Surse in comutatie LLC
iop95
Vezi controllerul PFC.
Initial acel UCC 3895 a fost realizat prin 1999 si revizuit in 2013.
Sintem in 2018 totusi.
Voi testa curind un PFC digital, dar sa termin intii "obligtiile" fata de clienti.
Yamaha vreau sa fie gata astazi.
Digital power factor correction
(dPFC) controllers designed to deliver the lowest PFC system
cost in electronic PFC applications. The controller operates
in a variable frequency discontinuous conduction mode (VFDCM)
with zero-current switching optimized to deliver best-inclass
THD and minimize the size and cost of magnetic
components.
The VF-DCM control algorithm varies both duty cycle and
frequency. This spreads the EMI frequency spectrum, thus
reducing conducted EMI filtering requirements. In addition, the
maximum switching frequency is reached at the peak of the AC
input, which allows the use of a smaller, more cost-effective
boost inductor.
The feedback loop is closed through an integrated digital
compensation network within the controller, eliminating the
need for additional external components. Protection features
such as overvoltage, overcurrent, open and short-circuit
protection, overtemperature, and brownout protect the system
during abnormal transient conditions.
Si pentru ca veni vorba si topologia HB s-a ales din motive de simplitate, pentru FB  se dubleaza componentele de putere si-n plus
cand iti face bum face simultan la 4 mos-uri (igbt-uri)  cu driver cu tot - un aspect deloc de neglijat pentru hoby-sti.
Editat de Akos
Driverele se pot proteja, in experimentele mele nu am trosnit niciodata driverul, chiar daca elementul comutator s-a facut "sirma" sau a explodat.
Topologia HB are avantaje si dezavantaje precum si cea FB
Cum IGBT si mosfeturile s-au dezvoltat logaritmic in ultimii ani, si costurile au inceput sa scada simtitor, multi prefera HB.
Printre care si eu.
Poate pe viitor voi face o schema de HB interleaved (am ideea in cap deja) prin care sa exclud (in caz de necesitate) si diodele interne din IGBT/Mosfet si sa le inlocuiesc cu niste SIC diodes, externe
Pierderile si frecventa vor fi la jumate pe fiecare element comutator, permitind componente mai putin pretentioase si dublarea puterii (teoretic).
Editat de Vizitator
Inainte de 2,2ohmi este 6,8ohmi in paralel cu o dioda care vin de la driver. Am crezut ca va ceda cea de 2,2 dar nu, ea nu a cedat, nici transilul, nici 6,8-ul
ci numai driverul ! N-as fi crezut ca transilul nu se va deschide suficient de repede ca sa arda 2,2 dar uite ca nu s-a deschis.
