bihari u96 Postat Aprilie 15, 2018 Partajează Postat Aprilie 15, 2018 (editat) Salut am la mine un crunch gtx 4600 ,in funtiune la 12,5 v merge ok dar daca ,mareste tensiunea cand masina e pornit la 13,3 intra in protectie ,nu am gasit piese defect ,puteti ajuta . Editat Mai 14, 2018 de George Link spre comentariu
M.Adrian Postat Aprilie 15, 2018 Partajează Postat Aprilie 15, 2018 (editat) In manualul de utilizare scrie asta "THE PURCHASED DEVICE IS ONLY SUITABLE FOR AN OPERATION WITH A 12V ON-BOARD ELECTRICAL SYSTEM OF A VEHICLE". Deci la 13 v sau mai mult e posibil sa intre protectia la supratensiune, totusi diferenta de 0.8V mi se pare cam mica.. daca asta e problema, incercati cu un regulator de 12V pe alimentare. Mai verificati o data conexiunile, tot in manual se mentioneaza si simptomele cu posibile cauze si remedieri, in cazul protectiei: "Malfunction: amplifier runs into protection mode (red protection LED lights up) 1. Short circuit on the loudspeakers or cables.>>>> Check and reconnect the cables. 2. Overheated by too low speaker impedance.>>>> Choose a higher impedance speaker or a new speaker setup 3. Insufficient air circulation by a inappropriate mounting position of the amplifier.>>>> Change the mounting position Ensure air circulation 4. Overloaded by insufficient power supply (too thin profile section on the power cables).>>>>Use a bigger profile section" Editat Aprilie 15, 2018 de M.Adrian Link spre comentariu
dan cod Postat Aprilie 19, 2018 Partajează Postat Aprilie 19, 2018 De unde stabilizator de 12V la curentul ăla? Probabil are ceva defect in sursa amplifului. Link spre comentariu
