marios013 Postat Decembrie 30, 2017 Partajează Postat Decembrie 30, 2017 (editat) Va salut , am un Philips 37PFL5405H ,defect de sursa ,(cred) ,ledul palpaie de trei ori si se tot repeta, ati putea sa imi dati o idee cam ce ar avea defect? Va multumesc anticipat Editat Decembrie 30, 2017 de marios013 Link spre comentariu
valivoi Postat Decembrie 30, 2017 Partajează Postat Decembrie 30, 2017 http://www.fixya.com/support/t12391777-philips_tv_red_led_blinking_3_times Link spre comentariu
marios013 Postat Decembrie 30, 2017 Autor Partajează Postat Decembrie 30, 2017 multumesc de link dar nu am gasit nimic care sa ma ajute la defectu meu Link spre comentariu
valivoi Postat Decembrie 30, 2017 Partajează Postat Decembrie 30, 2017 The TV is on protect mode.Try first leaving the TV power cord unplugged for some times, let say one hour or so.Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.The flashing light indicates a diagnostic state called protection.When the TV goes on protection there are only two possible reasons.1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.If you are in situation 2 , then there is an internal fault.Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable. Link spre comentariu
marios013 Postat Ianuarie 4, 2018 Autor Partajează Postat Ianuarie 4, 2018 Hallo, se pare ca nimeni nu a intalnit acest cod de eroare .oricum multumesc. Link spre comentariu
leoncris Postat Ianuarie 5, 2018 Partajează Postat Ianuarie 5, 2018 (editat) Ce vorbesti tata ? Sasiu Q552.1E https://elektrotanya.com/philips_chassis_q552.1e-la.pdf/download.html Sursa HR IPB37 , HD-P982A , 272217100983 ? LCD screen:LG LC370WUY(SC)(A1) ? Verificasi tensiunile pe sursa , in special cea de 12V ? Fa o cura de ... C_uri. Ori : Error 3 (I2C bus 3 blocked). When this error occurs, the TV will constantly reboot due to the blocked bus. The best way for further diagnosis here, is to use ComPair (e.g. read out the NVM content). Instead of error “3” it is possible you will see error “2” in the error buffer Editat Ianuarie 5, 2018 de leoncris Link spre comentariu
clony Postat Ianuarie 5, 2018 Partajează Postat Ianuarie 5, 2018 Am avut acest model la reparat care tot asa nu pornea si clipea led-ul dar nu mai stiu de cate ori. Tensiunile erau bune si am anulat protectia la invertor de proba si tv a pornit, vezi poate ai si tu lampi uzate. Link spre comentariu
