Driver audio PC,placa baza:FOXCONN-45GM-45CM
Radiotelegrafist
Va salut colegi,va rog sa ma ajutati si pe mine cu un driver audio pentru acest pc,mentionez ca am incercat eu cu 3-4 drivere si nu am reusit sa rezolv aceasta problema,va multumesc anticipat.
Nu am sunet,am si placa de sunet in pc,acum nu stiu pe care sa instalez sunetul pe cea de pe placa de baza s-au pe cea care este montata in slot?
Vezi in josul paginii
  Download Center
  To view the Download available for your Foxconn product, please select the appropriate item from the dropdown lists in the order of Categories, Series and Model. You may also search by using only Keywords.
Recommended browser to use IE8.0 and higher version of IE download files
  Select Your Product
Products  Please Select NanoPC Barebones Desktop Barebones Motherboards Chassis Card Readers Coolers Graphic Cards LCD Monitors Power Supplies
Platform  Please Select AMD platform Intel platform
Socket    Please Select Intel Embedded board Socket 1150 Socket 1155 Socket 1156 Socket 1366 Socket 2011 Socket 478 Socket 775
Chipset    Please Select ATI RC410 GeForce 7050 / nForce 610i GeForce 7100 / nForce 630i Intel 865G Intel 865GV Intel 865PE Intel 910GL Intel 915G Intel 915GL Intel 915GV Intel 915P Intel 915PL Intel 925XE Intel 945G Intel 945GC Intel 945GZ Intel 945P Intel 945PL Intel 946GZ Intel 975X Intel G31 Intel G33 Intel G41 Intel G43 Intel G45 Intel G965 Intel P31 Intel P35 Intel P43 Intel P45 Intel P965 Intel Q45 Intel Q965 Intel X38 Intel X48 NF 680i SLI NF4 SLI Intel Edition SiS 648C SiS 648FX SiS 649 SiS 661FX SiS 661GX SiS 662 SiS 671 VIA P4M800 Pro VIA P4M890 VIA P4M900
Models    Please Select 45GM 45GMX 45GMX-V 945G7AB-8EKRS2 945G7AD-8EKRS2H 945G7AD-8KS2H 945G7AD-8KS2HV 945G7MA-8EKRS2 945G7MA-8EKRS2H 945G7MA-8KS2 945G7MA-8KS2H 945G7MA-S 945G7MC-KRS2H 945G7MC-KRS2HV 945G7MC-KS2HV 945G7MD-8EKRS2H 945G7MD-8EKRS2HV 945G7MD-8KS2H 945G7MD-8KS2HV 945G7MD-KS2H 945G7MD-S2H   945G7ME-8EKRS2H 945G7UB-8KS2H
Keyword
200710260217120156_45GM_3-2.jpg   45GM
- IntelCore2 Extreme, Core2 Duo, Pentium Dual-Core, Pentium D, Pentium 4, Celeron D, Celeron processors, Socket T (LGA775) - 1066/800/533MHz (FSB) - Dual channel DDR2 400/533/667 x 2 DIMMs, Max. 4GB - PCIe x16, 1 x PCIe x1, 2 x PCI - ATA x 1, SATA II x 4 - 5.1 channel Audio - GbE LAN - 8 USB 2.0 ports
Specification
Intel®Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® D, Celeron® processors, Socket T (LGA775)
Intel® 945G + ICH7
1066 / 800 / 533 MHz FSB
Integrated
Search Result for : Motherboards + 45GM
  45GM    ( Submitted: 05/12/2008  |  Download Times: 275276 )
arrow_01.gif   Motherboards  :  Socket 775  :  Motherboards Drivers  : System & Chipset Drivers   View Detail
  45GM    ( Submitted: 07/30/2008  |  Download Times: 161303 )
arrow_01.gif   Motherboards  :  Socket 775  :  Motherboards Drivers  : On-Board Audio Drivers   View Detail
  45GM    ( Submitted: 08/06/2008  |  Download Times: 8804 )
arrow_01.gif   Motherboards  :  Socket 775  :  Motherboards BIOS  : BIOS File   View Detail
  45GM    ( Submitted: 04/29/2009  |  Download Times: 4065 )
arrow_01.gif   Motherboards  :  Socket 775  :  Motherboard Manual  : Easy Guide   View Detail
  45GM    ( Submitted: 05/20/2009  |  Download Times: 2294 )
arrow_01.gif   Motherboards  :  Socket 775  :  Motherboards Utility  : FOX LiveUpdate   View Detail
  45GM    ( Submitted: 07/14/2009  |  Download Times: 4176 )
arrow_01.gif   Motherboards  :  Socket 775  :  Motherboards Drivers  : On-Board VGA Drivers   View Detail
  45GM    ( Submitted: 08/17/2009  |  Download Times: 5744 )
arrow_01.gif   Motherboards  :  Socket 775  :  Motherboards Drivers  : On-Board LAN Drivers   View Detail
  45GM    ( Submitted: 09/10/2010  |  Download Times: 1714 )
arrow_01.gif   Motherboards  :  Socket 775  :  Motherboards Utility  : FOX ONE   View Detail
Mai incearca si de aici vezi ca sunt mai multe http://www.driverscape.com/manufacturers/foxconn/laptops-desktops/g45m/7426
De ce sa nu mearga oare?la alte unitati pc pe care le am functioneaza din prima?
Editat de Giorgi tv
