care suporta 20-30 A Link spre comentariu
cornel1962 Postat August 25, 2018 Partajează Postat August 25, 2018 ...se gasesc foarte usor pe placi de masini de spalat, atentie insa,...la 12v ! Link spre comentariu
cornel1962 Postat August 25, 2018 Partajează Postat August 25, 2018 (editat) La 23.08.2018 la 18:23, dem3ntor a spus: "fluxthight" La 23.08.2018 la 18:23, dem3ntor a spus: "fluxthight" ?....sigur este si acel " t " acolo ? Editat August 25, 2018 de cornel1962 Link spre comentariu
valivoi Postat August 25, 2018 Partajează Postat August 25, 2018 (1). Flux tight type.A construction which prevents invasion of flux during the mounting on printed circuit boards.Automatic soldering is possible.It cannot be washed for cleaning. (2). Sealed type.In addition to the construction which prevents the invasion of the flux,this is completely sealed construction which allows washing. Link spre comentariu
dem3ntor Postat August 26, 2018 Autor Partajează Postat August 26, 2018 Am pus un releu omron cu bobina la 12v si 7A si functioneaza. Nu s-a potrivit ca dimensiune, dar l-am prins cu silicon si am prelungit terminalele cu fir .. Multumesc! Link spre comentariu
