Cumparati de pe aliexpress ?
In marea majoritate de exemplu eu am cumparat componente electronice pentru o viitoare sursa v2,2 aparate de masura ,componente pentru un viitor cnc,structura lui nefiind foarte rigida va fi folosit doar pentru desenat si gaurit cablaje,solutie pentru reparat ciupiturile din parbriz si reparat dezaburirea de la luneta.             https://www.aliexpress.com/item/Mastech-MS8269-Digital-Multimeter-AC-DC-Volt-Amp-Ohm-Cap-Multi-Tester-Meter-20mH-20H-Inductance/32695568174.html?spm=2114.search0104.3.2.47dd6ebb8Kcjzc&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620,searchweb201603_25,ppcSwitch_4&algo_expid=0d7f520d-63d3-4046-acc0-7be4a455924b-0&algo_pvid=0d7f520d-63d3-4046-acc0-7be4a455924b&transAbTest=ae803_5&priceBeautifyAB=0                            https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20180308122553&SearchText=2PCS+lcd+1602
Editat de valivoi
imi apare cu ,ontul ativat
https://www.aliexpress.com/item/2017-New-MASTECH-MS2101-MS2001-AC-DC-1000A-Digital-Clamp-Meter-DMM-Hz-C-clamp-meter/32851934354.html?spm=2114.search0104.3.3.386248ffxS3rAZ&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620,searchweb201603_37,ppcSwitch_4&algo_expid=2e4f3fef-47fd-4d8b-b3f2-0c87708d699c-0&algo_pvid=2e4f3fef-47fd-4d8b-b3f2-0c87708d699c&priceBeautifyAB=0
https://www.aliexpress.com/item/Visbella-Windshield-Crack-Repair-Kit/32581624863.html?spm=2114.search0104.3.1.22ad5ae0HWkDc4&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620,searchweb201603_37,ppcSwitch_4&algo_expid=a221c189-3e34-4bd5-9505-02aa0d13b3d8-0&algo_pvid=a221c189-3e34-4bd5-9505-02aa0d13b3d8&priceBeautifyAB=0
https://www.aliexpress.com/item/Visbella-SKG-283-2-DIY-Rear-window-Defogger-Repair-Kit-Repair-the-mist-line-of-Auto/32776262529.html?spm=2114.search0104.3.56.22ad5ae0HWkDc4&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620,searchweb201603_37,ppcSwitch_4&algo_expid=a221c189-3e34-4bd5-9505-02aa0d13b3d8-7&algo_pvid=a221c189-3e34-4bd5-9505-02aa0d13b3d8&priceBeautifyAB=0
https://www.aliexpress.com/item/1PCS-50A-1000V-Metal-Case-Single-Phases-Diode-Bridge-Rectifier-KBPC5010/32835280353.html?spm=2114.search0104.3.37.227c48cfIK7CF2&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_10313_10059_10534_100031_10629_10103_10626_10625_10624_10623_10622_10621_10620_10142,searchweb201603_2,ppcSwitch_7&algo_expid=c03129d9-3b44-411d-8688-7fed8985966a-5&algo_pvid=c03129d9-3b44-411d-8688-7fed8985966a&transAbTest=ae803_5&priceBeautifyAB=0
https://www.aliexpress.com/item/Wholesale-and-FedEx-Shipping-for-500pcs-LM8UU-8mm-Linear-Ball-Bearing-CNC-Linear-Bearings-for-8mm/32815372270.html?spm=2114.search0104.3.23.2cdd1263mOOuZp&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10151_10065_10068_10344_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_10313_10059_10534_100031_10103_10624_10623_10622_10621_10620_10142,searchweb201603_38,ppcSwitch_5&algo_expid=41ac65bc-1f77-4036-8b89-1329bd547529-3&algo_pvid=41ac65bc-1f77-4036-8b89-1329bd547529&priceBeautifyAB=0
https://www.aliexpress.com/item/1pc-Aluminum-Alloy-Housing-Bracket-30x30x34mm-Silver-For-Housing-The-T8-Lead-Screw-Nut/32850834301.html?spm=2114.search0104.3.236.2738d5e4P2yfH3&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10068_10344_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_10313_10059_10534_100031_10103_10624_10623_10622_10621_10620_10142,searchweb201603_38,ppcSwitch_5&algo_expid=ddd56a4c-f089-4f14-ace5-4f9f27328ab4-35&algo_pvid=ddd56a4c-f089-4f14-ace5-4f9f27328ab4&priceBeautifyAB=0
https://www.aliexpress.com/item/10pcs-5W-0-33-ohm-Cement-resistance-0-33R-0-33ohm/32846226375.html?spm=2114.search0104.3.7.423d2f96nqzF6m&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_10313_10059_10534_100031_10629_10103_10626_10625_10624_10623_10622_10621_10620_10142,searchweb201603_25,ppcSwitch_7&algo_expid=f768bdbc-96bc-4777-b8a7-af7a081e1587-1&algo_pvid=f768bdbc-96bc-4777-b8a7-af7a081e1587&transAbTest=ae803_5&priceBeautifyAB=0
https://www.aliexpress.com/item/1PCS-WXD3-12-10K-Precision-multi-turn-potentiometer-Free-shipping/32828000595.html?spm=2114.search0104.3.16.189d2714QoIeJN&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_10313_10059_10534_100031_10629_10103_10626_10625_10624_10623_10622_10621_10620_10142,searchweb201603_36,ppcSwitch_5&algo_expid=9900a43e-152a-40c1-a92e-f428ade46450-2&algo_pvid=9900a43e-152a-40c1-a92e-f428ade46450&priceBeautifyAB=0
https://www.aliexpress.com/item/5-pcs-5W-0-1-ohm-0-1R-BPR56-Non-inductive-Ceramic-Cement-Resistor-Wirewound-Resistance/32809409264.html?spm=2114.search0104.3.53.2df46cc3Cqj6yP&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_10313_10059_10534_100031_10629_10103_10626_10625_10624_10623_10622_10621_10620_10142,searchweb201603_25,ppcSwitch_7&algo_expid=97f051f7-afd4-4acf-93c7-71805fae2bc9-8&algo_pvid=97f051f7-afd4-4acf-93c7-71805fae2bc9&transAbTest=ae803_5&priceBeautifyAB=0
https://www.aliexpress.com/item/3D-Printer-Parts-Accessory-Stepper-Motor-Aluminum-Alloy-Z-Axis-Flexible-Coupling-Coupler-Shaft-Couplings-5mm/32716822242.html?spm=2114.10010108.1000013.1.6aa161eabRFQ2r&traffic_analysisId=recommend_2088_1_90158_iswistore&scm=1007.13339.90158.0&pvid=9e570314-5830-4c0e-99e3-c02a483e0367&tpp=1
https://www.aliexpress.com/item/XL6009-Boost-Converter-Step-Up-Adjustable-15W-5-32V-to-5-50V-DC-DC-Power-Supply/32625458625.html?spm=a2g0s.9042311.0.0.Z9DCRL
https://www.aliexpress.com/item/2pcs-DC-DC-LM2596-Step-down-Adjustable-Power-Supply-Module-CC-CV-LED-Driver/32280741624.html?spm=a2g0s.9042311.0.0.qPTRvj
https://www.aliexpress.com/item/Mini-Powerful-COB-Led-headlamp-flashlight-ultra-bright-AAA-head-light-lamp-torch-lampe-frontale-headlight/32824159677.html?spm=a2g0s.9042311.0.0.Z9DCRL
https://www.aliexpress.com/item/DSN-VC288-DC-100V-10A-Voltmeter-Ammeter-Blue-Red-LED-Amp-Dual-Digital-Volt-Meter-Gauge/32843733989.html?spm=a2g0s.9042311.0.0.Z9DCRL
https://www.aliexpress.com/item/530pcs-set-Heat-Shrink-Tubing-Insulation-Shrinkable-Tube-Assortment-Electronic-Polyolefin-Ratio-2-1-Wrap-Wire/32811238417.html?spm=a2g0s.9042311.0.0.Z9DCRL
https://www.aliexpress.com/item/MingBen-LED-COB-Chip-light-9W-7W-5W-3W-220V-Input-Smart-IC-Driver-Fit/32819035581.html?spm=a2g0s.9042311.0.0.cmhrl0
https://www.aliexpress.com/item/4IN1-HD-Color-Screen-180-Degrees-Flawless-LED-Display-Panel-Meter-with-Voltmeter-Ammeter-Energy-Meter/32806896525.html?spm=a2g0s.9042311.0.0.cmhrl0
https://www.aliexpress.com/item/10PCS-A4-Sheets-Heat-Toner-Transfer-Paper-For-DIY-PCB-Electronic-Prototype-Mak/32571735391.html?spm=a2g0s.9042311.0.0.qPTRvj
https://www.aliexpress.com/item/50PCS-Kit3-Pin-KF2510-3P-KF2510-3P-2-54mm-Pitch-Terminal-Housing-Pin-Header-Connectors-Adaptor/32801489541.html?spm=a2g0s.9042311.0.0.qPTRvj
https://www.aliexpress.com/item/hot-1pcs-EU-Plug-Monitor-Analyzer-Power-Energy-Meter-Wattage-Voltage-Current-Frequency-Power-Factor-LCD/32637340883.html?spm=a2g0s.9042311.0.0.qPTRvj
https://www.aliexpress.com/item/LCD-GM328A-Transistor-Tester-Diode-Capacitance-ESR-Voltage-Frequency-Meter-PWM-Square-Wave-Signal-Generator-SMT/32722907639.html?spm=a2g0s.9042311.0.0.MHAGm4
https://www.aliexpress.com/item/Screen-Protector-HD-Toughened-for-Sony-Xperia-Z1-Z2-Z3-Z5-Compact-M2-M4-M5-Aqua/32581276285.html?spm=a2g0s.9042311.0.0.MHAGm4
https://www.aliexpress.com/item/LED-Strip-3528-SMD-300leds-5M-Cool-Warm-White-Flexible-Ribbon-Tape-with-12V-2A-Power/2042214199.html?spm=a2g0s.9042311.0.0.quusES
In general maruntisuri....
