Aparate radio tranzistorizate dinainte de anii 90
doru3160
Revin...
Un radio din colectie cu 16 benzi Grundig Yacht Boy 230 "E tare si mare" pe frecventele Tropicale 2200Khz (120m) -3400Khz(90m)  dar este de asemenea foarte bun pe benzile de scurte 49m, 41m, 31m, 25m... de departe un radio cu o sensibilitate si selectivitate ridicata.
Atentie! Fara bateria CR2016 aparatul nu porneste!
Country:  Germany
Manufacturer / Brand:  Grundig (Radio-Vertrieb, RVF, Radiowerke)
alternative name
Grundig Portugal || Grundig USA / Lextronix
Year: 1989–1992 Category: Broadcast Receiver - or past WW2 Tuner
Semiconductors (the count is only for transistors) 19:
Main principle Superheterodyne (common); ZF/IF 455/10700 kHz
Wave bands Broadcast, Long Wave, more than 2 x SW plus FM or UHF.
Details
Power type and voltage Batteries / addl. power jack / 3 × 1,5 & 3 / 4,5 Volt
Loudspeaker Permanent Magnet Dynamic (PDyn) Loudspeaker (moving coil)
Power out 0.6 W (max.)
from Radiomuseum.org Model: Yacht-Boy 230 - Grundig Radio-Vertrieb, RVF,
Material Modern plastics (no Bakelite or Catalin)
Shape Very small Portable or Pocket-Set (Handheld) < 8 inch.
Dimensions (WHD) 180 x 109 x 35 mm / 7.1 x 4.3 x 1.4 inch
Notes
13 KW-Bereiche (11 - 120 m Band), LW, MW, UKW Stereo (mit KH);
LCD - Weltkarte, Uhr, 2 Weckzeiten; Elektronische LS Regelung + Bandwahl, 5kHz Sperre. 6 IC´s . Uhr Knopfzelle: 1×3 V (CR2016), Batterien vom Typ " Mignon ", AC Adapter Grundig 30-75 (4,5 V).
Zum Betrieb ist die eingesetzte Knopfzelle erforderlich, ohne funktionsfähige Knopfzelle startet das Gerät nicht.
Net weight (2.2 lb = 1 kg) 0.5 kg / 1 lb 1.6 oz (1.101 lb)
Editat de Cristian74
Un radio mai rar Grundig Yacht Boy 215 ;
Video
poze
Country:  Germany
alternative name
Year: 1985–1989 Category: Broadcast Receiver - or past WW2 Tuner
Semiconductors (the count is only for transistors) 4:
Main principle Superheterodyne (common); ZF/IF 460/10700 kHz
Details
Power type and voltage Batteries / addl. power jack / AA: 4 ×1,5 / 6 Volt
Power out 0.2 W (unknown quality)
from Radiomuseum.org Model: Yacht-Boy 215 - Grundig Radio-Vertrieb, RVF,
Dimensions (WHD) 200 x 100 x 40 mm / 7.9 x 3.9 x 1.6 inch
Country:  Germany
alternative name
Year: 1994 Category: Broadcast Receiver - or past WW2 Tuner
Semiconductors (the count is only for transistors) Semiconductors present.
Main principle PLL, Phase-locked loop
Wave bands Broadcast, Long Wave, Short Wave plus FM or UHF.
Details
Power type and voltage Dry Batteries / AA: 4 x 1,5 & AAA: 2 x 1,5 Volt
Power out
from Radiomuseum.org Model: Ocean-Boy 340 - Grundig Radio-Vertrieb, RVF,
Dimensions (WHD) 190 x 110 x 40 mm / 7.5 x 4.3 x 1.6 inch
Notes
Empfindlichkeit schaltbar für Nah- und Fernempfang, Kopfhörerbuchse, 6V-DC-Buchse, Uhr mit Timer und Sleep, 5 Stationstasten pro Band, Tastensperre.
Die 4 AA-Batterien sind für das Rundfunkteil, die 2 AAA-Batterien für die Uhr.
Net weight (2.2 lb = 1 kg) 0.450 kg / 0 lb 15.9 oz (0.991 lb)
  • 2 săptămâni mai târziu...
World Radio receiver Grundig Yacht Boy 310:
video pe SW 49m ...16m (scanare):
Country:  Germany
alternative name
Year: 1983/1984 Category: Broadcast Receiver - or past WW2 Tuner
Main principle Superheterodyne (common); ZF/IF 468 kHz
Details
Power type and voltage Dry Batteries / 7,5 Volt
Power out
from Radiomuseum.org Model: Yacht-Boy 310 - Grundig Radio-Vertrieb, RVF,
Shape Portable set > 8 inch (also usable without mains)
Dimensions (WHD) 250 x 150 x 50 mm / 9.8 x 5.9 x 2 inch
Notes 7 Kurzwellenbänder
Net weight (2.2 lb = 1 kg) 0.8 kg / 1 lb 12.2 oz (1.762 lb)
World Radio receiver Grundig Music Boy 160
Videoclip:
Country:  Germany
alternative name
Details
Power type and voltage Line / Batteries (any type) / 220 / 5 × 1.5 Volt
Power out
from Radiomuseum.org Model: Music-Boy 160 - Grundig Radio-Vertrieb, RVF,
Dimensions (WHD) 270 x 160 x 70 mm / 10.6 x 6.3 x 2.8 inch
Notes Der Empfänger Music Boy 160 ist ein preisgünstiger Empfänger mit zwei Schaltkreisen und zwei Piezofiltern.
Net weight (2.2 lb = 1 kg) 1.3 kg / 2 lb 13.8 oz (2.863 lb)
Professional Radio receiver Grundig Satellit 400
video:
For model Satellit 400 International, Professional, Grundig (Radio-Vertrieb, RVF, Radiowerke)
Country:  Germany
alternative name
Year: 1986–1989 Category: Broadcast Receiver - or past WW2 Tuner
Semiconductors (the count is only for transistors) 68:
Main principle Superhet, double/triple conversion; ZF/IF 54400/450 kHz
Details
Power type and voltage Line / Batteries (any type) / 110-127; 220-240 / 6 x 1.5 & 3 x 1.5 Volt
Power out 6 W (unknown quality)
from Radiomuseum.org Model: Satellit 400 [International, Professional] - Grundig Radio-Vertrieb, RVF,
Dimensions (WHD) 304 x 180 x 70 mm / 12 x 7.1 x 2.8 inch
Notes
SW coverage (AM/SSB with BFO):
Satellit 400 professional: 1612 - 26100 kHz,
Satellit 400 international: 1612 - 30000 kHz.
24 station memories (intermix).
Switchable illumination for tuning instrument and LCD display.
External connections for antenna (75Ω IEC), earphone, AUX in, DC 12V.
Required batteries:
6 C-cells (Baby) + 3 AA-cells for clock and memory backup.
Preisangabe aus Grosshandels-Liste für Einzelhändler.
Net weight (2.2 lb = 1 kg) 2.1 kg / 4 lb 10 oz (4.626 lb)
World Radio receiver Grundig Signal 700 (se apropie de o versiune analogica a unui Grundig Satelitt);
video:
Country:  Germany
alternative name
Year: 1974–1976 Category: Broadcast Receiver - or past WW2 Tuner
Semiconductors (the count is only for transistors) 12:
Tuned circuits 5 AM circuit(s)     8 FM circuit(s)
Wave bands Broadcast, (BC) Long Wave (LW), 2 x SW and FM or UHF.
Details
Power type and voltage Line / Batteries (any type) / 110; 220; (4 × 1,5) Volt
Power out 1.5 W (unknown quality)
from Radiomuseum.org Model: Signal 700 - Grundig Radio-Vertrieb, RVF,
Dimensions (WHD) 260 x 210 x 70 mm / 10.2 x 8.3 x 2.8 inch
Notes NF-Ausgangsleistung bei Netzbetrieb: 1,8 W.
2.2 kg / 4 lb 13.5 oz (4.846 lb)
Este un model oarecum atipic. Cel prezentat pe radiomuseum n-are nici numar de înregistrare FTZ (ceva asemanator cu FCC-ul american). Stiti cumva unde a fost fabricat?
