Amplificator clasa D "TITAN"
Vizitator Marcel Ciobanu
  • Răspunsuri 4
  • Alin_cj
  • Mircea
Zile populare
In descriere ai totul, se spune clar ce si cum. Nu e nevoie de experienta. Trebuie citit bine textul. Pun aici partile mai importante.
"Power 1500W Class D requires several components to make the power amplifier and also pay attention to the components available in the market including; IC Comparator using IC TL071, Transistor Level Shifter using 2N5401, IC Logic using CD4049 IC, protection IC using combination of NE555 and LM311, IC Driver using IC IR2110, with 2 pairs Different Power Mosfet, Toroid, Email Wire, Capacitor MKP , Resistor, Diode, Led, Nonpolar Capacitor, Elco, IC Socket, Heatsink, PCB, Male and female socket, Cable.
The above circuit is almost identical to the series of Power Amp D-Class 3000W Gambit, a significant difference that is in Mosfet Transistors are used, the Power Amplifier is only using 2 IRF MOSFET transistor amplifier, but this power amplifier also has a high-quality performance, Very large power output. To use Mosfet Transistor I suggest you use power MOSFET with IRFP4227 type because this transistor is very good compared to good Mosfet Transistor for Audio (Switching) than like IRFP460 / IRFP460N, IRFP250, IRFP260 etc."
Spor la treaba. Sper ca aveti fondurile necesare experimentarii.
NB: daca cineva are email-ul lui wire, il rog sa-mi mi-l dea si mie ca sa pot pune ampliful in functiune. Multumesc.
Schema e depasita si puterea e exagerata de cateva ori. Mai bine fa iraudamp9. Cred ca ajunge si o pereche de irfb4227 daca nu utilizezi o sarcina cu impedanta mai mica de 4 ohmi. Fa cablajul intocmai ca in pdf daca nu te pricepi, succesul depinde de proiectarea cablajului imprimat si de componentele din zona de comutatie rapida. Ar cam trebui si un osciloscop mai rapid, sa vezi daca oscilatia are frecventa dorita si spike-urile de comutatie sa nu fie prea mari.
https://www.infineon.com/dgdl/iraudamp9.pdf?fileId=5546d462533600a40153569aee022bff
Editat de Alin_cj
Oricum nu am de gand sa folosesc mai mult de +-55V pe alimentare, stiu ca puterea e exagerata dar ma oprisem la schema asta pentru ca am cateva din cipurile necesare si niste irfp150n. Am putine dubii legate de ir2110, am auzit si pareri pro si contra despre el("crapa" foarte usor). Merci!
Editat de Marcel Ciobanu
Probabil "crapa foarte usor " pentru ca
1 oră în urmă, Alin_cj a spus:
Irfp150n are numai 100V vds, nu e sigur sa-l alimentezi cu +-55v.
