Vizitator Postat Iulie 14, 2013 Partajează Postat Iulie 14, 2013 Un radio de colectie sau cum ii mai spunem noi, o bijuterie de radio este si Philips Nicolette. Pentru inceput am sa postez cateva poze cu aparatul apoi o sa incerc sa-l descriu mai amanuntit. Philips Nicolette Germany 1962 - In Germany the use of the FM band caught up earlier than in The Netherlands. This is because the Allied forced occupying Germany after the second World War didn't allow MW broadcasts. Philips portable designs of those days were unbelievably crowded: the components are partitioned over three circuit boards (one shielded and serving as FM tuner) in this little radio! The Intermediate Frequency (IF) for the FM band is 6.75MHz, while virtually all other radios use 10.7MHz here. This German type is similar to the Dutch L2X22T,except on this radio you can see the German Kanäle, and the Dutch radios didn't have the exotic girls' names. Data for Philips L2D22T Nicolette Production Germany 1962 Bands LW (150-262 kHz), MW (517-1612 kHz), FM (87.5-104 MHz) Semi-conductors AF114 (FM RF stage), AF115 (RF conv.), AF116 (AM conv. and FM IF stage), 2x AF116 (IF stage), OC75 (AF amp), 2xOC74 (output), OA90 (FM mixer), OA79 (AM det.), 2xOA79 (FM det.). Cabinet Plastic. Size is 17.5x10.5x4.5 cm Weight is 650 gr Power Battery 4xAA, draw 25mA. Link spre comentariu
Vizitator Postat Iulie 14, 2013 Partajează Postat Iulie 14, 2013 Nu am gasit schema aparatului Philips Nicolette dar intre timp am urcat un videoclip http://youtu.be/8jEzspQp-aA 8jEzspQp-aA Daca va place dati like. PS: daca are cineva schema sau cartea tehnica il rog frumos sa ne posteze un link. Link spre comentariu
Vizitator Postat Iulie 14, 2013 Partajează Postat Iulie 14, 2013 Tot din colectia personala va prezint inca o bijuterie de radio de data asta fabricat in Japonia anilor '60 este vorba de radio AM/FM Marvel. Are o particularitate si anume scala este impartita in doua sectiuni cu doua indicatoare aurite, AM respectiv FM. Cateva poze cu radio Marvel: Marvel was better known for classy shirt pocket radios. This radio was also marketed under the Deville name, even with the same model number. Un pic de documentatie: Land: Japan Hersteller / Marke: Marvel (brand name), Japan Jahr: 1960 Typ: Rundfunkempfänger (Radio oder Nachkriegs-Tuner) Halbleiter (Zählung nur für Transistoren) Halbleiter vorhanden. Prinzip Superhet allgemein; ZF/IF 455/10700 kHz Wellenbereiche Mittelwelle und UKW (FM). Spezialitäten Betriebsart / Volt Trockenbatterien / 6 x 1,5 Volt Lautsprecher Dynamischer LS, keine Erregerspule (permanentdynamisch) Ausgangsleistung von Radiomuseum.org Model: Marvel 9 9FM-70 - Marvel brand name, Japan Material Plastikgehäuse (nicht Bakelit), Thermoplast Form Reisegerät für Batterie > 20 cm (auch Batterie/Netz) Link spre comentariu
Vizitator Postat Iulie 14, 2013 Partajează Postat Iulie 14, 2013 Si un videoclip cu radio Marvel, sper sa va placa. Am mai gasit pe net ca aparatul a fost fabricat cam de prin anul 1959, dar foarte greu de gasit documentatia lui in conditiile actuale de net... http://youtu.be/LBSlO9B9Xds LBSlO9B9Xds Link spre comentariu
franzm Postat Iulie 14, 2013 Partajează Postat Iulie 14, 2013 E simplu si clasic, asa ca schema nu e complicata si se poate desena dupa modelul existent. Link spre comentariu
Vizitator Postat Iulie 15, 2013 Partajează Postat Iulie 15, 2013 E simplu si clasic, asa ca schema nu e complicata si se poate desena dupa modelul existent.Am gasit doar documentatia pentru philips ...http://www.radiodatabase.nl/toestellen/ ... L2X22T.pdf Link spre comentariu
ctepeo Postat Iulie 15, 2013 Partajează Postat Iulie 15, 2013 Iata o reclama din 1982 la un aparat stationar care costa ceva bani pentru vremea aceea.Atât de baban şi era mono? Din Almanah "Ştiinţă şi tehnică" 1987, pg. 188: preţuri la radioreceptoare portabile Uploaded with ImageShack.us Link spre comentariu
Vizitator Postat Iulie 16, 2013 Partajează Postat Iulie 16, 2013 Radioreceptorul Panasonic RF542 (Matsushita Electric 1989) Videoclip cu aparatul pe ambele benzi de receptie AM/FM: http://www.youtube.com/watch?v=0t01OXKYQZ0 0t01OXKYQZ0 Daca v-a placut dati un like Link spre comentariu
Vizitator Postat Iulie 20, 2013 Partajează Postat Iulie 20, 2013 Radioreceptorrul Меридиан RP308, s-au fabricat incepand din 1984... Are doua lungimi de unda UM/UL si se alimneteaza la 4,5V. Cateva poze: videoclip: http://youtu.be/OqTGoyX8XoU OqTGoyX8XoU Mai multe detalii : http://radiotrician.ru/meridian_rp308_408.php Link spre comentariu
Vizitator Postat Iulie 21, 2013 Partajează Postat Iulie 21, 2013 Si un Dana Deck facut la Tehnoton (1979), restaurat acum functional dupa multa munca: Poze: Videocilp : http://youtu.be/iPkeWwiptV8 iPkeWwiptV8 Link spre comentariu
hpavictor Postat Iulie 22, 2013 Partajează Postat Iulie 22, 2013 Si un Dana Deck facut la Tehnoton (1979), restaurat acum functional ...Deck ? Nu cumva este o eroare ? Stiam ca Star si Dana a fost " magnetoafoane " portabile , cu banda in carcasa tip "compact casette " avand viteza de 4.75 cm / secunda , format mono , cu amplificator de mica putere inclus in carcasa , alimentare mixta baterii / retea ...schema atasata confirma ceea ce am specificat eu .A ansamblat Tehnoton si casetofoane tip DECK ( stereo ) ? Link spre comentariu
Vizitator Postat Iulie 22, 2013 Partajează Postat Iulie 22, 2013 Exista si Deck mono ( http://en.wikipedia.org/wiki/Tape_deck) cum de altfel sunt deck-uri cu selectie mono-stereo. Si chiar sursa de semnal poate fi mono, nu asta ar fi problema ci calitatea inregistrarii are ponderea cea mai mare in aprecierea unui deck. Acum depinde si de perioada de timp la care ne raportam cand facem aceasta evaluare. Oricum suna fain Dana Deck... al 2-lea casetofon portabil romanesc (si primul cu circuite integrate), de asemenea realizat dupa licenta Unitra ZRK (Polonia), modelul polonez fiind tip B113 Automatic IC; sunet mono; frecvente: 80-8000 hz; viteza benzii: 4,76 cm/sec; alimentare: retea sau 5 baterii R14 x 1,5V; schema electronica cu componente romanesti; spre deosebire de primul casetofon romanesc Star MC 12, acesta are autostop, microfon, iar schema include circuitele integrate: TBA 790 si UL 1901; tranzistoare: 4 x BC 172 B/C, 1 x BC 173B; difuzor: eliptic, 1W / 4 ohmi. S_au mai gandit si altii la Dana Deck...vezi Tehnium 5/1984 Link spre comentariu
hpavictor Postat Iulie 22, 2013 Partajează Postat Iulie 22, 2013 Notiunea de " DECK " implica lipsa totala etajelor finale audio !Nu contest ca un DECK ar putea fi mono sau stereo , dar Dana nu era DECK . Link spre comentariu
Untold Postat Iulie 22, 2013 Partajează Postat Iulie 22, 2013 Asa e.Am avut un Universum (nemtesc), un Star si un Dana, luate din talcioc pe 2 lei.Nu era niciunul deck. A ramas deck doar Universumul dupa ce-au curs bateriile in el si-a facut trosc cand l-am introdus in priza, moment dupa care i-am extras toata electronica prajita, i-am pus cap de redare stereo si i-am facut un premplif de cap stereo cu doua operationale BM382 sau BM381(B de la Beta-IPRS Baneasa) nu mai stiu, cum erau pe atunci.Stereo Deck erau Majak-urile 203 si 205. Link spre comentariu
Vizitator Postat Iulie 22, 2013 Partajează Postat Iulie 22, 2013 Notiunea de " DECK " implica lipsa totala etajelor finale audio !Nu contest ca un DECK ar putea fi mono sau stereo , dar Dana nu era DECK .So? :rade:Are mufa audio de iesire/ intrare semnal deci se poate folosi si ca deck...ca sa ajungem la un numitor comun.Nu asta este important cine are dreptate eu special am scris deck ca suna bine, si ca satisfactie ca l-am restaurat. Link spre comentariu
