Vizitator nick_boby Postat Iunie 28, 2007 Partajează Postat Iunie 28, 2007 Sl! am luat de curand un server ibm x330 second.... mi s-a parut o afacere profitabila...dar am descoperit ca pentru punerea lui in functiune am nevoie de un cablu KVM de tip 00N7004. am gasit respectivul cablu dar costa intre 150 si 350 de euro.....ceea ce mi se pare exageratas dori daca se poate o schema interna a mufei respective.... cu ce reprezinta fiecare pin ...in incercarea de a face singur acel cablusau si mai bine daca se gaseste undeva acel cablu la un pret rezonabilva multumesc Link spre comentariu
niq_ro Postat Iunie 28, 2007 Partajează Postat Iunie 28, 2007 pentru moment am gasit urmatoarele date: IBM - Keyboard / video / mouse (KVM) cable - 6 pin PS/2, HD-15 (M) - DB-25 (M) Product Features and Technical Details Product Features Product Description: IBM keyboard / video / mouse (KVM) cable - 2.45 m Type: Keyboard / video / mouse (KVM) cable Length: 2.45 m Connector(s): 2 x 6 pin mini-DIN (PS/2 style) - male ? 1 x 15 pin HD D-Sub (HD-15) - male Connector(s) (Other Side): 1 x 25 pin D-Sub (DB-25) - male Package Type: Retail Technical Details Main Specifications Product Description: IBM keyboard / video / mouse (KVM) cable - 2.45 m Type: Keyboard / video / mouse (KVM) cable Length: 2.45 m Connector(s): 2 x 6 pin mini-DIN (PS/2 style) - male ? 1 x 15 pin HD D-Sub (HD-15) - male Connector(s) (Other Side): 1 x 25 pin D-Sub (DB-25) - male Package Type: Retail Extended Specifications General Length: 2.45 m Type: Keyboard / video / mouse (KVM) cable Connectivity Connector(s): 2 x 6 pin mini-DIN (PS/2 style) - male ? 1 x 15 pin HD D-Sub (HD-15) - male Connector(s) (Other Side): 1 x 25 pin D-Sub (DB-25) - male din ce observ eu e un adaptor intre unitate, unde ai mufa cu DB-25 cum e cea de la serialul mare, iar in partea cealalta cele 2 mufe PS/2 pentru mouse si trastatura, respecticv mufa video HD-15 - PS/2: http://www.hardwarebook.info/Mouse_(PS/2) - serialul cu 25 de pini: http://www.hardwarebook.info/Serial_(PC_25) - video: http://www.hardwarebook.info/PC-9801_Video PS: treci pe la MULTITEC pe Romania Muncitoare... poate au asa ceva sau te pot ajuta ..... Link spre comentariu
Vizitator nick_boby Postat Iunie 28, 2007 Partajează Postat Iunie 28, 2007 dap asta este cablu..... ma intereseaza pinii corespunzatori in mufa ce se conecteaza in server sau un pret accesibil pt acest cablu Link spre comentariu
Vizitator nick_boby Postat Iunie 28, 2007 Partajează Postat Iunie 28, 2007 acea mufa nu este un serial...este mai degrba un dvi cu mai multi piniare in stanga 3 randuri a cate 10 pini si in dreapta patru pini pusi in "patrat"si 2 lincuri nu functioneaza...cel pentru mouse si cel pt serial Link spre comentariu
niq_ro Postat Iunie 28, 2007 Partajează Postat Iunie 28, 2007 cauta prin http://www.hardwarebook.info/ si ajungi si la mufele ale caror link-uri n-au mers.... Connector(s) (Other Side): 1 x 25 pin D-Sub (DB-25) - male = mufa tata cu 25 de pini, idem ca la serial... daca nu are iesirile la fel, asta e, mai cauta PS: vrei sa ma apuc sa dau eu telefoane si sa trec pe la firma aia, doar ca iti e lene? NOU UEI?! Link spre comentariu
Vizitator nick_boby Postat Iunie 28, 2007 Partajează Postat Iunie 28, 2007 iti multumesc pentru informatii....chiar acum ma voi duce la Multitec sa vad daca au asa ceva...daca mai gasesti cumva informatii te rog sa le postezi Link spre comentariu
niq_ro Postat Iunie 28, 2007 Partajează Postat Iunie 28, 2007 te-am indrumat acolo, pentru ca ei aduc si s/h-uri si sanse mari sa se fi lovit de problema asta... daca mai gasesc ceva, o sa postez.... Link spre comentariu
