gabiferaru Postat Februarie 20, 2018 Partajează Postat Februarie 20, 2018 (editat) Jucaria e folosita dar e in stare perfecta din toate punctele de vedere. USB to SPDIF(AC3 DTS) ConverterThe U2SX HA-INFO is a modern USB interface equipped with VIA VT1729A (latest generation component that supports asynchronous 24/192 via USB).From an excellent value for money this interface USB-S / PDIF also enables you to channel AC3 and DTS ES signals (to another multi-channel decoder).Small and StrongSuper mini sizePlug and play, very easy to useOPT / COAX dual outputOptical fiber / coaxial output not only supports PCM, more support for Dolby AC3, DTS multi-channel encoding formatMulti-System SupportSupport Mac OS / Apple IOS (Need camera kit) / Windows 7/8/10 System(Not support Android System)SpecificationsUSB INPUT: Mini USBDigital output: coaxial, fiber opticSampling rate: 16Bit 44.1K 48K 96K 192K / 24Bit 44.1K 96K Size: 64mm (L) * 21mm (H) * 46mm (W) Weight: 46gColor: Silver Pret: 180 lei. Contact: 0744694027 / SMS / Whatsapp / PM. Poze reale! Editat Februarie 20, 2018 de gabiferaru Link spre comentariu
gabiferaru Postat Martie 11, 2018 Autor Partajează Postat Martie 11, 2018 Anunt valabil! Link spre comentariu
gabiferaru Postat Martie 27, 2018 Autor Partajează Postat Martie 27, 2018 Anunt valabil! Link spre comentariu
