AMD vs. INTEL
tiptronic
Tot mai bine si mai bine!
Cel mai bine va fi cind va fi doar unu!
Atunci stam drepti, aliniati si strigam: Da! cel mai bun! cel mai mare si mai tare!
visul orcarui producator.
La asta chiar nu m`am asteptat, sper sa nu fie de banc!
Bai da-ma drecu !
Pai daca au recurs la asa ceva, inseamna ca e groasa treaba.
Eu zic ca astia de la intel, in cazul asta, sa vobeasca cu @dany_cta, si sa ii lamureasca el cat de cacat sunt AMD-urile astea. :rade:
Va rog scuzati, din graba...
La asta chiar nu m`am asteptat sper sa fie de banc!
Se pare ca nu-i gluma deloc si aceasta licenta vine odata cu ultimul microcode update care "repara" vulnerabilitati din procesoarele lor:
Citat
3. LICENSE RESTRICTIONS. All right, title and interest in and to the Software
and associated documentation are and will remain the exclusive property of
Intel and its licensors or suppliers. Unless expressly permitted under the
Agreement, [b]You will not, and will not allow any third party to (i) use, copy,
distribute, sell or offer to sell the Software or associated documentation;
(ii) modify, adapt, enhance, disassemble, decompile, reverse engineer, change
or create derivative works from the Software except and only to the extent as
specifically required by mandatory applicable laws or any applicable third
party license terms accompanying the Software; (iii) use or make the Software
available for the use or benefit of third parties; or (iv) use the Software on
Your products other than those that include the Intel hardware product(s),
platform(s), or software identified in the Software; or (v) publish or provide
any Software benchmark or comparison test results.[/b]
https://perens.com/2018/08/22/new-intel-microcode-license-restriction-is-not-acceptable/
E clara treaba, le e frica.
De acum in colo se pare ca si AMD devine un concurent destul de periculos pentru Intel, mai ales ca au reusit sa faca procesoare si pe 7nm
https://www.tomshardware.com/news/amd-announces-new-raven-ridge-2018-apus,37678.html
Quote
Intel is mired on the 14nm process as it works out the kinks on its oft-delayed 10nm process. AMD already has working second-gen EPYC processors built on the 7nm process. Those processors will debut early next year, possibly setting the stage for large gains in data center market share as those chips slug it out with Intel's 14nm Xeon lineup. AMD still hasn't provided a roadmap for 7nm on the desktop.
Adica acum sa inteleg ca in top10 procesoare o sa apara si un procesor de la amd ? Ar fi prima data in istoria procesoarelor, nu ca m-as grabi sa il iau, prefer calculatoare rapide si stabile chiar daca platesc in plus pentru asta.
  • 8 luni mai târziu...
E deja cu solutii f tari. Atat pe CPU cat si pe GPU.
Intel va avea o mare problema. Managementul ultimilor 3-4 ani a fost catastrofal.
Quote
:85
Daca scriati asta prin 1989-1991, as mai fi inteles...dar in 2019 e demential.
Editat de Spitfire
La 23.08.2018 la 19:08, maxente a spus:
Nu face AMD nici un procesor, ei doar le proiecteaza si atat. TSMC le face pentru ei. Si Intel ar putea sa aiba procesoare pe 7nm chiar acum, realizate in aceeasi fabrica daca platesc pentru asta.
Conteaza si cum proiectezi, executia urmeaza proiectul: ce bagi, aia scoti. Stim cu totii ca multe firme proiecteaza in USA, Japonia, Germania, Italia, Spania etc. si executa in China, Taiwan, Malaysia etc.
Oricum, am ramas pe Intel (forever!), am mai scris deja.
Nu ca as fi facut deja upgrade, intre timp, nu-i vorba despre cost, m-ar costa salariul pe o luna (MB, procesor, RAM, placa video), dar nu asta e problema... Nevasta e! Cica nu-mi trebuie, asta (pe care il am acum) functioneaza foarte bine, draga!
Nu recomand nimanui sa se insoare...
