ldoctoru Postat August 1, 2018 Partajează Postat August 1, 2018 Va salut, Un prieten a primit televizorul "TOSHIBA 32RL933" si are PIN setat la configurare.Care este metoda de resetare a pinului. Multumesc Link spre comentariu
iuliantv Postat August 1, 2018 Partajează Postat August 1, 2018 (editat) ,,Try this: Press MENU 3 times The LCD should show the current code. I found the user guide for a close model number. It should be of use to you,, sau incercati 1276 Editat August 1, 2018 de iuliantv Link spre comentariu
ldoctoru Postat August 1, 2018 Autor Partajează Postat August 1, 2018 5 minutes ago, iuliantv said: ,,Try this: Press MENU 3 times The LCD should show the current code. I found the user guide for a close model number. It should be of use to you,, Nu functioneaza Link spre comentariu
