amudsen Postat Iunie 20, 2018 Partajează Postat Iunie 20, 2018 (editat) Buna ziua, Avand in vedere ca au inceput sa apara tantarii care dau "like" la cei cu fereastra deschisa, am gasit un circuit cu pic 16f627 cu un fisier asm. Link-ul catre pagina> http://320volt.com/en/pic16f627-ultrasonik-kedi-kopek-kovucu-devresi/ Cine ma poate ajuta cu o conversie din asm in hex? ; www.endtas.com/robot ; pest repeller source code ; ozkal ozsoy PM_USED EQU 1 INCLUDE "16F627.INC" ; Define statements. #define OSC 4 RAM_START EQU 00020h RAM_END EQU 0014Fh RAM_BANKS EQU 00003h BANK0_START EQU 00020h BANK0_END EQU 0007Fh BANK1_START EQU 000A0h BANK1_END EQU 000EFh BANK2_START EQU 00120h BANK2_END EQU 0014Fh EEPROM_START EQU 02100h EEPROM_END EQU 0217Fh R0 EQU RAM_START + 000h R1 EQU RAM_START + 002h R2 EQU RAM_START + 004h R3 EQU RAM_START + 006h R4 EQU RAM_START + 008h R5 EQU RAM_START + 00Ah R6 EQU RAM_START + 00Ch R7 EQU RAM_START + 00Eh R8 EQU RAM_START + 010h FLAGS EQU RAM_START + 012h GOP EQU RAM_START + 013h RM1 EQU RAM_START + 014h RM2 EQU RAM_START + 015h RR1 EQU RAM_START + 016h RR2 EQU RAM_START + 017h _freq EQU RAM_START + 018h _sure EQU RAM_START + 01Ah _dongu EQU RAM_START + 01Ch _flag EQU RAM_START + 01Dh _sayac EQU RAM_START + 01Eh _sayac1 EQU RAM_START + 01Fh _PORTL EQU PORTB _PORTH EQU PORTA _TRISL EQU TRISB _TRISH EQU TRISA #define _isikvar _PORTA_2 #define _PORTA_2 PORTA, 002h #define _PORTA_3 PORTA, 003h #define _PORTA_0 PORTA, 000h #define _PORTA_1 PORTA, 001h ; Constants. _durs EQU 00000h INCLUDE "FAREKOV.MAC" INCLUDE "PBPPIC14.LIB" MOVE?CB 007h, CMCON MOVE?CB 0FEh, TRISA MOVE?CB 000h, TRISB MOVE?CW 007D0h, _sure MOVE?CB 002h, PORTA MOVE?CB 000h, PORTB SOUNDPIN?T _PORTA_3 SOUND?CC 06Eh, 005h MOVE?CW 07530h, _freq LABEL?L _dura LABEL?L _enbas HIGH?T _PORTA_0 PAUSE?C 00Ah LOW?T _PORTA_0 MOVE?CW 03E80h, _freq LABEL?L L00001 CMPGT?WCL _freq, 0D6D8h, L00002 HPWM?CCW 001h, 07Fh, _freq PAUSE?C 00Ah NEXT?WCL _freq, 001F4h, L00001 LABEL?L L00002 CMPNE?TCL _PORTA_1, 001h, L00003 GOTO?L _enbas LABEL?L L00003 MOVE?CW 03E80h, _freq LABEL?L L00005 CMPGT?WCL _freq, 0D6D8h, L00006 HPWM?CCW 001h, 07Fh, _freq PAUSE?C 0C8h NEXT?WCL _freq, 003E8h, L00005 LABEL?L L00006 MOVE?CB 001h, _sayac1 LABEL?L L00007 CMPGT?BCL _sayac1, 0FFh, L00008 MOVE?CB 001h, _sayac LABEL?L L00009 CMPGT?BCL _sayac, 0FFh, L00010 CMPGT?BBL _sayac, _sayac1, L00011 MOVE?CB 0F0h, PORTB GOTO?L L00012 LABEL?L L00011 MOVE?CB 00Fh, PORTB LABEL?L L00012 PAUSEUS?C 00Ah NEXT?BCL _sayac, 001h, L00009 LABEL?L L00010 NEXT?BCL _sayac1, 001h, L00007 LABEL?L L00008 PAUSE?C 064h MOVE?CB 0FFh, _sayac1 LABEL?L L00013 CMPLT?BCL _sayac1, 001h, L00014 MOVE?CB 001h, _sayac LABEL?L L00015 CMPGT?BCL _sayac, 0FFh, L00016 CMPGT?BBL _sayac, _sayac1, L00017 MOVE?CB 0F0h, PORTB GOTO?L L00018 LABEL?L L00017 MOVE?CB 00Fh, PORTB LABEL?L L00018 PAUSEUS?C 00Ah NEXT?BCL _sayac, 001h, L00015 LABEL?L L00016 NEXTM?BCL _sayac1, 001h, L00013 LABEL?L L00014 PAUSE?C 064h MOVE?CB 001h, _sayac1 LABEL?L L00019 CMPGT?BCL _sayac1, 0FFh, L00020 MOVE?CB 001h, _sayac LABEL?L L00021 CMPGT?BCL _sayac, 0FFh, L00022 CMPGT?BBL _sayac, _sayac1, L00023 MOVE?CB 0F0h, PORTB GOTO?L L00024 LABEL?L L00023 MOVE?CB 00Fh, PORTB LABEL?L L00024 PAUSEUS?C 00Ah NEXT?BCL _sayac, 001h, L00021 LABEL?L L00022 NEXT?BCL _sayac1, 001h, L00019 LABEL?L L00020 PAUSE?C 064h MOVE?CB 0FFh, _sayac1 LABEL?L L00025 CMPLT?BCL _sayac1, 001h, L00026 MOVE?CB 001h, _sayac LABEL?L L00027 CMPGT?BCL _sayac, 0FFh, L00028 CMPGT?BBL _sayac, _sayac1, L00029 MOVE?CB 0F0h, PORTB GOTO?L L00030 LABEL?L L00029 MOVE?CB 00Fh, PORTB LABEL?L L00030 PAUSEUS?C 00Ah NEXT?BCL _sayac, 001h, L00027 LABEL?L L00028 NEXTM?BCL _sayac1, 001h, L00025 LABEL?L L00026 PAUSE?C 064h GOTO?L _enbas END? END L.E. Ce vrea sa spuna " I've read the posts all the time and I 've built the PIC16F627 with some modifications. The frequency is measured with a scan frequency or frequency meter between 20 KHz and 60 KHz. After loading the original HEX content into the programmer, CONGIG must be repaired to 3F54 and downloaded." Editat Iunie 20, 2018 de amudsen Link spre comentariu
mars01 Postat Iunie 20, 2018 Partajează Postat Iunie 20, 2018 (editat) Pe site-ul celui care a creat acest proiect sunt atasate fisierul sursa si fisierul .hex http://endtas.com/robot/modules.php?name=News&file=article&sid=110 Stanga jos pe pagina lui, in caz ca nu vezi link-ul. Editat Iunie 20, 2018 de mars01 Link spre comentariu
amudsen Postat Iunie 20, 2018 Autor Partajează Postat Iunie 20, 2018 Multumesc, ar fi ok sa pun pentru un tweeter piezo asa ceva? Link spre comentariu
M.Adrian Postat Iunie 20, 2018 Partajează Postat Iunie 20, 2018 Ar trebui sa functioneze. Link spre comentariu
amudsen Postat Iunie 21, 2018 Autor Partajează Postat Iunie 21, 2018 Schema finala ar fi ok? Multumesc. Link spre comentariu
validae Postat Iunie 21, 2018 Partajează Postat Iunie 21, 2018 (editat) Schema poate fi oricum, problema e că țânțarii nu prea bagă în seamă chestiile astea, că nu-s audiofili. Când are nevoie de sânge, femela de țânțar nu mai ține cont de nimic.Plase la geamuri și dacă vrei să fii sigur, detonezi o pastilă fumigenă cu 10 minute înainte de culcare.Adică o pui pe un bec de veioză și o ții până iese tot fumul din ea.Lași câteva minute, aerisești bine camera și te culci.Sau dai cu spray prin toată camera, lași cinci minute să se sufoce insectele, apoi aerisești și gata.....nu te mai complica cu din astea, că nu au efect.La unele animale mai are efect, dar când le roade rău stomacul, nici acolo nu mai mere nimic.Testat temeinic, nu vorbe... Editat Iunie 21, 2018 de validae Link spre comentariu
mars01 Postat Iunie 21, 2018 Partajează Postat Iunie 21, 2018 (editat) @validae eu zic sa lasam omul sa isi faca placerea. Uneori si ideea ca ai acolo ceva care innebuneste pisica vecinului si tot este ceva Editat Iunie 21, 2018 de mars01 Link spre comentariu
amudsen Postat Iunie 22, 2018 Autor Partajează Postat Iunie 22, 2018 16 hours ago, validae said: .........."Când are nevoie de sânge, femela de țânțar nu mai ține cont de nimic".......... Si nu numai . Dar e o motivatie in plus..... Link spre comentariu
amudsen Postat Iunie 27, 2018 Autor Partajează Postat Iunie 27, 2018 Am facut montajul fara mosfet-uri pe un breadboard, prima reactie..... au zburat porumbeii de pe acoperis, dar nu am gasit nici o tantaroaica pentru masurarea stresului . Pe osciloscop se vede ca functioneaza, de auzit nu aud nimic, doar cel mic aude cica un tiuit enervant. Continui experimentul.... poate prind vreo femela (tantar). 1 Link spre comentariu
